View Full Version : Forced Induction
- changing plugs
- Oil Cooler - pressure
- motor questions
- What wastegate do i have???
- small turbo air filter
- Im in need of help very badly ! Question about Vafc Hack
- having probelms with my local machine shop, ( darton sleeves) suggestions?
- Help me with boost problems
- Need Hondata tuner in Colorado!!!
- WALBRO 255 FUEL PUMP question
- ZC TURBO EF
- Help with turbo on stock Honda CRX 1.6 VTEC B16A
- D series 1.5 Rods
- Distributor Rotor differences and eliminating electrical arc interference
- b16a = 344 whp
- Wastegate elbow question
- Intake inners valve springs on exhaust side?
- I'm loosing oil pressure when my car warms up!! HELP
- Finally got my turbo on!
- PLEASE HELP!!!! Turbo Problem
- Boost spike + map sensor issues
- turbo question?
- Boost Gauge and VAFC question.
- Turbo B18c5 VS. Turbo B18C1
- 8X turbo ls1
- h22 distributer bearing keeps going bad.
- need informed advice on turbo gsr setup!
- 3" Resonator/Muffer??
- Tuning Q, how much ign timing does honda run while cranking?
- Mounting JRC intercooler on a 1996-1998 Civic. Who's Car is this in the pic?
- supercharged...want to go turbo..advice on setup?
- Should I buy a used crankshaft or have my current one milled?
- Good Turbo Pistons/Rods
- anyone tried the obx d series manifold on ebay?
- Nitrous decision
- Checking Ignition Timing Before the Dyno
- T3 60 trim too big for a d16y8?
- Does anyone use a 4.785 final drive Si or ITR tranny?
- anyone running RX7 injectors?
- recommend me a BOV for 7lbs of boost
- signs of a bad fuel pump?
- NEED SOME HELP, TURBO IN BUT RUNS BAD!!!
- internall wastegate actuator question
- Whats the odds. Anybody have a zdyne tune for JRSC b18c
- Video of my car... Small but clear and has sounds, good for 56k'ers
- passion of the build
- Walbo In-tank 255 Fuel Pump high pressure or not?
- Information and options for Turbo? *noob*
- tig welder + home dryer plug?
- boost managment ????
- CTR cams on Turbo setup
- want to biuld on B20 engine
- Check these two 10 sec clips of my car smoking.. Maybe blown turbo seals
- Power Cutting In & Out HEEEELP!
- For anyone that has problems with bolts backing out... Problem Fixed
- Copper head gaskets?
- compression make that much of a difference?
- how much boost on 10.5:1?
- vacuum problem is really getting to me! Pics/Vid
- To sleeve or not to sleeve?... that is the question.
- my project....56k get a snickers bar
- will a fuel system cleaning work on my turbo d?
- Turbo Manifold fitment
- What this???
- SC61 compressor map...???
- greddy blue box - how rich do you run
- turbo install almost done...need some help
- Thinking about putting a turbo on the civic hybrid
- decided to be a nice guy and put a cat on my exhaust.
- sensor pointed at my timing belt broke...can i drive without it?
- Happy Memorial Day HT!!!
- Greddy TT, beeping and blinking stopped?!?!!?
- Will the Jackson Supercharger for the D series fit a ZC?
- first time using nitrous...need help
- how safe is ZEX?
- Help out a fellow boost buddy.
- OT.. anyone going to the IDRC East Coast Nationals @ MIR?
- Turbo Set up that can bolt on.
- Where to buy O2 bung?
- Where the heck can I download Uberdata 1.6666???!!!
- Need help with oil lines dripping (Pics Inside)
- just got back from latest tuning session 400 HP club yay
- Changing from synthetic to regular = check engine light???
- walbro 255lph hp pump require more amps/voltage?
- rebuilding motor after 10k miles needed with turbo???
- What are the 2 xtra vac lines on Apexi BOV for?
- D SERIES question
- timing obd1 with afc
- A/F ratio on turbo B16
- WTF is this
- b20 pistons???
- Maximum recommended Timing advance (tuner question)
- ARP torque specs for H22??
- LS crower cam users!!!
- Heat issues with tansmission. Need advice. HELP!!!!
- Boost controller problems
- Help me identify this turbo's a/r trims
- What Size barb fitting for vacuum manifold....
- Can you ID this turbo.....and is this GSR engine fixable?
- FMU
- which runner on manifold for EGT on turbo civ?
- -HELP- h22a turbo? Prelude SH?
- ZC1 SafeGuard or Sleeves.
- LoveFab Manifolds
- whos repping the t3/t4 B family here
- getting started with the full race kit!!!!
- New RC INJECTORS..........
- BOV problems
- Finished CF charge pipe...
- which HELMS?
- Turboing a d16y8 in a CRX
- ecu dizzy
- Stock block SOHC guys!! post ur set-ups/numbers!!
- Golden Eagle fuel rail / injector fitment issues.
- exhaut stream, wideband o2 reading...
- White smoke from my boosted civic HELP PLEASE !!!!!!!!!!!!!!!!!!!!!!
- Turbo Kit Components, need help
- What makes more power/torque built ls turbo or built h22 turbo
- AEM EMS Basemap
- B16A dyno'ed today...
- psi converted to cubic feet per second
- NEW ENGINE BREAK-IN...Some new ideas
- too much boost frying ecu?
- nitrous questions?? mista bone please help??!!
- Willem burner problems, HELP!
- jackson racing charged ep3
- LoveFab Manifold question
- where to get aem ems plug??!?
- New Product *WOW* Final Done Check it OUT! WHY DIDNT ANYONE THINK OF THIS BEFORE
- Which BOV?
- Just got a civic, your opinions on what motor for what i want to do.
- Install help
- ls/vtec benson block, need some opinions on my setup
- Why do i have to pay 500 for pistons and 300 for rods...
- B18a and Boost?
- Nitrous installation
- Need help ASAP.. blue box wiring
- turbo timer with alarm?
- 480whp SOHC D16Z6........
- Is my turbo to big?
- intake manifold diameter ?
- Why dose my Greddy type S Flutter?
- Greddy turbo Timer Install, help!!
- What fuel components do I need?
- 2 questions: 15G turbo & shaft play
- JDM H22A radiator selection question....
- camshafts no good for turbo...
- Function of Fuel Enrichment Relay on JRSC?
- turbo on GSR whats the best option?
- VAFC settings for my b16 turbo
- One More Time, Another Turbo Honda
- AEM EMS tuning.
- changing turbos?
- ....Turbo Timer ?
- D-series Clutch/Flywheel Question
- Throwing code 21. Vtec solenoid....what should I check to repair?
- forged rods, forged pistons, stock block, autotechnic block guard...problem?
- Southern Ontario FI folk(meet)
- yaye or nay?
- 91 civic SOHC turbo setup questions
- Spark Plug Gap???
- i think my AEM fpr exploded
- Idle Drops hard when fan comes on.
- Max boost for GSR vs Nos
- what do you guys think?
- anybody here using zex?
- Do sleeves with integrated block guard cause cylinder and block distortion?
- exhaust manifolds: Revhard vs InlinePro
- Looking for a good turbo for my 99 ex.
- Full Race supra manifold pic...
- Turbo manifold suggestions
- NOS Dry Kit question!! NOS jets, Nitrous Jets...
- Finally Off Jackstands! Turbo H22 Civic Hatch Part 2
- can i tap my oil pan here??
- going to get retuned on friday think i can break 400 hp?
- blown motor - cracked cylinder, crower rods still ok?
- 75 shot on LS motor?
- JRSC Lude@9psi safe or not?
- turbo gsr not starting after install??? HELP
- 3 bar map problem with uberdata?
- gsr-t not hitting vtec...
- Turbo kit Question!!!
- Timing belt
- where can I find a................???
- cPictures of my Test fit/DP fabrication today
- Offical completion (i thank god)
- i need dumptube ideas....please help guys. car is getting tuned tomorrow!
- Please read (2parts to this)...Is there a difference between a Type R oil pump then a SI?
- Question about a vtec head
- SpoolinPerformance NA-T supra #3 - man i hate these cars
- Single cam ZC motor can handle turbo ?
- t3 on lude?
- Help? Startup probs...
- Lookie at my turbo!
- question on welding O2 bung onto downpipe
- Attention Greddy SOHC turbo 15g or 19t users....is my wastegate arm set at higher psi?
- Help!!! Leak after dsm 450 install
- hondata s200b, does it have timing retard or should i use my btm?
- What to do after installing turbo, but before starting car?
- Is this price ok? 16g turbo, GReddy Manifold and Jackson Racing FMU
- T25, Accord, SAFC -- a few questions
- 6th Gen Accord turboed, check engine light came on...
- greddy oil catch can and aem big brake rotor
- I called AEBS today.....
- Evaluate my Dyno Graph.....and got a few questions.
- b18c turbo
- WTB: TYPE R BOV, 40MM WG SPRINGS
- Duty cycle issue with Hondata?
- Pictures of my T3/T4
- Willem burner power supply?? help!
- Misfiring on 450cc dsm blue tops
- Teg Turbo 94-95...
- what the? No boost
- Ideas on where to mount profec B in eg????
- downpipe question.
- pipe bender...
- veterans check this out stock b20b vs stock b18b dyno chart info any ideas why?
- q about charge pipes and oil cooler
- is $6000 tooo much...YIKES!
- Tuned boosted gs-r (dyno graph inside)
- 2.5 downpipe for greddy kit
- 14b or t25 for my d15?!? Need to keep A/C
- Where to find 3" 2-bolt exhaust flanges/gaskets?
- Another Turbo Civic
- wastegate and mbc problems
- Necessary Gauges for Supercharger?
- drag turbo kits
- Wastegate dump
- What happens if your crank is 1/4 oz (7 grams) out of balance.
- ATTN Sponsors: I need rings by Friday.
- About to install injectors...brief question
- hondata and "cold starts"
- Inlet Turbo Vent to controll boost
- Apexi IHI turbo car sat outside for a week, now won't boost
- A question about Darton Sleeves
- If I Mount A Turbo Upside Down, What's The Worst That Could Happen?
- 94 GSR, swaping pistons however retaining stock rods...need opinions!!
- Max whp a RSX-S can handle?
- Should I swap out my ITR with a complete GSR short block for boost?
- Peak power with a 14b turbo...
- DSM forums?
- Took my car to the track for the first time in 2 years... Ran pretty well. ;)
- just went to the dyno.....got some question....pics inside!!!
- GSR-T 8 PSI??
- Welding stainless steel manifold
- Errr...why me
- what intercooler fits best/easiest in 91 accord
- Scary - Stock ECU and car idles with 450cc injectors! Please help
- Is it possible to buy a civic turbo kit and fit it onto a teg?
- Just got my defi gauges, some quick questions
