View Full Version : Forced Induction
- Quick question.........
- WTF? Can't boost, no boost? Just installed Greddy Kit
- Link for break-in process?
- turbo project version 2
- FS: custom tubular manifold from Full Race
- Crank Pulley seal or oil pump problem, Anyone ???
- suggested gauges for SC install
- Can't Decide Type 24 or Type 31
- Quaife LSD
- 1 bar
- dsm injector question
- I'll be back in a few
- Whos got an F22 Turbo?
- FS b20/vtec built with turbo setup
- Where to buy HEAVY DUTY "CLAMPS"???
- ITR 100 shot
- fabricating downpipe and manifold question
- Check out my monster oil cooler...too big?
- Serious Nitrous with Turbo question...
- skunk 2 intake manifold vs. GSR dyno plot
- Eagle Rods for the B18a/b on Ebay! No Reserve!!
- Sneak Peak... Of my New Turbo Setup (Race ZC) More Coming Soon!
- JRSC or Greddy Turbo kit?
- oil feed question....
- sizing bearings for turbo
- Products that dont work
- FJO 341B Engine Management
- RC 550cc injectors for DSM on Prelude Q:
- Revhard 2C kit is ready to go!
- Apex i SOHC civic kit internal wastegate/oil leak problem?
- More DSM injectors questions/concerns:
- Walbro inline fuel pump install?
- What aftermarket ignition do you guys use?
- JRSC Support Bracket Installation
- T3 with built in waste gate better?
- hondata
- Ok I did something evil... piston/wall clearance.
- use fields SFC in place of afc hack>?
- Hks Teg/civic turbo kit?
- D16A6 turbo vs. D16A1 turbo
- ... vafc hack with 550's
- EGT probe not reading?
- Quick!, Where the hell do I put the vaccum line off my Greddy 18g?
- integral wastegate springs?
- Going turbo--quick question....
- drag kit has arrived!
- Feasability of running a JRSC with 12.5:1 CR...?
- Hondata tuning /questions
- 4gen prelude drag intercooler question
- Threads on the oil pressure switch - what type?
- ok new problem.. well same one but more info..
- attn: Ji Simmons
- How much do you think this Drag III kit is worth?
- Attn: People who work directly for Hondata
- SuperCharge b18b???
- safc vs. vafc
- Turbo Feed line, oil prssure gauge line, ls/vtec oil line.....How to get it all?
- i what to do a custom turbo kit
- factory turbos and wastegates
- zc turbo fuel management question
- Has anyone tried making a heatshield for non-greddy kit cars?
- OBDII turbo inspection check
- wastegate gasket question
- Friggin SS line....
- Is this HP possible with the JR??
- Strong fuel smell during/after boost, but goes away instantly...what is this?
- T28 vs. 18G
- 3 inch downpipe????????
- Who's running a b16 turbo?
- Going Turbo in 1 month, what usually breaks First ...(if anything)
- Hondata turbo setup
- IAT question
- News on the 3" exhaust GB...
- Electric superchargers - please read - not a joke / ebay scam / etc.
- Exhaust Cutouts...
- can a stock y8 handle 7psi and nitrous
- would greddy blue box for D16Z6 work on a B18B?
- Apex kit, what all is needed to complete the install...
- Dyno Tuning guys, i need your help...
- Tial BOV/WG deals
- Idle Surge
- What should EGT temperatures be at?
- How can I boost with my T3 nissan 300zx turbo safely??
- Blew my rings when boost controler failed!!!!
- is an intake for the turbo necessary?
- necessary to run colder plugs on FI?
- Sleeving a block
- Injector question...
- hondata with VAFC and 02 simulator question ???
- Installing supra fuel pump, pls help
- JG Engine Dynamics and their service??
- hooking up oil feed line questions
- need help with LINK engine management
- ITR valves vs others?
- turbo timer question. please help
- Exhaust size?
- which tranny? LS or GSR?
- WOOHOO! just finished my turbo kit
- RevHard Turbo kit
- ls or gsr tranny?
- melted timing-belt cover!!! oh NO!!!!
- Downsizing wheel size
- Eagle and Probe Rods
- O-ring.......
- Is it OK to install my missing link before boost is available?
- Turbo for my LS powered hatchhback
- Installed my N.O.S. Wet kit and going to the track!
- Yet another Custom Turbo Project Mini-Me Turbo Project (DSM TD05h)
- Anyone running a straight t3 on a b18? How is your spool up? Whats the max boost i could push on a t
- need a good laugh?
- 12 Second Prelude
- new to turbo, any info can help
- h22 Turbo
- MP equal length manifold!
- Well isn't this a kick in the nadz?
- integra greddy turbo w/ no intercooler ok?
- HELP!!!!
- Compression
- water cooling a turbo?
- DSM N/T injectors w/ inline...Still need SAFC or no?
- IS there a lt of addition maintainence with turbo cars
- Will i need a slim fan with my fluidyne and drag 3 kit?
- How do I program my S-AFC for first time turbo use?
- Where's the oil send line go to?
- Mitsubishi turbo on a honda H-series?
- turbo exhaust question
- timing for forced induction
- a simple question for the pros
- anyone know what metal the greddy piping is made out of?
- convert MMhg to LBs of boost...
- OT but pic of my bike want to turbo it
- should i go hybrid turbo?
- fuel line ?'s for anyone that used the ss ...saw the other posts
- Well it finally happened........KABOOM!!!!
- Back from the track.....
- Arp head stud interchangability?
- Help! My boost controller is not working
- regrinds and turbo question
- Zex nitrous kit sale!
- this is what IM doing (read if you can help)
- waste gate and blow off valve, what do they do?
- Questions about 310cc injectors
- Turbo GSX-R 600
- WG adjustment and boost ?
- Turbo Sohc 0 - 60 (100 KM/H) Time please
- Vortech FMU w/ AFC ...
- fuel pressure in excess of 99 psi!?!?!?!
- did a leak test on my pipes/intake system
- how much power can the stock ignition handle?
- General radiator questions
- JB weld question
- Expected power from this set up?
- Anyone have 4-1 headers for the H22a?
- Comptech Exhaust on Turbo Setup?
- Got a finger on my Problem finally
- DLB1994!!!!!!!
- High Mileage Engine: Smaller Turbo: Worth It?
- Crane fireball hi-6tr for sale...
- blitz bov concerns
- Cams and Valvetrain - HondaSaver
- Tial 35mm identification
- dsm injector color?
- turbo progress (pics)
- Smoking, and leaning out after a few secs of boost...help
- 440cc injectors, is a 180lph pump big enough???
- DIY turbo rebuild???
- Turbo newbie question
- integra ls on nos, dynoed!
- PLEASE HELP!!!!!!!!!!!!!!!!!!!!
- I got a GReddy kit...
- Too Rich, Bad o2 sensor?
- flat spot and no acceleration?
- Need a fuel pump...look at my setup and help me out.
- toggle switch question...
- Turbo kits for F22B Non VTEC
- Integra: Is It Trouble to Turbo?
- Tech question for all ya...
- Moroso Oil Pan and dipstick
- JRSC fit on B18c1 in a EG?
- Was the pesky daily driven blue 10 second turbo CRX in town today ?
- fs: brand new thermal 3" civic/integra - virginia
- damn egt probe broke....
- PGMFI Web Site Revamped: Come hack your ECU
- Will this dp fit both these turbos?
- Can I use a new stock throw out bering and a pto bering on a chutch master stg 3?
- turbo info needed please
- Which Turbo to order?
- Removing the C Clip that holds the wrist pin in the piston?
- turbo sucks!!!!!!!
- finally figured it out-new times!
- Need new radiator. Which one is best?
- Humpty Dumpty Runs!!!
- jackson fmu problems
- where can i find all the specs for a 2000 si?
- B20VTEC Vs. B20NON-VTEC ?Torque?
- Some questions on turbo size for my application.....
- Tial WG spring?
- JRSC bolt up
- Bad exprience need some advice
- Pics of my race car at last event in Trinidad.
- How I made a turbo adapter plate
- Hesitation/Miss seems to be getting worse, need help
- ford injecters for turbo???
- Turbo-ing D15b7, What should be done to prep?
- Best place to get wideband O2?
- ls turbo smoking
- Optimum fuel system for around 400 whp MAX?
- A little OT, but a question about engine mounts...which to use?
- LS-VTEC Turbo running lean
- Greddy Turbo v All
- well its tuned, and heres the pics!!!!!
- ... injector question (dsm - not talon or eclipse)
- anyone have a "Predator" hood on their turbo car???
- Damn damn head gasket
- Tech Edge wideband questions...???
- HELP! Boosted B16 running lean?
- Fuel system guys....
- H series manifolds...Who makes them
- DSF, please read!!!!! fiorentd@hotmail.com!!
- all the little cracks on the DRAG manifold
- any good quiet fuel pumps out there?
- Where do I get a wideband O2 sensor?
- boosting problem please help
- Starion Intercooler, Modded for Civic
- Installing Oil Squirters on a LS/CRV Block?
- Greddy Oil Catch Can
- oil pressure switch
- D16Y8 and turbo in EF ?
- Anyone run an apexi turbo???
- Gave up on Greddy FMU =(
- Having trouble starting new motor....
- new PICS of the beast for you guys!
- what gasket for greddy downpipe????
- what bolts to use on the turbo?
- FS: MF10's, etc. (so. cal.)
- revhard stage2 vs. revhard stage2c?
- Attention Hondata 4b guys...
- head gasket???
- are these A/F #'s ok?
- 96 gsr installing rc550's need help to install resistor box
- ok lets find the overall best kit out there for the LS motor?
- AEM Plug n play EMS or Hondata Stage 4B
- which motor to turbo?
- Where's a good place to draw oil for the feed line for my turbo on my b18b1?
- Civic EX motor noise.....HELP!
- does anyone know where i can find flow rates for siemens injectors?
- Need help from turbo gods... Werid problem only occouring once boost has been hit...
- So when's the next turbo groupbuy gonna happen?
- Honda Rings
- leaning out all of a sudden.....help
