View Full Version : Forced Induction
- turbo dx in simpsonville sc
- need opinions before i purchase jrsc kit for my gsr
- tranny changing a/f ratio
- AEM UEGO controller range?
- What's good power for a B16 w\ Drag 3 Kit?
- inaccurate boost gauge
- Best Turbo kit
- car started......having issues!!!
- Looking Into an 82mm Bore for my stock sleeved B18B1 Motor for Turbo. Can This Be Done Safely???????
- oil feed
- need soundclips of tial bov!
- 99 turbo civic wont start
- steel braided oil return line- how long do i need it
- is my rod fixable?
- My 2% leakdown motor smokes... WTF?!?
- b16 or lsvtec
- 30 psi?
- blows oil through dipstick
- whats wrong in this cylinder? spark plug pic
- Ahh!!! Digikey is out of Atmel 29C256's!!!
- b20 turbo help!!!!!!!!!!!!!!!!
- Has anyone ran there turbo in this way?
- Debating boost..
- My DIY oil catch can
- Turbo info
- What's better...internal wastegate or external wastegate????
- anyone have any opinions about turbo specialties
- when do you guys turn on/off your nitrous?
- blue box question
- Autometer boost guage question
- 12.1 c/r good for turbo
- z10 girdle or GSR machined??
- Thinking of using a test pipe but have a flexpipe question.
- modifying oil pump for more pressure at idle?
- shorten or lengthen the wastegate for more boost??
- Smog - Test Only station - ca + boost
- 3 bar map?
- rebuild block due to high compression..........
- WHOS RUNNING A CLUTCHMASTERS TWIN DISK
- How much would you pay for Garrett T3/60-1 ...........
- New injectors/pump/exhaust & tuning??
- b16a Turbo Question..................
- REV HARD TURBO KIT FOR MY 92 HATCH
- gettin h22 tuned...long drive... dont wanna boost..take spring out of wg?
- Turbo Honda/Acura as reliable as factory turboed car?
- T3 Rebuild Kit
- need turbo to match my needs
- Any intrest in having a TUNER come up to the Northeast? JDogg, Mase?
- How many people O-ring their motor?
- which one has a better powerband?
- flex section between the turbo compressor and the charge pipe ?
- smokes under boost/ load
- new dyno numbers-558.9
- a/c compatible prelude turbo mani.
- drag turbo kits
- Looking to upgrade.........
- Turbo Rebuild
- this is what happens with turbo xs
- civic edelbrock turbo kit
- big difference between T3-T04e .60 vs .50 compressor?
- Will a new exhuast housing increase my downpipe size?
- what does your car do from 100 to 200km/h
- whats a good plug gap for fi sohc
- Built H22-505 whp and 378 ft-lbs at 21 psi
- turbo question....
- --Vortec H22?--
- ac lines touching manifold.. and oil return question
- almost boosted ;-)
- cleaning an intercooler
- What To Do With These Pistons?
- Turbo n00b Questions
- Very fine red/rustish looking dust inside distributor cap???
- Jun flywheel and Titan crank pulley.. good idea with 10psi?
- What size turbo for my drag gS-R ?
- t28 bb turbo
- Will this work
- Beating a stock B18c1
- I have a Greddy 18G on a b16. At about 7200rpms boost drops to stock wastegate setting. why???
- leClutchMaster clutch?
- h23 camshaft
- 92 Lx tranny work on 93 Dx?
- Zeitronix Datalogging software new update available!
- Intercooler vs. Radiator
- mixture problems with black top dsm's
- another turbo question
- Any Turboedit Feedback?
- SSAUTOCHROME?
- Edelbrock Turbo Kit
- CP 9.8:1 pistons from a GSR
- How should I set up my oil sandwich plate, pressure & temp gauge, & restrictor setup (pics inside)
- Zeitronix datalogging: How many "Frames" per second?
- Jackson Racing blows - help me pick new D16 turbo setup - $ is no object
- turbo d16y7...what fuel pressure.
- Does this look like a Walbro 255 to you?
- dont u miss your turbo honda? ...... non technical forced induction post.
- just installed turbo setup and no bov action
- just curious... How come JR superchargers don't need oil like turbos?
- LS turbo teg FINALLY DONE! dyno/video inside
- how can u tell if a JRSC is a M45 or M62
- oil return line
- greddy emange and eo1.. is fuel already set up?
- New Electronic Boost controller Anyone used it?
- D series guys post your timing tables
- Turbo D15B7 or Turbo Mini-Me??? Which one?
- Type R cams or crower turbo cams..????
- Boosting a D15B7
- 84mm pistons......?!??!!
- ls tranny on boosted b16...is it really that bad
- running 5-8 psi
- difference between .48 stage III or V, and standard .63 AR exhaust housing?
- Oil Pressure is INSANE!!!!!!
- How to adjust fuel on V-AFC?
- bore and headgasket meaning???
- people with CLUTCHMASTERS STAGE 4 (4 puck sprung)... please chime in with your DD opinions
- ohio builders (columbus)
- :::::::Monza Bov ::::::: anyone got and use it
- Max for on stock B20 sleeves?
- Help:garrett 60-1 turbo setup
- quick FMU question...?
- Rebuild advice
- Action clutch 2ms or Act xtr-6?
- is the LS oil pan the same as the b16 oil pan
- stupid question but can't figure out the answer
- power steering cooler?
- Hello If you need any recall info or other such "honda" information Honda IN network
- Direct port N2O with Big Cams.......need advice.
- Precision injectors, Who uses them? and how....
- Can I get 300-325 whp?
- ideas for new turbo on b16
- .....7 months on Boosted Hybrid tune....:0
- Finished Install...IDLE LOPING..NO BOOST!
- custom vs peak boost kit
- 1.6 bar =???Psi
- how much should oil feed line flow?
- Nitrous cams for my b18c
- 2003 RSX-S [AEM EMS, Uego, etc... (16psi, plots)]
- For you Dark Side SOHC turbo Peeps
- dynoed my turbo ls
- Spark Plugs...Which do you guys run?
- Will Aluminized IC Piping Rust ???
- ?s about golden eagle lightweight crank
- Car is going super lean at 3000 rpm's
- Is it possible to monitor your engine's sensors on an LCD screen
- greddy blue box
- Possible ignitor problem? Or something else?
- do i have blown something?
- just an update on my project... pics of course
- headgasket to lower compression
- dual exhaust for turbo setups (don't laugh)
- Rant...Rev Hard intake mani
- have lsvtec and wanna know whats best pistons and rods to throw in her
- Mitsubishi TDO4L - 15C - 8.5CM2 / 390 CFM! good for d16?
- 02 sensor question
- Blitz BOV, old Vs new , same flange?
- T3 compressor flange
- CEL, no start... help
- Welding Charge piping good or bad?
- My build *comments*
- LS bottom+ R Head...??
- H22 Turbo NEED HELP!!!!
- Help TurboXs hp MBC
- should i bore out my throttle body????????????
- I'm Planning on Turboing My Little D15b8!!!!!LOL
- WTB 5-6 lb Deltagate II spring..?
- Fittings are starting to piss me off...
- block adaptors "Oil sandwhich" which for autometer gauges
- does it matter if i have a cable or hydraulic?
- Blcok girdle on a b16
- 300 whp on f22 w/ aftermarket pistons and rods?
- TURBO ASSEMBLY HELP!!!
- Anyone gotten Ostrich to work with HonData?
- Getting it tuned saturday, how far should I push it?
- compression test: 25 psi???
- who can install a turbo kit??????????
- Any way to approximate how man RPM's lost between shifts (LS Tranny)
- 14b oil return
- tuning budget
- Request : Oil Feed Line pictures and oil return pictures
- b16a2 how much boost
- want to lower compression on d16z what gasket
- sohc TURBo z6 or b16 with bolt ons??????
- HELP!!! Built GE block....No cranking COMPRESSION!!!
- Built motor help
- diy sohc turbo
- 7.8:1 Sohc 1.5 Base Timing.
- B18b Turbo 7psi Track Times
- nonvtec turbo setup good or bad?
- install greddy kit
- Full race Hatchback....SC61, 20psi
- Help! New SOHC setup with BogginG iSSueS!!!
- Has any one had any experience with this manifold?
- Help..Is it better to run the Inline fuel pump OR Intank fuel pump??
- Got my Built Motor Tuned
- What mods do i need, help me out please
- $ for IC piping, DP, WG tube??!
- 18G owners with B16A engines, how muc boost are you running stock block?
- Greddy type Rs Blow off valve
- Alcohol timing question..
- GReDDY EVO TT ExhausT for Turbo apps
- i'm about to do my first turbo install. greddy turbo kit d16z6
- -------TURBO EDIT---------------
- non ssac ebay turbo kit opinions
- what about the greddy type-s ripoff bov's on ebay??
- just another one of Mase's 500+ whp tunes
- Wastegate vaccum question.. I searched already
- Need some help with a clutch question
- Stock 92 Accord ECU...
- were to get downpipe already premade for d16?
- Ac in my boosted car?
- SC 61 OR SC 63 OR T3/T4-67 ??? Before i spend my loot !
- for a long time
- Bearings?
- HELP!!! Car Died oil everywhere!!!!
- ......................what size is this for me to use an fittings???????????????????????????
- My h22a turbo setup, what you guys think.
- question for those who have aftermarket manifolds
- Post up for boosted Ls Motors..
- Does anyone know the CFM on the johny racer intercoolers?
- what should my goals be?
- Fouling plugs every couple of days.
- boost controller
- what throttle body will bolt right up to jd edelbrock victor x
- High mileage?
- wastegate hits hood
- OK so still having oil consumption. Please read and help diagnose wtf is going on :)
- Converting internal dump to external = get rid of boost creep?
- turbo question
- can i use the Apexi AVCR with the Power FC and will it be better than the boost control option for i
- Full-race difference
- stuffing a FD RX-7 TT setup into your Honda
- 3 bar map sensor
- What are the lows of the H22A internals when it comes to boosting?
- daily driven turbo cars....
- SFWD turbo verification
- (Engine dyno results)Full-Race long tube Manifold Vs. Cast log manifold
- People Running Thicker HeadGaskets: Chime In!!
- Those w/ LS-Turbo setups what plugs are you running?
- easy question... heat wrap coolant hoses?
- gsr crank weight
- Compression good, but too low for 9.1 pistons, decide which pistons???
- Does my oil return look ok?
- how to find vacuum leak?
- slight smoking under hard accel. im alil stumped here? any ideas?
- Block setup for (450-500hp)
- anybody running a cat and resonator, no muffler
- How much power for 750cc injectors?
- need info from b16 cartech drivers
- My new downpipe and exhaust... finally got rid of the 2.5"
- What's the most power and fastest ET you've ever seen from a B18A/B
- NGK plugs
