View Full Version : Forced Induction
- Injectors
- Drag kit gen 3 intall help on B series
- wtb 57 to 63 trim turbo
- Zex cam install, clicking lifters?
- turbo seal leaking oil
- Del Sol radiator vs Koyo/Fluidyne/Pwr
- Engine Blowing Code: High Circuit Input IAT
- 500 hp?
- Will these RC 550cc injectors work on a GSR?
- I've decided to turbo. Any turbo DB2's out there?
- What size allen are the freeze plugs?
- Just did compression test....
- Help with injector size
- What could it be?
- anyone have a basemap for an H22A supercharged?
- Is factory oil pressure sensor needed if running aftermarket sensor.
- extra oil...
- Mahle Slugs In The H22
- breack out like iF i was running open Boos
- uberdata, turbocharged
- What Intake mani/throttlebody
- REQUEST: Substitue these links with the same stuff but for cheaper, lol...
- I Found a GOOD eBay Turbo Kit?
- 38mm wastegate good for 600whp
- Boosting F22 Auto. Questions...
- How do you install a turbo on a K series car? from the bottom?
- witch injectors for t25 ?
- Switching from dsm 450s to precision 780s = clips dont fit?
- WANT TO SEE: Some SOHC turbo setups with AC and PS!
- Will Crower 404 on b18b good for JRSC????
- Fidanza Flywheel with boost?
- jacobs mastermind wiring
- pi-thon hose clamps
- oil feed idea -- need comments/critique/suggestions
- turbo gsr: Oil keeps repeatedly gettin on sparkplugs
- Revhard Stage II turbo kit installed
- can coolant cause 3-3.5k idle?
- Individual EGT 4 for each runner? Fine Tuning?
- Fuel Delivery: higher fuel pressure, or longer pulse width?
- does tube from valve cover...
- *JDM* SARD turbo timer
- Greddy KIt
- Oil Line Kit suggestion...
- Dumptube Bends: Mandrel vs. Crushed
- turbo price
- remote turbo(non-honda)
- white smoke after driving (built engine)
- Turbo kit or scrap together a kit
- Any Skyline Guys in here Need some advice
- Is this a needed item on an h22 engine? Cooling
- spoon n1 exhaust + 3 inch piping?
- question about adding timming and spark plug heat range.
- Turbo suggestions for my setup...
- Dual stage boost controller and your tune?
- golden eagle sleeving cost?
- Do I really need a block guard???
- Why does my spark plug insulators keep cracking?
- can The Stock Type R Hold 10lbs Boost
- Anybody use JB Weld...
- Fuel setup for 650-700 hp??Post Pics!!
- Where to get turbo rebuilt?
- greddy turbo lude 12lb boost?
- 670whp Talon Video
- Another Ebay turbo question, blah blah blah...
- Going to Junkyard: Cars I can get a T3, 4-bolt outlet turbo from?
- can you run a 90degrees silicone coupler off the turbo??????
- what turbo is good for my set up???
- Boost Creep!
- Compressor Surge!
- how much boost
- Nitrous Problems
- quaife lsd install question
- class action lawsuit against one-fab
- OBX oil pan????
- What do you guys think about the Turbo XS manifold?
- Drag manifold crack...
- Question concerning new HKS SSQ Valve...
- RUNNING NO DUMPTUBE............. KILLING PERFORMANCE???
- forged pistons bi6a b16b question
- B18C1 EK Coupe 1/4 mile
- proper gauge readings?
- Where can I find a "I LOVE MY HONDA" shirt?
- Breakin off a 2.0L ls/vtec
- need help getting turbo ready
- Vortech Superchager on a B20B
- Dumptube question..
- Few questions about boosting an H22
- Secondary Butterfly Question/Theory
- can a b20b run 7-8 psi reliably for daily driving???
- Hondata 2B?
- Injectors RC 440 help
- turbo specialties turbos
- f23a1 good for turbo?
- best muffler for turbo?
- Greddy Blue Box HELP!!
- Ebay manual dual stage boost controller?????
- meutek manis?
- auto tranny?
- Inline Pro T3 manifold with 3" DP??? Can it be done???
- best/cheapest oil lines
- JRSC for GSR - Intake Manifold?
- uberdata tuning in nashville tn area???
- May be an odd topic, Turbosmart Boost Solonoid Wavelength?
- Intercooler size for integra
- Got the car street tuned tonight
- rebuilding a turbo
- c16 race gas in miami?
- what type of nitrous kit to go with, with boost
- question about the Turbo smart MBC
- Good turbo for D16?
- confused b18b
- Manley rod Breaks
- hondata blue box wtf does it do???
- Help Please! JRSC Bypass Valve Seal Torn?
- street cars. top mounted daily drivers
- turbo tuning in chicago
- ls t super afc settings
- block threads stripped...
- What do I do with this? Blocking off = cant idle + misc. wastegate lines questions
- Anyone heard from Stan (Flamenco-T) or Fast-Turbo?
- no power under 3k ? (t25 crx)
- Moroso GSR Oil Pan
- My new car
- Cylinder #1 Not Running - Got Spark/Fuel/Timing - Pull Plug Up And Its Perfect? Why?
- tdo5h turbo coolant lines
- Skunk 2 Stage 2 Cams For Turbo.
- Tuning in Missouri? Are there any shops that tune in missouri KC STL???
- Cranks & Displacement, how do they effect spool up time? (motor builders needed)
- smoking exhaust housing
- Open Downpipe problems.......
- greddy type s bov
- EGT placement
- Turbocharging my 96 HX?
- 97 GSR (dead spot in RPM)problem
- problem with str cam gears
- turbo filter sizing
- Anyone tried the AUTOTUNE on the S300
- where is this vac line going from the GM 3bar map?
- NOOB BOV ?
- Questions for Turbo XS MBC users
- B16 turbo setup
- HKS Supercharger for ZC?
- What does hondata do?
- HELP!!
- ATS 4.929 FD too high for boosted cars?
- Disabled O2 sensor but still CEL code #1 pops up
- boosting problems
- Crx Sounds Like A CHOPPER!!! Why? No power, Fresh Rebuild. Exhaust sounds way to choppy
- quick vacuum/boost question (searched)
- SuperCharger squeal...
- need a quick answer
- oil pump?
- 750s maxed out at 320 hp
- top mount turbo?
- low oil pressure after hard boosting >>
- How to reset TPS?
- looking for b-series low boost gt30 (all variants) dyno graphs
- to go T25 or to go t3/t4. that is the question!
- Help me build a nice street/strip SOHC Turbo
- CRX Owners post your setup here!
- 250whp out of a kit?
- wich ecu tu run in my car?
- wireing a areomotive fuel pump / aftermarket pumps
- is this fixable??? t3 turbo
- Hondata S300
- Can we say Full-Race Time ??
- Can I fit a 3" downpipe. PICS included.
- TPS info needed
- Golden Eagle head studs ???
- Ladysman Update...Finally done for now....SOHC build.. 56k, go get food...lol
- stupid....MAP sensor....problems inside
- Who sells synchronizers other then Gear-Speed.com
- Kill Switch in an EG w/ a Turbo Timer
- What Grade Motor Oil?
- is this a myth or a fact?
- Finally some dyno numbers - 424whp / 365wtq SOHC D16y8 >>
- Car does not boost
- How do I install a misinglink on a 90-93 integra ?
- How many rpms with built lsvtec
- greddy bov
- Tricks of the Emissions Trade...OBDII -> OBDI users
- Kteller or Burns resonator
- Noob question about boost contoller/ wastgate relationship
- Turbo Civic D-series, need advice on 1800 mile trip
- Precision SC50 .48 a/r turbo on a GSR...powerband?
- my wastegate is not opening
- need help no boost
- post pics of your turbontetics delagate
- Nitrous h22
- G1 Integra: Boosted B16 problems
- Internal Wastegate Blockoff on Borg Warner
- Building Head Questions??Skunk2 or Ferra??
- What is the most HP you have seen on a Drag mani???
- How could I have possibly burned my piston rings????
- questions about my whp numbers
- curious about my whp numbers....
- i want to paint my intercooler what is the best way?
- Has anyone seen substanial hp gain from a drag mani to a equal length ram horm manifold?
- BOV help...new tuner here
- Best Method to hook up the wideband to the hondata??
- map sensor??missing link?? Help
- Boost reading 2psi?
- Help with turbo calculator numbers for LS turbo
- Need Tuning Advice (Which EMS?)
- Just need to know alittle more about turbo..
- how can i be sure what I have are wiseco's?
- Questions on some turbo kits.
- turbo vacuum lines?
- Turbo Seal / Oil on Spark Plugs
- HKS SSQV with recirculation
- Thinking about getting coated
- Missing link?? Help
- Cooling efficiency
- Turbo build project help
- gt30 compressor housing inlet?
- Throttle Body / Throttle Cable Issues * Pics of your throttlebodies requested *
- clevite bearings
- Internal Vs. External wastegate
- What Size Vacuum Lines and Tee's for Boost?
- T3/T4 B16 turbo setup, need help!
- how much hp on stock ls axles?
- Wich bearings?
- yet another exhaust/cat question
- Who is running blandar tune
- just a small question
- personal reviews from the ssac or xs racing please
- Look at this setup on the QuakerState car at ETown yesterday!!! I have a FI question
- Will back pressure blow something? ( searched )
- turbo prelude help
- OEM/Budget boost build: B18C GSR/ITR pistons in a B16A.. Hypereutectic/Coated vs Forged
- huge intercooler mounting
- Opionions NX incognito kit
- will a 93 YS1 flywheel work with my b16 tranny?
- Hose from valve cover to intake pipe?
- toughest but most driveable clutch for d16?
- OS Giken Clutch price
- how do i adjust apexi twin chamber bov?
- 536whp/349wtq Dyno Video & Sheets of a customers ls/vtec stock sleeve sc61 - Phearable.net Tuned
- The best connection for AVCR
- Need opinions
- Got the turbo in--and it runs (wow)
- Drag Kit on GSR motor
- NEED SOME HELP!!!!!
- turbo and supercharger
- Boosted GSR and Drivability/Traction
- Aluminum flywheel?
- Tuning Complications with Crome
- need to get rid of fuel cut for increased redline.
- 630whp and 390tq on b16 with T3 sc61 and.......
- Snapped some shots + small video of 3rd g3Ar b00sted y0!
