View Full Version : Forced Induction
- Is my car a genius?
- can people post some pics of their profec b?
- tial WG bolt and gasket blown
- Prelude guys with 3" custom exhausts and downpipe....
- whats the technical name for these "wraps"?
- Electronic turbo Kit?? WTH
- drag owners, howd/when did you put the driverside fan back in?
- Autometer A/F gauge....bouncy as hell
- Need some knowledge guys (JDM B16a w/ 18G Turbo set up)
- Manifold choice
- OT: RC injectors for sale, and other stuff too
- Where to get a 3'' resonator?
- What are good pistons/rods to get for a B20?
- Neutech Race Gas?
- apexi turbo timer harness?
- I need help really bad!!! Please help...
- A few turbo and compression questions
- recommended crankshaft replacement for FI
- eagle h-beam rod clearance
- Jackson Racing Supercharger....help!!!!!!!!PLEASE!!!!!!!!
- Help adjusting BOV
- Mr.Gasket Turbo/Manny
- pic of thrashed t-25!
- Phantom Grip LSD.. yes or no?
- who has wide band 02 sensor
- t-25 -can you answer??????
- bov
- greddy 18g spec?
- Oil and Coolant on a 97 Civic Si (Canada Ver)
- who makes better axles
- DIY 3" exhaust
- Clocked my turbo...shaft play?
- WTB: stock FPR
- Golden Eagle Groupbuy
- 11 psi intercooled gone, now 15 lbs of straight boost.
- pics of engine
- Haltech vs. AEM EMS
- Cheapest stand alone?
- which turbo came on which car???
- To all of those with an AFC...
- t25 stock psi?
- Drag Gen 4 kit Best price?
- anyone interested in a 3" exhaust GB?
- Will -30% work with DSM's ?
- Does anybody have the instructions on how to wire up the blue box on the Greddy SOHC turbo kit
- Blitz turbo timers with boost warn?
- Oil line fitting for Greddy turbo
- how does an i\c work, and how does a water/alcohol cooler work?
- how can hondata be stand alone and not the e-manage
- Turbo Gurus only please!
- Greddy Turbo "?"
- Are there any other good sleeve companies besides Golden eagle?
- Moroso Oil Pan Problems for D Series Engine?
- swap and turbo
- FS...MSD BTM and 3 step ....
- Broke axle halfshaft.
- Drag 3 downpipe were to get flange
- am i safe w/o an intercooler?
- Turbo Dyno Graph
- h22a drag gen 4!
- Is MSD BTM worth running on turbo Ls?
- crankshaft question
- whats the flow rate in cc's on these injectors?
- Backordered boost....preparation in the meantime
- CX Turbo Manifold
- Giving you guys first chance: FMIC FS
- need homemade turbo help please
- 75 hp with NX
- Question about Manual Boost Controller. Lost my ball and spring.
- Custom Turbo Setup
- WHAT IS...........j&s safeguard
- newbie question about ebc
- Blitz EGT gauge? advice please
- Top speed TRANNY vs AutoX TRANNY, mix'n match gears
- How much do turbo installs usually run?
- sfp manifold on a drag gen 3 kit???
- Greddy Profec B for sale $250 shipped
- Adjusting internal wastegate
- egt or a/f gauge? pleae help!
- Greddy FCU (obdi2)
- Does Racing Team use Turbo ? ? ? ?
- Turbo + Nitrous or Thicker Head Gasket and more boost???
- boost problems
- For all of you piecing together your own turbo kit! (Roll Call)
- ouch
- bullet proofing a jdm b16.......
- A lot of people have been asking about custom IC piping ...
- AEM fuel filter
- does your HKS SSQ bov twist and turn too?
- Profec b hookup/works in reverse
- Oil leak, but can't figure out from what....
- who uses a filter on there turbo setup?
- Thermal R&D, exactly how loud?
- best header for JRSC
- Spare Block (picture intensive)
- Fuel Pressure gauge reads 0 at idle??
- OT:where can I get a H-T.com t-shirt?
- HELP! Finished turbo install...car keeps dying!
- OT:figure this out problem
- Couple of turbo questions, hopefully I don't get flamed...
- got a Hondata and J and S for sale...
- Which Turbo to use ? ? ? ? ? ?
- Nitrous Oxide Injection question . . . . .
- Smoke AND Oil coming from breather
- HELP! I'm thinking of selling my AEM EMS!
- manifold bolts?
- HELP asap! how'd you guys get the bolt in for the drag manifolds?
- hks manual boost controller?
- ls rods in d16y8
- Is a block gitdle necessary
- Inlinefour Head Gasket, Does it really lower the compression of b18c1 dramatically?
- Clutch not holding?
- Overheating with Oil/water-cooled Turbo?
- Greddy 18g turbokit on 94gsr(?)...
- where does the line after the BOV go?
- Dont know what to do! So Stressed...
- Autometer Oil pressure sender on turbo (instead of behind the block)?
- 60-1 T3/T4 Turbo Sale
- Has anyone had air conditioning functioning probs after a turbo install?
- Forced Induction on an auto
- Sell the 00 Si for a EG hatch?
- Hondata's ful-throttle shift feature...
- any pics of drag kit w/ tial wastegate on 99-00 SI
- anyone have pics of a coolant bypassed engine w/ the hondata gasket?
- JRSC GS-R removal... any tips?
- Where does your Fuel Pressure gauge read when you are boosting at WOT?
- engine building for turbo. help please
- Analyze my Spark Plugs...
- vafc hack or hondata?
- Silicone hose??
- All right guys the time has come
- H22 supercharger...
- tore that "o-ring" inside turbine housing, how bad is that?
- Obd3 Turbo?
- Revlimiter at 5000rpm !!!!!!!!!!??????????
- buying a fmu with different ratios
- Missing Link MAP, missing red O rings....
- Check this out!
- a friend claims he ran a 12.6 on his auto turbo w/ 50 shot in ls teg!
- knocking and pinging help??
- a question concerning the removal of ac for turbo purposes
- my melt down
- MAP sensor plugs?
- For the hondata guys...
- OT: Car insurance for your boosted car........
- Intercooler question: Apex'i vs. XS Engineering
- modified mag
- MaxRev intercooler...
- Greddy turbo kit(do i need the blue box)
- buying a turbo soon.....need help deciding
- wastegate still messed up
- Hondata users please help!!!!! Something wrong!!!
- Turbo feed line ID's
- Tial 35mm/40mm hybrid wastegate?
- LS turbo hondata tuned.
- reassembling turbo?
- Best tranny for a built turbo motor?
- Poll: Turbo owners
- difference in standard drag III turbo and T04E turbo?
- want your oppinions on a good settup
- Is a 255 holley inline fuel pump too big for stock injectors on 9psi?
- why is fuel spraying everywhere?
- pics needed....T3 super 60
- How well will a T3/60-1 work on a built ITR?
- Importparts.com 5th Birthday - DRAG Turbo Kit Sale!!!
- 440's, 12:1 disc, V-AFC setup?
- What exactly is this??? (pic)
- Sleeve question?(Badger)
- will the greddy bov fit hks flange for drag kit?
- Red GSR in Honda tuning mag?
- tips on setting profec b....
- LS turbo?
- Bosch Fuel Pump (10208)
- If you could do it all over agian.........BOOST or ALL-MOTOR
- WG's: deltas and tials, but what about greddy's and HKS's?
- What do I need to run more than 8psi on the JRSC?
- Anyone here sell Endyn pistons?
- Golden Eagle GroupBuy
- congrats to someone on this board, summer slam etown, nj
- Junk yard turbo??
- Sparkplug cleaning.. do or don't?
- life span of block (turbo users PLEASE READ)
- map vs mas
- adjusting a deltagate??
- Check out our big brother.... WoW
- driving without intercooler?
- ZEX problem
- lighten flywheel on turbo cars? yes no?
- how many of you guys track/auto-x your turbo'd car??
- Build your own standalone?
- Where to get turbo piping from?
- Rev Hard tubular mani
- Anyone get their car jacked from someone on the web?
- O2 sensor question..
- Cooling for a b16 with place racing mounts with a big t3/t4 turbo
- intake manifold Q's
- Auto to Manual swap... How much?
- Anyone uses one of these? (intercooler)
- which is the most acurate greddy boost guage?
- OK, once an for all..IS A GIRDLE REALLY NEEDED? (did search)
- Turbo mani for spiderman's car
- Help with Oil Feed Fittings
- Need help with removing hub to install studs???
- =some new videos=
- Drag downpipe doesn't fit???
- did some math earlier for my turbo set-up. Need you advice guys.
- What turbo should i use?And What Intercooler..
- is this oil line kit for turbos any good
- online place to buy new or remanufactured.....
- o2 sensor, egt sensor question.
- b18b or b20b/z for turbo?
- Front mount intake piping used for charge/ic piping?
- whats better, mechanical or electronic boost gauge?
- bar and plate vs. tube and fin Intercoolers
- lots of boost lag
- spool up ?
- crazy turbo nsx
- wut inexpensive exhuast should i get for turbo gsr?
- *Guys Please Help!! Car died today and its a timing problem...*
- Some goodies...
- Junkyard Turbo
- what size wrench do I need to take the pressure plate bolts ?
- What '94-'95 GSR Greddy kit set up you guys have?
- places to buy turbo parts??
- suspension inquiry
- Anybody here ever tried to un-bolt the crank pulley bolt by yourself ?
- OT: One step closer to my turbo eg!!!!!
- IC piping?
- VAFC Hack Dyno?
- is this one good for dataloging? thanks
- turbo civic(d-series) + aem cam gear = advance or retard?
- Can anyone get me a NEW oil pump off a GSR or Type R???
- i removed my air to liquid intercooler, pics inside!!
- Boost Leaking...
- MAP limiter/larger injectors
- Looking for some RELIABLE AND KNOWLEDGEABLE info on turbocharging
- would this supercharger work?
- Turbo 4gen prelude peeps, how big is your intercooler?.....
- **Best Headwork for Turbo Setup (P&P, Valvejob, etc.)?**
- Question about hooking up a Oil temp gauge.
- WTB hondata dataloging
- what speed laptop for dataloging?
- why is this stock b20 running lean?
- fuel system ???'s
- stock camshaft
- Thoughts on Crower DOHC Vtec valve springs?
- used hondata
- Mustang fuel pump for boost?
- engine temps
- looking for greddy oil feed line
