View Full Version : Forced Induction
- Want to hit 11's
- blow by caused by unadjusted valves?
- Turbo Lag at high boost
- lookin to trade my tranny
- Fuel Pump wiring
- Does dipstick work with Moroso turbo oil pan? What about pickup?
- Pump gas switching to race gas?? Searched!
- Anyone know where I can get these from?????? Silicon reducer
- Anyone have a GSR'd Honda with a T3super60 in the Chicagoland area?
- where can i find a good deal on some rc 550 injectors
- Looking for 200 WHP
- need tech help!
- \\ IS IT OK TO USE BLOX TYPE A CAMS IN A TURBO CAR //
- OH NOOOO ... i broke car.. fuel problem?
- any required reading before I consider Nitrous?
- 4 bolt vs. 5 bolt
- EVERYONE USING AFI RAMHORN MANIFOLDS
- What did I just buy and was it a smart decision?
- what kind of turbo do i have? its a turbonetics and i have all the infomation from the box..
- Tuning for spool
- T4 manifold fitment ? (using t3/t4 turbo) w/ making a flange
- After a blown hg, check out my block/pistons
- My other thread got locked here it goes again
- another msd ignition problem ?@@ help
- Question
- Using inline turbo manifold need HELP
- massive power loss when i add 3" exhaust?
- differences between AC and non AC manifolds? is there one?
- *request polished precision intercooler*
- Turbo H22 Aftermarket Intake Manifold options
- got some 81mm je pistons for my b16, fitment questions??
- B16 with Inline pro: Which IM??
- .Just replaced clutch, now it grinds?
- which engine torque damper would you prefer
- Wastegate Spring ?
- why am I boosting different pressures in different gears?
- THE MISSING LINK to get hondas to read boost how do i make one
- Stock Engine & Turbo Charging
- Turbo Seal Blown > Restrictor Needed? > or Valve Seal Problem? HELLLPP!!!!
- Weird bends on turbine
- MSD BTM Wrong wiring?
- Would i be fine w/out headstuds?
- JRSC GSR Spark Plugs?
- **347 WHP SOHC Turbo Ninja**
- S300 Upload error
- Turbo gone bad?
- Please explain how this MBC works!!!
- Oil Filter Relocation: Add Extra Oil??
- log mani + turbo, too much weight for exhaust bolts???
- type r tranny ???'s
- How much WHP can a stock S2000 Rear End hold???
- Would it be a good idea to turbo a SOHC engine? d16y8
- turbo H23....gonna build it now...what pistions...news from importbuilders rods either?
- piston rings
- gutting cat... searched
- help!!! rpm signal disappear after 6500rpm
- Where to tap turbo coling lines?
- anybody turbo a 200k mile motor before?
- is this a garrett gt series turbo?
- What to do with block?? Dart or sleeved?
- B18c1 TurboD
- GS-R Turbo setup... what do you think?
- 1st time @ the strip, H22, 92 hatch
- Oil drain issues???
- Running my nitrous 55shot for first time
- What kind of flange i need??
- 2000 Civic Si JRSC kit, do I need this bracket?
- been a long time since i posted here :)
- garrett gt seal bad with blockage?
- new track times...
- Boosted problem...
- downpipe question
- Edelbrock turbo b16a2, headstuds, and clutch
- SOHC turbo DYNO question?
- Airesearch M11 turbo
- for all of you svt, which head would you boost on?..
- a/f ratio/oil pressure,volt, guage where do i hook up the positive
- Compression Test results before Tuning Sesion, your thoughts?
- How much can i safely boost on this setup???
- SLS straight line specialties
- The Final Pull
- white smoke when in boost. compression consistent
- gsr head for turbo....
- HKS bypass valve (pop off valve)
- Help with my moates burn 1
- Vented the Valve cover
- Need sum info on this setup
- had some pitting on one of my pistons ??SRP
- OT: Someone stole JDM00SI's old 455whp Si!!!
- Manifold options for internally wastegated turbos
- Golden Eagle intake manifold...specs??
- Going price for turbokit install (search broken)
- Just picked up a JRSC for my 00 Si (THANKS CRUFORK) have some questions.
- turbo d16. t3t04e or gt28?
- pics of a borg warner S400 compared to a garrett t67
- Spoolin Performance
- Wastegate install
- compressor maps
- Post pics of your oil pan baffles
- PCV valve question
- Ceramic coatings
- Search is down I have a clearance question
- Which route?
- Possible to have to big exhaust?
- axle and blu box obd2 question???
- Is this Compressor Surge (Video)
- RevHard knock-off manifolds?
- Which injectors to buy
- Need A Turbo ID
- Need help deciding- Buy another b16 OR go LS-
- car runnin hot ?
- turbo filter
- D series torque VS B series curves
- newb here
- turbo...how bout SS valves
- How many degrees to retard per pound of boost?
- which flywheel for boost opinion..?
- sohc turbo vs. ls/vtec
- hondata and plx again!
- Posssible to bore exhaust housing?!?!
- oil line turbo
- 86mm B20 Headgasket survival question
- Running wastegate vacum?
- Carbon Creation's Honda Fit!
- Is there a BKR7E v-power plug?
- How's my drain? Yes another one...
- Overheating with Precision Intercooler. 750HP
- Blow off valve placement
- Water Cooled Question !!
- going to be going forced induction...compression ratio drama
- cometic head gasket
- Will a SC61 fit on a Drag Manifold???
- question about a/r.........please
- SS AUTO CHROME!!!
- can you identify this volvo-turbo
- Retune question
- Pics of B16, GSR, Type R cams?
- Struggling in boost??
- ****AWesomE TUNERS in The SOUThest**
- what pistons should I use?
- Blue Smoke
- is sleeving the block worth it?
- Rc 550cc injectors
- How to launch...
- dumptube too short?
- New Turbo Setup Help
- Wastegate gaskets
- What HP is the Walbro 190lph pump good to?
- flywheel for turbo balancing
- Is this -3an Will I need an oil restrictor
- peakboost manifold with 4" downpipe pics?/
- hit boost then it sputters?
- turbo setup?
- sc 50?
- Update Velocity Trends RHD K20-T **pics**
- draining fuel tank
- Supportive mods for Turbo
- !!!!vTEC SOLENOID!!!!????
- Super-tech or Rev??
- What Rods and Piston Combo For ITR Block
- The best bolt on turbo kit
- best b16 turbo cams??
- oil pan tap...need help?
- AEM UNIVERSAL FPR ORIFICE SELECTION?
- Different boost levels in different gears?
- Honda unveils diesel system to rival gasoline cars
- Supercharge or turbo?
- fuel pump ?
- Manual Boost Controller Install Problem - overboost problem
- plugs and gap ... plz help
- Dyno Graphs
- need some help here
- All 400+ whp EF Owners Please!
- H22 carbonfiber intake manifold
- A'pexi 3" World Sport II Universal Muffler on 96-00 Hatch with CTR rear lip
- Which Bottom end To Build With Current Set-up?
- question about running lean.
- which turbo kit?
- anit-lag "d'valve" does it actually work??
- what turbo is this?
- Hardware to mount electric oil pressure sending unit to firewall?
- Best turbo for a b16
- Turbo Problem
- Turbo prelude started running like crap. Need Help!
- turbo car??????? how can i tell
- Turbo car getting hot
- Turbo prelude now running like a
- New Turbo Project, 1995 Honda Del sol, looking for 12.4999999!!!
- block guard?
- turbo qestion
- Start of my winter project. S2000
- DIY el cheapo block filling 4 boost
- HYBRID_H@TCH's "new" FI build up. Part 1
- turbo help...
- can you run stock fpr w/stock ecu while turbo...read on.
- act pressure plates the same?
- request: measure the thickness of stock B series sleeves (whichever block you have nearby)
- Question about Pricing
- Where to tap for water temp sensor?
- ~*Got my Turbo GSR Dyno'd on Pump Gas.... PICS!*~
- wastegate spring swap
- log manifold capable of 300whp??
- Who rebuilds turbos
- turbo at the track
- boosted d16a6 running like poo
- StartUp Problem after Gas Fill....Need Opinions Im stumped
- will mixing 93 octane w/race gas change my a/f ratios??
- dumptube = ends near oil pan.. can this be bad since it can shoot at oil pan?
- INJECTORS STOPPED WORKING...WHY!
- striaght T04b turbonetics on a b16? more specs inside..comments??
- A/C problem...OBD1 and 2 related???
- Where Does This Go? *wastegate broke, fell on road, spring somehow fell out*
- which injector clips?
- OBX joins the turbocharger game!
- 250whp b16 hydro need a new CLUTCH, smooth engagement this time! (no action please)
- Painting the turbo intake housing
- Turbo GSR Daily driver
- Modifying the Tial
- oil line setup questions
- ps/ac compatible?
- Big cams for a supercharger?
- my precision turbo
- Fuel Injectors
- turbosmart mbc : how do i know where to set it?
- unorthodocs crank pullys NEVER USE THEM!!!
- Quick EMS Question
- oil feed / drain , turbo center section? (searched didnt find exact answer)
- 600+hp guys, How high are you Revving?
- blitz to greddy BOV ?
- HKS turbo timer.. why does it keep counting down on me even though i didnt remove key?
- exhaust: quiet vs. fast
- Nitrous Guru's......
- LS/VTEC Turbo : LS Oil Pump OK If I keep limiter at 7000
- Got retuned by Church Auto. Wanted to post some pics...
- MBC question..
- what size is a stock B16a head gasket
- How was your first experience with BOOST?
- What else do I need for 550+hp?
- Other BOV on TiAL flange?
- best turbo manifold for b16a2
- Fidanza flywheel for ls boost?
- how many times can i reuse my eagle rods/arp bolts?
- Precision 750hp intercooler... mounted on EG..
- turbo si set-up needs help
- the max of a 14b and side mount set up?
- help
- Never buy those "15% stronger" halfshafts.
- Whats The Smallest Trim GT35R ?
- PLX vs. AEM UEGO?
- how many miles in your exedy twin disk
