View Full Version : Forced Induction
- Just mounted Inline Pump, is it too low?
- Is turbocharging a 88 civic legal?
- Stock Fuel Line to AN Adaptor Fittings question
- boosting a b18c5 type r..
- Tial BOV Question?
- h22a4 and 91mm bore
- Help a Toyota guy? :) AFC hack for speed-density car (like Honda)
- Ebay turbo kit, d16y8, help
- Boosting an H22?
- 42r oil pressure
- compression low in #3 but no smoke what so ever?????
- AC condensor and fan?
- Forcedtunedengineering experiences
- MAP sensor
- 1988 CRX turbo options:
- Looking to switch from a supercharger to a turbo:
- Wastegate dump ??
- re-tune or not
- Planning to boost..
- trying to break 350-400+whp on stock B16 block w/ built head
- Advice on my JRSC'd ITR build
- what to do if orders are delayed and delayed and delayed and delayed.......
- Comptech aftercooler icebox
- 8 spark plugs in 2 days. WTH is going on?
- no o2 sensor
- where to get a 3" downpipe
- CROME users, P30 or P72 based Roms???
- Who all runs intakes/filters on there turbo
- hp numbers?
- radiator hose pressure
- VIR Redline Time Attack - Full-Race Civic FTW
- help what do i do with a b20b in a deli?
- AEM EMS ? I don't quite understand. :(
- Basic BOV, DV questions
- Eagle rod woes
- OEM FPR boost ratio?
- What is a Garrett 60-1 equivilent too?
- long term d series people... street tuned only.
- h22a question!?!?!?
- whats a good turbo for high horsepower?
- Custom turbo setup help DC5
- t3/t04e 50trim w/ .48 hot = 350whp possible?
- has any1 had a meutek turbo mainfold
- fixing a blown motor for $200, how long do you think this set up will last?
- 1/2 oil pan hole too big?
- ***The Official Nitrous Thread***
- to sleeve or not to sleeve
- How to tell blown turbo seals????
- hf manifold
- LS tranny with b16 FD
- turbo and safc?
- b16 t4???
- fuel problems on startup..fresh motor need help
- The best combination for turbo aplication
- Boost/vac gauge video, question
- issues with new turbo install
- turbo size
- E3 Spark plugs. Anyone run these
- ITR throttle cable rubbing
- exhaust setup
- getting pistons for sleeved GSR?
- My Project under processing b20VTEC 650hp but...
- Do piston rings make a 100% seal?
- injector question?
- Help the NooBie! How do i read the names of turbos & understand what it means?
- Building gsr head?????
- JRSC GSR--11lbs. Opinions, help, advice, etc.
- Horizontally-Mounted Intercooler???
- B20 vtec TURBO build (NEED HELP!!!)
- Boosted Integra - My new build
- Are these 440cc Precision Injectors???
- Turbonetics CHRA = Garrett CHRA ????
- ***Help Car wont Build Boost After tune**
- info on garret turbo m11? t3?
- wiring slim radiator fan.. neeed help
- JRSC, could the super charger be causing my IAT to raise
- filled blocks
- need help!
- EK Si Fuel Injectors
- oil in intercooler
- anyone have a pic of the top mount with a bracket? (searched)
- high compression and supercharger
- HELP PLEASE! ABOUT RODS AND PISTONS FOR F20B
- "Dear Baby Jesus!!"
- Full race top mount and dry sump setup? Possible?
- Skunk2 Stage 1 cams ok for JRSC
- port and polish???
- hks ssqv gen 2. reviews
- looking into buying a turbo integra... what you guys think?
- Any Suggestions on a B18 Turbo setup?....
- Beeyond Engineering H22 Civic ultimate Full Street car.
- vtec?
- supporting vendors....prices for gt35r
- turbo is very pouchy, & oil in the pipes= what????
- turbo manifold that clears block
- can i disable the GSR secondaries on the intake manifold
- Fuel Cell for Nitrous Question
- smoking, milky coolant and vtec not consistently engaging.....HELP!!!!
- people with 350-375, what cams r u running?
- piston down... 175-175-175-130 why
- Q?: Built Head w/GSR Cams or Stock Head w/Cams for Low Boost
- Heat wrap for A/C lines?
- Heat! what would you do?? :(
- 92-95 civic hatch intercooler question
- 400 whp Stock B16
- Ecu humming?? Hondata light green and red
- anyone running skunk2 intake manifold?
- need a 3" dp
- Skunk2 Intake Manifold, old-vs-new pro version
- H22A Turbo or N/A?? Please share your knowledge with me.
- b16 turbo bogs when vtec hits
- Tunerz Image?
- noobe question about gas
- 86mm boost?
- ECU Tune question...
- Magnetic Drain Plugs, all they are the same?
- Hatch tuned with Crome with exhaust @ 2.25 can I run 3inch exhaust and will it hurt my tune?
- Anyone running t3 60-1 on DD GSR?
- b16a turbo build parts list how does it look...
- Real quick water source Question
- B16 Dyno Let me know what you think
- trouble with NO2 install and nitrous control
- moroso oil pan users
- 12V constant to fuel pump ok??
- Nitro Methane
- high horsepower valve train??
- Electric Supercharger
- common for more lag at less boost?
- -10 AN fitting what is this in imperials sizes?
- Keeper Broken on a h22 Turbo?
- Compressor maps, is there a wesite with all listed?
- Where to find Divided T4 Housings for GT35R?
- Do you really need gasket from turbo to manifold?
- Guys need some info on stuff for my turbo setup on b16a
- Endyn catch can crankcase breather kit spewing oil - How do I fix it?
- Anyone run IAB's on a p28?
- Do I need new headstuds?
- Where can i get srp piton rings for a decent price?
- Type-RS BOV Adjustment?
- Tuning issue *please read*
- Buying a turbo car - n00b questions (sorry)
- I need help!! RC 550 injector seals
- built NA b18c1 wanting more power by turbo
- should i or not?
- JRSC Needed
- some suggestions please?????
- tuning
- D16 Greddy users???
- Boosted K20 Smoking Issues-- Need Advice!!
- Ignition break up problem
- 16g on d16
- Thought i could share my build with you guys!!!!!
- B20 Rods
- Sub 300HP LS. What is needed?
- Automatic LS Turbo ??
- turbo question
- best tranny for turbo setup?????
- Rc Engineering Injector jumpers
- b18 crower stroker kit Experience
- Intercooler size for d series turbo
- best manifold for lst?
- Throttle Body Size for FI?
- Boosted ls/vtec
- td04 turbo
- what turbo is between a t3t4 50tim, and the smallest sc61?
- B series Fuel Rail that come's pre tapped for Bosch injectors
- Boost issues! need help...
- will this work?
- Overheating in boost with ac on
- best catch can setup for d-series?
- keep blowing coolant hoses... need help
- coolingmist methanol kit
- What motor????
- MSD Ignition and Coil...is it necessary for JSRC?
- max psi
- turbo help
- H2B turbo setup needs help
- drag turbo kit/ world sport exhaust?
- at what rev a T3 hit full boost in a b16?
- tuned by chrome?
- peakboost kit just installed....
- oil cooler?
- B16A + t3t04s..what to expect?
- Fresh built motor,cracked sleeve in week!!!!!!!!
- forged rods and oem pistons?
- dpfi turbo?
- Clocking turbo help?
- just bought an rsx
- Where do you hook up the bov vaccum line too?
- freash built and now a code on start up
- psi drop
- Oil pump for LS Turbo?
- Build my d for turbo
- IAB's and Nitrous
- STR intake manifold port size
- New Track times and some help with tire size
- GSR oil squirters ?????
- Noob Question: Is 81.5mm bore stock sleeve OK for boost??
- bad wideband o2 sensor?
- b18c 400-450hp
- trying to choose pistons endyn or cp pistons? turbo application.
- I see comparisons from Skunk2 T1 to Skunk2 pro 1 but,
- Boosted stock K24a1 8psi
- Quick question for apexi avcr users (Target Boost pressure)
- What IAC for STR intake manifold?
- new car, new motor, new goals!
- best b16a turbo?
- Need a Hondata tuner in the UK (Have searched tuner directory)
- overflowing oil catch can...
- inlinePRO manifolds
- Is there a difference between D16Y8 injectors and D16Z6 injectors? I have a Y8 manifold.
- t3 t4 upgrading to gt3076r questions
- Prostreet Auto & Performance in Las Vegas are scammers *BEWARE*
- need a tuner
- cyberdyne boost guage and map sensor question
- i need turbo seals
- turboing my gsr help me
- What to use for tranny fluid on boosted LS?
- A couple of last minute questions before trip to get tuned..
- Te04h oil drain flange?
- question for xenocron
- What ignition retard controls to use with progressive nitrous controllers?
- Greddy turbo picture
- car only revs to 5000rpms.........why?
- HF manifold for turbo?
- Planning to go turbo. Have questions
- spark plug wires coming off
- Arp tq specs?
- Wastegate hood clearance question
- Stock H22a Turbo
- crvtec-t reliability
- boost problem
- What would be a good DD head setup???
- post your b series/ stock si turbo set ups w/ A/C
- map sensor question.
- d16z6 made no power on dyno and tuned at philly dyno works
- headgasket blew,any other damage?
- turbo nitrous
- *B17 + t3/t4 + (time x money) = Boost* SUGESTIONS AND HELP WELCOME!
- the diff.between peek boost and full race?
- a/f guage or digtal display?
- Project Perry Winkle Finally done **Non-Honda**
- another obd question
- t3/t67 vs t3/t67HO
- SRT-4 Intercooler Efficiency
- Ross turbo pistons?? anygood??
- Garage Sale: 99-00 Civ Hood/B16 Log Turbo Manifold/.48/.50 T3/Downpipe/+more
- turbo with cams
- Turbo SOHC Opinions
- crower stroker kit turbo
