View Full Version : Forced Induction
- questin about power potential
- Opinion: boost on stock ek cx
- i need turbo parts please help!!!
- need help with rpm/ tach signal for gauge
- need help with boosted da with b20b4
- wanting to run a kinda side winder manifold on a b16
- B20- Calling out engine goro's-Need HELP
- B20 Going for Boost? Need help on build
- b20 Going for Boost? Need help on build
- Help please with wiring HKS turbo timer
- built motor carnage
- I need some info iv never heard of any one doing this??
- oil leak: oil sammish adapter...
- Boost control Via AEM EMS
- TUNERS: Tuning on a DynoJet, I need some help.
- torque spec for arp2000 rod bolts?
- will 38mm wastegate hold low boost with ramhorn?
- dsm 450cc
- 96 Tegra SE Turbo Setup???
- what to dip in to a 12.0 on street tires
- Welded WasteGate
- High rpm missing...
- greddy turbo timer ?
- thinking of boosting my 93 hatch
- HELP PLEASE!!! oil feed line getting really hot.
- zex dry 50 shot fuel to rich
- Removing head studs?
- Looking For Turbo Opinions And Advice
- my boost build, lots of PICS!
- lsvtec crx with t3/60-1 70 trim
- getting turbo kit, will this work with ps and ac on my 96 gsr??
- Source for pauter rods
- Thoughts on A/r's for gt3076R
- Where did you mount your catch can and battery? I'm looking for ideas and pics
- How much can the stock sleeves take?
- TURBO NON-VTEC or TURBO VTEC
- upper hp limit of .63 ar 57 trim
- what cams are you guys using 500hp+
- car keeps breaking up and blowing ignitors? help me troubleshoot
- removing arp studs??
- gotboost.ca twincharge civic (procharger and turbo???)
- installing vacuum hoses for the tial 38
- Resistor box affect tune?
- H2B QSD TWIN
- Need Help Please Noob ???s b4 tuning (eg6 gsr turbo) is it ready? mix messages
- Need Rods info pls help too identifique this rods Thanks
- Turbo manifold
- Bosch NTK 5 O2 wiring diagram
- best set up for b18c5 turbo??
- Turbo intake side very close to radiator - is it a problem?
- Ok to drive to tuner with no boost ??
- Full-Race Pro-Am traction bars
- Who uses these HEI plug-in towers for their coil? Should they be loose?
- fouled plugs in nitrous motor kinda lost on why!!!!!!!
- whats wrong with my car or turbo????
- vitara piston rings question
- Which turbo to go with on Vitara set up
- Map Sensor question..
- Is it worth turbo?
- formula prototype kart
- Noob to FI, need a few Qs answered.
- dyno'ed my built integra today...
- quick turbo question ?
- B16-T To B20V-T
- Apexi AVC-R or Greddy Profec B-II
- Vortech Supercharger kit. . . How are they?
- Overboosting Bad...Nothing has changed from the original tune
- 11.3:1 CR and Turbo Charged
- Is this block salvageable after hydro lock??? Pictures inside
- vitara piston rings 2nd ring, should the nouch be facing up dwn?
- Turboing a B16A2
- Boost leak outta nowhere!? Help!
- Turbo'ing my Hatch!
- Are GSR cams worth putting in my stock b16a head..?
- tdo5sh18g GReddy Turbo in my b18c1 ek 9psi 240whp 210 lbs tq
- Let's see some T3/T67 setups...preferably B series
- gm 3 bar ?
- Need some help
- s372 seal allready shot?
- Boosted DC integra pic thread.....
- Any reason a built motor shouldn't last just as long?
- turbo 98 civic price
- sleeved b16, which turbo?
- water cooled turbos
- Camshafts
- Question For The D-series Precision Injector Users
- LS-T Set Up
- B16A boost question!!
- BOV Problems on my Si turbo.
- Help me size a new turbo for new setup: high comp z6 EF
- Checking to see if people have interest in something like this, oil manifold
- Manual and Automatic
- setup questions- 42r,200 shot, 16000cc, eagle rods, a1000 FP
- Anybody have a part number for the GM 3 bar map sensor?
- Anybody Ever run one fo these.....
- oil pressure locations on k series motors?
- turbo size sugestions
- co2 wastegate
- Overheating LS-Vtec Turbo?
- I want to upgrade my 3.0 vtec to a intercooled turbo setup any ideas?
- ARP vs Golden Eagle Bolts
- h23 crank, h23 rods, h23 pistons in h22a block
- what spring rate to run in wastegate? im a bit confused...
- 4 bolt 2.5" AC Downpipe - Possible???
- help on 99 civic turbo
- r/s ratio for custom length rods & vitara pistons?
- Where can I get L19 or custom aged 625+ rod bolts for Eagle rods?
- Clearances too tight?
- Tial 44mm wastegate V-band Clamp......
- New ARP Headstud Torque Specs Released?
- BW ETT compressor wheel on a garrett gt r BB turbo?
- info on a BW s262?
- major issues with ac on a turbo motor!! helpp
- might sound stupid, but hear me out...lol 95 gsr boost
- Gizzmo MS-IBC - anyone like it?
- 1990 CRX Si Turbo Help
- how much hp will walbro 255 flow for?
- need ro put a new head gasket fel pro any good ?
- t3/t04b
- pauter or manley rods for ~600whp gsr motor?
- IAT Sensor
- quick help...... compressor housing oring o-ring
- Austin,TX stock jdmb16a gt35r dyno
- comp calculater?
- Stock Integra Type R Swap in a 99 si
- mahle pistons...h22
- anyone have good expeience with a 60-1 turbo
- Help Turbo seals? Valve seals
- stock ls turbo
- ALL boosted 99-00 civic Si with AC..need to see what fits.chime In Please
- really need a direction to go with overheatting problem
- new ecu and injectors - accord got some questions
- High Compression Nitrous Build On Pump Gas.. Nitrous guys chime in for me.
- When whe need a 4inch dowpipe
- jackson racing supercharger type r on a b16 head?
- help
- New waste diaphrams
- so got my sohc done, but having a problem while driving...
- itr cams on b16 turbo
- Decided to keep the TEGGY!
- How has everyone routed there twin scroll dump tubes?
- What to use to make a baffle inside the valve cover without welding?
- manifold help
- what size turbo
- GSR Tranny or LS tranny?
- what exhaust setup for boosted LS?
- b16 oil pan on ls bottom
- d16y7 Compression Numbers
- need advice.
- 6G's for a full build help me out TURBO GSR
- need help. gt40r w/ coolant pouring out of dp
- Ideal A/F Ratio?
- Help : Installing electric oil pressure sender
- IACV leaking boost
- Dual Wastegates?
- usdm gsr pistons on b16 rods
- lsvtec nitrous build
- New H22 Dyno numbers
- bov questions
- High EGT on turbo ITR (DC2)
- any type r supercharge?
- sohc turbo heating problem???????
- Midwest Autoworks New Poject Car. 1998 Integra GSR. Looking to hit 10s.
- aftermarket Valve springs w/ stock retainers
- Oil feed line leak
- read these plugs for me
- baffle inside oil return line for turbo
- What IAT's are you guys getting
- Will I run lean because of a manifold gasket leak?
- piston compression ratio's
- whos running a borg warner s352
- 408.4rwhp, 314.3rwtq @ 8.0psi
- how much can it take
- phearable chip +FMU???
- blow off valve
- fully built sohc turbo
- More Turbo?'s
- ecutout???
- Boost issue...
- mac solenoid duty cycle %, whats yours?
- SOHC turbo???
- High Oil Pressure
- Blitz blow off valve?
- proper tuning of tial bov..
- Have a turbo questions. some advice please
- Air/Fuel gauge not working!!!!!!!! Help!!!???!!!!
- Overheating problems on painted block?
- Rebuilding My Civic *Some advice please*
- wideband question
- *Must See* SOHC finally dyno'd great numbers
- Digital Gauges
- divided turbine housing,UNdivided manifold?
- Need a steel oil drain flange....
- Causes of increased cylinder pressure / head lifting
- looking fo a z6 turbo build thread
- custom B18/B20/LSD build... need some suggestions
- Searched... Losing boost at high rpm band
- weird problem
- how to make a stage 3 t3t4 a stage 5? Shodan
- anyone have a compressor map for t3t67 HO also check out this dyno
- How risky is this... I desperately need to get through emission testing..
- Turbo manifold leak at head ...
- Advice on twin turbo for rb26
- Spal 13" fan
- Load differences with people in the car??
- boosting help
- blox comp cams??
- What about Turbonetics turbo with ebay turbo kit ?
- Pic request of full race dual gated top mount dumptube setup
- why wont the oil stay in my catchcan??
- JG crankshaft vs B18C5 crankshaft?
- head ported to much
- street tune help.
- turbo shaft play?
- RC or Precision fuel injectors
- Turbo???
- Turbo???
- greddy turbo
- need help with 93 boosted da w/b20b4 swap
- ls pistons/itr cams clearance issues??
- Bore out intake manifold ports...low hp goals
- Action 2MS won't go into gear/disengage
- boosting a gsr
- Input on this turbo kit...
- Clevites are they any good?
- 220whp b16a turbo build, Turbo Selection?
- greddy type s Blow off valve whistling???
- How do I know if Iron Sleeves have sank?
- Overheating-vented hoods & overheating+vented hoods=real results
- thinking about turboing a 90 crx with b18a
- msd hvc blaster or distributor?
- Car dosen't run right when its hot out?!?!HELP!!
- HELP !!!! RSX is in retard mode !!!! lol
- spark plugs
- turbo and intake mani
- retorquing arp rod bolts?
- Trying to find forged B20Z pistons
- Which injectors should i get?
- Anyone running a stock Evo VIII or IX Turbo?
- BW 372 Turbine housing
- Borg Warner Vs. Garrett Turbo's
- new motor
- Turbo Manifold help!
- mini me boost
- no start on base map
- Digital boost Controller Gizzmo
- Any EG S372 EG civic out there?
- oil restrictor??
- tuning setup
- Wanting to boost the stock motor but have room to grow....asked before but what you guys think?
