View Full Version : Forced Induction
- Supercharger or Turbo system
- could #10 code be anything...............
- Will Drag IC piping line up with Greddy 15g turbo?
- Piston to head interference?
- dry nitrous on a b16a in 4th gen
- Quick question about spark plug gap
- Zex and turbo
- Why are my numbers so low? H22 Turbo *dyno pic*
- New AWD DynoJet in Reading PA.
- SOHC zex nitrous decision AGAIN!!!!
- Wastegate Question?
- should i keep or buy a aftermarket intake mani?
- Question about Oil Coolers
- greddy turbo help
- auto tranny, low boost, cooler
- What is the CMF of a the apexi turbo kit.
- Which way does the B18 flange go on???
- Why is my motor running hot?!?!?
- Fuel Pressure Problem
- accord turbo guys help me!!
- anyone know anything about this manifold????
- PRO LITE race mufflers of Woodstock, GA
- rods and pistons for the z6
- need turbo kit install help
- Hide my Zex?
- rod bearings badd??
- Garrett T3 Turbo...
- what engine managment.............
- FPRs; AEM=explodes, B&M=cheap garbage....So whats the better alternative?
- 92-00 PWR Radiator (Earl)
- oil pressure question
- where to buy greddy boost control solenoid?
- boost on stock block
- problems with jackson racing supercharger idle air control
- Can I run turbo B16 on a P06 with Uberdata?
- greddy kit for 00 civic EX
- I need help...car smokes in vacuum!
- Exhaust housing spraying oil
- NEED HELP!!!!!!!!!!! ON MY LS VTEC FULLY BUILT TURBO BEAST!!!!!!!!!!!!!!!!!!!
- 300hp club finally only 10psi
- anyone try cryotreating their syncros yet?
- what kind of oil should i use???
- Thicker oil needed?
- head question
- Turbo upgrade for '93 SOHC DelSolSi
- will you lose HP if you change your wastegate dumptube to be welded to your downpipe?
- Turbo seal leak
- d16 turbo question??? need help
- Tacoma/Lakewood/Seattle Area
- defi gauges any good
- H23 TURBO
- 15psi compression on #4, built motor
- dp question??
- Anybody have experience with Majestic turbo???
- 2nd gen=no boost!
- need a hondata basemap for 550s,
- Question about running just wastegate with no boost controller.
- 1998 Prelude, Turbo + 5-7psi + fmu.....good Idea?
- 16G work with drag manifold?
- goals met: 400whp club-- 2001 Integra GSR
- Reuse Head Gasket?
- Tapping brake booster for vacuum mani
- How does my return line/radiator look?
- How long do you have to??
- Turbo install oil leak
- turbo pros .... critique setup
- Installing a Greddy Turbo Timer into an Integra
- Couple pics of our new sleeves
- Deff of "clipping impellar" what does it do/change/improve?
- cap and rotor question...
- No vtec when boosting
- b00sting woes!!!
- My buddy's dyno sheet (D-Series yO!)
- Annoyed Turboer needs help!
- B16A Turbo Full-Race Kit @19psi
- Car stalls and has no power once it's gotten hot... Ideas?
- Boost question
- Car won't idle with 550s and basemap
- advantages/disadvantages of Full-Race Style set up??
- hf/vx manifold
- b18c block b16 head
- Stock or overbore pistons?
- full-race downpipe not clearing o2
- new pics with the t4 (and for u body kit haters)
- List of Items when bought (Hondata s200b)
- anyone have a black intercooler???
- Post pics of hondata ecu P28!!!!!
- Import builders manifolds???
- ProDrive oil pump goes poop.
- Nitrous refill question????
- Is it worth it converting OBD0-OBD1 and swapin heads for turbo??
- Drag mani on gsr oic request
- JRSC boost upgrade?
- My two year challenge...
- Not really liking my AEM EMS - Anyone else have any wierd problems?
- Video from MapleGrove Drags
- best way to use nitrous on my turbo hatch
- Used t25?
- evaluate my dyno chart please
- t25 downpipe on 14b?
- Sleeved block with 84.5 pistons. Need correct ring gap???
- Does MSD cause higher EGT's and lower IDLE?
- Uberdata disable vtec pressure switch for use with jdm engine?
- New track times. :)
- I GOT LUCKY!!! with a already socketed and chipped ecu uberdata here i come.
- please help i have a sick motor and im scared mommy help sike!
- Q's.... Best way to DRIVE to the TUNERS...? When turbo is in the Car?
- Looking for a HONDATA tuner in SO.CAL ... RECOMMEND anyone?
- 02 Housing leaking....blown seals?
- AEM EMS 2 step Rev limiter
- b16 stock internals at 8 psi???
- Pictures of my new stuff and improved W/A setup....
- how much hp can i make with my maxrev manifold?
- Throttle body gasket w/JRSC
- any uberdata peeps in so cal?
- Willis-palooza at Titan Motorsports all the time!!!!
- Turbo Oil feed line restrictor size? Think my turbo is burning oil...
- she's done!!! i am now a fellow ninja!!!!! D16y7 & T3/T4
- Thread size of T3 flange on Lovefab SST?
- OMG Precision Rocks (And so does titan motor sports!!!!!!!!!!) Come listen to my experience with the
- Does anyone offer larger piping diamer IC piping kits?
- Vid of our Supra with its new setup......sorry if off topic, but you'll enjoy Im sure!
- Question about Speed and wheel size?
- Looking for the video of the Purple EG coupe SOHC Turbo from a while back..
- drag turbo kit
- boost/ ecu qestion?
- Why am I getting a grinding sound when I get on it
- machine shop called "autoshop" from orlando
- vacum lines with profec b spec II..help
- Louvered glass packed core, Resonator which way faces back?
- Can I run 5-7 psi without a intercooler
- ALL Tial Wastegate Spring Colors/Sizes/Corresponding Boost Pressures listed!
- For the unexperienced turbo guy.....
- Mounting BOV on intercooler? Why or Why not?
- 2 or 3 bolt flange for downpipe?
- Knock Knock
- Anybody running a Volvo FMIC ( EG's)
- Revhard with bunch of other goodies, but are the goodies necessary?
- Blew my motor.....
- MBC installation
- a look at my FI 89 hatch ..
- Idle Problem and Hondata Launch Control!!!!
- fuel cut (rev limiter) dangerous?
- T3 60-1 with .70 AR exhaust housing
- Anyone have any input on a Greddy Rebic?
- My progress and then some frustrations.....
- bolts for hks wastegate
- Well JB Weld work on a manifold
- airborn coatings?
- Normal oil pressure?
- Engine knocks.. BAD!
- Quick Question
- part number for freeze plug replacement adaptor for catch can
- TurboXS RFL Problem...
- help - billowing smoke from tail pipe
- who has the best 84mm turbo piston?
- Exhaust you run with your JRSC
- help me with fuel management
- check engine light when boosting
- Greddy Bolt on Kit for 99 Gsr
- turbo h22...mixing cams? stock cams vs crower 2t turbo intake cam w/stock exhaust
- tuning question for turbo'd 6th gen accord
- no boost when wastegate hooked up
- Hey guys got a issuse i was shipped the wrong FIN LSD
- Boosting problem
- pics of 2JZGTE Turbo Manifold for Garrett Turbocharger's SEMA Booth
- Greddy Turbo Kit??? How much boost?18G
- b18c1 Turbo....Ways of getting additional power???
- Who gives the best head?? Final Word!! (Type R vs. Ported LS)
- whats highest hp output on a Precision SC44 .60 comp w/ .63 exhaust
- i love boost
- Well, I figured out why my car wasn't boosting right.....
- Interchangeable A/C Compressor with other cars????
- Turbo question
- Compressor Wheel Question???
- WTF is this?
- MIGHT BE A STUPID QUESTION... BUT ALL QUESTIONS ARE... ABOUT TURBO OIL LINES
- Ultra 94
- Tial wastegate spring colors. We need a definite answer!
- @#$&!!! Im still getting detonation like a sob.
- Turbo 2.0L LSVtec, Turbo B20Vtec or Turbo 2.0L GSR???????
- New head gasket?
- Need help coming up with an idea for a water tank
- Cleaning FMIC
- jrsc install anyone?
- Rev Hard 4-2-1 Turbo Manifold
- max psi on oem rods...
- Greddy turbo guys: How did you route IC piping around the downpipe?
- O2 sensor...how close is too close?
- quick ? on oil and h2o pump
- ChicagoLand Area Hondata Tuning Questions
- Ignition retard per pound of boost?
- Boring for CP pistons question
- 3" resonator internal size question
- SOHC Greddy Kit... What injectors?
- Need advice on sohc turbo
- D16Z6 swap Need help!
- Turbo B16 w/HX35 and stock block numbers, opinions needed
- 550 cc injectors good enough
- Matching Head to new Sleeve BORE
- b16 blcok w/ gsr head good for turbo?
- D16Y7 turbo
- Cracked piston/broke ring lands on a turbo'd d series?
- PVC system mods...
- CTR cams on turboed GSR?? anyone?
- Holset turbos???
- uberdata gsr map?
- Compression Ratio
- are my fuel injectors being stressed?
- Greddy SOHC Kit with FMIC, tiny pinging (sometimes) at 8psi..
- boring throttle bodies on ht; someone did it for 100 i cant find it..Help
- eletric oil gauge ????????
- will a 70mm throttle body make that much difference
- JRSC detonation
- another quick question
- jrsc headers
- boost creep in 3rd gear any answerS?!?
- So u got the power, but u got the wheelspin...
- 4th gen Civics/CRXs with Inline Pro manifolds...
- finally got my turbo on!!!
- Has anyone used a knife edged crank for a turbo setup? (PICS)
- Nitrous Honda
- Inline Pro headgaskets?
- HELP me with my custom turbo catback
- JRSC injector sizing
- How many people have had boost creep/spike issues with drag manifold?
- help with apexi avcr - will not boost above 7psi
- D16z6 in EH2 Overheating after turbo install HELP!
- Sending oil to my turbo
- Intake Questions with an accord
- installing a nx kit in a civic dx few questions??
- quaife install- indentify diff & bearings...
- Integra LS Turbo Help.........
- jackson racing throttle body?
- Having trouble with my afc setup.. Wayy rich, not making power.
- Wont boost over 4 PSI on greddy Sohc Kit
- ATTN: People with 4" Inlet on turbo, intake filter question.
- piston to cylinder wall clearance..look odd?
- ZC, OBD1 questions?
- who should I get to tune my car
- Looking for a part #...
- Look at all these turbos!
- where and what size bolt for oil drain flange?
- Sonny's CRX vs CA Smog Referee
- HEY D-MAN QUICK ? ON ARP D-SERIES HEAD STUDS
- ohhh thats why it ran like a wrx ;)
- friend has oil coming out of exhaust port on wastgate
- Best Location for a hood vent?
- Any of you guys reinstall a timing belt with all the covers on?
- Turbo NOOB
