View Full Version : Forced Induction
- It Runs!!!!
- My Dyno results
- Labour cost for sleeves
- how would you build your D series???
- B16a1 turbo power!
- F/I newbie questions for LS motor in CRX
- tuning difference between daily driver and race car???
- travelling from Germany to US just for sleeving block :-)
- 0-5v Wideband output....any hardware/software that can datalog?
- would a fan not turning on while driving cause it to overheat?
- Make virtual list for D16 turbo.
- Got wideband, need to know how to log these #s
- got head? gsr turbo head advice please
- lovefab vs full-race manifold
- which injectors, wastegate, intercooler
- Oil?
- Installing Greddy kit on 99 civic si
- Turbo b16 good setup?
- Can I use this as a boost controller??
- Full Race Pro-Am Top Mount Turbo Manifold
- can someone provide me a good map for uberdata?
- obd0
- SFP turbo manifold pic request
- Noob FI Question on Vacuum Lines
- Who's goin Import Wars NH
- high volume fuel pump
- Fuel pump and lines for my setup...
- Zeitronix Group Buy has been started!
- how thin is too thin (exhaust manifold flange?)
- OIL return line question
- diagnose my plugs.......( overheating issues )
- check out my bad weekend!!!!! motor go byby
- v mount intercooler...
- Manifold choice
- were to buy the slimmest electric fan????????????????????????????????????????
- Advantages of tilting radiator???
- Pics: Detonation in motor
- B-series crew 400whp+, b16 tranny or gsr tranny (the key differences)
- RevHard Turbo Kit Fit with a dual FAL Fan set on an Integra?
- oil feed line flange?
- How do you use wideband o2?
- fuel question can i drive my car without engine management
- Mental Debate:Buy Full-Race Kit or Peice together comprapable kit?Opionions needed
- hp estimate 4 a d14a4
- facing turbo downward
- No boost...Help!
- F*&^ stock pistons. . Questions about my build
- Tuning???
- turbo newbie - cheap setup
- Show me your Hondata clutch switch installs!!!
- Stuck Sparkplug
- Is Aluminized Mild Steel OK for IC piping
- Detonating with AFC Hack (N/A)...
- DP flange
- turbo seizure
- Where can i find compressor maps?
- Washed cylinder walls and compression test
- Pricing a used 14b turbo..
- finally getting tuned... what do i need to do?
- Vortech BOV
- Best place for wideband sensor
- D16Z6 threw a rod - Suzuki Pistons on rebuild?
- 1996 TURBO DX
- **105xxx on the motor, can I boost it?**
- Twin Turbo setup? Yes/No??
- 280zx turbo information?
- Help Guys. Hondata Q's Tuners Owners
- Fixing to push my stock block B18b to the limit. Tuning advice needed.
- H22a Turbo 1/4 times in Civics, accords, preludes, etc....
- Just recently boosted, ran good for 2 days, then misfire, bogging, car dies.. *LEAN*
- turboedit timing
- Is this exhaust housing junk?
- Questions about LS Turbo
- Apex avc-d wiring diagram????? Anyone got it?
- need some help- if your a dick, dont post. and YES i searched
- Does this sound like a good Idea?
- My turbocharger
- Intake On Supercharger?
- NEED HELP TURBO BUILT NOT WORKING!!!!!!!!!!!!!
- gt28rs/lovefab mani vs gt3071r/inline pro setup
- how much can the stock transmission handle
- How 2 Manage an N/A and Nitrous Setup? *Fawking Detailed*
- Pinning the B Crank
- b20 technology article!
- what should i do next
- stock head gasket or cooper head gasket
- Turbo Honda's can't road race!!
- Possible to make ZEX direct port? any info would be great.
- Compression test is kinda bad.. It was too good to last :)
- Is my vacuum hose for WG too long???
- need QUICK help!!
- Could nitrous be the way?
- injectors sizes
- turbo timer Greddy or Apex
- What clutch and where?
- what to use when cutting oil return line
- Would I need a Wideband 02 to tune my car with uberdata?
- PISTONS FOR B16 PLEASE HELP
- Ls Turbo Teg progress pics
- IHI RHB5 vs. TD04L-13G.
- 360 vs. 360 Race Bearing
- gettin' out of the turbo game
- help me choose the right turbo.
- Intercooler Plumbing sizes/materials.
- Help.. question about greddy type S and HKS SSQV BOV
- STOLEN
- AEM EMS HELP. Idle Target?
- Fake Tial BOV
- Who's Managed 400+whp on a B16a with T3/T4e???
- just did a compression test......
- Who Knows There Theory/Compression Shit (COMPLICATED!!)
- anyone using a hondata/profab gasket on a boosted car?
- ls/vtec block girdle
- MSD External Coil Conversion with Stock Igniter
- Damn nobody can help me with theese NOS wires?
- does anyone run this turbo????
- Not building any boost after ITR IM Install
- Crower 404 Cam Shafts
- BOV suggestions
- opinion on my motor build-up parts...
- Turbo kit for a B20
- I need to know the serial no of eagle rods for b18c
- TURBO ON STOCK B16A???
- keepin motor cool
- turbocharging b18,good for daily driven but will kick some ass
- Hose clamp hell, need some help please
- I need help with pocket programmer 2
- Lacquer or Enamel Spray Paint for FMIC??
- darton or goldeneagle
- TURBO EXHAUST QUESTION
- sc34...turbine side..
- Audi 1.8 KKK turbo on B16A?
- Oil comming out of valve cover breather!?
- Actual Temperature Difference of EGT in Manifold VS Downpipe
- building a fast crx
- D16Y8 & T3/T4 Power Predictions
- Good EGT range
- not a honda but is this intake manifold even efficient? (experts)
- Here's my #'s from this past friday
- wont rev pass 5,000 and bogg at 4500
- car sputtering b4 boost
- Flames out of the exust. ???????????????????
- How to ruin a perfect Saturday......PART 2!
- My car blew on the dyno, your comments pls!!!
- Couple Questions Re New Turbo Install
- how much time are you boost'n with stock internals ??? (D's ONLY)
- d16z6 head lifting under boost??????
- put the 9psi d15b7/y8 mini me on the dyno
- my mpg is killin me.. ls turbo w/ fmu/missing/fuel pump
- back from the dyno 400hp ls/vtec stock sleeves!!!
- Tial 40mm Waste Gate....Turbo XS Boost Controller WTF!!??
- quick b18c5 + boost questions
- ebay turbo questions
- how much power can a stock clutch hold
- replacing supercharger pulley?
- What kind of tuning for a JRSC D16Z6?
- jsrc fuel management help ??
- Fuel management for JRSC
- setup almost complete.....now how much power to expect?
- Should I run race gas? D15b vtec + 10psi
- AEM 8 or 4-Channel, Twin-Cap Digital C2DI Ignition Module
- dsm 450 questions (please help)
- 310cc injector flow?
- stock injectors...will they hold up???
- coolant boiling, please help
- info on gt35e?
- need advise n a TD04 - gsr
- Where to get downpipe material
- Supercharger on JDM B16a?
- need some help/advice
- anyone use a gt35/40r or gt40r on thier h22?
- question about mismatching brands of SS lines and fittings...
- What's the thread pitch for this oil feed on?
- anyone order from ssautochrome.com?
- misfireing at 17PSI ?
- boosting 93 teggy
- Accord Turbo F22B2 how-to
- Why did my turbo seal blow?
- Need help.. what is the best turbo setup for a stock gs-r motor.
- Need Uberdata tuning Help!
- HELP..Sleeving a b16
- 480+whp w/ 11.2 compression, sohc, on pump gas---
- Thinking of going too boost...
- msd fuel pump
- back to the dyno tuned off the wastegate spring
- Building LS for boost, headwork?
- New book on the shelves everyone here should read...
- Anyone running an oil restrictor on a -3AN oil feed line?
- what kind of exhaulst manifold is this?
- Distributor Issues
- fuel question
- Independent piping for ITB's 56k beware
- what does everyone have?(poll)
- CFT Street Integra "vid" 500+ on mustang dyno
- K-series sleeve strength
- turbo on civic help me
- Way OT...but Touring the Panoz Motorsports Facility
- Turbocharger Sizes and how to identify them?
- Please critique MY plugs..
- turbo/wg/bov problem help please
- tuners, what is your opinion on different dyno types?
- n o s on type r pistons
- Where did you get your manifolds for your DSM turbos?
- How much boost?
- cooldown with turbo car
- question about a/f
- Having a boost creep issue......anyone Tial wg valve ever stick on them??
- Which motor would you do for boost.... JDM GS-R, USDM GS-R, or LS
- Need Base Map for T3/T4E on Stock LS Motor
- A though I have about fixing the afc hack..
- whats the length on a stock ls valves
- For those starting out with OBD0 Turboedit.. a newbies guide! Willem programmer help also
- Gas Mileage with AFC hack?
- any turbo d15b7 success stories??
- What do you think of this setup?
- Tial Wastegate------Need to know what kind of screw, or i'm screwed.
- alright guys heres a taste of my new project 4dr civic turbo for under 3 grand
- ??? What fuel pump for my set up ????
- STOCK B16A.. TURBO CAN IT HOLD UP FINE?
- GE fuel rail
- help with turbo questions?
- obd2b-obd1
- How bad is traction with 400-450 WHP at 16's?
- Well i decided to be the Guinea pig
- limits on stock valves b16a2 head
- HELP!!! WHICH PISTONS TO GET!!!
- Loud whistling noise.....fuel pump??
- Apexi N1 TURBO Universal muffler(pics)?
- need help on my fuel setup
- What motor should I choose for Boost setup?
- DSM injectors will they work???
- greddy profec b b/c used on internal wastegated turbo?
- injector sizing and boost question for my gsr turbo
- *** turboXS Dual stage boost controller (stage 2 will not work)
- 450 fuel injectors
- step hoter plugs when runnin' rich
- CRV pulley time!
- Spark Plug Question...
- Twin Turbo Teg
- water in #3 runner
- Pistons/Rods combination for RSX-S Boosted. recommendations
- Gasket in between Manifold and Turbo inlet?
- Gator Racing Axles???
- Screen on turbos good or bad?
- Which tranny for boosted LS?
- my car isnt dead any more
- b18c5 turbo
- HELP!!! Turboing my 86 Civic SI... turbo location and radiator fitment issues...
- gsr boost ?
- type sh (atts) prelude and oil feed???! please help
