View Full Version : Forced Induction
- Jergel's Noob turbocharged HPDE/Autocross Mayhem build
- Downpipe troubles....chime in
- EG6Noise's B16A2 - Going FI? or another route... Not sure yet. Where to start?
- TSX w/ nitrous. what ignition control?
- Turbo Inlet Filter Options
- b16a2 turbo and rebuilding
- Differential Assembly & Disassembly -Jeff Evans How-to
- How do you properly build for a turbo setup and choose the right one?
- Boost on stock f22b2
- Low Compression b16 Cams?
- B18C water cooled turbo running hot.
- Is it possible for a GTA2256V turbine housing to be used on standard CHRAs?
- Turbo integra : 10psi fuel pressure no start
- Boost cut engages at 3psi.
- Axle comparisons : Raxles vs. HASport vs. DSS. What's your pleasure ?
- Boost controller set up and vacuum lines
- Setup concerns:. LS/VTEC Turbo High Compression Build pendiing
- BIG Boost D16y8 build - ARP 1/2” head stud question
- Troubleshooting: 95 Prelude H23/H22 - Map sensor error?
- Anyone Have Experience With JUN Camshafts?
- Product Feedback request: Compstar B18c rods from Callies - Good for 800whp?
- Assistance Needed: Unknown Garrett Turbocharger identification
- Question: what components make up a well-designed fuel system for FI?
- Troubleshooting: Unknown Garrett Turbocharger - How will I know it's capabilities?
- BoostedHatchFreaks-96 Hatch Build
- cdsk8tr1's 650whp Project CRX Build thread
- GT45 Turbo on a CSS B18C5 block... Anyone want to gamble on how it'll do?
- GT28RS or GT3076? B18c1 91oct No track days, no autocross, and no drag racing;
- Top Mount GT28RS? what age you're thoughts about a setup like this?
- B20 w/ STC Hunter...AWD
- More noob? Cr-v turbo build
- PCV simplest method on B16? and smoke on new install
- Big exhaust leak from turbo hotside
- Which AN 6/8/10 fuel pump match for D16y8 ZC
- Experience of Hondata traction control on B18 Turbo (or any high power motor 600whp+)
- Question about wiseco pistons and head gasket
- How much power gt35 b16 8psi?
- Any of those Running Fluidamper or ATI
- Product Feedback Needed: D15Z1 roller cam use with Bisi's 3.6 D16Y8 camshaft
- calling JDM front integra with boost; asking for FMIC fitment
- KilowattBandit's needs suggestions for a Turbo B18C1/5
- Timbo74 Needs advise on a BB6 Prelude w/ JDM F20B (turbo?) set up
- ARP CA625+ Evo Headstuds in a b series
- Assistance Needed: Fotis2000 Intercooler End Tank creation. Suggestions welcome.
- Oil in Exhaust Port?
- Supertech valvetrain for boost
- Oil catch can from valve cover breather (Turbo)
- Wanting to turbo My EK VTIR civic
- Waste gate hook up/ general ?s
- Troubleshooting: CNC WERX CSS B18C1 has inconsistent cylinder compression #s
- Thoughts, Opinions, Input, on extreme carbon build-up on this setup
- Parts Opinion & Feedback :Walbro 525LPH Hellcat
- what is the power capability for a stock engine B18A/B that is turbocharged?
- Best B series Turbo cams +600whp
- Troubleshooting: oil pressure unusually Low idle . Normal oil pressure when driving.
- GTX3076r coolant lines route
- User Feedback Request: Stock B20vtec turbo reliability-How durable is your build?
- Different coolant temperature readings between AEM & aftermarket gauge. why?
- Turbocharger oil feed/return & it's fittings
- Help W/ IC piping reduction 3.5" - 2.5"
- Bar and plate or delta gate intercooler.
- Advice for a turbo build: stay D-Series or?...well, yeah..
- Using OEM B-Series conrods for a turbocharged application..normal to do?
- Leplease's Stock GSR Turbo Questions
- Options needed: Single disk clutch for turbo k24/20? 400WTQ
- 1976 Honda CVCC engine Turbo swap Project: To "B", or not to "B"?
- THERMOSTAT...YES, THERMOSTAT *SOLVED*
- Knock detection for street tuning
- Drain back oil catch can setup with stock GSR IM
- GT35R to GTX35R - Made Less Power w/ Better Turbo
- Troubleshooting B18C1 Turbo has idling problems with current setup *SOLVED*
- Assistance needed: D16Z6 300whp+ daily turbo parts build list
- B18B1 psi to run with gt35
- Troubleshooting: Loss of boost pressure due 3 possibilities
- Troubleshooting: Engine will not idle properly-Used a pin to lock open VTEC lobes
- Opinions Requested: A Responsive turbocharger option for a stock bottom K24a2
- Assistance Needed:B16A Turbocharged CRX w/ inconsistent rpm under positive pressure.
- Installing skunk2 pro 1 cams. Quick settings?
- "But, an Ebay Turbo Was All I Could Afford" - learning the lesson
- Opinions Needed: Is this used JRSC for a B18c5 appear to be operational?
- Maxwellmercer-Quest for 500whp inside
- B16B Turbo Build Need Turbo Advice!
- GSRTeg02's 2000 integra GS-R's planned turbo project: Suggestions are welcome
- Help needed diagnosing low voltage in boost/ fuel pressure drop
- This used intercooler look okay?
- Can anyone help assess potential damage on this Turbo?
- What size injectors would be best for a b18a1/b1 turbo build
- Comparison of a Victor X IM vs. Skunk2 Ultra Street IM on a GTX3582R powered B16A2?
- CRX SiR Turbo Manifold Options?
- Adding a heater core to turbo coolant lines: Discuss the pros/cons
- Feedback request: B16A2 Engine utilizing the Gen 2 GTX3076R
- B-ryan has a few questions on his GS-R going turbo
- Oil Catch Can Setup for VTEC engines w/o silly -10AN Valve cover Vents
- Discuss: Using an Aisin amr500 supercharger on a D15B7. Thoughts?
- K20.ek's Fuel Pressure Regulator Turbo B-Series question??
- 98+ Spec ITR with Turbo?
- Water to Air Intercooler, Heat Exchanger, & Pump Needs
- Troubleshooting: B16 turbo has low boost pressure after installation & tuning.Causes?
- Troubleshooting: TiAL Q BoV and 38mmMVS WG issues
- B00STD wants a LOT of assistance in making a future EG Hatch Turbo build
- Seasonal and Geographical Volatility Classes for E85 Handbook is available
- 300-350hp limit on stock B18c1 - GTX2860r Gen II?
- Blox Eco-fi injectors review
- GT2860RS on a stock B18B motor?
- k24 or d16?????? advice needed
- How to install 3 port oil catch can
- Southbay Fuel Injectors? Product feedback inquiry
- finally back and running but time for an upgrade...going E85
- Troubleshooting: Engine Load "2 step" problems!
- Is using a 76mm Inducer turbo from CXRacing on a K24 engine a good idea?
- Lilskull4's B18b1 1st time turbo build thread. A lot to get to learn
- Matteggy's B18b1 Turbo Build- What are the advantages of Boring out the cylinder?
- New to Superchargers on the H22: Hmmm..where to start on my questions.
- Suggestions needed: DC5 chassis.. optimal location to mount an oil cooler
- B16A CX Racing Turbo kit Build: What type and size injectors are optimal?
- Problem with sleeved B18C6 running on GT3076
- Turbo selection for 2.1L roadrace engine
- RC750 injectors. The clips are already soldered in. What's the next step?
- GSR Intake Manifold with IAB for quicker low-midrange spool?
- Boosted B18B1 Misfiring/Hesitating/Sputtering/Pop in boost - Datalogging help needed
- Product feedback request: Blox eco FI injectors. What do you think?
- What location to have an 02 sensor mounted is optimal?
- Forged All Motor Pistons on Turbo Car?
- B16A2 block with GSR head
- Oil Feed line for turbocharger question. What's the safest route in this case?
- Suggestions needed: B18c1- What does it take to go from 330whp to 450whp?
- N5Spire's GReddy18g turbo kit dyno results. Thanks for tuning in
- Preventing Damage to Wideband O2 sensor
- Nine3Sol's LS Turbo build needs assistance
- JGTW's take on sub-$400 Fuel injectors!
- Skunk2 Pro VS Stock B16a2 Intake for Turbo Application
- Feedback request: Hunter Tuned Injectors
- Solid centre or spring clutch- what are the differences for my needs?
- F22b1 stock NOS system - Novice attempting to understand
- Clutch recommendations for lower power/torque levels
- oil pan tapped close to the bottom?
- Are most turbocharger rebuild kits the same? Are they interchangable?
- Vteccrackhead - Building my dream street car, GSR Turbo EJ8
- Chubludc2 needs to know - What to change and what has to go-B18C1 Turbo Project
- Compressor wheel size comparison. Can it alone determine volume of airflow or HP?
- GT3582R with a PTE Turbine housing. Is this normal? Should I be worried?
- How do I run a Water cooled turbo on a B18C1 Block?
- Assistance needed: Initial start after D16Y8 Turbo Buildup
- General Question: What is the HP limit of a B18 Sleeve in this day and age?
- B16A2 ARP Torque Specs - Please bear with me..
- EK B16 exhaust manifold for road race suggestions - need to cool things down!
- Is RSX wideband O2 capable for E85 supercharged?
- 500whp G"LS"R Turbo options. Precision, Turbonetics, or Garrett?
- What's the feasibility of using a Compound diesel turbo on b18b1?
- Turbine housing swap
- What's the better option? Rebuild the D-series or Swap a K? Warning: Low funding
- Boosted B18B1 start-up issue, idle issue, boost issues
- Did I just make a mistake buying 2001 B18c5 ITR valvesprings?
- Passing New York State inspection with a turbo CRV. How is it possible?
- Going by PSI vs HP for engine limits? I don't think PSI matters much?
- GO-AUTOWORKS Rejuvenation Build Project..modest goals but custom w/ walk throughs
- Overall turbo engine enjoyment factor discussion.
- Twin Scroll Discussion: Divided housing pairing and is there a difference?
- Can we Discuss Effective Compression,Elevation,Fuel type?
- Suggestions needed: Novice Honda B18B1 turbo parts gathering
- Montanacivic's proposed D16Z6 turbo build - How it's going so far.
- Showing off: eBay turbo kit running a Stock B20 rockin 25 psi. I'm so proud..
- hpw1707's LS/VTEC quest for 450-500whp "street monster"- turbo education required.
- How common is it to use 440cc High z injectors in a B18A1 turbochrged setup?
- newb turbo tuning questions
- Suggestions Needed: Turbo "kit" or other FI options for the EP3 w/ K20A3.
- Suggestions/Dilemna: Using the B18C1 Oem oil cooler in addition to a sandwich plate
- B16A2 Top-Mount Darton turbo setup: Does "Twin Scroll" help in this case here?
- Suggestions needed: Adjustable fuel pressure regulator for boost application
- Is there any advantage to using a B16 Intake Manifold vs. a Type R one in FI world?
- How can I Understand the Limits of my GTX2867R on my B18C1 project?
- Boostedjd's Prospective GS-R turbocharger build thread
- Palmerboy's FD2 TypeR Kraftwerks Build Ideas.
- Discuss: The probability of using an Auto Transmission powered B18C w/ a PTE6062
- Troubleshooting: Car is reaching positive boost pressure, but car NOT going anywhere
- R3X5150 needs Help in identifying the capabilities of a turbo "deal"
- MastaFlyMason wants to know : Is THIS an example of a build good for 400whp?
- B20v turbo with skunk2 pro series stage 2 cams? Good idea or no?
- Augustine Reyes- B18C1 turbo project - Novice builder that needs guidance
- The threads stripped on the CHRA's oil feed - What does one do?
- Rebuilding Jackson Racing Supercharger
- D16 Vitara Beater build -A 300-400whp Walk-through by Go-Autoworks
- Beginner Turbo Build Questions
- D16Z6 valve unshrouding: worth it?
- Any Front Sway bar options for a RD1 CR-V w/ Lift kit & Turbocharged?
- Troubleshooting: spark plugs destruction - damage to cylinder head 2004 1.6 litre
- Feedback request: SanadaSand's207 G"LS"R T3/T04E 50 Trim E85 Build progression
- Fluidampr - jetspeedz's Personal Impressions - Review & How-to-Install write-up
- bcintron95's S362-sxe B18C1 Dynamometer Results
- DaX's D16Z6 turbocharger build - older, but maybe not any wiser
- Boosted B18B1 won’t boost past 8 lbs, according to my boost gauge
- Inquiry: D16z6/y8 Component Questions for a 500BHP Build
- Ohisofly’s 91 Si project – 700hp or bust
- Chubludc2's need for advice on a turbo build that's in progress
- Opinions Needed: Drag Cartel 004.5 camshaft vs. OEM DC5 - K24 turbo
- Troubleshooting: B18CR Turbo running too much fuel - running idle issue
- Suggestions Needed: B20 turbocharged - What are optimal transmission choices?
- Can this block still be used for sleeping despite destroyed pistons?
- Understanding Forged internals for a B16 turbocharger build - How does one start?
- Troubleshooting:Swapped a b20 w/ b16 & changed turbos.Black smoke results
- IndyTeg's GSR "Banshee" turbo build *running log*
- Ram horn, tear drop wastegate size on 61 lbs+turbos?
- GTX3576 GEN2 vs GTX3076 GEN2 - What are the differences when installed?
- Greddy TD-05H 18G - what’s it worth?
- Surface gap spark plugs? Any experience?
- Recommendations Request: Which Transmission is best to use based upon my needs?
- Intercooler pipe questions...
- WojtekG's LS/VTEC Turbo: Un-Mothballing a classic. What are these parts again?
- Opinions requested: Supertech pistons for boosted D16Z6.. Whadoyathink?
- Opinions requested: B16a gt3582 and pro 1 cams. Mid range & top-end possible?
- Turbo B18B1 ‘flatlines’ after roughly 5psi
- (5th Gen Prelude) - H22A4 Turbo Build Question
- Title changing is extremely annoying and nothing but an ego trip
- white smoke after acceleration: crankcase issue? *Solved*
- Difference with aem map sensors?
- Crank Case Ventilation
- Previous/current F20c F22c, H, and B engine builders
- Inquiry: What are the specifications of this Turbonetics Turbo? T56327?
- Turbo build an LS help..
- Large framed turbo options for 650whp-750whp B16A2 power plant?
- Feedback request: Who has used a quality Top-Mount manifold on a B-series engine?
- Fuel line size recommendations for this K20-powered E85 turbo application
- NITROUS B vs H stock bottom end? 150 shot+ 10 sec CRX goals
- Question regarding turbocharging a "Rover" K- series U.K. engine
- 96 honda accord ex f22b1 full build and turbo
- Is my oil pressure normal?
- Weird cooling issue on turbo b18c(84mmx89mm)
- Looking for Suggestions: 3" Exhaust for Turbo apps - APEX'i vs. Thermal R&D
- K20 O-Ringed Block coming up. Which Head gasket do you recommend?
- Robertohdz's attempt at getting 500whp out of a D16A6
- Questions about using turbonetics tnx 30-56 or 30-60
- The return of The Rice Bowl. Vol.2
- Assistance Needed: Turbo civic - Setting physical timing. Same procedure as NA or no?
- Idle Curiousity - Anyone Know the Actual Dimensions of the FK8 TD04 Turbo?
- TurboLScrx - Making my return to the fold
- Looking for a Turbo Recommendation for 600whp range for under $800
- GARRET G3 TURBO ON A HONDA ACCORD 1987
- Meth nozzle conversion sizes? for "M" sizes
- Lsvtec turbo - gas smell in oil
- AZ_CIVIC'S Build, Testing Things, ETC.
- Feedback request:Expected behaviors with a Stock B18C1 using a "60 trim" .48A/R Turbo
- Used Turbo identification (turbonetics)
- Parts ID Help: Valve Retainers
- Feedback Requested: Em1Dustin's B18c1 "Fun Daily" Topmount Build Thread
- Seeking d-series cam recommendations for boost application
- egycasper's 12.0:1 300whp PTE6362 B18C build thread
- Blowoff Valve Vacuum line location - Intake manifold or another source?
- Questions on the several "right" & many "wrong" ways to run a Honda Catch can
- Feedback request: JDM front DC2/DBM Circuit race tucked radiator options?
- Troubleshooting: another Turbo b16 that won’t start
