View Full Version : Forced Induction
- Garrett gt36/67r? No "garrett" on casting
- RSR Exmag Muffler or Vibrant 3" Muffler
- Rochester, NY area
- What fittings???????Please help
- question on ge sleeves???
- Precision turbine housing swap?
- About how much boost can you run with 10:1 compression and 93?
- looking for PP job in SFL
- B16 or LS-vtec boosted?
- m62 roots style blower work for b series?
- Injectors
- Turbo w/cat....how long did the cat last?
- Intercooler Piping Question
- Oil Pump ?
- quick question?
- 300whp on stock ls
- got my block back from the machine shop...
- any idea what size bolt is used to hold on the oil drain flange to a t3/t04e
- RX7 Turbo on my honda
- Wondering what my block is worth
- car making ticking sound
- tuning
- is nitrous illegal in california???
- fuel pressure gauge
- TURBO SIZE ? WHAT DO U THINK PICS INSIDE
- what is the limit on a 190lph walbro?
- difference in 99-00 civic b series and delsol bseries clutches?
- hondata s200
- Quick IAT question...
- head bolt question
- Torque For ARP Head studs on O-Ring Block
- BEST TURBO FOR UNDER $1000 HELP!!!!
- ceramic or metalic core cat?
- Clutch set-up 300whp?
- leakdown test on a cold motor- is it accurate??????
- RSR Exmag 2.5 ID Sufficient for Turbo?
- need help
- turbo blown
- how to install zeitronix boost sensor?
- normal for car to smoke at WOT?
- built motor pass smog?
- High Compression LS will have boost!! Please Help me with some advice though.
- intercooler piping doesnt fit?!?!
- b16 turbo questions
- Built motor question.... ls-t then later going lsvtec-t?
- difference between S housing and E housing?
- Walbro 190
- quick question lads on hks evc
- boost creep or something else?
- Holset turbo identification...
- CANT FIX THIS STUTTER!! TE 3 bar 450's. HELP
- universal fpr questions
- the little boosted b16 that could.......
- Tial wastegate hardware!?!
- what bearings?
- WTF is wrong tons of smoke, car shutoff??
- Manifold / wastegate <- Help identify?
- Will a Skunk2 intake manifold fit?
- stock gsr bottom should i do head work?
- full race manifolds, differences in CFM flow between prostreet ramhorn/ prorace manifold?
- Anyone runnig a small dry shot on boost?
- Going boosted GSR from b16 few questions...
- typr r cams low idle help
- Had head resurfaced Is that bad? b18c1
- Boost question
- N E dragway tomorrow
- Import Source Performance's new dyno... Many Thanks to Ed from balance and Neukin
- ACL RACE bearings in my built GSR engine...troubles later down the road?
- 1 channel vs. 2 channel CDI?
- Two way VS Three way boost solenoid valve (MEs Look)
- b20 vtec turbo set ups... post you setup
- OPINIONS of my set up
- How do i figure out what kind of turbo i have???
- what fuelpump do i need?
- tilton TO bearing?
- A'pexi 3" World Sport II Universal Muffler fitment
- Should i lube my turbo before install/start up???
- 2 1/2 to 3inch exhaust adapter
- question about boosting
- Cheack engine light....Boost+afc hack
- SEARCHED: ebay XS power wastegates (are they terrible?)
- b20 vtec turbo
- injector question
- fuel line question
- best turbo for me
- new motor....when should i go synthetic?
- CR for 8 psi supercharger
- air/fuel/oil pressure/water temp/ where do i hook up all the positives?
- are z6 valves the same as a y7 or y8>??
- Tilton clutch help
- help turbo civic .. missing bad
- Vtec as Nitrous Activation?
- too cold of a plug?
- Got caught by the COP!!!! =[
- fit and turbo ??
- my new cheap turbo project the RT4wd wagovan ultimate DD
- Questions about crankcase ventilation
- Which Pistons and Rods?
- Need help car won't rev up..
- eagle esp rods
- ITR or aftermarket Valveterain??
- Oil pressure drops after good ride
- JRSC fuel management question.
- Catchcan Help (searched)
- steel intecooler piping... rust ?'s
- Which Gauges?
- :::VIDEO:::Not a Honda buts its still got twin GT35's
- Turbo S2000 Pieced it together myself
- grade my sleeper project
- Polished combustion chamber
- CC-Fab: Manifold Review
- Can u Spray a CTR Motor?
- overbored throttle bodies
- looking for weldless oil pan drain fittings!
- Boost holds, but progressively drops with each gear?
- AVC-R solenoid not working? (Searched)
- ???y1 tranny help???
- how to get a y8bottom and z6 head in base time....
- boosted d15b8 208whp... didnt last long
- CEL 3 & 16 on LS Turbo bogging...HELP!
- turbo selection
- Weird sounds...
- Need advice, fuel pump shuts off with no warning :(
- What did you pay your machine shop?
- can someone explain to me how these turbos differ from one another
- dont know what to call this problem
- stock srt4 intercooler on 92-95 civic hatch
- can someone post Tomzilla turbo pics?
- Need some advice from the turbo VETS!!!
- What is this? Rod pics, something wrong
- Can someone measure something for me on their Precision 750hp?
- what tuning for jdm d15b turbo setup?
- zc turbo
- Only running catch can through stock PCV effectiveness
- noobie needs help SAFC hack throwing CEL
- Intercooler fans?
- Will 60mm gauges fit in a 52mm pod? Can it be bored out? [defi mounting]
- Vafc or safc??? Please help
- SICK OF THE BUCKING! Please help this is the weirdest shit EVAR!
- Tuning / Troubleshooting help in Warrington, PA
- **Official Boosted EF Thread**
- Oversized valves on a d16z6, how big can i go >?
- Gutted/hollowed out PC valve on FI setups.
- DIY $5 - Fiberglass muffler, will this work?
- have no clue please help asap
- Sohc built motors!!! I need help
- Air-to-Water Intercoolers
- Difference between eg and ek greddy turbo kit?
- Weird studderin at -10 and 0??
- 42r
- question about hybrid turbo
- freeway pulls
- poorman type r turbo set up
- turbo exhaust
- lsvtec
- Does anyone use a 68mm Skunk2 Pro-series throttlebody?
- rpm keep reving after spark plug change(2000 si)
- WRX Turbo plus D16
- clutch 6 puck ?
- New low cost Manley Rod
- is my wastegate broke??
- h22a boost options?
- How many whp, should I expect with this setup ??
- need help with h22
- Need HELP with my LS-Vtec build up!!!
- possible bad wastegate?
- air/fuel guage hookup in 2000si
- Chipped JDM ITR crank pulley
- How can I tell which is the oil pressure sensor on a H22 engine?
- 95' Teg, Should I buy it???
- Any way to make a small turbo function bigger?
- b16a3 block build. Need some inputs. <-----
- HELP, vaccuum diagram for installing manual boost controller HELP
- Turbo help
- how many horsepower can i get t04E
- ran my si with msd it ran fine for a few and now i have no spark, help?????
- Will Arais SPIRAL clips work in SRP pistons?
- Just got my hands on a set of valve....install or stay stock?
- Circuitworx oil pump gear installation?
- rld turbo manifolds?
- Turbo Manifold for a B-Series W/ a Mitsu Flange??
- Garrett GT28RS...T3 Housing ???
- 90 degree adaptor elbow from rev hard manifold to turbo? is one available
- Supercharged d-series exhaust
- S COVER/HOUSING
- how hot should the coolant temp be in a b16?????
- wiring a /an APEX-I turbo time
- Gettin' hot.
- ting
- External wastegate install?
- t70 w/ built b16
- Would this exhaust setup work...
- Turbo Fitment Issues
- I got a question and you may have the answer Tuners please look!
- Decel CEL b18b jrsc on chrome
- need some help I am at a loss
- Is it necessary to upgrade radiator???
- Anyone with Garret GT3076 on H22A experience?
- Question about going b16 turbo?
- looking to make 300whp... which turbo to choose? t3/y4
- WG vacuue from turbo VS manifold on dyno?
- Mazda turbo manifold? who makes this?
- Boost leaking...
- Building a 400whp B18c GSR bottom end, best place to get the parts?
- look at my set up. need experienced knowledge.
- I want to know a difference in performance from endyn vs jrsc
- COP Set ups
- My SFWD "Starting all Over" Build-up
- 100 shot on stock motor :D
- GT35R??? on ebay
- Question running itr cams with gsr valvetrain Boosted
- d15b7 turbo
- CAM Q's NEED HELP!!
- JRSC HIGH BOOST KIT
- t3/to4b capable of 300whp?
- NEED HELP!! searched how do you install a blox oil pressure gauge
- Compression numbers on turbo b16a - what next?
- chippin hondata
- are intercoolers paintable?
- to small??
- Help! how to set up this Blitz electric tuning system....
- Turbo newbie: What are the shims that come with a wastegate? PICS
- drain hole size on turbo?
- 3 inch downpipe where?
- what causes oil burn when not grav drain?
- 1998 gsr turbo questions?
- TURBO + DP= DP WELDED 2 TURBO WTF
- whatever happen to the pinks raffle?
- t3/t04e
- My first turbo tune runs 13.6 (few questions)
- tearing out my hair!!! boost dielemma
- Ek with Gsr swap and vortech supercharger
- putting a VF4 turbo on my civic y8
- DSM injectors on OBD0 car?
- LS crank shaft into GSR Block
- B18 EMS for Automatic
- d15b2, eagle rods and vitaras? will it work??
- is this turbo to BIG
- cooling system probs
- JRSC fuel ratio?????
- Oil lines, where it buy???
- Anybody running O2 dumps? Post setup pics, numbers.....
- turbo noob help
- b16 with msd sci, have 1 degree cooler plugs but no spark, help????
- JDM HKS PFC-FCON CRX / CIVIC Plug n Play Stand alone computer TURBO/SUPERCHARGE
- 6 psi wg spring, why did it go up to 9 psi with my rpm's?????
- Help me fill in the blanks....
- turbo rebuild question and intercooler
- Eagle rods on a b16. Power capabilities?
- H2B HELP
