View Full Version : Forced Induction
- Purge contol valve
- piping
- Setup for a b18b
- I need help finding the right flange that I could weld to
- GSR Turbo Setups, Dynos, Numbers, etc...
- Fuel pressure an Turbo cars...
- What's the difference?
- beed roller???
- d15b7?
- ic piping...
- T25 turbo
- charge pipes
- Hooking up boost gauge need help.
- Just installed my 255 pump
- street turbo setup
- oil pressure low, why?
- AVCR wont make over 14psi of boost
- horsepower/torque predictions
- which arp headstuds for single cam d16a6 ?
- HELP JRSC
- injector question
- ****the offical "whats your favorite setup"***
- tuning problem with plx300
- What makes a turbo setup non AC compatible?
- Colder PLugs??
- forged rods and oem pistons?
- What Intercooler piping???
- Is 100 safe for my GSR??
- bslightly sunken sleeve???
- Guardian Install
- E-Manage Question
- Trying to figure out what went wrong... Cylinder #3 is TOAST! DOHC ZC w/75 shot... Pics
- zdyne ecu starts base timin at 18* instead of 16* , what should i do ?
- RMS fab Ryans gt4202 dyno video
- vouches Philly Dyno Works
- pump gas?
- whats a realistic hp and boost goal for my setup?
- what should open loop mode be set to?? throttle above % and map above voltage?
- 470 hp tuned misfire problems
- LHT K20a Insight
- my plans....with questions
- Turbo + Fuel Supply
- im trying to figure out.....
- Help looking for the post pics of you FMIC thread??????
- Quick question!
- Video For All My Honda-Tech Friends: Inside cylinder
- Stock LS at 17 psi.
- YCP Vitara 75.5mm pistons - need help on piston/cylinder clearances!
- FMU or Not????
- Shop Integra: 499whp 341ft-lbs 93 octane
- Turbo must haves.
- what is the oil temperature on a honda?
- Whats the "IN" turbo for 2007/2008
- Snapped timing belt, 92 accord
- Vortech FMU
- boost gauges
- my stock gsr dyno setup
- Cant richen it up Crome with 1000cc injectors WTF!!!
- Hey all, noob to Hondas...
- jrsc now what
- replacing rods/pistons
- dumb question.. can a car build boost if i jack it up and drive through gears?
- Will this work with my t3 super60???
- Turbo oil inlet thread size?
- is airtex e2315 inline pump worth using?
- TB coolant bypass, quick question...
- 3 inch twin loop muffler
- srt-4 577cc injectors
- "new" turbo is perfect accept.....
- Map bypass valve.
- Where to get tial springs?
- New project need info
- turbo manifold??
- turbo manifold??
- Random Weird Question
- compression test results.....
- 567whp dyno video
- hey hotshot tuners how do you listen for knock
- OMG WTF lower compression made MORE power!!!!!!!
- Is this a good turbo for 500 whp?
- A1000 fuel pump
- ls turbo?'s
- my sohc zc build: lots of pics!
- SLEEVEING
- Engine swaps and turbo setups
- ls turbo question
- 57 trim or 60 trim help
- need opinion on supercharger setup
- manifold adapter
- odd clutch engagement issue
- Where to get this high temp/pressure oil line?
- changing bov sound on a dsm bov........
- DIY!!! What you need and/or should get when building a turbo kit. Gurus chime in...
- B16 EF HATCH WANTING TO BOOST
- wondering about this turbo?
- hesitation?
- 92-95 civics, what is the biggest I/C you are using w/o modding bumper reinforcement?
- JRSC Injector help!!
- EBAY TURBO SET UPS
- Intercooler Sizing for 500+ whp?
- how long will a stock ls last making 250 horses
- Hondata IM gasket, where to buy?
- Turbonetics Evolution Wastegate vacuum??
- Turbo Math excel spreadsheet
- boosted em2 question
- EM1 HELP!?!?!
- motor healthy enough for boost?
- GT35R CHRA = T25/28 CHRA?
- Just a little help PLEASE PLEASE PLEASE
- Car burns oil in vaccume
- hks ssqv blew off
- obd1 conversion and emanage
- friend was in pa the other day...
- Help out a fellow HT member...
- Apexi kit tubo size of oil drain hardline??
- Civic ef 1.3 TURBO
- pics of a very clean setup
- apexi bov flange question
- put my motor together tonight (got a few questions)
- Help getting wide band to display AF in hondata s300 smanager
- b16 84mm turbo pistons difference?
- 1300 whp!
- emission question???
- Dyno numbers
- I need pistons and rods!
- How long should it smoke after rebuild (GSR)
- Want to go LST.. b18a or b18b better?
- Timing advance for C16/Torco118 vs. dyno tuned 93 Octane
- How to fix snapped & cross-threaded bolt in log mani? Will the flange warp? Helpo!
- Autolite spark plugs. Have you tried these??
- xtd clutch
- Boosted b16 wont rev past 7800~ rpm????
- Turboing D16z - prep parts list for pre turbo - opinions?
- 300hp+ sohc's which injectors are you runing?
- B16 Boost Question
- Post up your stock boosted B series dynos!
- Should I replace my injectors? PLEASE HELP!
- Whitfield Racing !!!
- does b16s need a aftermarket girdle for 600whp?
- garrett .50 trim or .57 trim
- Cams on 1,8L for 8-900hp ?
- stock head studs
- My boosted 95 H22 Civic....
- wow 500whp boosted h22!!!!!!!!
- i Need Help Guys
- surging idles...revs lower and lower...then dies...need help ASAP
- TURBO TIMING HELP IN MOUNT JOY !!
- Going Turbo
- my motor broke.....need to sleeve and turbo.....i need help
- Will I be able to re-use my Action 2MD? Also, are flywheel shims a good idea?
- Boosting a stock 96-98 B20
- using dsm 450cc blue tops. can i use stock clips?
- Please help .... boost controller setup
- 10pis stock d15...with a new block...
- do i need a wideband?
- high compression h22 turbo
- www.KnockBox.com.au - detonation detection
- turbo in winter
- inline pump question..
- 180000 mile ls motor what bore pistons
- 13 head gaskets in 3 years Please help!
- Fuel management
- 2.5" intercooler piping too big for my setup??
- spark plugs
- Best 70mm TB w/ Edelbrock manifold?
- Thrust Washer failure
- What parts would I need to prep a d15b for 300hp turbo setup?
- spark plug gap?
- sign of bad rings or ringlands?
- car cutting off after vtec 2nd gear and 3rd gear
- 440cc injectors??
- Turbonetics T3 Turbo Question
- b16a2
- nippon low comp pistons how much boost?
- b16a turbo build
- PeakBoost Topmount Fitment Issues
- injector problem, running hondata s300!! HELP!!!
- saving of bottom end
- Boosting a y7?
- nitrous wiring is this right? pic included
- 3 phase 450v
- INJECTOR Question
- which clutch 500hp 350TQ.
- 517whp 375Tq XENOCRON TUNED 85mm B16a
- Need a turbo...but which one?
- input please... b16aT early rev limiter... 7k??
- My 570whp H23a1 Set-up by AV Engineering
- twin scroll exhaust housing on non twin scroll manifold?
- Integra t-manifold to fit a Eclipse (stock) turbo?
- Hp rating?
- TD Autowerkes Civic makes 822hp
- fuel pressure on b18c1 with a sc34 turbo
- what size turbo is this?
- turbo size for d16?
- AFC hack ? Dont hate.. i know i need some real tuning..
- injectors run poorly
- Thicker Headgasket.....which timing belt?
- full-race manifold cracked...
- faint misfire?
- DOG Box anyone?
- Turbo Cams?
- EGT gauge
- injecter noob question regarding resistor box.
- Making 300 WHP w/ T3
- passing emissions
- BOGGING OUT / HESITATION PROBLEM ?
- MSD HVC II 7 series coil
- Turbo 4afe.
- Hitting 12's on stock LS turbo?
- anti-lag found this interesting vid
- need so help with b18 motor
- manifold reputable?
- Lets see if I can get some advice for my turbo brick. -Volvo 945 Turbo Wagon-
- Car runs to hot!
- Turbonetics turbo rebuilt?????
- valves? low compression..
- newbie at turbos**
- Skunk2: Dual Valve springs
- New turbonetics turbo makes a strange noise
- Turbo or Squeeze?
- Eagle rods in D16Y8 not fitting arp rod bold head to big anyone have this issue?
- WAS THINKING ABOUT PICKING UP A CRV
- B16a2 FI Safe Boost>?
- It started (but still need your help with the turbo)
- Water injection testing
- Automatic Turbo fueling options ?
- how much hp does power steering waste at high rpm?
- pistons?
- CP pistons recomends putting the top compression ring on a axis point anyone???
- Runs a little too hot for my liking... what else to do?
- Whats a reasonable amount of time to....
- How to tell if my injector went out?
- Turbo Question garret t28
- Anyone pull just the motor and not the tranny for a swap?
- sx fuel pump to a weldon db2015-a pump
- How much power can you really use in a streetable FWD setup?
- coolant in the bay and empty overflow. what happened?
- Boost problem with friends turbo type r
- I have a question
- gsr jackson racing super charger
- LS Rods in a 97 civic d16Y8?
- ordered 2 sets of same injectors but have different numbers on them??
- dohc f22b
- Fuel Injectors
- does it matter where on intake mani the map line is tapped?
- Bad o2 sensor?
- post pics of your internal wastegated turbo setup.
- computer question
- Balancing a turbo after rebuild
- AEM Tru-Boost Controller
