View Full Version : Forced Induction
- FJO wide band problems...
- Question for you guys.....?
- Done with turbo install (14b d16z6 in EH2)
- Map Sensor Wiring on H22..*SEARCHED*
- Do i need both turbo timer and boost controller?
- sizing turbo's? displacement vs rpm band.....
- Hondata intake gasket worth it??
- post sohc turbo setup
- !!!!!!!!!Another stock GSR dyno!!!!!!!!!!
- anyone know where i can get a HKS WG Dumptube flange?
- A few turbo question?
- Stealth IC?
- The Drop Shop and Jon...Screwing people again!!!
- Major Turbo Problems!
- Need to buy new rings again.
- are my compression numbers ok
- CTR Pistons in GSR
- profec e-01 lost in outer space
- Water/Air Intercooling
- would these vortech sc kits fit other motors b16 and b18 motors?
- fuel pump on turbo ls
- how to check your oil pressure
- can u use a z6 aem fuel rail on y8 i/m?
- what side of intercooler would u rock? name side or no?
- What would you recomend with this turbocharger?
- What is the difference b/w Street and dyno tune?
- Greddy oil line?
- K03 Turbo + ZC DOHC = good combination? I need some help...
- Just got my COATED Pistons Back from AKARI MOTORSPORTS.
- SVE 3 bar MAP sensor?
- GSR butterfly as vaccum port?
- Headstud threads in block stripped help..
- Nitrous on stock d16y7?
- the turbogods hate me (gen 2 teg
- What do you guys think? Greddy turboed SI #'s...
- dsm 450, need help to identify!
- Greddy Blue Box questions.
- Is JIMFAB still around??
- Tuning fundamentals
- Upgrading axles a few little hints I learned this past weekend.
- Whats up with my Vtec? any suggestions welcome
- Any of you guys using pusher fans have cooiling problems?
- ZEX 59100 cam
- safe to spary on 10.0 CR?
- code 14 and 20 (electronic air control and electronic load detector)
- making some serious HP on a T3/t4 B
- Why do my Dyno #'s suck!? Turboed D15b vtec..
- EXTERNAL OIL PUMPS............
- Profec A install?
- Getting custom piping made, few ?'s
- Helicoil gone bad!
- Advice on h22a custom turbo setup....
- How Noisy Are Built Engines?
- for u turbo heads : do u guys smell gasoline?
- where to mount MSD????
- Intercooler Sprayers.....
- where can I get injectors tested and cleaned?
- FMIC
- Help, Installing turbo...
- Need Help!! Overheating and Coolant Reservior overflowing!
- 590hp Civic EG on Superstreet
- H22 turbo kit worth the $?
- How much it worth?
- xs-power!
- Random CELs right after shifting...
- Siemen Deka Injectors: HOW DO I GET THEM TO FIT?!?!?!?!
- (Turbo Dreams) GS-R motor but what size for my goals
- Straight liquid CO2 inside a liquid intercooler without liquid? drag strip of course
- Utah Motec tuners or close state near !!!!!!!!!!!!!!!!!!!!!
- t3/t4e vs t3/t4b, searched!! need answers
- turbo kit???
- running super lean and need help!!! b18b turbo
- opinions wanted
- D16y8 TURBO HELP PLEASE!!
- can i get a little help with my turbo b16 hatch
- Built motor, but missing intake manifold...which one to finish it with
- 500hp civic??????
- 3 power adders on a big block!
- 400hp----->SC34 or T3/T04e?
- H23 with TD04/14B
- little help plz with a dodge conquest turbo.. on my CRX SiZC.. linkage arm?
- I can't find a part; I need your help.
- vtec cutting in and out in 3rd and 4th gears help!!!
- aem 5 bar map sensor
- will hondaya fix my car? help please
- intercooler help
- no wastegate movement, normal?
- rx7 460cc injectors?
- Turbotrix Evo => 9.95 @ 143mph Video and Pics
- After Hondata Is Tuned Can I Go Back to OBD II for emissions?
- Info: Junkyard Intercoolers comparision DSM, Starion, Ford/Mazda , Toyota All trac (pictures inside
- n20 plug change
- Need a manifold
- Garrett Turbo Index...
- junkyard with MR2 turbo?
- All you DOHC Greddy Guys!! Post your Dyno, PSI and or Times Here?
- saturated injectors with a resistor box
- Will a stock intake air box on my gsr fit with JRSC?
- Dart Blocks ?
- Two intercoolers in squiental order, read before you comment please.
- HELP stock turbo B16
- intercooler question... help..?
- how to play with evo/scoob's ?
- Rod Advice
- what hose is this? (skunk2 manifold install)
- Using Stock TURBO from other cars!!??
- Aftermarket Dual Core Radiator Fitment (Inlinepro DC2)
- EG hatch w/type R motor JRSC
- Need Infos on RX7 Purple Top 89 Injectors. Thanks.
- Question for avcr users
- any thoughts on this wideband o2 reader?
- Clutch Advice
- afc help fpr needed
- Help piecing together custom turbo for 98 GS-R
- Greddy turbo timer wiring codes
- ****Why does my vtec pressure switch light constantly stay on (hondalogger)??? *****
- MSD 3 bar map sensor normal or compact ver is there a difference?
- recirculate o2 dump
- B18B + 188k + Zex = ????
- EGT temps....
- one fab manis????
- AVCR or Standalone system
- question on afc settings?
- Internally Gated anyone?
- Would wrong wireing on resistor box make me run rich?
- Turbo Mini Me Setup Question
- Turbo , how big is too big ?
- bolt doesn't fit in manifold... WHAT TO DO?
- explain to me the walbro intank fuel pump
- Another Turbo Prelude is out on the streets
- downpipe help...........
- Jackson Supercharger Vs. T4 Turbo
- 92-95 aem fuel rail fit 96-00 motor?
- Getting oil in my exhaust.....
- b18b turbo set up is allmost done what do you think?
- ok to have a dent like this harm done? pic
- took hondata out of car and plugged into computer.. now what?
- tuning gone wrong...CRAZY AFR...whats wrong???-
- engine bogging on hondata?
- Strange whisteling noise
- d15 turbo setup
- Ignition tuning
- Couple pics of my new setup install
- leakdown:difference between cold and warm
- Project Big Block Compression Test.....
- How exactly does an IC work?
- Injector size......
- Tuning FUEl maps for new turbo TurboLS Cams
- CO2 chilled water/air intercooler?
- Car sound cat.
- where to buy suzuki vitara pistons??
- Can too much HP crack ring lands?
- can i use this downpipe with this manifold?
- Will the ac clear for my setup?
- ACL bearing help?? please
- ZC 300 whp
- which camshaft For Turbo Civic
- E-Cutout Boost Creep
- H22 Turbo vs B18C Turbo
- Dyno Tune and then exhaust system
- AEM Fuel Regulator - Need assembly instructions
- Where to get Lucas injectors?
- would spiking to 20lbs of boost on a stock map sensor break it??
- oil spraying out fo turbo lines? HELP FAST
- Running WAY rich with S-AFC & 450's ----WHY?
- compression test results in.
- Turbo to Manifold Gasket and Downpipe connection HELP!!!
- question about T3/T04e feed and return lines
- "PIC" Resistor wireing...did I do it wrong
- H22 Civic Super or Turbo?
- best manifold for 4 bolt? need ac
- Pre boost/Maintenancing
- what wastegate to use????
- Stutter after ENDYN install
- Swap done, have issues
- skunk2 intake manifold problems on a gsr
- oversized headstud?
- DEtunning the JRSC
- Ran at the track last night!!
- vortech question
- Oil leak
- garrett t3 turbo question
- AFC Hack guys, please check here. (CEL 45, Pre turbo)
- Motor Rebuild time!
- Super quick DEFI question?
- VIDEO driven the Opel Speedster TURBO
- quick questions... FMU 8:1 or 12:1?
- Engine spec for high output turbo
- What turbo kit
- Procluth Stage 4 good for 400whp?
- Where can I get a gasket for Blitz Dual Drive Blow Off valve?
- Strange VAFC hack Fuel problems.. Input needed!
- Two oxygen sensors for B16 in combination turbo manifold. How?
- [sorry] Can some members recommend a shop for me
- 400whp and PRECISONLY confused...
- b16a1 turbo - Good or Bad?
- Ebay I/C's?
- Lifespan On JRSC
- It finally runs!! Back from the dyno
- boost and injectors
- d16y8 head on d16z6 bottom. questions.
- my long day at boosted hybrid's
- Greddy Manifold ??
- keep popping fuses... new developments, and im stuck :(
- Is this a bad idea??
- how do I upgrade my T25????
- Need help ASAP MSD Ignition whats needed?
- injectors not fitting in skunk2 manifold?
- ZDYNE one wire conversion (Hasport)- whats the best way to go ensure good tune for boost?
- arp head bolt loose??
- Just got back from dyno..NEED HELP
- is there any way to find out if my BOV is taking a dump on me?
- Jet Coating.
- went to the track last weekend...
- Anyone know where to buy a internal wastegate actuator for a 14b turbo???
- Will intercooler piping fit?
- where to buy custom cometic headgasket>
- apexi avcr and greddy profec b spec 2
- anyone have a 3inch downpipe with A/C????
- anyone using an E-cutout, and can show a pic of thier set up??
- whats the closest you can mount O2 near turbo on downpipe?
- What kind of clutch to use for a B18 turbo
- d16y8 dizzy timing and boost
- injector question
- oil in my catch can?
- boost dropping around 5000-5500 rpms. Could it be my mbc?
- Time Slips
- compression test
- skunk2 install question...pics inside
- what should my buddy do next?
- 8:5:1 d16y8
- drop shop manifold, turbo install, HELp
- Downpipe too close to a/c condenser?!?
- Microtech ltx 8 with 4 coil on a teg
- Civic 96-00 ek turbo piping routing HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Fitting to replace black breather box question >>
- drag turbo question?
- boosted-hybrid, tuned you guys must read!
- best place to buy a kit?
- how do u install missing link?
- MSD window switch...can you use it with zex?
- BIG TURBO COMPRESSOR FILTER QUESTION? (knowledge and opinions are welcomed but need proof)
- B18b 15 psi dyno
- couple questions: plugging hole in compressor and boost leaks
- What should my vtec engagement be set to?
- Pinned stock block..........
- turbo needs more oil?
- Integra with del sol si radiator, Hoses???
- cel 24?
- Motor Sport Injectors
