View Full Version : Forced Induction
- hondata, 550's,stock intank...who runs this?
- RC Injectors
- endyn catch can HOW TO??
- Nitrous Question
- lay down intercooler
- Innovative Turbo
- NOS jet size
- u think my engine could handle FI??
- how do I know if my manifold is cracked?
- Anyone using MSD Digital 7 Programable?
- anyone have pics of block with benson sleeves?
- looking at buying a allredy turboed EG hatch,whats kinda up keep do they need
- B20Vtec+JE 11.5.1 pistons+ NOS DP= safe?
- A'pex power fc
- Engine Overheating after turbo install?
- AC autotechnic VS. Golden Eagle Mfg oil filter block
- What resistance does OBD1 ecu expect from injectors?
- How Bad: No DP, and 02 unhooked?
- Godzilla Sleeves???
- Question about crank
- whats wrong with my engine ... ( smoking )
- Need DEFI D series pics at night
- Regret on buying blue box
- check engine light after clutch install
- I am looking for a TURBO KIT (Complete) wanna trade?
- Fuel system for OBD0
- lost pintle during injector install
- ... oil filter magnet... anyone use?...
- Turbo and adapter plate bolts question
- btm and other detonation questions
- removing fmu ... need help ....
- thermal 3'' exaust
- Who can tune zdyne ecu?
- t3/t4oe coolant lines
- Should i buy??? blown GE block
- GREDDY turbo kits
- New Turbonetics Wastegate - Betagate (Supposedly better than TIAL) 56K BEWARE
- Will this heat shield clear the block?
- OT - A new Civic you guys will dig!
- ECU & Installing Data Loggin Hardware
- symptoms of needing a rebuild
- Any regrets on boosting a honda?
- please analyze my set-up
- who has h22 turbo wheel h/p numbers
- Revhard or Drag 3???
- Bad injector ?
- intercooler size
- got car tuned and dynoed.
- JRSC FPR setting?
- Wanted: Greddy Type 24 FMIC Pics
- Opinions/Thoughts/Comments/Help: Please read!
- whats the difference between tial 35 mm wastegate and a 40 mm
- can I sleeve this block?
- t3/t4oe Dp
- fuel settings for b16a
- Help me with my Oil Feed Line
- Turbo Manifold: porting worth it?
- Someone here might know...SR20DET/S13 wiring help!
- New batteries in the digi took some pics (compliments of KS and Hondata)
- MotorMatrix=Dumbass
- homemade manual boost controller
- EGT probe in DP.. Anyone running theirs there??
- Please help!!! blue box diagram???
- ... compression and timing question...
- jackson racing question....
- Wheres the torque???
- race gas! how much boost?
- KS Motorsports Clearance Sale
- Will i have enough fuel? Look inside!
- Has anyone seen Uberteg????
- max boost on stock ls block
- Profec B Install Question
- what do I trust?
- Show Pics of how to hook up MBC to a Tial Wastegate
- w/ a wideband o2, is there any reason to goto the dyno
- Damn, I have an oil leak..arggh. Can you guys help me find it? (pics)
- To get a dumptube or not?
- -8an...to small for oil cooler lines?
- Don't understand EGT
- plz post pics of where you have mounted your gauges!!
- Heard a theory today, maybe you can clarify.
- suggestions for replacement O2 sensor. (other than NTK)
- Stainless Flanges? Anyone know where I can get em?
- Need pics of RC 440's
- ceremaic coating piston?
- Turbo guys need some opinions?????????
- Any problems with running like this?(fuel pump and Hondata related)
- What Size threads for T3/T4 center section (water and Oil fittings)??
- forced induction basics..
- a final answer on how to hook greddy catch can on b18c1 please help
- Turbo or JRSC
- GSR, head gasket, and C/R..
- Which A/F Guage Is The Best???
- 94 Civic SI rebuild turbo, need help
- trying to figure out amount of boost on B18c
- anyone know where
- Which is better for a turbo ls/vtec setup??? Why???
- my car is acting up again!!! now what!!!
- Turbocharged a D16Y8
- 3rd or 4th gear dyno runs much difference???
- hows this? too ghetto?
- Ignition suggestions.....
- stock JRSC set up on a gsr. whats wrong with it?
- Bolts !!!
- WTB: T3 turbo
- Got my precision turbo today but had a quick Q.
- after i week of boost, piston rings are gone. rebuilt on the way, what parts to get?
- Wider view of perspective..
- parts for intercooler
- SOHC low budget head porting results
- Cheapturbo.com Rebuild Service - Big :thumbup: =)
- Internal Wastegate Question?
- Valvetrain Replacement
- Most important FI gauges?
- T3 turbine wheel stages
- ** who is boosting on B18C Us with STOCK INTERNAL **
- JRSC on b18B....how do i get 8psi?
- head studs w/ sleeved block
- Thinking about ditching my D and going B
- maxrev bov sucks
- anyone heard of this sh*t happening???
- hondata and higher boost and emissions(experience please)
- JRSC boost upgrade procedure question
- turbo manifold
- Funny Site......Check it out!!!!
- Serious valve tap issues, need help!
- what can my this engine handle?
- FS: New Siemen-Deka 83 lb injectors w/ AEM Fuel Rail
- sohc owners what could I do
- NTK Sensors Available
- Stock Component Theory
- Check it out Boyz
- -3 feed line? too small?
- what do i need to do............
- D16Z Apexi turbo setup
- T3/T4 Exhaust Side flange???
- Techedge 1.5 w/ wb daily?
- RC 370's or DSM 450's (what would you choose at 9 psi)
- GM map sensor and AEM
- timing advance on 8.4:1 CR
- Please fill me in on turbos
- ?'s about jrsc on a gsr
- efficiency of the drag kit intercooler(spearco)
- Need opinion on my new turbo car
- Its about that time....
- Top end issues...
- Has anyone done a VAFC hack with 4th gen lude injectors???
- help how do i put pics on here?
- ls turbo
- Drag 3 kit
- how to know if your car is in open loop or close?
- Apexi or F1 turbo kit?
- Boost question
- Just a few custom turbo kit questions
- best way to track down charge pipe leak?
- greddy turbo kit prelude question..
- Starion intercooler effiecency???
- AFC problems please help!!!!
- bad ride hondata
- tuneing debate, race gas or pump?
- electic exhaust cutout
- huge a/f drop when i pounce on the gas?
- oil additives
- Lightened flywheels and boost?
- Piston Q's again
- Some interesting info about the Apex'i SOHC turbo kit
- rotated my T-25
- eagle rods (Any modification have to be done to block?)
- D16Y8 turbocharged
- Weird AFC Hack Experience.... Ur ideas/suggestions Pls.
- MSD Inline and Walbro intank use both?
- TPS Hack, what is it????????
- Car was broken in last nite, turbo stuff missing
- VAFC: sensor settings anyone know what they are for
- Mechanical and Electrical gauge?
- Anyone using a decked and sleeved block?
- porting exhaust inlet on turbo...
- turbo type??
- what's the difference bet. VAFC hack and this setup??
- DP and exhaust question
- D-Series Tech: Factory Roller Rockers
- what is it that makes people give up on their FI car???
- homemade turbo
- Old member back, need help apprasing car
- fucking walbro fuel pump
- Low boost + Nitrous + pump gas=????????????????????? Nitrous people read.
- question for those with diy wideband
- JRSC on b18b1...timing question
- How much Horse power are you guys laying down
- Max PSI on AFC hack
- Anyone here have the Tial BOV/WG in black?
- help w/crx boosted setup?
- Cam Gears
- wideband 02 sensor question.
- profec A
- H23 Turbo Set up
- DIY turbo SOHC guys.. how'd you do you oil feed/return
- A question for everyone in FI.
- what size is this turbo?
- quick dsm injector help, middle of install
- who uses a palm pilot with thier wideband
- greddy sohc kit on d16a6
- Cybernation Black Magic ELF BOX??
- I'm checking out.
- B18C1(JDM GSR) piston and rods questions
- fs: TypeR Oil Cooler; 450cc DSM Injectors+ resistor box; LS TB
- how much WHP is a TiAL 35mm WG good for???
- How much boost are you running with the V-AFC hack? Post up....
- greddy on maxrev flange
- Engine smoking needhelp
- Connector Sizing
- Tuning AT d16
- Congratulations to HT member in GRM $2003 Challenge
- budgeting for turbo
- ferrea valvetrain
- APEXi GTR FMIC question
- Finally driving!!! pics
- A few questions.
- Techedge WideBand O2 sensor..
- washers on bolts from turbo to mani?
- gsr boost questions
- Charge Pipe
- i'm new to F/I some questions
- inlinepro/tial clearance in a civic?
- RC/Greddy 310cc question about fitment
- Fmax Help
- For those that make tubular manifolds, do you bend the piping or buy it bent?
- WHERE TO put bung for wideband?
- rc 310's and str fuel rail and other stuff MD/DC/VA
- 02 voltage sense
- Are there diff style G Blue boxes?
- Installing Front Mount Intercooler ON Teg.
- bov
- b18b retainers?
- ITR cams+ boost???
- need help building equal length turbo manifold!!!
- Some turbo install pictures.
- turbo installation problems >_<
- What do you think? New Dyno Graph of Spark Racing Turbo Kit@8psi Dyno Tuning by Track Masters
- where to tap for egt
- wow 439hp rsx
- d-series turbo.. keep ac?
- Traction control...
- Greddy e-o1 boost controller instructions???
- Ill buy this for a dollar
- Ohio Sleeves
- base timing at 9 psi
- greddy turbo kit owners
- Oil gauge
- LoveFab + Precision = LOVE!!!! Lots of pics!!!
