View Full Version : Forced Induction
- code 15 appearing after wiring in MSD 6 AL box, standard honda internal coil
- Water cooled turbos
- MY car got idling problem (need some advise)
- OBX TURBO????
- IAT sensor relocation
- bolt patteren
- Who here has done the TurboPanda Piston/Rod combo for the D16? Also have info.....
- turbo impellers
- 200 whp enough?
- Garrett T3 ~"45" trim
- help! switched to aem wideband gauge type controller...
- expolitedracing manifol, megan racing and first time booster
- Drag III Kit want to upgrade to InlinePro T3 Manifold, Can I still use My downpipe?
- Oil feed and return lines
- AFC or Autometer Gauge? Whats right?
- Turbo H22 Got some questions
- catch can for d series
- WASTEGATE SPRING, NEEDED???
- 1st gen Eclipse BOV ???
- vacumm lines on da turbo
- Techedge 2.0 WB questions...
- ATTN: High HP B series setups...Knock sensor, and Hondata...
- Siemen Deka Injectors
- Turbo install in the LA area?
- JRSC part question
- turbo accord
- Head Gasket
- I need oppinions.
- Re-use the head-gasket?
- WOULD A B16 HEAD/GSR BLOCK BE GOOD FOR TURBO ?????
- full race manifold fitiment questions
- ECU chip burning question.
- GReddy kit: is it new or old? (searched)
- gsr turbo kit fit LS
- Installation of Z10 breather kit- ?question?
- Cant break a crower rod eh?
- 450 hp on pump gas??
- hose clamps...
- Good machine shop in central Fl
- When good oil pumps go bad..A parents heartbreak
- i searched all ready but i got a exhaust question???????????????????
- Torque Specs for Crower Rods
- Looking for best price: 3-Bar Map Sensor
- precision injectors
- Anybody have a part number for the garrett TS04 .70 ar compressor housing?
- Dishwashing block?
- Need a reputable head porter.
- 91 b16a with turbo can I keep AC?
- Oil Return Line
- DOHC ZC COMPRESSION
- Track numbers
- Street Tuning
- intercooler mounting question
- Bogging?
- LOOK at my injectors...quick question!!!
- BYE BYE PISTON
- revhard kit....retard timing in my case?
- building and porting a head in dfw
- injectors???
- B18B, forged internals, stock sleeves. Limit on 93 pump gas?
- Water temp sensor.
- need help w/ turbo install.... FRESNO!
- Tuning AEM EMS w/o wideband?
- Split in Wastegate diaphram
- my birthday came...so did I *56k warning*
- Skunk2 valvetrain good enough for turbo???
- Getting head built?
- Best Plug for 550+
- Do I need MSD or can I use stock ignition??
- Am I the only one that thinks there is something wrong with these pictures??
- B16 Turbo Questions
- DSM Injectors in 6th gen Accord?
- Hybrid turbo. T3/26 (KKK K26+saab t3)??????
- Which Injectors for b18b TURBO????
- Has anyone installe the ENDYN block breather kit while the engine is still in the car?
- Do you think I should be fine with this set up?
- Idle issues. Please give suggestions
- air to air intercoolers under the hood....
- where to get a VORTECH Supercharger for Integra Type R ?!
- ARP eagle rod bolt (free length)
- What Turbo kit to get?
- will theese work???
- greddy install, mil on (searched, no luck) help.....
- FMU & intercooler/piping suggestions > DSM turbo f22 prelude
- I have a spare y7 and a little money.. exospeed?
- Need help with piping dimensions for drag intercooler - need drag piping dimensions
- important question about Cltchmasters Stage4
- Good Buy??
- AFfects of installing the Walbro 255 LPH HP Pump While still stock?
- Well I guess it was bound to happen one day... (R.I.P "freak" B18C1)
- finally boosted but my car wants to explode, please help me out!!!!
- VW TDI owner here - need information on turbocharging a '95 Integra RS
- exhaust question for boosting.....
- so who makes a A/C combatiable D series mani??
- Built z6???.
- Denso Part # Are these the right ones?
- DSM SMIC install on a 5th gen civic
- piston + rods combo
- Thanks goes out to Adam with the TurboCRX...
- SUPERCHARGER QUESTION
- Hack without boost?
- Someone tell me how much hp you can pull out of a crv/vtec 2.0
- What kinda injectors are these? They look pretty big
- My Setup (Feedback Welcomed, Be Nice)
- LS Head question with turbo, is it worth it???
- Top 20 basic tech Questions on .....CYLINDER HEAD PORTING
- I need endtanks put on my IC core in Central FL, PLEASE
- Coolant Lines For Turbo
- Boosted Motor. How to Check total timing advance?
- HELP WITH A B18B TURBO SWAP
- Low compression motor drivability
- step on brakes, electrical power loss?
- what flange for my turbo??
- Builders in CT/MA
- Tuning Emanage
- problem with DRAG turbo kit
- last minute info...
- Quick MBC Question
- Wastegate problem Non-Honda
- My turbo setup!
- check engine light
- Inline Pro Rods???????
- Installed a walbro 255, things are going wrong..
- does anyone make an air to air intercooler like this?
- Drag manifold question??????????????????????????????
- What to do about clutch, wasted money $$ (kind of)
- d series questions
- Which camshaft specs are best for TURBOCHARGING.
- How to strip paint off intercooler?
- Problem with detonating, have any ideas?
- Silicone or Nitrile?
- Can someone explain timing advance with safc?
- JG Victor X IM inlet size...
- Has anyone bought any mandrel piping from this place?
- SETUP Pics!!!!!!56k warning !!!!!!!
- Fuel Maps bulletin forum?
- Opinions: Fried ECU or Bad Basemap
- come one come all (boosted h22s)
- V-AFC vs Greddy Blue Box?
- pte sc34 on a6
- ***important*** sAFC + Rc 310 injector question
- PTE injectors, do the dsm ones fit our cars?
- IAT relocation cuz of nitrous?
- Who carrys Pauter RODS?
- square ports on FI setup??
- JDM b18c with how big of a wet shot??
- If I change out my valves do i have to replace valve seals?
- Should I put the turbo on?
- n2o NHRA rules
- oil feed line?
- max bore wanted on a sleeved turboed b16a
- anyone have a turbo xs rfl BOV?
- Some help with gauges
- PLEASE help problem with jrsc install civic si
- Catch can oil= really thin + smells like gas?
- Hey do you think this clutch was SLIPPING when I went to the track? Pics inside!
- ? for Turbo/Nitrous users!
- greddy 18g turbo how much power can it support? (searched already)
- guages
- can a 84.5mm headgasket be used on a 84mm bore?
- shop in Maryland to make intercooler pipes???
- Intercooler Pipe size...
- ? with my injectors
- egt or no egt. i have an aem wideband.
- Aftermarket d-series intake manifolds
- turbo size for y8
- Need Help Putting Engine Together & Turbo Kit On in Va
- How difficult is it...
- What size Precision injectors are these??
- Hondata Issue For Archive
- info on b-series engines?
- eight injector manifold...
- engine buildup, stock rods ok?
- intercooler size question?
- why do you have to hone the cylinders when you use a block guard?
- T3 question
- Quick wastegate nub question!!
- uhhhh is my profec b SPEC II solenoid supposed to do this ?!?!
- HALTUNER A/F ratio meter
- custom dp...how do you get the o2 sensor fitting?
- Golden Eagle sleeving?
- Turbo F22
- Anatomy of a Turbo
- Quick transmission question...is it worth swapping?
- Where to get Turbo port/Polished in IL? help
- Thomas Knight ESC (electric supercharger)
- SSAutoChrome needs to do its homework
- Small Turbo Problem
- 4 psi without any fuel management?
- turbo rants and oil annoyances
- "HOT ROD'S BUYERS GUIDE-PURCHASE THE RIGHT RODS THE FIRST TIME"
- Does this turbo kit look good?
- turbo weld flange
- Intake temperature sensor on B16A
- 13's in my 93 gs teg without sleeving??
- VAFC pressure reading converted to boost psi???
- ??? on full-race a/c manifold
- am i being scammed by overblownmotorsports.com??
- EK B16 Turbo People.... Charge piping/intercooler piping setups?? enlighten me....
- Which clutch disc to use??? Clutchnet, Action, Act, Centerforce
- Removing valve springs
- All D series JRSC the same? Z6 on a A6?
- precision intercooler bolt size
- what throttle bodies are you running on your H22?
- building my motor, advice needed
- Custom IC Piping for H22 Turbo Civic w/ Greddy Kit?
- afc+fmu?
- Power FC Boost Solenoid.
- how to tell if turbo is bad?
- Reasons why not to buy product from HULKHB aka www.crpturbo.com
- Anyone KNow the dimensions of the Drag Gen one Intercooler for an INtegra?
- crank pulley sizes/diameters for all honda motors?
- Bored out 2.0 B16 motor??
- Does anyone have the pulley sizes and equation to figure out jrsc boost?
- stupid dyno questions but.
- Will you do my homework for me?
- Who has cp 9to1 84.5mm pistons in stock, help
- Running NOS on a TurboCharged GSR????
- To any integras with large FMIC
- quick turbo sizing question
- n00b turbo question
- "big boost electronics" what's the best for igition??
- Please enlighten me with Fuel Pump Knowledge
- help wit abbreviations
- Best Intake Manifold for Boost? Edelbrock or ITR
- Fuel Gurus. Have a problem.
- stock b20, 550cc, how much to boost
- daily driver: cast or race?
- U.K Turbo
- this boost problem is really pissing me off man!!
- just finished....pics inside
- leak between mani and turbo???
- Setup finally done! first time boosting!
- what do you guys think about b16b turbo???
- Got my Flamenco T kit today (thanks stan) Have a few questions
- sensors and tuning
- fuel pressure booster
- Cars been in storage, now what to do when starting it back up....
- AEM Gauge-Type Wideband UEGO Controller
- Oh what a day
- lookin for the right turbo!
- help on piston size and dart block
- Got the turbo bug. Little input and help for a newb please.
- custom DP in socali?!
- i need oil feed and return line 4 set up
- "Auto Gauge" Do they make good stuff
- wth happened to "johnnyracecar.com"?
- Blitz bov flange the same as.....????
- Anyone in the NE interested in helpin me tune a car w/ Hondata?
- where to mount my 1g dsm bov
