View Full Version : Forced Induction
- ls turbo
- Another "how fast" question, look please tho.
- Can Hondata control 700+ cc injectors?
- Are GReddy injectors drop in?
- Installing turbo kit in 1 week, BUT i am missing some parts.... help....
- how loud is the 3" thermal exhaust
- Can I use 450cc injectors off a eclipse?
- JRSC install time
- symptoms of a fuel leak?
- tapping oil pan
- Boost, detonation, Stock and a CRX
- Injector Issues!!!
- how much boost on stock internals?
- Turbo-ize my Trooper
- turbo GSR in EG hatch
- DRAG TURBO SPECS
- Turbo sizes
- Addt'l injector controllers?
- WARRANTY
- NGK BKR7E...From what car?
- TAnabe racing medallion?
- BKR7E gap for JRSC?
- 375 hp Turbo Type-R
- JRSC and intake Q
- Anyone know where I can get some yellow teflon tape?
- Rod Questions
- Turbo Questions
- Install and Dyno for So. Cali Drag III owners!
- DRAG CHECK VALVES for sale!!!
- urgent..calling all peeps from new jersey/new york
- APEXSER - Question about your turbo
- Good value boost gauge....
- Just to clarify...Profec B
- Greddy blue box
- new family member
- Best price for Je pistons and eagle rods?
- Why doesnt rev hard have a intake pipping and filter ?
- Boost timing master troubles
- Hondata
- what is a tdo5..20g compressor?
- how do i turbo my R?
- Is HONDATA right for me?
- If you need a wastegate gasket replacement.. check these out...
- F-Max Group buy!! Great kit, great price!!
- get the most out of your turbo with the apexi power fc
- who using a A/R.49 turbine housings
- VORTECH TURBO FMU for sale!!!
- NOS
- Zdyne opinions?
- Vortech: how loud? Audio files?
- OT:sorta.....Anyone who knows DSM's in here?
- Twin turbo on a Honda????
- Spark plug gap...
- Garrett T03 Turbo Intallation
- Inline pump location
- 15lbs and haltech....
- Anyone know where i can get information on the vortech supercharger for the 94-97gsr?
- Which way should I go before putting turbo kit?
- Tips for driving on slicks
- Stupid autometer fuel pressure gauge!!!!! grrrrrr
- need help tires: 205/45/16 vs 195/50/16
- Turbo? Supercharger?
- Skunk2 Intake Manifold with Turbo Setup
- Eclipse 450cc injectors work???
- Turbo
- what is a good turbo for a 93 civic vtec?
- help, fuel line headache
- who is the turbocharged black integra that works at bodygraphics
- CEL throwing Map Sensor and Fuel Injectors code
- Building a sick FI LS motor for a drag car. .
- Got the car through inspection, and tied up a few odds and ends...
- how to get lower psi for the oil feed line?
- what is the best turbo for a 93 civic vtec
- Best Exhaust for Turbo'ed Cars
- Total drag
- want a good MBC for less? then get...
- Fuel pump location for Drag airtex pump... please help!!!
- nitrous
- Plug Opinions
- What do you think of this setup?
- 5qt Moroso oil pan for integra
- Hooking up first gen J&S
- Map sensor, comes with f-max kit
- Spark plug question?
- Difference Between Greddy Injectors and RC
- Manual vs Electronic Boost Controller
- inline pro head gasket........tell me more please
- B16a turbo.......... read more please
- went to track killed clutch...
- Video of Hondata tuned Progress/Vortech Civic Si @ 173 mph
- Getting very excited now!
- is there anyway possible for a greddy turbo for a civic ex hit 11s in the 1/4?
- Stock Sleeves, good to what PSI?
- itr intake and exhaust cams..is it worth getting for turboed gsr?
- Cartech FMU w/stock FPR?
- DFI 7
- need more out of my car
- My Type R dynoed with HONDATA (pics)
- Part throttle detonation?
- boost controllers... which ones suck?
- BEN WHERE ARE YOU!?!?!
- NY inspection w/turbo....
- VP Race gas info
- OT:do you need hood pins to race with cf hood
- Largest bore in b-series block?
- JRSC GSR pulls VERY slow in 4th @ 6800
- turbo setup help please many questions
- Non-intercooled Turbo D16y8 horsepower?
- Do's & Dont's Of Runin Hondata
- wastegate acuator problem..please help
- NEED HELP ASAP!!
- FMU or MF2
- LSVTEC to CRVTEC
- Drag Gen 3 flaws?
- WTF? psiton pins don't fit....
- Price for a turbo install.........
- Whats the best standalone for me?
- Can my sleeves be damaged
- lets talk race gas
- 300hp VTEC turbo
- What is this kakimoto exhaust?
- Other Considerations when punching out to 2.0L
- Anybody have a program to look at saved dyno graphs?
- Maybe you know why?
- Drag III kit with air/water instead?
- How much for z10 products?
- Is it boost or horse power that ruins engines?
- prepping pistons?
- argh.. block grinding
- what kind of gap do I need on sparkplugs witn greddy turbo?
- This $hit is FUNNY at least to me..sent by my VW friend.
- Does anyone know what happened to John Brown?
- where to buy octane booster
- thinkin about goin LSVTEC
- Tuning
- Step by step Turbo installations?
- Building a daily driven B18C turbo
- BOV and Wastegate Vaccuum Lines
- Custom Test Pipe for OBDII or OBDI USDM/JDM for $50 Anyone interested?
- Took of my intake pipe/filter. Turbo makes a high shriek when shifting.
- Would I need benson sleeves?
- Going T3? Currently have a T3/T40e
- grr....
- Passing emissions
- J&S Safeguard ver1 dipswitches...
- Lets talk about the Greddy turbo kit for a bit
- the reason B18B's are so cheap..
- Nitrous Oxide in The Fast And The Furious
- what happens when you overboost?
- Oil pressure sender
- what kind of flywheel should i get???
- **Need advice on performance brake pads**
- Anodizing intake piping
- oil pan tapping vs pretapped pan
- Compresion test complete after 1 year w/ turbo..need info
- greddy turbo kit on 98 civic ex....how much for kit and install???
- Ignition advance + turbo
- Apex Power FC
- Turbo Gas Mileage
- overheating?
- SOHC what to do?
- Need Help with Drag install
- 7psi limit revisted...
- question about the inline fuel pump that comes with the drag 3
- does anyone know what the tools name that is used to see inside the enginer
- Drag III, Greddy??
- Turbo owners with oil catch can?
- Greddy turbo kit for 96-XX Integras, what about 95?
- F/I fuel pump.
- secondary o2 sensor, does vafc need to be initialzed everytime?
- would it be wise to put a headgasket on a ls to lower the compression?
- FI for a 93 gsr
- Performance injectors
- How much power can be made until an ignition amplifier is necessary?
- EG with LS turbo with probs
- someone in DFW area looking for a benson's block?? check this link out.
- Fan in front of IC??
- Smog without an Exhaust!?!?
- got my carb papers from greddy...
- Good FI piston? Price and performance.
- whats a good turbo setup for my 96 GSR?
- building a d16 turbo setup and looking for suggestions...
- wierd supercharger noise
- 1yr., 1mo., and 6000 miles later..................
- Profec A Instructions
- Would you guys recommend a b18c for turbo
- 14.91 @93mph ??
- Is a turbo manifold supposed to glow red?
- anyone with a D16 turbo???
- Cost for pistons?
- ECU Options
- Question for Drag owners...
- my h22a is running a lot better, but still a problem
- Accel DFI
- The sad sad sad sad truth
- Head work for turbo
- What does a SUPERCHARGER sound like?
- Turbo Newbie
- supercharger high maintanice?
- JRSC @ 9000 RPM?!?
- H23 turbo??
- car died tonite need help asap
- 300hp stock fuel system
- B16a2 oil pressure sender
- Do I need to add more fuel with skunk 2 manifold?
- good brake kits..
- Purge Control unit for vacuumn source
- Will these Injectors fit my Teg?
- Oil coolers...are they worth it?
- Budget Turbo question: RX-7 turbos on a Integra???
- 2.5'' exhuast VS. 3'' (GReddy GSR)???
- where can i find a thicker head gasket
- Question on ware and tare?
- I need a cat that fits my 3" Thermal exhaust and my Fmax DP
- Is there an HKS turbo kit for the integra?
- GS-R or LS turbo
- OT: Save speedvison!
- is it okay to buy used greddy turbo?
- 3" resonator
- Which exhaust or muffler do you turbo guys reccommend?
- HElp with turbo street setup?
- kinda OT ubt need help on Fields controller, in process now....asap
- what is str's websight
- How does this Greddy setup sound?
- TurboXs boost controllers??
- block guard ??
- question about engine wear! horsepower or boost determined?
- Finally Dynoed. 271 HP & 246 FT/LB Torque LS TURBO
- which manifold fits better????
- Thermal Exhaust
- Running rich with 440cc/min at idle...anyone else?
- How does a Eletronic Boost controller work?
- 425 HP LS turbo @ 22 PSI
- how much boost is the 35mm tial wastegate?
- How much for intercooler piping?
- anyone own a Greddy profec A?
- need help installing o-rings for injectors
- RPM Kill switch?
- Supercharge a GSR
- already problems with car hahaha
- 75 or 100 shot of N20
- wastegate to profec b solenoid?
- Supercharged LS ?
- Standalone Units
- head gasket question for 94 ls integra
- Spark plug question...
- New Nitrous Times......(suggestions)
- finally I am part of darkside :)
