View Full Version : Forced Induction
- Just bought a JRSC kit for $550 for my D16. Took it apart and this is what i found.
- Installing Intercooler on Integra Questions
- greddy turbo elbow question
- Which sohc setup is better for boost
- Wideband help searched already
- cams with no cam card
- ok ive got a 89 hatch back
- Turbo Elements FTL
- Using exhaust from 2 cylinders to drive a small turbo?
- How To Clock a Turbo.. properly, without damaging anything
- P28 ecu on crome. Problems?
- so i broke a bolt
- Tuner Toys rod bolt TQ?
- blown couplers?
- greddy internal wastegate blown?
- Sleeved H22a oi; squirters?
- Ricardo's own sequential setup!
- chipped ecu
- nitrous setup question.
- New to Honda
- built b16 turbo laggs when i shift fast
- AEBS Manifold injector fitment.
- This turbo OK for my goals?
- High boost timing
- Build for boost
- Quick Resistor Box Question
- My TurboD16 Project - United Kingdom
- will these work
- Difference between side-port and top-port on ext. WG when useing a EBC
- New to boost. Setup Help.
- NOS jets sizes
- Need opinions on aftermarket adjustible camgears.
- help on hp goal or psi goal
- Big turbo vs Small turbo
- JRSC ITR/CTR how is relaiblility?
- head gasket ???
- How hot do sleeved built motors usually run?
- post your filter setup: for blox/ and other a/c style manifolds
- Oil return line question
- LS Turbo Questions??
- injector nozzle type
- Most HP you can make with a .63 t3 turbine w/ stage 1 wheel?
- PT 61?
- turbine intake
- Best vtec head for turbo
- precision sc50 WONT CLOCK
- DSM Injectors/resistor box after install problems!!! HELP!!!
- Injector Box (K-Series, 1000cc Peak and hold)
- CP Pistons Piston CC charts?? Piston Dome Displacement
- quick greddy turbo manifold question
- s372 on peakboost sfwd manifold
- wastegate springs universal?
- DSM flange on a T3/T4 manifold???
- 96 Integra LS: Converting to OBD1 for boost?
- snow performance meth injection instal
- low oil pressure
- compression test
- damn inline walbro...is this gonna be a problem?
- Turbocharged 2001 Prelude: how to pass inspection MA (scanner)
- CAMP 1320
- WOULD THESE WORK WELL???
- Help finding A/C compatble for D16 less that $400
- anbody have the tial bov o-ring size?
- Is this not a killer deal?
- info on garrett t3/t4E 57 trim
- p08 ecu
- B16a to Ls question
- Oil Dip stick feels like its hitting something going in?
- td04 stock wrx turbo flange
- golden eagle or camp 1320 screwed me
- LS turbo price for value?
- Burns Stainless
- Gurus with turbo wisdom I need your help.
- Help with relay - JRSC B16
- Oil drain line too long on edelbrock kit?
- keep fouling plugs!! HELP searched!
- Stock ITR limit
- Any idea where to buy Jackson Racing boost upgrade kit or 8-11 psi pulley?
- 10:1 compression ratio
- 400-450 whp safe on 81.5 GSR??
- D15z1 at 8lbs Boost
- vw wideband sensor
- DENSO injectors around 440cc
- b series vs d series
- sc61 rebuild
- manual boost controler
- Full H22 Turbo Kit on Ebay
- *Turbo XS Dual Stage Boost Controller, Need help!*
- boosting a stock bottom h22?
- How to diable speed limiter
- f22 o2 sensor question
- Cracked a sleeve after installing mishimoto radiator. Opinions/experiences?
- Where to Buy 5.5" Coupler
- B20 problems
- Honest Personal Review of SSAC XSPower t3/t4 and customer service
- 82 mm b18c stock sleeve on boost?
- Are Skunk2 pro1 good for a turbo set up on a B16 engine ?
- 40MM tial wastegate ok for my setup???
- Question about Boost Control with S300
- hi all, noob here, advice needed.
- Benifits of race gas.
- turbo parts for sale
- possible to run a Holset hx-35 on a gsr teg with ac?
- Boost Flutter Wastegate Junk? Turbo SOHC
- rebuild for turbo?
- How this oil return
- NOS questions
- AEM Wideband and S300
- Just got my 404s
- OBD1 Boost Inspection
- 1998 integra RS finally done, for the most part
- Largest turbo with air conditioning
- Couple of questions on JRSC. for B18c
- max deck block?
- Mac Valve Question.
- where to buy 0-5 v oil pressure sending unit?
- thermostat temps, what are you running?
- boost keeps spiking?? what could it be?
- How will a t04b perform on a stock b16?
- WTH....My car wont even Crank
- blowing oil pan gasket. need help!
- turbo kit?
- hondata !
- MAC boost solenoid - problems sticking?
- How to identify what type of RC injector i have?
- WHATS THE BEST???
- want to boost a f23a1..
- Help Finding stolen parts!!!!
- lifespan of a F/I engine
- Mobil Delvac 1300 Super For a Turbo Built Honda?
- Running ind.. coils
- anyone run a 4 spd trans on a boosted single cam?
- Turbo GSR SSBP: IT'S ALL DONE!!!
- 38mm wastegate hook up
- what other wg are compatible w/ hks wg flange
- got input on plugs?
- 18g downpipe flange
- I have a question about spark plugs for my nitrous setup.
- going ls-t want to ask abot some things please help!!!!!
- another noob question.....
- turbonetics are they any good?
- f22 manifold options
- Drag kit not fitting... too big of a turbo??
- fuel managment q's
- F@!$@! racing works.com
- removed heater core and parts, loop heater hoses?
- 400Hp Vitara MiniMe Project CRX
- help!!!!!! with turbo-smart dual stage boost controller
- am i being stupid or is this just wrong?
- B16 Dizzy for sale
- B-series A/C Turbo Manifolds
- Timing Look ok?
- Name this turbo
- manual or electric
- LOOKING FOR OSTRICH !!!
- Sequential shifter for H22!!
- NEED BOOST HELP !! ANY REPLIES !!!
- Turbo GSR EF Build Thread
- what turbo to get?
- Rebuilding a 240Hp H22a1
- 65mm tb or 68mm tb?
- anyone with pr4 ls pistons vtec engine ?
- what MAP sensor
- turbo help
- white smoke and a little oil leak in turbo what can this be?
- white smoke
- Turbo: wrong way and need help
- Stripped oil jet threads? Please HELP!
- Mazdaspeed 3 BOV swap yeilds 20+hp gains?
- What are acceptable knock volts? ...
- p30 oil pan the same as p72 oil pan???
- DA wont start
- arp b16 studs in gsr?
- Hello! I am new to this thread. :)
- How hard is it to add ac to turbo gsr in eg?
- Not overheating, but coolant overflow gets filled to the top
- Things to do before "starting" fresh build
- b16 Z10 block girlde.. need GSR/R oil pan too??
- CROME TUNER IN WISCONSIN???
- O-ringing sleeves?
- B18c Tredstone turbo kit???
- some questions... fuel rail/manifold/ac compatibile
- Vacuum block or Vacuum manifold users.
- Need some help on daily driven ls-T setup!
- Is anybody using a BDL FPR and Filter?
- ATTN B SERIES TURBO PEEPS: list the contents of your setup (preferably non-vtec)
- What rods are these?
- Thieves in Northern DE- TRIED to steal...
- 15psi on stock MAP sensor?
- turbo integra wont start
- Temperatures inside the engine bay
- 4" or 3" thick intercooler?
- wastegate vacuum line??
- fuel return too small?
- darton flanged or darton replacement sleeves?
- DSM setup on d16
- Won't start with 750cc injectors
- Any recommendations where to get a Turbonetics turbo rebuilt?????
- spooledperformance.com?
- Is the Greddy Turbo kit the way to go?
- What rings for vitara pistons? Part number?
- T3 60-1 Users Chime in!
- Throttle body?
- need some help for setting up a turbo on my 88 crx!!
- Custom Liquid to Air intercooler set up, over boosting problems input needed, PROS ONLY
- Stock block fitting size?
- who else has done stupid things when putting together setups??
- oil on pison?
- Car hitting fuel cut when in boost...help
- Underdriven Alternator pulley question
- Need help building a monster
- Boosting a 96 honda. Need timing help!
- Plx M500 Map reading
- Devcon filled blocks
- b16 build with pr4's ?'s
- want to go turbo
- Are bends in door bars legal for NHRA?
- anyone with dyno's of boosted cars on spray?
- Valve Clearance for Boost?
- Twin scroll wastegate problem?
- air fuel help
- Misfiring new build.
- B18 MID DARTON Sleeves On B20 under process Pic inside
- My Car's Strange Purrrrr?
- Running925's Build Plans, Your insight would be appreciated. Thanks
- where can i buy iat sensor flange? (for a venom IM :S )
- 550cc tuner toys injectors????
- Piston Selection
- Looking for advvice on what turbo parts needed to get started.
- Need a computer with tuning capabilities that I can still be obd2 compliant.
- injectors
- Dyno question
- D questions head choice
- E85 users...anyone calculate their TRUE gas mileage yet? Lets start a database.
- A few questions about turbo housing.
- e 85
- turbo ?
- wastegate hose?%@#
- 3 inch exhaust or keep the 2.5?
- b20 JRSC help
- werid smoking issue
- what timing belt is good for high hp oem or after market
- Quick question: OEM headgasket
- Feed and Return lines?????? PLZ HELP
- tune changing, wtf?
- How tight to make oil jets in block?
- supercharger question
- Car sputters
- please help BLOWN TURBO
- my ek9 turbo build
