View Full Version : Forced Induction
- Boost Question?
- 3 bar install help
- What is the "oil control orifaces"??
- can i make up for a low exhaust A/R ratio by turning up the boost?
- feel like mad scientist-uber tuning
- CALI people--> Official Mase's West Coast Tour sign up thread! Help Support Laskey Racing!
- What clutch to get for 300whp gsr?
- Please Help -- Transmission / Clutch Trouble with the Boosted GSR
- Trimming bumper support for fmic
- gsr pistons VS. Ls pistons
- how does my vband fit on my turbo????
- Clutch ans axles
- my first leak from turbo.....
- edelbrock turbo kit
- Ninja Dyno Day, Tuners get in here and diagnose !!!!! Uberdata !!!!!
- 5 lbs on Gsr?
- Nitrous Jets Question
- Should I run ITR valve springs on turbo setup?
- Anyone running bigger cams with your turbo set up?
- OT: my custom 350z grill setup
- Anyone Have D16z6 Head & D16y8 Block In there car?
- turbo size
- FI Car owners, Need Your Help..
- Scat Rods for a Turbo'd D16z6?
- greddy blue box
- TurboEDIT 2.0.10 (Try 10) Now Available
- how to tune Turbo H23 ?
- Anyone ever do a twin intank fuel pump setup?
- New gen 4 JRSC with powercard technology???
- boost controller and wastegate spring question
- how much boost on your DOHC ZC?
- jrsc
- Help: Windshield washer fluid w/ FMIC piping
- Indycar turbo on an integra?
- Msd SCI vs. Msd 6A on turbo motor?
- sc61 with a 2.5" dp?
- For all you with feed restrictors/or who question them, read.
- Whats the ideal oil pressure at the turbo...
- For those with Stan's Turbo oil drain kit... I have a question
- Where to get V-band flanges, specifically 2.5??
- Looking for a D series turbo mani and intercooler
- 93 coupe with d16z6 swap and edelbrock turbo kit...
- going to dyno this afternoon!!!!
- Need a sleeved b18c block
- 370cc or 550cc injectors...ls/vtec turbo?????????
- IC Piping ?
- How would you Finish this setup ????
- Can i drive a tuned map for 550cc with 700-750cc injectors??
- Oxygen sensor problems
- Hondata... what exactly is needed?
- In-line or In tank fuel pump??????
- Knowledgable shop close to NE, PA?
- Missing Link testimonials
- Any One Know Where To Get.........
- Oil Return - How Big is Too Big?
- need advice on leaky oil pan
- T03/T04 vs sc50
- hondata or not
- turbonetics t3/t4 .57 trim ar63 upgrade to t4??
- ever experience bad plug wires since boosted?
- Walboro Fuel Pump?
- How do my plugs look?
- Is y21 a tranny that exist on USDM. Want to order axles, LS 5th and a quife etc.
- Golden Eagle Mfg oil feed adapter plate...
- Tilton carbon twin disc impressions!
- Hole in compressor housing: what size bolt to block?
- Integra ls turbo bov/boost questions
- ZEX Nitrous Jet Setup - Need help quickly!
- Calling Turbo Preludes!
- ATTN: Turbo Experts, Need Advice
- welding gas bottle ?
- Help Out a New Guy!
- Oil return fitting????
- AEM EMS not connecting to lap top?
- How do I fix this??? (lovefab shorty)
- ecm mounting ? for anyone with hondata.
- T25 flanges Nissan & DSM
- Couple pics of the current project(d16 turbo)
- What to do about the fan?
- Tuning question
- Can Someone explain:
- Anybody here with Garrett GT40 experiance??
- SC61/full race mani fitment question
- Which nitrous do you guys use?
- SuperCharger Question
- turbo or supercharger?
- did 2 wire iacv conversion and still problems
- Nitrous Gsr What Kind Of Pistons and Rods?
- Anyone ever use these spark plugs in their setup??
- Resister Box?
- All Import Turners in Tampa FL read this ...
- Does anyone's INNOVATE wideband have a bouncy RPM reading?
- oil pressure sending unit question
- Throwing 2 codes.....advice please.
- Looking for a 5v gauge to use with my wideband...
- just got VAFC, hack question
- Boost timing issues
- Question about Inline Aftermarket Fuel pumps...What if...
- Moroso Oil pan help
- does open dump make inacurate air/fuel readings on dyno???
- Vac Connector On Wastegate
- another ebay H22 turbo kit?
- Radiator fitment in a 90 civic lsvtec turbo????????
- code 14, and the worst day of my life so far
- help with turbo timer?
- best turbo for a d16 zc
- how mcuh boost will a G1 Profec-b hold safley?
- Old-Skool D-Series Babble
- Fuel Sump on a street car.....
- Suggestions on turbo setup please
- Anybodyu know the size of the oil feed fitting on a TB03?
- Question about full-race products..........
- how hot (on temp gauge) does your turbo'd integra run?
- 4inch air filter
- Pics - N2O Install
- How many Boosted miles on your high flow catalytic converter?
- What do i need?
- 400whp on pump gas , what are the secrets tuner gurus!!
- Higher RPM feels like im hitting a brick wall???
- Intercooler Air Flow
- What kind of muffler on custom exhaust?
- Greddy Blue Box with Vafc II. Vtec Problems.
- Can I use R5671a-9 for daily driving?
- looking for an fmic to support 400whp at least but...
- AFC, MAP CEL at only 8PSI, this one stumped Liam, what do you think?
- where to get EGT probe
- Finally finished Full-Race install, but got minor problems(any help?)
- blown seals? how hard to rebuild? info advice, thx
- oil and filter
- Does cat direction matter
- nitrous plugs?
- Anyone have pictures of exhaust pipe running under the gas tank?
- Turbo and a/c. Why cant I have both? grrrrrrr
- South florida performance (SFP) vs. inline pro
- B18a/b vs. D16z6
- Where to buy O2 bung for AEM UEGO WB with Bosch LSU4?
- camshafts for turbo ......
- What to do to get a 450-500 hp
- Holt Batman, My Oil Pressure once boosted!
- Post your best turbo setup parts
- Coil to Distributor spark plug like wire
- Looking for someone to do a HOW TO nitrous install.
- boost spike
- inline pro 5 bolt manifold?
- Inline Pro Manifold and Tial 38 MM Wastegate...will it fit?
- My Temporary setup
- Intercooler Size for EK???????
- uberdata installers in NOVA??
- Neetronics, Toronto
- i know you dont like OBX... BUT... look at this
- Dirty Block
- B16 Turbo WHICH ARE BEST PISTONS???
- Just in from importparts.com!!
- Soooo....How much $$$$ do u all have in your fi project car????
- WHAT do i have to do to get my jackson racing supercharger to run correctly?
- Wastegate is staying open....need help.
- JE Pistons
- B16A ARP headstuds on B18C?
- sputtering under boost and @ WOT
- Not the answer I expected from a company
- Do stock injectors max out with 83mm bore and 9:1
- HELP! NO FUEL PRESSURE?!
- is there such a thing as 1000cc saturated injectors ? or am i stuck to get peak and hold?
- How much hp will thei fmic handle?
- Anyone have a sc50 on a b18c1?
- are there alot of different 5 bolt flanges for t3's?
- car bogging!!!!
- Where to by flanges?
- Electromotive TEC III
- will this turbo d16 setup work?
- block swap, 2.0 or 1.8
- turbine spool = boost?
- Not FI, but you guys know alot sooo...Loud squealing, vacuum related!
- 370cc good enoough for 10 psi? small t3
- machine shop in north VA.
- How does my setup sound...
- greddy oil line question?
- Ls/vtec Turbo
- HELP!! need quick assistance so i can get my car on the road...wastegate question!
- Turbo XS Type S BOV with greddy sohc kit?
- just got my turbo... starting the project
- wideband placement & EGT
- question about timing retard and detonation
- Need HeadGasket by tuesday where at
- Will a drag downpipe fit w/ custom log manifold?
- turbo and block hit each other
- A different kind of forced induction..(56k sorry sit this one out!!)
- ARP or AEBS head studs
- 4get S/C im going TURBO!
- What should I do with my Type R
- HELP I DONT KNOW WERE TO PUT MY VACUUM LINES
- turbo term explanations
- Pictures of my turbo and some questions
- Truth or Hearsay
- aftermarket regulator and vortech fmu
- LS turbo
- SC61 vs. SC34 for a 350hp Setup.......
- AFC Hack, Boost level, and Turbo size... are they linked?
- IAC Motor
- Precision 350HP Intercooler & CRX will it fit????
- vortech fmu on a d16
- Compression test results too low? - b16a2 with 9.4:1 CP
- JRSC belts gone - ok to run car?
- b16 b18b questions......
- Plans to run GReddy kit. Any suggestions?
- OK...I need sizing, trims, etc etc, information on turbos
- Greddy turbo kit problems, boost hits 7psi then drops to 5, any sujestions?
- need some help guys... car stalling for no reason
- anything missing from these pics...
- Turbosmart 35mm wastegate - vacuum fittiing thread size?
- 450 whp@ 19 psi...finally
- tubular manifold vs log style. facts?
- best place to buy drag 3 turbo kit?
- 660HP from B18c! now looking for something cheaper to use turbo application
- 200 hp SOHC on 15g?
- eagle oil adapter
- Tuning new turbo setup....
- Which Clutch for 03 Civic Si w/Greddy Turbo
- Adding Nitrous to the mix with a T25???
- how come all of these 500+hp hondas keep popping up and...
- Dyno Numbers for a GSR Hatch Tdo5h-18!!!
- Ebay Prelude H22 turbo manifold any good?
- has anyone ever heard of MASTER POWER turbines?
- Tuning for open downpipe...??
- Beefing Up D15 for turbo (cant post in FI)
- Chipping a P28 ECU
- 750 cc Injectors ---> Max HP?
- My car had the hiccups...among other things...help?
- At idle i can feel exhaust gas coming from my Tial WG...
- B18B injectors
- Add me to the 400hp club
- what diameter exhaust for turbo LS @ 7lbs?
- 2.5 or 3
- Any how-to's out there on a DIY (piece by piece vs. complete kit) turbo setup?
- Honda Civic Hybrid
- Hondata real-time programming using eprom emulators...
- Anyone with 1st gen CRUSHED DSM BOV?
- white smoke
- Fully built B20 turbo
- hows ssautochromes products
- isuzu trooper
- New to forum.....Help on Turbo Set-up???
- stock b18b with basic jrsc kit. help asap : )
- SS sources? Race Muffler Choices?
- Oil Line Distribution Block
- Do you have noisy injectors???
- Whats your leakdown %? Ring Gap?
- Is 2" piping too small?
- What is the easiest way to get alternator pully off 99 si with JRSC installed?
- AEM/DC Civic Si pics and Dyno
