View Full Version : Forced Induction
- full-race kit question?
- how do i fix code 16 - fuel injection system defective...
- Would this be a good/bad bottom end for forced induction?
- Received my Intercooler, Mothers Metal Polish works Great!
- Fuel technical question
- The Little SOHC that Could.....Finally Dyno'd my Z6 at 12psi!!!!
- Questions about Boost - parts list
- greddy fuel issues
- wtb: 3in. filter
- 15.47@87.44mph
- E manage in EP3 problem, please help!
- spark plug gap????
- VHT TrackBite alternative?
- Adjusting BOV
- intercooler
- IC pipping.. APEXi VAFC?
- Valves size
- different BOV different sound?
- Integra Type R Tuning Qustions
- Anyone familiar with any Holset turbos?
- Anyone sparying on 11.5cr
- LS/ Turbo Street buildup help
- secondary O2 sensor eliminator for obd2?
- went to the track yesterday, here are the times
- Lookin for some Turbo stuff
- ITB's + NOS??
- cam gear settings???
- Getting tuned at different elevation/climate....
- What kind of exhaust use for future turbo integra?
- Weird idle problems when starting the car, gone when warmed up
- Will LS manifold fit b16 head?
- Hondata/ Rc 550 injector install problems!!!!1
- GASKET SEALER?
- 440cc's upto 720cc's question!?!?
- Simple question for you HT'rs and your Dyno Graphs...
- Turbo Issues
- log style manifold
- Nitrous or Water Intercooler Sprayer kits Reviews?
- Turbo motor, how did you break yours in?
- this is wierd....
- wideband
- won't boost past 5,000 rpm
- HONDATA QUESTION
- B20 or LS??
- Wideband's on VX's... (searched..)
- your best guesstimate...
- Anyone have a good base map for aem ems...
- How's Automotorsports (AMS) in IL for tuning AEM EMS?
- So.. The SRT4 is the BADDEST 4cyl ever!!
- 453 whp b16 all out of a 2.25 inch exhaust...
- Problem regulating fuel on edelbrock kit.....Suggestions please
- hondata problem...
- I give up and feel like a retard...which cam is which?
- which spray for my intercooler
- Hotter PLUGs ?
- Autowave FI tunning?
- Hack with sc61
- are b16 turbo plugs differnet than type r turbo plugs?
- Detonating... help!
- JRSC + Power FC
- Need HELP ASAP, Clanking, Vibrating, LOUD noises!!!
- Flywheel...... how does it affect boost?...
- Turbo people list your Fuel Management Setups HERE
- HELP! Building bottom end.
- Broke 1 of my rings, need help
- Vibration up through steering wheel when on boost = confusion
- want a $11.87 Vacuum manifold?
- mild steel flanges on mani... ?
- Boost spike got me! need help guys... *pics inside*
- What's the thread of ARP Headstuds (keywords: headstud, tap)
- questions about turbo for d16y8!! please L00K and HELP!!
- Fully Built JG GSR Head....Questions...
- Suggestions on Precision turbo sizing - My SC61 is too big. SC34?
- JRSC q? w/ CAI
- need help distinguishing a turbo...
- Turbo for a '90 Integra w/ JDM first gen B16A
- Starting to build a homemade supercharger.
- White smoke/Compersion test Read
- Crushed 1G dsm bov on low boost...
- who can identify these cams?
- Our times and setup for boosted ek hatch
- Some numbers from the track tonight..........
- off topic..not really
- Want to turbo my d16z6. Have a couple of random parts. Will they work?
- Washington EMS Tuners???
- Quaife Lsd problem
- What do you think?????????????
- Does the Crower Rod have to face certain way?
- Fan/slave cylinder in the way!!!!!
- full size Radiator in a civic?
- When to Upgrade Ignition ?
- Z31 300z T3 or .63/.60 T3... whos using them?
- !!!ANY & ALL EXPERTS!!!
- Arizona Hondata Tuners Needed, Look Inside...
- Anyone know of an intercooler fed from both sides and exits the top?
- supercharger or turbocharge my b20?
- tial waste gate spring wont fit in deltagate wastegate
- stock rods
- What do you guys think of my turbo intake?
- what cams to use on my b20 with ls head if i want to go turbo?
- turbo help
- AEM wideband sensor question
- PINNED block by endyn...opinions?
- REVHARD Turbo Kit and GREDDY EMANAGE question?
- about to smog any suggestions?
- Get custom cut carbon fiber gauge panels by RacePlates-Special Promotion
- Dyno on a LS vtec turbo setup?
- Problems, built new motor!
- Tell me what you think of this idea
- Anyone uses one like this
- FS: 1997 SuperCharged GSR...!!!
- Some Help Here !! (Supercharge)
- Compression test on your Turbo B18C1 motor
- just installed drag kit and got a problem
- OT: OMG Kyle @ Wired Speed Rocks!!
- vortech aftercooler on b16 vorteched crx?
- Spark plug gap Question...JRSC GSR
- Freon based intercooler ??
- Tapping a FULL_RACE MANI for egt prob HELP
- Pics/Info---DA Traction Bars from Z10
- Computech EGT Plus
- AEBS Head Studs
- how do i paint an intercooler?
- Turbo wheel trim question
- Engine builders, please help me out!!
- good place to order silicon couplers and aluminum piping?
- Silicone Coupling question??
- NSX dyno'd at Autowave!!
- 2x fuel pump?
- Static timing with afc hack
- b16a turbo charged and braking it in...
- what u guys think of this turbo stuff? link enclosed
- Is this boost leaking from IC pipes?
- UH OH compression test result are bad news, and i'm still clueless....
- Fuel Cutoff at 7k??? B18C-R/Drag Turbo kit
- ***MA$E sucks @ TUNING!!!! Blew my buddy's motor!***
- C1 with zex....wet or dry
- How Much H.P.??
- D16z6 rev capability?
- STR throttle body?
- Intercooler piping question, Kinda weird, on SR20DET S13
- 25480L Turbocharged 2-Stroke Diesel
- snap ring removal
- Any Tips On Junkyard Turbo Picking?
- what manifold h23
- t28 smaller than t3?
- What should I get done to my head?
- quick o2 question
- Need help finding pressure gauge for zex bottle
- Earls XRP Fittings Steel Braided Lines Pissing Me Off!!
- Another o2 bung?
- Got my 38mm tial today and have a mbc question????
- 92-95 civic charge pipes
- Shotpeened rods on a boosted daily driven motor? Whats it capable of?
- A question about Shaft movement in new turbo.
- boost under high miles
- how low should i make compression on a z6 for about 15lbs boost?
- engine building in maryland/VA
- Please help me identify the flow of these injectors
- the DARKSIDE calling my name?? Opinions wanted.
- Just curious- Intercooler piping diameter size... HIGH HP- What do you run? Opinions wanted
- Oil for turbo on a 240sx?
- car started, idled. then wont start again,...
- T3 60-1 .70ar/.63
- Quick Greddy Boost Gauge/Pod Question....
- Compression question JDM B16
- Air/Water intercooler use in a Street car...Good Idea yes or no?
- Prototype all wheel drive turbo vehicle coming soon
- ? about needle valves
- Port and Polishing - Who to go to...
- another "which clutch" thread....125shot nitrous
- How to build boost before launching?
- I'm having a dilemma; can someone help me decide.
- Greddy Turbo people..need your advice. Will it work?
- Hondata!?
- procharger superchargers..
- 2.25" IC piping or 2.5" IC piping? what TB size be best?
- What all i need for turbochargin my crx si?
- Finally, My 300whp Turbo SOHC
- STRAIGHT FROM JAPAN **NEW TURBO BOV** - JDM SPECIAL ! !
- EG with B18 Turbo Question
- MICROTECH STANDAOLNE UNITS
- WHat should I do with my Y8 "Please be critical"
- the hack 270 RC injectors
- Flooding cylinders?
- spark plugs popping out when i rev?
- Anyone here make custom IC piping?
- B20a5 with an automatic transmission?
- hondata doesnt recognize 3 bar map!!!!! help
- fuel pressure problem
- My Homemade Knock Monitor.
- good idea to retorque headstuds before installing new turbo?
- bad ass new waste gate
- I need help?????
- Boost and Vacuum related issues..
- Brown Guy showed up with this...
- revhard or drag
- Log VS Tubular manifolds and the Pros/Cons of each.
- Fuel Cut ? SH Prelude 98 -
- what type of turbo
- turbo muffler or not
- final build plan
- Stock turbo GSR tuned by DRT
- Noob turbo question
- OBX inlet manifolds for SOHC's???
- map sensor question
- Battery Relocation: Pics of how you setup your terminals in the bay please
- Anyone know of a good tuner of hondata in kansas city missouri area?
- "whhhhhiiiinnnnnggggg" (noise)
- Del Sol vtec turbo tuned with hondata. Dyno pics.
- After Market valve keepers
- about air to water setup .. about the BOV
- customizing turbo kits...???
- tdo5h with FMU...is there a long term problem?
- Lovefab manifold + Full Race IC
- Quiet Muffler for LS turbo civic?
- Do IHI turbo have the same flange as a T3?
- B1 or C1 with zex??
- What is the best Affordable TURBO for a Integra 99 GSR!
- Anyone ever heard of forward thrust in kansas city missouri?
- Turbo Manifold K20
- Downpipe?
- Need opinions on a valid engine management question
- 2.5" vs 3" downpipe?
- Just got wiseco pistons for my sohc what is the coating on the skirt?
- leakdown test efficient?
- ZFR7F-11 = BCPR7E-11??
- what turbo to use?
- Stock b16a2...is 180psi compression good enough???
- tunner in fl?
- What size injectors for my turbo setup??
- has anyone made a homemade 2 stage mbc?
- checking timing
- are there temp. and pressure electrical outputs off of ECU?
- SPARK PLUGS for LS Turbo, which ones? (searched)
- Who to tune my car
- Great link i found!
- Precision Turbo @ SEMA Int'l Auto Salon
- maybe a bad FPR...
- Code 13
- 300+bhp b16a civic
- Unsprung clutches.
- 1995 Civic Si Greddy Blue Box issues
- Sidewinder vs Sidewinder cast
- why Ross piston to cylinder wall clearance is so big?
- How do you know if your piston rings have seated properly???
- swapped my injectors yesterday to run more boost, and the car idles like sh*t!
- turbo bracing...
- how does vtec affect lbs/min flow????
- Roll call for H-T members going to the CHICAGO efi101 tuning seminar
