View Full Version : Forced Induction
- exhaust
- 600+whp goal.... Suggestion on fuel system upgrades
- gt3255 on my SOHC. HAPPY TURKEY DAY!
- steel braided or high temp hose?
- boost question
- 60-1 on d16z6
- Not a honduh any more but she's boosted!
- AMR Coilovers
- Got a few turbo questions.
- suggestions on my engine build ?
- tial wastegate question...
- reusing valve guides
- 4294r 0r 4202r
- supercharged civic
- supercharged civic.....
- someone clear this up . Greddy T25 flange . what fits on it?
- srp 81.5 pistons can i still use them
- turbo manifold
- New Main Caps for a Sleeved Block, Pro-Help Requested
- considering boost...need some input
- Getting a Gs-R in the 14's
- B18A/B B20B/Z Non-Vtec Supercharger Power?
- Need turbo rebuild kit turbonetics 60-1
- full race gt35r
- debating turbos...my 500-600whp build.
- Boosted ECU choice
- Best way to break in this motor?
- full race gt4088r
- compression vs boost
- MSD 6BTM retarding timing with boost
- Eagle rods spun a bearing. Rads still usable? Pics inside.
- civic pistons
- which ecu can be chipsed ?
- NEED YOUR SUPPORT
- skunk2 turbo exhaust 70mm
- Did I blow my motor?
- gsr vs lsvtec dilema need help
- ebay axles??
- Are D series Greddy turbo manifolds interchangeable?
- boosting an ls, help me pick a snail
- Big Throttle Body (H22)
- another Nitrous and boost thread
- Need Help with greddy Type RS
- Boosted stock B16a
- Greddy 18G Bolt on Kit!
- b20 or b18
- Beginner question: Info appreciated
- 400+whp .. D-Series .. check in here!!
- Need Tuned , Live in Central Iowa.
- SRP's with coating? or no coating. good idea, or bad idea?
- did a WOT pull and checked my plugs
- Driving without a hood for about 10 miles ok if im runnin turbo w/o a filter?
- lookin for 250whp+ out of a turbo h22a4
- Silicone Connectors - Bulk Quantities ?
- Using the boost control feature on an aem ems to control a VNT stepper motor
- AEM EMS Question with Uego
- Intercooler Piping Help, what kind of drag will come from this
- simple B16 or B18
- is there suppose to be a gap at the bottom of the wg valve?
- turbo ls/vtec questions?? which kit??
- Walbro 255 In-tank fuel pump question
- TD Autowerkes 4 inch Aluminum Exhaust, Child-proof
- Who is building custom turbo manifolds in the new england area?
- B18c1 low comp pistons
- Turbo Installation Help
- eBay turbo kits
- turbo oil feed line
- TURBO INFO
- Axles
- Wideband question
- tial 38mm wastegate HELP!!!!!!
- Low Compression + Emissions
- H22 head TROUBLES???
- h22 trans with boost
- h22 with 100 shot of nitrous
- Car gets 11 psi with 5 psi spring !
- Turbo GSR question: no vtec?
- Engine turbo dillema... please help
- what do you guys think about manaul boost controllers?
- Cams?
- FPR
- b18b
- gt35r or gt40 for B16 ??
- Removing stock valve cover breather and tapping for NPT-AN fitting...What size?
- ls/vtec
- crx RamHorn custom fit?
- Turbo Ram Air effect?
- AXLES who makes the best for the D series
- Which do you prefer?
- what is this set up capable of
- brake boost?
- dyno sheet, need opinions why it looks this way?
- what are some good parts sites?
- Pictures of a viper/ferrari/vtec/whatever killer
- do the full race t3/67 HO utilize T31 back housings?
- Homemade turbo kits?
- Quick Question: Installing ARP head studs....metal sleeves?
- any one get cel 1 after a lil bit of boost?
- Looking for opinions on OBD 0 Engine Management
- good Or bad Turbo setup
- a weird question???
- turbo question.
- How safe is this set up?
- Broke E-mount bolt off in block... Suggestions on removal?
- vtec issue cel 21
- turbo setup question
- Question about injectors
- gt28r or gt30r for daily driving
- Question about turbo return flange.
- crazy Honda civic with b18c engine,GT35/40
- hondata adjustments
- sludge build up?
- DIY Port and polish....
- 240cc injectors for a turbo'd D14A4 with crome?
- Anyone good with MAP's?
- Is 10 to 11 A/F ratio too conservative???
- NEED HELP
- What clutch/flywheel combo to go with for a max of 250whp on a D16Z6
- Saw a boosted integra video clip, it sounded like a v8
- So i went to get my car emissioned for shits and giggles with no cat
- SFWD turbo limit size??? 72mm inducer?
- oil sandwich adapter
- Blitz sbc single stage controller. peak and hold?
- oil drain way below oil level but it dont smoke? why
- Internally gated questions
- Brand New Turbo - Smoking Already?
- would any "T" series garret turbo kit work with my drag kit?
- adding velocity stack on inlet pipe
- ignition map
- Devil's Own on a JRSC...before TB or in manifold??
- Turbo Trims
- Ordering a top-mount... Ordering from One-Fab... they any good?
- bent valves?
- Anybody heard of Custom Car Care in Hampton, VA?
- have a few questions b16 jackson racing install
- resistor box
- Most convenient place to buy Plastigauge kits?
- Someone please help me out about NG
- building for boost question
- B serie oil pump gears Q?
- 225 BF Drag radials..
- fuel lines..
- How to take apart turbosmart ultra-gate??
- Need help with a jrsc belt question?
- help with build?
- How many people are pushing over 450whp on a T3/T04E turbo
- noobie question
- show me your 14b setups!!
- gt35r and T3/T66 HO vs. GT40r
- Reading Boost
- just got turbo kit done. couple ??'s
- blow off valves
- need info td05h 18g
- Max bore for b18 ls turbo...?
- PLease look and advise 01 Turbo GSR
- is it ok to drive with larger injectors and stock ecu for a little bit?
- Help! Car Smoking From Oil Breather And Exhaust BaD!
- 98 GSR Chare Pipe Specs
- The PM6
- T3/T4 wastegate issue. Too much boost.
- Replacing precision injector seals?
- Should I buy these used Wiseco 81mm pistons? *HUGE PICS, 56k = FUBAR*
- exhaust manfold bolt size
- Question about the Tial flanges...
- Running wb 02 w/o gauge
- manley piston...
- H22 Catch Can: Draining oil back to the block?
- general tuning question about boost when compared to load and temperature
- How can I convert a T3 A/R .48 to handle more power?
- what do you think of this setup?
- electronic boost controller...
- best burner?
- does d-series manifold fit on a b-series??
- melted piston/timing question
- ITR 4.7 LSD Tranny good or bad for boost? Drag
- Stud Size Please
- Tilton Hydrolic Release Questions..
- WATCH OUT!
- blox
- Where to get 92b18a block resleeved and bored
- How do you know when rocker arms are bad?
- Turbo questions, please help
- Heres what happens when u have no oil
- code 9 cel help!!!!
- Ceramic JRSC
- PSI relitivity to Sleeves & piston compression
- Need input/tech advice.. using nitrous with jackson racing supercharger...
- Help! Greddy Turbo SOHC sputtering.....
- h22 turbo
- Chris Rado's Time Attack tC w/ the Borg Warner S200
- bending back intercooler fins?
- where to tap in a boost gauge??
- ** The E85 Thread **
- Recomendation for turbo
- how much are je total seal piston ring set
- gt35 non-ball bearing on a 2.3 liter... opinions wanted.
- EGT-differences between the four cylinders - how much?
- can someone show me where to mount manual boost controller
- SUPERCHARGER OR TURBO?
- eg pipping fit ek
- Trouble with dsm injecters
- Methanol Injection good or bad for turbo b16
- Guide to Buy a FI Vehicle
- greddy emanage
- quick resistor box question
- s300 launch control (2-step)
- No front motor mount + engine dampener = OK??
- Intercooler u bend for hot side.
- how much boost can i run on stock internals?
- How do I know what kind of turbo this is
- Fmu or fpr or both?
- first vitara setup?
- FS: BRAND NEW APEX GT INTERCOOLER ... 534-KH01
- which egt gauge should i get that will work with my LM1 + rpm converter ?
- Quick, need some opinions on this turbo
- stock transmission sounds like a dog box
- FULL RACE... Full of BS
- greddy boost gauges question
- Sleeved B18C1 block problem *pics inside*
- turbo install torquing specs?
- b16 with sc34
- BOGGING at low rpm...HELP
- t25 exhaust stud broken need help
- D16z6 catch can question.......
- Surviving A Boost Spike
- Garret T3 Flanged Inlets? where to buy Flanged pipe?
- injector question
- Alternator Belt problem with 400+whp cars
- Turbo D16 overheating...
- '95 b18b in a '94 civic...
- am i gapping my plugs right?
- Canadian members... Any good sleeved block suppliers?
- chipping questions
- bewm biatch....pics of a blown up d series inside
- WHAT AM I MISSING??
- get the bosch 044 or walbro 255hp
- Exedy Stage 2 clutch
- CP pistons + stock rods?
- Need Some Help Please
- QTP E-Cutout
- New Clutch... 300 hp MAX...what would you pick!
- Stock B16 bottom @ 10psi ??
- Need some wide band help
- question about a cast manifold I just bought....
- Injector Resistor Box?
- S2000 turbo manifold options
- Question turbo Hole????
- turbo d bogs out.. help
- Hondata question
- 400hp is the goal
