View Full Version : Forced Induction
- Noob question: Is there a way to bleed off boost based on engine RPM?
- calling all t3/t4e guys and gals
- DSM BOV and STD Manifold
- OT- Best DSM forums?
- what are my turbo ?... (stupid question:/ )
- Wastegate dumping? Is there any advantage...
- will i be able to sell these 720cc injectors?
- im mad!!
- timing and EGT's
- should i do my own pnp?
- Cleaning out a used built motor we got.......
- FI fuel management
- FI noob question. What is a crushed BOV
- Just got back from the dyno
- my car at the track, thanks guys
- *AFC Hack* After issues.....running good
- ok now im pissed itr or gsr camshaft?did a search
- How will car run untuned?
- Field & RC 440's
- artturbo and doughboy,theres two sides to every story
- thinking to turbo my R...
- what is the proper way to bleed the cooling system?
- Limitations B18a with ARP rod bolts and block guard
- I'm now one of you! Almost..
- Built bottom to boost 12 psi?
- can't find this damn fitting and it's killing me*ARGH*
- Need help with Tial BOV
- fixing weak point on honda tranny
- I am pissed and all my friends are in here so I posted in here.. bleh
- $115 for wideband o2 sensor shipped(group buy info here)
- Recommended Shops in VA/DC/MD to bore a GE Sleeved block?
- H22A fuel pump upgrade for B16a
- q on profec b with deltagate
- NOS owns j00. All of you. Here is the graph.
- our day at the track, some good info for everyone.
- Boosting on 15 pounds DAILY and 20 POUNDS race which fuel components and SETTINGS
- Used Greddy Turbo Kit?
- Which Sleeves would u Think will Hold More Boost Darton our Golden E
- ATTN. orange county backyard mechanics
- The straw that broke the camels back...
- How can you tell a real JG built head???
- turbo questions for 1992 Civic with BUILT H22
- I did a comp test today...sound good?
- Nitrous question (dump tube)??
- ?s on cylinder head porting "Technical"
- b18b to 14b manifold
- Overheating. Car seems to EAT COOLANT.....
- Question for the High Altitude People
- T3 upgrade to an Hybrid?
- Tial BOV??
- Whats a good size Street Daily Driven turbo?
- Last night being turbo--BURNOUT!
- DSM Injectors what if......
- noise????
- Fuel pump
- Thicker d16y8 head gasket? help!
- FPR on ZEX kit, help
- Hasport ecu chips
- Help whats going on AFC HAck
- WTB D series Manifolds
- Prices on PWR Water-to-Air barrel intercoolers..in stock now
- How Much Can Honda Stock Internals Take ?
- Dumb EBL question
- wastegate question
- F-max vs drag
- garrett turbo??
- ... diy mbc with a deltagate wastegate
- Do you think $300 is a fair price on a used Revhard IC (30X8X3.5) in good condition?
- who makes venom injectors?
- Which Flywheel for boosttt.. 7-12psi.. Fidanza or clutchmasters?
- Who has JG/Edlebrock Intake Manifolds IN STOCK RIGHT NOW?!
- size of tires...
- AVCR Boost Setting Q's
- RevHard Mfg Prelude 96-01 turbo kit .(new release)
- boost gauge? 0 at idle?
- An update on the Supra truck (pics)
- What hp my Should my B16a1 w/ T03/04 Turbo Run @ 8 Lbs psi
- Am i out of Turbo effeciency
- afc hack and boost questions (even after a search)...long...
- Apexi WS for turbo b18b?
- zip:question on smc?
- Who has the highest...
- wide band o2 sensor where to buy
- anybody know where to buy quik disconnect fuel fittings?
- I hate these types of ?'s but i need your input
- Pics of my Goodies and Car in shop
- RC550's Question Part # I was sent the wrong ones
- Walbro in tank fuel pump question plus in line question
- need help finding an intercooler
- Electric supercrap...
- The Official -- I want a free SMC thread
- Cam gear settings?
- HELP - Turbo 96 Lude Si, which missing link MAP bypass valve needed?
- Anyone try or think of this? dynamat your car with 3" exhaust...
- Turbo Questions
- Quick Question.....HP capability of 2" charge piping?
- intercooler question
- Electromotive TEC 3
- how acurate is is the temp gauge
- Coolant lines necessary?
- Dyno Day in the Tri-State Area!!!!
- How many PSI is the Tial .65bar wastegate?
- doing track burnouts in second gear?????
- Back from the dyno.....
- Looking for a Used XS engineering GTR intercooler
- what is better Golden Eagle Sleeves our Darton Solid Deck Sleeves
- JRSC question
- With 8 lbs of boost, what are the most efficient injectors?
- To big of an injector to run with stock ECU?
- Anyone have a J&S classic w/ monitor FS ?
- anybody selling their FMIC
- Whats the average turbo to put on a b18?
- Hot off the UPS truck!!
- 2 1/4" IC pipes?
- Compressor housing plug
- What plugs should I use? SOHC V-tec turbo?
- T3 flange question??
- new pistons and rings how bad?
- Boost Gauges
- Best place to buy a J&S Knock Guard
- F series turbo manifolds
- What A:F do stock turbo cars run in boost?
- Turbo Timer Install Question
- What is the highest whp car with the Inline pro setup and stock block?
- Street legal greddy turbo kit.
- 85mm b18b
- So where should the probe for my DIY wb go?
- Question for you guys
- Anyone use the Thermal Stelth 3" exhaust?
- My ITR Intercooler Pics...
- Any Hondata guys, please look here.
- intank AND inline ???
- Quick AFC Hack questions...
- Went to the track, not sure if my time is good or not?(pics)
- Really weird turbo question ... !?!?!?
- where can i get a inline pro head gasket??
- FS: Greddy Turbo Timer $110shipped
- I want to see pics of 3" exhaust systems on the car
- new dyno #'s
- Can someone explain "bracing" an equal length manifold
- Blarg, Overheating?
- air/fuel guage not working...
- Q's on shaft play...
- How long will a turbo last?
- anyone tired sds em-4 yet??
- JG Manifold Dynoed on NA B20
- Is it OK to put in my DSM 450cc's before adding boost?
- Air Fuel Ratio or EGT which one?
- CA gasoline
- my ERS (eibach race springs) and Tig welded cromoly subframe diving board
- Yay! I blew my a/c line
- quick N2O question
- toyota ct-26 turbo?
- went to track tonight
- H23 gude strip cams with turbo
- can you add fuel by using a S-AFC
- ballistic? yay or nay?
- BIG SC PROB before track day!!
- How free is the turbine suppose to spin???
- Got sick of my Thermal 3" being too loud...
- JRSC Problem
- b18b and b16 exhaust ports...easy question
- 10.1 too high?
- My Day at the track.
- I NEED HELP!!! Electrical Problem.....
- biggest n2o shot from a single nozzle
- First Born for data logger!!!
- GB: JE pistons $500 shipped
- Hondata + intronics emulator.
- DSM BOV opinions; anyone use it?
- gtr size core 24x11x3 is this overkill on a built to the tilt sohc?running aprx 12 street 20 track
- quick question a/f gauge\purple wire
- need some help with dsm injectors.
- North Cali Turbo Intall help? $$$
- Pics of my turbo!
- turbo civic goes to texas...
- water to air in steet driven car
- V-AFC hack or Hondata 2b? can't decide, need intelligent H-T opinions...
- When you check CEL and......
- wat is needed to retard my timing
- help with turbo ls oil pan
- oil burning blue smoking HELP
- Guess WTF happened to me on the way home from school today?!
- Are the RC 550 Injectors sufficient for this set up?
- Anyone need an intercooler
- Help me settle disagreement......(hondata)
- AEM intake specials
- Pics of my boosted EF, almost done; take a look...
- h22a turbo hatch is it possible?
- Zdyne Injector Seals For DSM Injectors
- JG intake manifold???
- JG ductile sleeves???
- Please help, is this normal
- blown head gasket?
- CAI or Short
- Just got back from meeting art(artTurbo) Chris(direp972) and John(VaporTrail) at the dyno
- 3" exhaust or bigger??
- Injectors for sale in clasifieds section
- What is Step Deck?
- turbo rookie here really need some informationplease
- How well will dsm 390's work .....
- FS: Autometer Boost/VAC gauge...Cheap if you ask me...
- Spark Plugs
- diff between greddyturbo and t-3 from from rev
- Hondata Customer care..........
- Couple of pics for you to enjoy...no they're not of me naked, sorry :P
- Thanks Viren for making my car more bearable!
- Does anyone know of any website that have info about...
- Uh Oh.. like I don't have enough issues!!!
- Need faster spoolup..
- This sounds a little fishy to me... what do you guys think?
- who can I order arias piston rings through?
- Challenge To all FI members
- Fully built race motor for sale:
- who here has done the DIY wideband O2
- How hard to do v-afc hack?
- who has the fastest all stock LS quarter mile time
- AEM EMS Base map for b18b with 3barSensor..
- str outta business cmon now!!!!!!!!!!!!!
- oil feed line questions....did search already
- *** 97 b18b turbo crx...what ECU??***
- can turbocharging hurt engine life?
- Getting an idea of what I *might* sell my turbo kit for....Please help.
- Oil in my coolant system?
- PWR Air to water ICs make POWER !!!!
- everythings stock
- cometic headgasket
- Is VTEC noticeable on your supercharged GSR?
- Does a Bigger IC allow me to boost more????????? EGT gauge Q's---too much boost? lots o q's
- Cel Code 71, 74
- FS: NEW Garrett GT30 Ballistic Ball-Bearing Turbo (with Ceramic Coated Turbine)
- Supercharge a 97gsr
- I love hondata
- HELP striped the nut on turbo exhaust outlet!! shit!
- question on custom turbo kit
- GB:turbo mani's real cheap
- s-AFC or B Profec.. whats more important
- anyone tried the fmic's made by homemadeturbo.com??
- apexi EGT gauge.....probe?
- What size shot can a b18b take safely/reliably on stock internals?
- JRSC'd GSR + ITR exaust??
- Electirc blower question......
- Map sensor for HONDATA 4b....
- quick questions about MSD 6BTM
- Turbo D15B2 any suggestions
- Finally boosted... Lots of pix!
- Engine Setups for 97 Prelude SH???
- OT- My father and I made this diy turbo kit for his miata!!
- Finally got my engine back....
- sleeving???
