View Full Version : Forced Induction
- replacing head gasket. need some info please
- need help with Blitz SBC-Id install !!!!
- Zex Wet or Dry Kit? what other components do i need?
- nitrous help........
- B16 looking for Turbo but daily driven
- some relatively basic Q's for a work in progress
- Ever painted a down pipe??
- V Bands for turbos
- What "Turbo" should i get..?
- Has anyone ACTUALLY put a muffler on a dump tube?
- bang gears with act 6pk xtr pp and car stutters, CEL flashes on, lights go out... then normal
- 92-95 zc sol boooooosted with apex kit...
- Supercharger Questions
- WHAT HAS HONDA DONE TO MY CAR?!!?
- safc settings/help
- good news for you obd 0 kats near the 408 area.
- Car stuttering!!!! Could it be detonation? HELP!!!!!!
- what problems can valves do?
- Intake pressure rised and now car idles funny!
- Is my Turbo 2 BIGG
- Exhaust raises boost?
- Is it possible to pass smog in California with a turbo?
- has anybody used any turbo's from audi...
- retorqing ARP studs
- let us be boosted!!
- I think I killed my engine
- bigger injectors want more boost...what to do???
- problem with obd2 2000gsr with revhard A/C kit
- enlarging charge piping on a Evo
- precision ????
- h22 hondata issue
- turbo kit or stroker kit
- ACCEL DFI Users
- shaft play problem
- Question for anyone using an ACT Clutch
- VX 02 Sensor?
- stock sleeves
- read my plugs....yea yea, i searched a little
- car dies
- fuel pump for turbo
- Anyone have this problem?
- Where can I find Honda cylinder compression numbers?
- Pls help me out wiseco or JE
- vortech supercharger on itr motor
- Almost Ready To Go - A couple questions before TURBO :)
- open downpipe question
- Cant get fuel injectors to seat with ITR manifold
- suzuki pistons? whats the deal? D series turbo
- what FI cams do i need ??
- DRAG III DOWNPIPE Question
- Another "what flange does this turbo need" quiz
- AIR-Water Intercooler for Jackson racing Superchargers
- turbo behind motor
- d15 turbo pics? !!HELP!!
- whos turbo ek is this?!
- Car bogs under high rpm/boost. Sometimes.
- How hard/easy are you guys on your daily driven cars?
- posting d16z6 block?
- tuning 250-300whp d16z6?
- car leans out under boost, need help!
- Wha Turbo Kit Should I Consider??
- Quick ? about Endyn install
- Time to Play: Where is Arturbo???????????
- not another electric supercharger
- can't even boost over 5lbs and i have a 11.6 lb spring.
- What kind of flange is this?
- intercooler sprayed flat black bad?
- Built motor, this problem worries me
- NEW: PLX Wideband Display Gauge
- Aeromotive FPR #13105 stock line compatibility?
- How much boost can I run safely?
- quik q's about safc
- How is this clutch setup?
- Which build would you choose?
- need a little t25 info
- How to install a Block Guard?
- B16 JRSC with CRV pulley belt size.
- plx wideband + apexi turbo timer
- Fuel pressure question
- car bogs til 6 grand then boosts?
- turbo-kits.com
- N3wb question regarding SC'd S2000 with FMIC?
- Pice of my True Race/Burns Collector/Manifold - work in prog..
- Old School AVC-R wiring info needed
- Came back from the DYNO what do you guys think?
- smoke out exhaust...plz read..
- Hondata Datalogging without the interface box.Possible with ecu serial port???
- b20 block
- 3" piping exhuast
- block with o-rings....what torque on the headstuds?
- Vortech BOV problems help me.
- Yet another GReddy Profec B Spec 2 thread
- quick question
- SC-5 E-Turbo
- anyone try this new eagle rod yet
- Jackson Racing BTC, FMU, and Map Controller all for sale....
- question
- OK this is How We get ARe Money
- Anyone use this 2-step method instead of buy it?
- Integra Type R on nitrous questions..........
- stock wrx turbo a good matchup for a d16?
- What oil do you use?
- Help me make my car faster. How do i do it?
- Engine break-in question
- 390cc settings?
- GM boost solenoid, I have two different directions to connect it, which is correct?
- fuel pressure too high!!! help
- Eeryone running a P28 on GSR
- Oil shooting from BOV.....HELP
- could i use 3-bar map sensor efficiently???
- b16 swap- turbo or supercharger
- Greddy 18G install question
- clutch goes out when driven hard.
- Dyno Time in Nine Hrs
- need somebody to just check setup please,
- Simple question pls answer
- wondering about clutch engagement
- CRAZY VOLVO!!..
- help motors back firing
- HELP HELP HELP HELP HELP Motor Build up won't start...
- Vafc tuning question with a turbonetics t3/T4 on a Built 10.1 comp B16 w/ RC440's, Whats ur settings
- swift performance.anyone..help?
- JDM APEXI 50MM wastegate??????????
- Civic reverted back to NA today. Wastegate flange/welding question...
- Quick question...60-1
- HELP!! Where To Get This Flange? W/PIC!!
- MotorMatrix mike reich caght in action
- what does it take to make 450-550 whp out of a b16
- HKS Head gasket
- compression test results - good to go on turbo
- NEED HELP DECIDED TO BOOST MY 00 SI!
- Some turbo questions...
- turbo lags bad all of a sudden
- Set up and 1/4 mile times
- 36lbs of boost on a stock bottom end...
- help SC61 will not spin at idle
- Question about how an electronic boost controller that uses solenoids works using a Duty cycle.
- injector lingo
- Radiotor fluid loss every 3 weeks
- help: compression numbers freshly rebuild motor
- d16 greddy turbo topping out at 11-12psi! HELP!
- NEED HELP FAST!! DSM INJECTORS AND SAFC NOT WORKING
- BSPT & NPT Fittings or Tees?
- Want to build custom manifold, where to get parts?
- D-series ninja needs help
- Garrett turbo starter kit
- G2 integra manifold turbo set-up???
- Centrifugal Blowers vs turbo charging
- its another 'how much is...' thread...sorry
- looking for some help/input
- machine shop help. ls rods on d series
- coated turbo housing... how to reinstall?
- help... 'sheared' turbo manifold... how to remove?
- D16Y8 ARP headstud install and other new goodies *56k consider suicide*
- NOT HITTING BOOST!!!!!!!!!!!
- turbo setup probs.
- good reliable manifold thats ac campatible
- Steel-braided Fuel lines $$$
- fmu to go with?
- Hondata Map + A/F Ratio - It's running again
- Fmu 10:1 or 12:1 for around 9 psi??
- Help me decide between a sidewinder or inlinepro cast
- What intercooler to buy?
- wiseco piston and eagle rods what u guys think?
- 3in Kteller question?
- sc61 upgrate problem, please help!!!
- FMU: Don't run, try using an AFC and 2 fuel pumps!
- lots of smoke coming out of valvecover breather? ALOT!
- Question for you guys.
- t3/t4 series can it fit on my 02 civic ex?
- My Boosted GSR wont turn over this morning! Help! Only click on crank!
- NEED HELP WITH NEW SET UP BEFORE I GET TUNED
- which turbo to use?
- nitrous refill bay area
- pic of mounting for inline fuel pump?
- oil feed line question, how to uninstall? (kinking)
- LS rods on boost
- car acting UP!!!
- Propper cooling from a "half core" radiator?
- Vortech owners
- crx b18 turbo q
- Quick Walbro Question
- Cometic 0.120" Head Gasket!
- please school me on tranny gear ratio....
- dseries success stories?
- cost: techedge 2A0
- Fan Fitments w/ Fluidyne radiator and turbo? (searched)
- 94 integra, want to keep power steering and A/C, need turbo manifold recomendations.
- how much power am i loosing?
- After Turbo Install, car wont run...
- Some last minute questions.....
- turbo and apex controller?
- what does your vac guage read at idle?????
- What set-up should I get..
- Wastegate difference 35mm(standard) and 35mm(HP)
- adjust boost on my deltagate?
- 200 miles and a Basemap??
- 100 shot on LS.....how to build properly to handle?
- Overheating ghetto turbo D. NEED HELP
- WTB: built bottom end!
- AEM Fuel rail Question
- Bar on Turbo
- injector spray question please help
- ACCEL DFI GEN6 WILL IT WORK WITH HONDA IGNITION MODULE
- what precision turbo do i have?
- Tial wastegate question/ seating problem
- Fuel Rail Necessary?
- Using Narrowband output of Wideband to Feed Stock ECU?
- t51r in street integra?
- What size and pitch for running a tap through D series blocks?
- Need fast help with mixture/ignition problem
- Tuning nitrous with Hondata
- What is this part????
- coolant problem (i hope its not the hg)
- timing retard...
- cutting a bumper to show all of FMIC does it really help ?
- F23A1 Auto + Turbo Kit Setup - HELP !
- P91 ECU work for Uberdata?
- B16 or B18 for boost...
- Calling all MN people...
- Water/Air Intercooler Mixture
- Big time deceleration when I go off throttle
- all gaskets and seals for gsr motor.
- D16z6 vs D16y8 head gasket. Which is better for boost?
- Weird Check Engine Light Pops Up
- how long have you been driving your 300hp+....? (daily drivers)
- help pls
- HELP! ? Crower rods
- WS or N1 for SOHC TURBO?
- fake tial problems messed up turbo =(
- crx pic's and time slips
- car doesnt rev past 5k rpm
- would a .60 swing valve fit a .48 ?
- Help high boost sputtering
- 36 lbs on stock bottom end
- i dont hear my bov in 1st and 2 gear.
- what size piping turbo manifold? 1.5inch (38mm) sufficient?
- Basemap + 3" Exhaust...Too lean?
- Where to get ARP head studs for d16 cheap?
- turbo is really slow on spooling??? opinions please
- wierd overheating problem
- Help me make an 11sec civic
- PLEASE HELP WITH TURBO MODS
- OBD2 Distributor???
- hks cast iron manifold, seems good, what do you think? anyone use them?
- Looking for a tuner somewhere near the midwest.
- for my obd 0 old school kats
- Need advice on injector sizes
- Those who know OBDII MAF engines.. Sputtering in boost
- Pictures of my BMC race manifold....
