View Full Version : Forced Induction
- B20 vs LSvtech
- how much hp can a 190 lph fuel pump support?
- sleeved LS block to 84mm VS. stock B20 sleeves
- CODE 20: disabled eld and still throwing...any ideas?
- smoke from valve cover breather during warm up... any ideas?
- cam seal leaking???
- look what i did on valentines day
- how to start freshly rebuilt motor??
- Greddy manifold...are they really that bad.....
- Maxrev or Inlinepro?
- EG w/ T25 stock manifold question..
- qeustion about liquid intercooler for a sc
- Retorquing ARP studs on a D16a6
- head parts???
- what size turbo for an ls
- greddy E-Manage vs. Hondata. OPINIONS
- Action 2MD clutch users
- brass nipples on turbo???
- Need info on JRsc'ing a b20z or any other brand of supercharger.
- 3inch exaust out the side of bumper???
- where to set vtec with vafc?
- Will a Maxrev mani work with a precision turbo?
- NX intercooler spray!!!
- Just installed BOV, still getting compressor surge. =(
- Tire size q's for traction
- b16/GSR won't run. Cam timing? Ignition timing? Gremlins?
- Sc61?
- Fuel pump problem, I need help fast!
- t28 turbo setup
- hondata tuning w/ newer laptop???
- Manifold, turbo and Downpipe question
- ZC VTEC 1.6L Turbo
- Went to Super Autobacs today...I could kick myself!...hard!
- question about comression ratio
- SAW THIS IN ANOTHER FORUM... MUST SEE!
- OBX Intake Manifold Good For Turbo?
- Hondata 2b screwing up timing
- T3 turbo fit drag manifold?
- INSTALLING QUAIFE LSD ANY MORE INFO
- what kind of down pipe?
- did i miss anything?
- mugen valve cover (fake) maybe
- JRSC+DTR header? Good or bad?
- Some welding information you all might find helpful.
- Anyone have experience w/ Full Race rods?
- traction problems
- Spooling up questions, please help confirm the answer...
- D-Series Turbo Header (pics)
- Quick Turbo Exhaust Question
- Boost gauge problem ..
- screwing fitting into oil pressure sensor probs (tapping block)
- integra gs-r turbo upgrade - suggestions, opinions, etc welcome
- Need the hard facts about MSD BTM
- Going from pick and hold to saturated injectors need HELP!!!
- Can someone please help me find a gasket for a HKS D turbo manifold and a Jdm T25/T28?
- A Buddy's LSvtecTurbo
- Profec B Spec II woes...(please help me)
- need help with power FC
- Best Closed Deck sleeves?
- anyone heard of Trick Engineering??? there out of NH.
- Best Turbo Kits
- My Experience with TorqueFreaks in Portland, OR
- how much boost on stock type r?
- b16a2 with Vortech charger dyno
- sk2st2 + nitrous?
- Where to buy a 3" resonater
- please help!! turbo injector problems..
- rev hard manifolds?
- Fuel pressure regulators...Stock GSR VS Aeromotive..., and GE fuel rail ?'s...
- At what point do you upgrade spark?
- Finnaly boosted!!!
- Car dies with hondata
- Turbo JDM B18C questions
- oil leaks ..help???
- a/f guage install?
- Notching crossmember, welding plate
- oil returns
- FMU Setup Question ....Newbb
- Need help modifyin my F-Max setup on '99 Accord
- Another satisfied customer of Earl
- suggestion needed for my b18c motor rebuild for turbo!
- vac lines on the frotn by the why wont my wastegate hold at 6psi.....q's
- manual cam swap into auto b16...
- Turbo B18B DC4 for street and road racing (HPDE's)
- Are 440's too big?
- Vacuum Connections? - important!
- Do you turbo guys upgrade your valvetrain?
- Hondata Rom Editor 3.5.5 and hesitation
- gt32?
- How Much Hp can the Drag intercooler handle?
- resistor box with stock injectors
- Preventing boost to drive for tune
- hack vs retarding timing
- Engine bay
- bov question...?
- timing with afc...
- TUNERS in Michigan
- B16A2 IM vs. ITR IM?
- Got tuned by Torque Freaks today! Almost part of the 300 club...
- Greddy kit, intercooler options??
- Place to order NGK BKR7ES-11 plugs?
- sufficent water pump for aftercooler?
- Defi gauge question.
- turbo d16a6, no boost, help!!!!!
- Need HELP picking turbo.
- Engine burns oil... could I still boost it?
- best place and cheapest to buy NX shark nozzles?
- best turbo for my 84mm gsr project
- can you lose power w/ a 3" exhaust
- installing turbo, with no fuel or tuning
- has anyone made one of these manifolds?
- hey is this turbo too big for my setup??? i already searched
- DSM 450's vs. Anything else
- Endyn Catch Can Install on a Mounted B18B
- EMS capabilities with JRSC
- Tuners: Your opinon on timing for boost..
- opinions on setup\prices
- can you use air filter from AEM intake??
- Turbo Setup Opinions
- Hondata and Knock sensor question, and Tach question...
- What wastegate is this?
- D-Series Turbo Manifolds
- Im OFFICIALLY sprayin it dawg :)
- 3" muffler's for custom exhaust...what sounds good?
- emissions...??
- Need oppinion on which of these 2 turbos to go with!
- took my turbo kit off and my radiator starting leaking
- Procharger kit for the GSR?
- Sleeving B18C1 block to 84mm... Required to match port the head chamber????
- directions for greddy 93 si turbo kit blue box install????
- ANY Boosted f22's out there.. Post up pix and/or some specs and numbers!
- HKS Turbo Timer Type 0 Programming Help
- Does Vortec make....
- LoveFab Manifold Owners, help needed.
- we all know the SC vs turbo has been beat to death!! but i have a question!!
- Open o2 housing
- help.......injector question!!!!!
- anyone heard of a type s head on a b20 block?
- safe to boost 104k mi. d16y8?
- Getting a bit of smoke at idle.
- So Cal Dyno Day - Rage Performance Style
- what do you use???
- what should I use check valves, or missing link????
- gains of y8 mani swap
- Everything is ready for my Endyn setup, then I find this thread...
- simple question
- ACT Clutches?
- GSR with Type R radiator, Will greddy turbo w intercooler still fit?
- What Turbo Kit is Most Upgradable? Want to Upgrade Turbo and Manifold
- Audi 5000 turbo questions(KKK K26) and 1 intercooler question.
- Carrillo Rods
- TURBO D15?????????
- jdm ls or jdm b20 for boost?
- How long will a T3/t4e 60 trim take to spool up around 16psi???
- greddy full auto turbo timer tech question
- Cool down time.........
- what honda manifold fits dsm turbo?
- what turbo to use?
- AVC-R Owner's need your help!!!
- calling people that know SOHC FI #'s well....
- jackson racing supercharger
- Eagle Haters and Pauter lovers info inside
- Whats is the max boost with stock sensor + hondata
- 2.0 Liter Forced Induction Build Part 1!
- DSM crushed BOV?
- confused on b18c1 block vs b16a2 block
- NB - ceramic coating at home
- MSD 6 BTM wiring installation
- I need HELP!!! PLEASE!!! (Turbo Integra Type R Questions)
- is this "clocked" enough?
- long extention cord for 1320
- HONDATA OBD2 Emissions
- TURBO SET UP HELP -- Any suggestions are welcome!
- HPARTS.COM is shutting down soon
- Presition turbo <-------(sp)
- DSMtrader.com
- GReddy Profec-b 2 boost controller.
- torque specs for eagle rod bolts?
- Aftermarket Turbo and emissions?
- Finally!
- where can i put my license plate without??
- Is a little bit of exhaust moisture normal?
- hondata ???
- 2.5" exhuast pipes vs. 3"
- GReddy T78 ... Can someone recommend a place to purchase with good pricing?
- Slim Fan for 94 Integra
- turbo my b16a, YEE HA
- AEM Wideband 02 sensor and race gas
- Stock psi?
- Looking for a city in cali thats about 2000 ft above sea level (need tunning conditions with similar
- Help pick T3/T4 for a G60 1.8 8v VW engine...
- blowoff valve q's...... hopefully easy q
- tapping oil pan
- comin out of the underground....st00pid tuned my car
- head gasket question??
- Question about a Greddy Kit on a Prelude Type SH
- TD05H and dowpipe on a 4G civic/CRX
- Turbo?
- Joining the B16 turbo bandwagon
- precision sc60 or t3/t4e?
- cant find a recent thread in here on an intake manifold...help if you saw it!
- DIY Turbo Kit,U buy the Manifold and Turbo. Where do you get the Misc Pipes,Peices
- *Post your S/Vafc set ups*
- oil drain does it have to be S.S.?
- running lean with the blue box?
- AEM EMS (JRSC B18C1 7psi) [plots inside]
- blew my motor the other day...
- b16 vs b18c boosted
- I got a question about my T25 will this part fit it?
- can somebody help me identify this turbo?
- how to hook up turbo oil feed and oil pressure all at once
- header wrap where should u use it on ur setup?!
- H22 numbers
- iratic idle
- Greddy Turbo GSR with out intercooler...
- Advice with current build up
- stock header bolts sizes
- how do I wire vafc up with blue box
- Hondata tuners please help: loss of power/hesitation @ vtec engagement
- where to get a oil pan flang?
- head flange, whats that site that sells them?
- TD04L 4 b18b1
- thicker head gasket?
- Turbo XS-RFL? VIDEO?
- HT Dyno day part2
- wastegate hood clearance
- Bosch Injectors
- The guys from turboforum are having a dyno day at xotic on Sat Feb 21
- help me identify this turbo
- HKS SSQV springs
- Installing the JRSC support bracket
- missing link???black smoke???
- any one have pics of reverse turbo?
- import builders
- people who use turbo AND nitrous
- Stripped studs in head ...
- Faced with a tough decision..
- A quite exhaust?
- Need Turbo help, have a few questions
- Peakboost Manifold
- downpipe---traction control bars problem?
- are all 5 bolt hosings made by precision
- whats cheper allmotor/turbo setup
- Need some help selecting a turbo
- Vacum lines help (already searched without success)
- wastegate o-ring
- b16a or b18b
- lower compression piston ?
- Need input on this oil cooler setup for my turbo
- Rod bearing tang towards intake or exhaust?
