View Full Version : Forced Induction
- drag III guestion
- Superchargers: Vortech vs. Jackson Racing
- (PIC) My drifting hb!
- Boost - HS Turbo Kit Pics
- Vaportrail, Sqt, and any other EXPERIENCED dyno tuner please help..got some ?'s
- greddy boost gauge install help/confusion
- anyone know about german turbos?
- Stalling and hesitation
- I messed up my engine tonight
- Very important questions, need experienced answers. Please help.
- Question for those who have installed Hondata heat shield......
- I need help!!!!
- ACT question
- what kind of turbo is this?
- Darrin u around IM ME
- I miss my Turbo!!! :mad: ****eye candy inside****
- 2 stripped manifold bolts, many cuts and bruises later, another Honda goes boosted!
- My gauge is not reading right
- today christian rado made history
- turbo help...
- Where to rebuild turbo?
- Turbo newbie, need help please.
- Need tips on doing an engine build-up / rebuild...
- dam, blue smoke again!!
- stock SOHC vtec + 8psi? Please read
- Which turbo kit should i go with?
- I think there is a noise coming from the clutch??????? HELP!
- JRSC with Nitrous
- Exhaust leak and symptoms...........
- Help with my turbo setup
- what the f@#ck!!!! some read this(fuel question)
- FMU Questions
- technical question about vortech FMUs...
- Stuck between rock and hard place.....need opinions.....
- Spark plug review
- Gsr ignition timing
- Where can i buy a 3" carsound cat?
- Has anyone hear of or have a...
- 3inch exhaust Q
- Do I need to upgrade my stock fuel pump?
- Which way to turn wastegate bolt?
- Dyno plot... (This isn't your Daddy's Oldsmobile)...
- Turbo install question
- NGK Spark Plug Wires?
- Newbie Turbo questions... :)
- Problem of Profec B
- Trouble of Profec B...
- Just got back from Englishtown.
- What is smallest trim t3 flange turbo produced?
- I need an install tutorial
- Any Austin, TX turbos care to meet up?
- Air/Water Intercoolers? Any opnions.
- 84mm 84.5mm//whats the Difference??
- H22 head studs...
- miss-shifting with forced induction... any bad side effects?
- B18C w/ Jackson Racing Supercharger
- Correlation of Quarter mile time to Trap speed q's?
- How the hell do you take off the rotor inside the dist cap?
- Ignition cut for turbo?
- Does anyone manufacture a smog legal turbo?
- Questions about the MSD Activation Window and nitrous
- the use of a bigger radiator
- walbro hp pump for fmu?
- Just got my Defi Boost/Link combo.
- Turbo GSR or N/A GSR
- Do I need any special tools to disassemble my engine?
- Wastegate actuator, where to take boost feed from?
- Fastest times for SOHC turbo
- gas mileage after supercharger...still decent? you like it??? (don't tell me to get turbo...)
- Import Meet. . . . .
- exhaust question
- From your experience or from what youve herd what you think is the best kit
- Is a cold air setup on a turbo worth it?
- Which block should I use
- FMU Installation
- What do you think of this manifold?
- plugs for boosted sohc
- Rebuilt motor - good way to break it in?
- Please Look : Need opinion on custom turbo set-up
- So, who on this list has recieved their GARRETT turbo? Just wondering....
- B17A exhaust ports the same as B18C exhaust ports?
- So, if I turbo my car, will my insurance increase?
- wtb: 650-800 cc/min peak and hold injectors
- I went again, even better times!
- I know this not a kill forum, but juss gotta share my first kill
- boost gauge
- mods sorry to post fs here but turbo relatated: $55 shipped greddy steering wheel remote
- Cheapest place for T3 rebuild kit
- Garret T3 a/r 48 on z6 minime ?
- Acuator rod length?
- i took my car to the drags
- Compression-What's yours?
- greddy e-manage ...
- sanding pistons
- Opinion..on Drag 11 manifold.
- VERy STrange, turbo smokes, now it stops
- Almost a Kill: ME!!!!
- Just ordered my Drag III today from Ben!!
- I just bought a T3 turbo, Pictures
- Blue Box: Does the flashing green led mean I spliced things correctly?
- need pics of sparkplugs(what they should look like after boosting )
- Just can't decide (On an engine for boost)
- how much retard? (timing, of course)
- intercooler finished , all of it, testing tomorrow!!!
- If I could have fit these on my Honda, I never would have sold it.
- How long until my piston rings seat?
- check engine light code 13 after greddy turbo??? HELP!!!!!!!!!!!!!
- Question about an Engine/turbo set up, Need help and advice!
- update on my 5hp turbo setup.
- cometic - bigthumbup
- Darkside is closer than ever! But I need to get my engine built for high boost! What shops in Cali
- My turbo arrived today!
- post your turbo videos
- What's the best fuel system
- websites
- BOV sounds
- 10psi MAX. S-AFC or Hondata?
- zex install question
- Aeromotive FPR, 1000hp Fuel pump... Opinions
- My new and *unexpected* car!
- turbo xs bov
- aluminum welder in so. cal
- I just talked to Joe at Alaniz...questions
- Anyone want to trade????
- 98 GS-R Turbo Kit - What's the best & Why
- Have you ever hit boost in Reverse ?
- baffles in stock oil pan
- Quick help please with turbo info.
- What cams on JRSC??
- Hey, you guys have any experience with stroker kits?
- Its Friday!!!!!!!!!
- turbo manifold for t4
- Need heat protection under the hood..
- New times from last sunday's meet
- Pressure on oil return line
- Max-Rev H22 Manifolds
- Machine Shop? HELP!
- How to hook up inline fuel pump?
- sohc greddy turbo kit wanted!!
- Has anyone ever disected their turbo?
- OT: attn bay area GSR Drag 3 turbo people
- Why don't we hear anything about Alaniz Cylinder Heads?
- problems passing smog test after turbo?
- in the process of dsm injector install but they dont want to go in!!!!
- Loud Boom!
- Just in Time!
- WHY are superchargers listed first in the FI forum description?????
- Turbo D16 dyno and timeslip (JFK78's)
- Good reads...?
- Can you guys post your first Experience with your turbo installed!
- GSR ECU and Greddy Turbo Kit
- Which gauge has a smal scale? ->>
- what do you think of my setup?
- Well, I just broke the bank.......
- I need your help.
- Anyone ever do this?
- any major complaints about your drag turbo kit?
- Profec B
- custum turbo for b18c1 wich parts?
- bigger cat or test pipe?
- Intercooler mounting troubles Help!
- QUESTION!! Is there anyway to get Torque #s Close to Hp with Turbo
- fuel delivery mods
- leaded Race Fuel
- who has got a turboed del sol
- Oil fitting help
- Boost controller
- best size turbo for an integra gsr runnin on stock internals?
- turbo "accesories"
- Got room?
- LS Potential Setup
- how high do b18B LS cams make power?
- SOHC turbo guys.
- whats the average price to get a stage II w/ boost hondata tuned?
- WANT TO BUY DEFI GAUGES! XS ENGINEERING IS OUT OF THEM!!!
- Garrett turbo
- Where to get a turbo installed??????
- Just ordered my rev hard kit!... i feel nervous, yet happy.. i dont know!
- I need help with this setup
- injector failure?
- What do you turbo guys do about your front license plates???
- Turbo kits choices
- Pple with b18b turbo setup
- greddy td05 18g exaust manifold
- Tuesday is dyno day!!
- Octane Booster, Does it work?
- AEM Fuel Pressure Regulator
- New Turbo Cars
- How much boost should i run with my setup? any help apriciated
- which bov with drag III?
- Vortech FMU
- vacum lines
- anybody dealt w/ brian crower?
- Jun/cosworth piston
- Quaife Differentials Group Buy
- how much is a hondata for boost (10psi)
- dish in combustion chamber concern... <image>
- Show me your gauge setup!
- wastegate from B18B?(VSracing)
- greddy turbo ....what plugs shouldi use
- oil pressure sending unit question...what size socket?
- retain AC with turbo kit
- TORQUE SPECS for ARP head studs on b18c1 head onto b18b1 block ?
- What do I need?
- 3" downpipe, do I need one and where can I get one?
- SFP's website?
- Rev Hard Manifold
- Turbo specs for stock cars.......
- clutch master and slave cylinder...gone BANG.. due to fast turbo 1/4 runs
- How often do you BOOST?
- How much did you guys spend on your Turbo setup? I mean EVERYTHING!!
- Do gauges ever decrese in price over time?
- Dyno #'s!
- B18B1 Stock Injectors...what are they good for?
- Ran my car- awesome results!
- Do you think those are good EGT temps?
- NOT FI RELATED, but you guys are the smartest on H-T!!!
- Boring out a GE Block
- Sandwich Adapter for oil feed...
- Turbo Lifespan
- 18-22 psi on SOHC, Questions
- Flex Pipe Question
- Earl's fittings, and ss hose online?
- LOL, results are in... $1500 later, I gained 5hp by going turbo!
- Opinions on MF2 with custom setup???
- I've decided to go with the turbo SOHC
- what do i need to know to build a custom turbo?
- Huge Intercoolers For Sale
- Custom Front Mount Intercoolers For Sale Cheap
- what kinda exhuast are you guys running? ( curious )
- Anyone have the wire color codes to a '94 GSR ECU?
- IHI turbo from Mazda 626 GT
- Tial wastegate install
- Anyone going to Carlisle?
- dyno today!!!!
- fuel problem *URGENT*
- Drag 3 install question
- turbo map for my t3. does this look right to you guys?
- stock or aftermarket ignition at 325 hp?
- anybody need a bottle warmer?
- Any equal length, A/C PERMITTING, turbo manifolds?
- which clutch for turbo..
- what to do to lower egt readings...?
- J&S Safeguard install question
- Hey, my turbo with 2.5in down pipe....
- Just wondering bout the Garrett turbos groupbuy..........
- vaccum source for bov and wastegate ?
- stock psi for mitsu 14b ?
- b18b-Max PSI on the stock sleeves?
