View Full Version : Forced Induction
- MOETES BURNER JUST CHIPPED BUT NOT SURE??????
- Turbo Efficiency Specs please help, dyno day approching soon(flame suit on)
- having a hard time choosing a turbo manifold?
- Personal Experience needed for Turbo Upgrade Suggestions
- My B16 Setup 481 whp / 312torque
- TurboSX RFL Instructions?
- How do you know when your fuel pressure gauge breaks?
- Finnaly St00pid Tuned 565HP 391TQ @21PSI
- sc61 numbers
- GT2871R Compressor Upgrade
- ((Need info asap)) 97 gsr swap with boost
- Would this Garrett T3/T04e be too much?
- Edelbrock Turbo kit????!???
- So I had fun with my first HMT, Now the snail just grew a bit ;)
- The best turbo toy yet! Oh and my EM1-T shows its face on the forum
- JDM B18C Type R swapped into a 1999 civic si...
- Need Of Dumptube
- Head + Manifold = Problems????
- new to honda, any suggestions?
- st00pid tuned 364 whp @ 18ish psi!! Dyno chart inside!!
- Greddy bluebox question???
- should i upgrade to bigger turbo?
- question about internals for turbo setup
- Building B16 for Turbo setup
- 1FAB manifold???? (SEARCHED)
- B16 Hydro Tranny or replace my Stock GSR tranny with the same?
- NItrous Setups and questions.
- Which manifold for Full Race back door intercooler?
- Unorthadox Crank Pulley on Supercharged Integra LS
- Greddy Turbo/Rev Hard/Drag Kit users...
- help with new turbo install
- water cooling
- mbc vs ebc which do you perfer?
- question about BOV. no sound??
- plastic charge pipes or not?
- LS rods in d16
- Questions about turbo???
- Fu** it... I'm excited that she's about to start up... sorry 56k
- DIY piston coatings for my vitara pistons?
- Tial Wastegate Not Opening
- Aeromotive FPR 13116, anyone else having issues with these >>
- AEM ems conversion question
- Saturated injetors
- finally done, pics and 1st impressions >>
- gsr on 8psi - what injector size?
- Vented Hoods + Ramhorn Mani + Rain = *? Heat Shield Needed?
- prelude nitrous
- Turbo Civic guys...which bov you running?
- pick a turob
- What are you guys using for oil return line?
- Help needed B18B swap and turbo..
- Changing Color of FMIC
- oil pan question d16y8
- Drag- turbo to IC piping?
- Prodrive gears or stock???
- Fuel injector cleaner?
- Has anyone tried pocket rockets racing from ebay???
- Interchangeable Turbo Parts??
- Who sells 2.5" aluminium intercooler piping kits?
- b16
- Boost Noobie question
- h22 turbo clearence - front mount bracket/block wings?
- will 35 mm tial wastegate be suffice for 300 hp?
- efi tuning book
- tial style wastgate
- Help identifying this t3/t04e turbo...
- spraying on a h22
- do all b-series have the same timing?
- Tilton Hydro Release bearing kit install....please help!
- ss autochrome
- cutting out at 4500 rpms.
- Turbo b16a is in Now what?
- Prelude JR Supercharger question...
- which ebc greedy profec b or hks evc
- best place for boost gauge and wastergate hookup
- Bigger Injectors Needed?
- Whats this hole on t3 turbo?
- **Pic Request** Where did you mount your Greddy e01 screen?
- jackson racing question
- I/D Hose Size For WG/Bov/Boost Gauge.. Whats the best?
- Turbo Problem HELLP
- Need help with e-manage injector harness
- Screwd? Main Journal Damage..... (burr/markings)
- Moroso oil pan with oil retun
- No fuel or spark ? >>
- jb weld on bov flange= good idea?
- Best "half" Civic radiator (to fit in a teg) for FI?
- manual boost controller acting up
- Search is down, quick ??? about Hondata Intake manifold gasket
- Rumor someone told me about Hondata, is it true
- Help Me!!! my car is missing?
- Car is surging
- Calling all GREDDY PROFEC B SPEC II users
- ls vtec turbo oil leak--help needed!!!!
- Automatic and Boosted ? Identify yourself if you DARE...
- AEM EMS or Hondata???
- Water/Methonal Injection
- Please help me!!!@#$%^
- problems with revhard intake manifold
- Any experience with Lightning Motorsports out of Baton Rouge, La
- Full Race t3/t67 Oil feed Question
- Comptech intake fit on JRSC for LS ?
- Piston slap w/SRP's
- Q:flexible aluminium pipe for air filter
- What is the best turbo for a dohc zc in a crx
- Is it really worth it?
- Does your manifold stand over the oil test stick ??
- probably the ignitor
- Hi All
- Crazy Tach Needle, Breaking Up, Ignitor or Coil?
- V-AFC Fuel Control + Stock Y8
- ctr cams in lsvtec turbo what you all think
- Gonna turbo my h22.... lemme know if you think this setup will do the job...
- help me with 1gen dsm bov with the stock pipe, wat u use to put on ur TB
- Wastegate Gurus. Inform Us All *MANY PICS* Assembly/Install/Checks
- Mid Atlantic st00pid Dyno/Tuning Days Sponsored by Boostfed Racing In Virginia April 15-16th Sign UP
- Open dumptubed or recirculating?
- Anyone have an older version of Hondalogger?
- Nitrous and low compression
- Pics showing the Difference in the Moroso Road Race and Drag Race oil pans.
- Blitz Power Meter
- HELP turbo went out.
- Nitrous bottle switch?
- bnc's contact information
- D17A2-T question
- Injector question?
- S/C K24 ?
- How do I control My boost?
- Pic request: B-series oil pan with an extra quart or so
- whats a good size turbo for a stock b16?
- how does this deal sound for a turbo?
- making manifold, what size pipe???
- Who is making 350-400bhp?
- Leaning out w/ AEM EMS. Pix and all info...please help get this back up and running...
- Sohc Vtec Turbo or B16 100 Shot
- Hot Hot Hot..........oh.....oh shit
- CAI Vs Short ram for JRSC B18C
- Where to buy precision injectors?
- b18c block w/ b16 head vortech
- boosted D-series w/ EXmag
- Vband??? WTF search server down
- Bigger injector question
- Project: SSBP Turbo Photos
- Greddy turbo Kit for Si on LS????
- turbo d16 question??
- Igntion Problems before boost install. Help!
- LHT intercooler?
- are these spark plugs right?
- Car Running Rich
- Intake Temp Senser question???????????
- Precision Turbo
- Engine balancing... Is it really worth it???
- full-race turbo kit
- How many of you daily drive your boosted hondas?
- LS TURBO.....rebuild?
- a few questions for the boost junkies
- just boosted my b18c.. backfiring problem..
- question...greddy fcu? and greddy e-manage? wats the diff
- ZC (sohc vtec) with a CT26??
- Everything needed?
- white smoke from down pipe
- who to build your block in dallas
- where to buy new rebuilt turbo?
- Where is this benson fellow
- Downpipe too Close to Alternator???
- how bad will not having an LSD hurt me?
- Full-Race Pro-race manifold..
- egt is like a bass guage
- oil cooler
- hf adapter (HELP)
- carburated turbo setup>?
- Need a Turbo manifold...whats better?
- drilling a hole for a flange?
- b16 head valves?
- Precision Turbo any good
- Which ECU?
- quick uberdata question*
- How much torque on 81.5mm stock sleeves...
- hydro b16 tranny, JR BTC MAP VPAC FMU, NGK wires
- Basic setup advice
- b16 eg progress pics tell me what ya think.....
- How can you verify which rod bolts in Eagles???
- About to purchase mandrel bends, need last minute advice.
- Noob to forced induction!!!
- Kooks style manifold (a.ka. Full Race style) - Why is it equal length???
- 4" DP mockup begins (link to previous thread inside)
- Some pics of my new project
- will dsm 450's work?
- Break in period for new rods and pistons?
- I know it's not a honda, but turboing a NA FC3 RX7?? NO TII
- Another EGT question (searched)
- Misfiring w/ a Greddy kit
- Searched inside and out for 18g compressor maps...
- this manifold WILL get you laid
- Bulldogg83's History.....The Clarification Thread....Feedback Needed!!!!!!!!!!
- GReddy Aluminum Mounting Flange
- Is it too big?
- turbo exhaust manifold
- TopLine Rod and main bearings
- Which resonator? 14" or 18"
- Aftermarket parts for turbo B18B1?
- TURBO SHOOT OUT!!!!! ........ WINNER TAKE ALL
- Tial wastegate forgot to put the Metal ring in HELP>
- confused...fuel management injectors ect......
- Precision Turbo = SS Autochrome?
- Turbo Help???
- What Fuel Setup systems do you 500+ hp people have?????
- rom editor 2.5 password?
- Michigan tuners?
- can some one give me a conversion from bar to psi?
- Valve sticking or bad stem seal, would you still boost??
- Precision Turbo....
- AEM Ems or Apexi Power FC
- Integra obd conversion
- diy - want to hook up turbo by this weekend.. help
- S14 200SX Project (56k No go)
- prepping the b16a for TURBO maybe some help.
- Just installed built block, knocking sound ***video***
- DO I NEED TO CUT MY LOWER BUMPER SUPPORT FOR IC??? SEARCHED
- headgasket holes don't line up with my sleeved block need help! *pics included*
- john d VS z28 (vid)
- Is there a chip burner and chip that works for Uberdata and hondata?
- 24" OR 22" SLICKS FOR MY SETUP UPDATED
- B-Series Turbo Kit
- turbo uberdata maps
- What is Lambda?
- after fixing exhaust leak which was wastgate not fully on...
- arias pistons
- what ecu
- SOHC TURBO T20 QUESTION AND NEED A DOWNPIPE WITH FLANGE
- my new nitrous setup: questions
- n00b turbo tech question
- fuel regulator mounting locations
- Need Help: Charge pipe questions
- b16 blue box work on b18 NON VTEC?
- Any ideas?? (coolant problem)
- boost controller. I'm needing one. step inside please
- cheap back yard turbo???
- vacuum line question?
- stand alone engine management
- turbo exhaust set up
- uberdata?
- IHI VF39
- fuel sump pump selection
- nipple broked
- can one use a walbro as an inline pump.
- Gt3255e vs Gt3251e, Some prices, and options, and crap would be nice to
- MSD SCI any good?
- Difference in TD04H-15G and TD04H-15C *specs, pics inside*
