View Full Version : Forced Induction
- I having missink link still get check light?
- wastegate flange question!
- Has anyone seen any convincing evidence to go with a 360deg thrust over the 270?
- smoke coming from exhaust need help
- Aluminum Vs. Steel
- Is anyone else running a Garrett ball bearing center section conversion???
- Is GT3567R more worth getting than the T3/T67 H.O.
- Help me to identify this compressor wheel (pic inside)
- Could someone explain CHARGEPIPES???
- Uberdata vs. neptune ?
- what tires do you like for you boosted dd honda??
- Couple SCM 4inch Exhaust fitment pics and a 35R sneak peak...
- Advice on cleaning up my sloppy frontend!
- What do you think
- If i go with a differnet turbo do i have to change my flange becasue its a hf manifold?
- Uberdata/Crome users in Maryland
- boosting a y8 couple questions
- Greddy oil filter block adapter leaking
- compression test results ok?
- shoc non-vtec boost build
- -3an or -4an oil feed line?
- what is a missing link???
- how many PSI should a run and on a 95 LS. i'm planing on putting in nrw rings in the spring
- XTD any1?
- Which on of these two motor mount inserts will give me the best results?
- HKS SSQV BOV on Honda help...
- Possible blown head gasket? *PICS*
- Where to buy 2.5 inch to 3 inch adapter coupling?
- what do you think?
- happy median between GT4088 and GT42r?
- How do you tell what type engin you have?
- Optimum C/R for 8-10psi
- what the hell is this? sx performance fuel pressure regulator?
- how to hook up water/oil cooled turbo?
- T25 turbo and 450cc injectors from a DSM on a 95 LS motor into an EG. throw me some in put
- Block guard for ls/vtec
- Tapping head for oil?
- turbo ?
- wastegate dumptube *searched*
- which int manifold is better?....
- Full Boost... Traction Issues Wider Tires?
- SRP question on a boosted D
- ls/turbo setup help
- greddy turbo gasket. Where can i get it!
- Increasing Intercooler efficiency??????
- Daily Driven B20T???
- Check out my plugs and broke ass toe
- Unable to tighten some turbo manifold bolt
- ramhorn manifold
- 2000 b18b turbo kit what to purchase
- NPT Male to BSP Female Fitting?
- injector question
- I need a NY or NJ area tuner!!!
- map sensor for turbo???
- swap in a 98 ex coupe
- difference between 255lph and 255gph
- Greddy Turbo exhaust flange! Question!
- Does anyone know of a kit like this?
- Mounting IC and IC piping.............before the rest of the parts
- How does this regulator works?
- using crower stage 3 on a turbo setup
- know of any good machine shops/engine builder in NJ/NY area?
- Smoking Problem?
- Can somebody read my plugs for me?
- Boost stays until redline on small T25
- Turbo Collar?
- forged internals?
- vortec question
- Greddy exhaust
- compression
- intercooler/piping
- In our spare time we roasted some uniroyals!
- knocking noise at cold start
- need photo of CTR or ITR or skunk2 stg1 cams (compairison)
- turbonectics t67?
- Timming Problems
- AC in civic ?
- turbo for eg
- Is this normal blow by?? please take a look
- Installed Turbo Yesterday, PROBLEMS!
- Rod Bearings Photos, Please, need opnions.
- Merry X-Mas Boost Freaks!!!
- ordered 3 bar map sensor,work with uberdata?
- Tuners LOOK, elevation question.....
- FMIC mounting?
- Precision Turbos Now In Stock-Ready to Ship
- 450cc injectors
- lovefab
- need advice on fuel systems
- Compression Ratio?
- Turbo help!
- Since turbocalculator.com seems to no longer exist, which would be better for 20psi...?
- Crazy Speedo/Tach/Odometer, part deux
- What wideband should I go with?
- Disadvantage from TOO BIG intercooler?
- Psi/Boost question and the relationship with hp
- Crome Pro users... I need some feedback.
- Aeromotive A1000 fuel pump wiring...need some help
- TURBO f22B1 Plug and piston question
- Efficiency of this turbo I have here...
- edelbrock dyno numbers for LS-turbo kit?
- vafc + fmu =?
- will a hf manifold hender my power(over a turbo mani.)????
- Tune for e-cutout?
- how much psi is a t3 (.42/.48) efficient up to?
- Interesting Dyno Comparison..
- What is the most HP you've seen with a stock fuel system???
- greddy bov and dsm. same flange?
- T04R compressor wheel and T04 69 trim turbine, anyone using this setup?....
- B16 t67, which A/R should I go with?
- working for 600 powerd h22
- Other B16 Turbo question...
- Oil leak from turbo drain line....ok to remove gasket and torque that sommabitch down?
- Overheating with heater off..Can I remove the heater core?
- upgrading a drag kit
- Mini me turbo
- Wastegate flange=dumptube flange?
- T3 .60/.48 worth it over a T3 .42/.48?
- boosting gsr block
- greddy type s help
- Anyone know of So Cal ECU Tuners?
- emanage, Why is everyone against it?
- Edelbrock Intake Mani vs ITR manifold
- JRSC install, now motor BOGs after 100 miles..... PLEASE HELP.
- feels like im pulling a house!
- Compression Test Results. Need some help...
- Want to boost an F22
- Good turbo for stock b16 with future forged pistons and rods in the works
- Anyone need a B-series scatter shield for their winter project?
- Is my intercooler too small?
- HKS SSQV
- GT series oil flanges.
- full race turbos
- Where to get a turbo rebuilt?
- e-cutout people: where in your downpipe is your cutout???
- what do you think this motor will make?
- 500WHP on 91 octane possible on this setup?
- greddy type s?
- T25?
- Boost Controller w/boost cut for each gear?
- B20 Setups
- B20 VTEC TURBO HELP
- turbo tuning
- Crane Cams Firewire???
- T3567R
- can i keep my ac with this manifold please help
- JG block 600 whp??? good idea???
- What would you pay for a used T3/TO4?
- bump
- apexi turbo kit
- need input on my proposed B18C CRX fuel setup-wanna make sure it's good for 500-600WHP
- wtb single cam turbo manifold any ideas
- Jackson Racing vs. Turbonetics
- Higher idle speed after clutch and flywheel install.
- picking a intercooler
- what is the best log manifold for a DA ?
- Questions galore, anyone want to help?
- Turbo??? Help
- Anyone w/Stock Valvesprings in 300+hp
- gt42r 700+hp SFWD EG civic in the works...Pics inside
- Used Je pistons
- Ideas on a mystery oil leak?
- Anyone have an idea what turbo this is?
- arp headstuds
- boost a b18c1 wiht itr pistons
- dsm injector compatability
- Anybody ever dealt with Turbo Elements.com?
- When is Neptune being released??
- stepping into the dark side, newbie to turbo need a little help
- "Missing Link" question....
- garrett
- what turbo is this
- Which turbo for my setup..?
- gt28 wastegate problem
- Please Help B18c1 Build
- Fatboy Garage Turbo... Anyone ever run one????
- Fuel Cut/Ignition Cut + CEL flash? Hondata + P28...
- very,very, low idle.... searched... help pls.
- Is this a bad sign? (blown seals?)
- Mild steel vs Stainless steel dp.....
- Turbo b16 clutch choice
- Silicone 90degree Tight Turn Elbow... efficient? pic inside
- psi, cfm and turbo sizing
- time sitting after build
- Will the Apexi Power FC work on OBDII cars?
- Water Injection on Roots blower?
- maybe a newbie question...
- A couple of questions about this lsvtec setup
- drag kit dyno
- Quick adapter plate question for sohc turbo
- FR T67 with SC61 turbine housing can i do it?
- Custom Setup
- boost problems!
- need tune for turbo
- rc vs precison
- Are these signs of a bad ground?
- Question about turbocharging a supercharged car
- B16 Sleeve Help
- del sol downpipe
- Turbocharger balancing
- Big up's to John at J-K tuning!!! Emanage sucks Chipped OBDI is the way to go, plus IACV help inside
- Give me your opinion!!
- HELP PLEASE!!!
- question about turbo for my EG...........
- Oil and Water flange for Gt2871r
- Opion:Turbo Vs. Supercharger on 2nd Gen B16 EJ1
- Greddy Profec Type S boost controller problem
- 613hp / 510tq K22
- Emissions?
- throttle body question
- Need help with head/valve work(ITR turbo)
- Whats the A/R ratio of this housing
- post your b16-t setup
- Is there any concerns boostin a JDM B18C (higher compression)
- At which power level would you upgrade the clutch?
- Cold air with turbo?!
- turbo question
- 2004 civic EX turbo kit?
- Wastegate spring question
- Armrest for Ek 96-00 is there a soft top swap for this?
- sohc boost question
- was this a good deal? building b16 block
- info about contacting vince @ krb
- clutch upgrade for future turbo...help
- SSAC IC
- wastegate springs the same??
- how long do your motors last?
- Advantages of a Type R block over a b18a
- Hondata gasket VS no name ??diff??
- Oil Pressure
- stroker kit
- anyone have any Honda .cal files for Autronic I can use just for research?
- Black Plugs Already!!!
- What intercooler do I have?
- Most boost PSI from Airresearch T3
- tired of looking i need wheels studs and lug nunts for my gsr
- new dyno: d16z6 t3t4e 57 trim @ 25 psi 550's 2.5 DP Servion Neptuned 340 whp 305 tq
- can my motor handle it?
- can i run fmu inline pupm and 440cc injectors w/o tuning
- is a 84mm bore to big for a reliable turbo setup
- Dynos and Phone #'s in VA?
- WHAT SIZE INJECTORS WITH UBER-DATA??
- Help: is this the correct turbo piping for a 1996 LS?
- d16y8 vs b18b1 on boost
- The Shodan's OTHER Boost project
- wastegate questions...
- Greddy Turbo kit for GSR. IS it worth it poll
- car not building boost.... Help????
- JRSC, valves vs exhaust.....round 1 - FIGHT!
- Tuner Toy Rods dont fit Wisecos
