Need help! NEED TURBO BASEMAP Z6 HONDATA S300
Hey guys. I'm in a sticky situation. My daily stock civic blew up. Threw a rod out the block so it went to the scrap yard. So in the meantime all I have to drive is my built turbo rt4wd wago with Z6 running Hondata s300 but it needs a turbo basemap badly.
I need a turbo basemap that I can run on it for a little bit while I save money to buy another daily and save up to take my wago to the tuner.
I know most of you will say take it to a tuner, we'll I'm going to, just don't have the money at this exact moment to do so.
So....
Does anyone have a half way decent turbo map I can use to drive on for a couple months while I save for a new daily and a good quality dyno tune for my rt4wd??? It's my only car and I need something to get back and forth to work so I can feed my kids.
Like I said I'm in a sticky situation.
For those that might be able to help here is a run down on my set up.
D16z6 swap with rt4wd trans with SL gear, Eagle H Beam Rods and bearings,
Vitara Turbo low comp pistons and rings,
High flow oil pump,
Block guard,
Along with some head work.
log turbo manifold,
.57 trim turbo,
3 inch down pipe with 3 inch exhaust, running Hondata s300 installed in a obd1 P28
upgraded fuel filter,
fuel pressure meter with Regulator,
upgraded fuel pump,
Custom made Intake Manifold,
440 injectors,
BOV,
wastegate,
FMI,
SF 3 Bar Map.
Thanks in advance.
Help a fellow importer out who is in need!!!
So....
High flow oil pump,
Block guard,
log turbo manifold,
.57 trim turbo,
upgraded fuel pump,
440 injectors,
BOV,
wastegate,
FMI,
SF 3 Bar Map.
Thanks in advance.
Re: Need help! NEED TURBO BASEMAP Z6 HONDATA S300
Phearable.net?
I have run a few different maps from them...2 of which were turbo vehicles.... I ran a D16z6 motor with T25 turbo @ 7 psi for almost 2 years never had a problem.
Its not the "right" way but it will work
I was thinking pherable but I'm currently broke and with bills it will take me a while to even get the extra cash for one of their basemaps. That's why I thought I'd ask one here if anyone has anything I can use first.
I tried a hondata basemap but my car still runs like cap. Wants to cut fuel at around 3500 rpm. That's why I was wondering if anyone had a decent turbo map I could use.
Like I said, I'm desperate
Unfortunately I do not. Sold my moates burner a couple months ago to help pay my insurance payment. All I have now is a computer with smanager and a hondata s300 in a obd1 p28 I saved up and bought myself for my birthday beforemy daily took a dump on me.
Who is Mr Robot?
You just need a USB cable to upload a map into an S300, no burner.
Making a map isn't that hard...
