Best cams for k20 ported head turbo, 800+hp range
Whats up guys, i current am in the middle of rebuilding my motor for next year. I am currious as to what you guys think is the best cam to support my motor. currently have ipskt1 cams , was looking into maybe kt2's or some prayoonto stg 2's or stg 3's ?
Previous setup: K20a2 , car made 761/440@31 psi
stock ported head
excessive center feed intake
90mm Throttle body
PTE6766 t4
IPS KT-1's
11:1 cpr
86.5mm bore
New setup i am looking to change up a few things on the car to make more power and be more efficient. power goal is whatever the turbo will make.... rated at 950hp
New setup: k20a2
Kmod stg.2 ported head **Flows 355 cfm @ .600 lift **
ported excessive center feed
90mm Throttle body
PTE6766 t4
11:1 cpr
88mm bore
stock ported head
90mm Throttle body
PTE6766 t4
IPS KT-1's
11:1 cpr
86.5mm bore
New setup: k20a2
90mm Throttle body
PTE6766 t4
11:1 cpr
88mm bore
Who is Mr Robot?
Re: Best cams for k20 ported head turbo, 800+hp range
I'm not trying to be a fanboy or anything but Skunk2s new Ultra/BMF cams for the k series engines look to be killer and in testing have outperformed cartel and Prayoonto cams with similar specs. However I take the dynos with a grain of salt since David does push products a lot on Facebook
Im personally not a big fan of skunk 2 cams ..... ive read to many issues about the tensioner failure that i just want to stay away. Ive been running the ipskt1's since 2010 with not issues what so ever. Couldnt be happier.
Any one know that if i were to use the kt2's or pray stg2 or 3 would there be any clearance issues with the v2p ? comp is 11:1
Who is Mr Robot?
Yea some of the older profiles had that issue. These cams I'm talking about are still being tested. Results so far look promising though.
I've heard good things about the kt1s but I don't really do enough K series stuff to be up on the latest cam choices. It seems like every week there's new drama in the K series world, typically surrounding cams (damn you Nikos lol)
On a funny note, David/Skunk2 made the part number on a K series billet part, tensioner I believe (see what S2 did there lol?) that phonetically spelled out "**** Nikos." I died.
well i know nikos is always talking about svm cams . i have not really looked in to them a whole bunch . skunk 2 is always in my mind for having bad cams , atleast for k series that its.
krystianitr
09-25-2005 08:05 AM
Going turbo. was wondering if I should sell my current all motor head or keep it for the turbo proje
obd2gsr
09-01-2003 10:20 PM
