View Full Version : Forced Induction
- What to do about a filter on my turbo
- where to find egt bung plug locally?
- Show me pics of direct port install
- My T25 Dyno #'s
- D16 small setup users check in!
- how much boost should i run?
- Just got back from tuning at Church Automotive
- 301WHP and 255WTQ with 10psi on my little mini van
- Real price or Mistake?? 1495.00 for a LS greddy kit (NEW)
- what size turbo ?
- I need help choosing a Turbo?
- spark plug NGK R5671A-7
- cheapest place to buy hondata s200 at??
- would a RB26DETT Skyline TT fit into a 94 del sol
- would a 4G63 90-94 Eclipse T fit into a 94 del sol
- Dual core intercooler
- Compressor Wheel
- Is tt ok to run 18 lbs on a fairly stock head??
- what do i need for a direct bolt on turbo, so i dont have to mess with wire harness?
- Cometic Head gasket
- JRSC Question
- My Solution to Charge pipe popping off.
- What does the trim of a turbo mean?
- 94 del sol engine swap ?'s
- Compression test results, burning oil questions
- Opinion on broke ring;ringland fixment...
- Just boosted, LOTS of problems, pleae help.
- precision "600hp" intercooler install
- new quarter mile times...d16z6 turbo
- Does the length of the downpipe effect power?
- 91 Saab TE05-12B Turbo
- high compression numbers but...
- Boosting 135k mile GSR with 240 compression?
- HOW TO: Use a 2G DSM BOV on a Honda setup?
- sleeves qestion...
- Uberdata 1.66
- WHAT TURBO SHOULD I PUT ON MY B18A1??!?!?!?!
- Oil smell 1st gear boost
- what turbine should spool faster?
- Plx wideband help!!!!
- NO oil pressure at top of LS-vtec oil line.............help!
- Wideband Sensor Placement: after resonated test pipe ok?
- Ok, after tunning your car how long did the life of the engine last
- Just installed injectors and we have a problem...
- After boosting hard car feels like it's running on 3 cylinders, but only until I turn car off
- camshafts
- >> Turbo Compressor Questions <<
- How long has ur 300whp stock block lasted?
- Problems with RC injectors opening?
- Finally made it to fastestfwdstreetcars status. New 1/4 mile times (RADIALS)!!!!
- LS/vtec turbo conversion..........now i gots no vtec......WTF mate
- Retuned with DIY port/polished head and 62402 cams...MISFIRE!!
- What happens when boost meets d15
- seimen injectors , be honest with me.
- hondata s200 with boost question (about to order)
- Can I use two gas tanks- 1 with 91 and the other with 100
- Full Race Fuel Sumps
- Something about an aftermarket ignition
- Quick and Simple Question..
- turbo sohc which is better?? v-afc or hondata
- silicon couplers?
- Help me with my intercooler piping, please!
- Those with just rods/pistons: Are you running a blockguard?
- Looking for a video of a turbo yellow hatch
- raptor...no, turboxs...YEAH!!! bring on the noise. Adapter ???
- How do my spark plugs look... ls turbo...
- Uberdata problem here(fuel related...i think)
- would this collaboraion of euipment help to make my exhaust quiet
- SOHC,11's in the 1/4 345 hp 238 trq.
- speed pro DFI & Motec.. any one have any luck?
- A Greddy SOHC Turbo Manifold Redrilled for a B-series Motor
- Crx turbo EMS?
- Are 400cc injectors enough for my car?
- Article: Wideband and Narrowband O2 sensor explained! PLEASE READ!
- Are all the Greddy 18G's for the DOHC kits the same?
- 95 civic turbo??
- Any other d-series Jackson SC peoples out there??
- Building up a JDM D15B SOHC V-TEC/ Cheaper than B16A
- Please explain block sleeving procedure?
- Clutch and MAP sensor help.
- 2001 Civic Ex (K20A2 Turbo) [Dyno video]
- questions about blockguards and darton sleeves
- DIY Dual Stage Boost Controller
- How many psi have you put on a d15b7?
- how does this work??????? scramble BIAAACTCH
- MF2 injector driver
- scramble button to increase boost 5 or 8 psi
- Does this look like a regular/normal head resurface?????
- Wiring a 3 bar on obd2 gsr
- Backfire problem on Nissan KA Turbo setup. BANG!!!!!!!!!!!!!!!!!!
- Project Turbo GS-R!! ** (Warning 56k) **
- Surging Idle after JRSC
- intake air temp...whats yours
- 12:1 FMU with RC 310 cc injectors?
- boost drop at high RPM
- Help between two turbo's
- max boost question
- Finished new gauge cluster, some pics
- Jdm D15b head on d16z6 block...a few questions
- Turbo safc settings
- Love Fab Cast Sidewinder
- Turbo to Downpipe gasket
- Turbo inlet flange. Do you guys run one?
- should i use 97+ h22 injectors or RC's
- Turbo cams
- resurfacing head block necessary? (d series ninjas help out)
- looking for info on the SVP sohc turbo (~350whp)
- quick question for the precision owners
- 90 Degree Transitioning Silicone Hose
- HELP! I got the sniffer test!!!
- aluminum flywheel and boost?
- Anybody have a SMALL turbo to donate for an engineering comp?
- 475whp on stock sleeves....
- should i remove butterfly plate?
- Need Opinions/Advice Planning To Turbo
- profec b stopped working?
- JG Engine Dynamics
- 1992 Civic Si b16 jdm..
- What will it cost for a full turbo kit on my d16z6?
- quick questions...help please!!!
- Have a LOVEFAB manifold? Help me out here....
- D16 bottom end question
- My new intercooler(best of both worlds)
- What Map sensor do I have?
- type of turbo timer and boost controller....
- OT: anyone using Microtec???
- i want the t51r turbos sound
- preventing OVERBOOST...w/ pressure relief valve
- ready to start planning turbo..
- Need Relay switch for water pump on Vortech SI supercharger? anyone help me
- Which of these 2 trannies will help on my setup, Ls tranny took a dump =(
- Anyone know where to get greddy oil return flange that goes on turbo?
- Supercharged D16!!!
- Am I a hater at heart?
- Need UberData Programmer
- Rsx Turbo...
- cheapturbolines.com
- Hondata w/ or w/o vtec controller.
- what does it take to light up BFG's in 3rd?
- Studs, bolts, and other random parts for turbo....Where to buy?
- Help- JRSC pressure switch? where does it connect?
- Does anyone have a sound clip of detenation I can't spell.....
- how to hook up a vortec fmu
- 350 + HP with Stock Valves
- almost done
- S-AFC with 3bar mapsensor & Crome
- exedy clutch juddering
- dsm injectors
- wierd timing problem , please help.
- Oil research, please take a look!
- Will my JRC 6" intercooler be a flow restriction at 350whp?
- Event : Throttle closed / High vacuum
- can the wastegate bee too big?
- Help with Boostin GSR
- turbo application... anyone here with window weld filled motor mounts???
- Quarter mile time inside... Chris gets owned by drag racing (13.3/112 MPH)
- For your F.I. viewing pleasure: 240SX-T vs. LS-T hatch
- Turbo Rebuild Questions
- turbo questions
- Finished Install (lots of pics)...Oil Leak Advise???
- injector question... searched
- What wires go where on NOS relay
- turbo on a two stroke?
- having over heating on closed b16 with deck sleeves please help
- My Endyn wanabe cylinder head work...
- VTEC WONT WORK!!!
- NORWOODS 4000 HP INTEGRA IS ON HISTORY CHANNEL NOW!
- boosted dirt bike
- need good advice on b20 PLEASE
- Which 3" Flex Pipe - 8" or 12"
- Help me understand turbo talk...
- Rev hard intake manifold....pros and cons
- Check out the Garrett turbocharger on this old race car
- GSR VS. SI turbo?
- Finally finished my vr6 turbo - video inside
- also can i fix this
- stupid how 2 do question
- Largest size injectors running on SAFCII ?
- Block finished! Pics of machine work and new parts! 56K go away!
- This might be a stupid turbo question?
- want to bulid no2 set up
- shaft play?
- What are your guys opinion on the Apexi Turbo kits????
- Quaife easy to install?
- block to condensor Clearance
- Question about Greddy E-Manage
- Correct spark plug gap for LS Turbo?
- boost control
- turbo charge pipes for 94+ teg fit 6gen civic
- im trying to put a turbo in my civic
- d15b7 with a td04
- help with boost turbo
- The finished product pics + VID :)
- what's the best NGK plugs for 99 civic si with jrsc boost 6-7psi
- quick question bout spark plug wires
- website where they sell log manis?
- getting a used dc sports supercharger for h22\h23 anyone heard of these?
- need advice wtb headgasket for boost!
- For the turbo tuning experts
- **Polished DSM Intercooler** CHEAP!
- What is needed to make 15psi on a b16a2 without blowing up
- Turbo LSVT, stock rod bolts, stock oil pump... just stock...
- Wastegate !?!?
- Incase anyone cares some guy did a write up on my car from pulseweekly.
- Where can I buy Mandrel bend dp part ?
- Most HP on Stock Sleeves with Forged Pistons and Rods
- B18B, trying to put down 350HP
- ls vtec supercharger build?
- Turbo Problem. What could it be?
- Is my turbo kit shitty?
- JRSC belt size
- Hybrid Build Up. Who Knows There Shit. Need Compression N Clearance help
- turbo oil flange
- anybody having problems with the 255 high pressure fuel pump
- new setup, downpipe help
- base setting for safc
- ls turbo numbers(impress me)
- Any Sug. on a im for a boosted b18c?
- Why isn't my turbo LS making more torque?
- just dyno'ed my b18b. Not as much as I though but stil pretty good
- AVCR: Scramble Question
- What Compression Pistons??
- where to get oil and coolant feeds.
- Fuel pressure problem on jrsc d16
- how to clean gunk off turbo? (just got turbo oil line intercooler for 260)
- O2 Feedback Question (AEM EMS)
- questions about b16 stroker kit+turbo
- 12:5 compression. NOS Dry 40shot. wierd hesitation.Help!
- whats the best way to plug the FIV hole on the TB???
- t4 turbo
- b20vtec turbo info?
- oil for turboed ex
- high hp fuel pump aeromotive vs bosch?
- Bad valve stem seals? 56k run and hide
- Who has enough balls to run this turbo???? OMG!!!!
- uberdata blew my friend's engine!!!!!
- So much farther to go....sucks
- Clutch slipping causing turbo to smoke?
- Build a turbo kit for 2,000$. Possible?
- 8psi LS turbo bogging at 4,900 rpm.. please help..
- About to go tune for first time.
- b18c5 turbo??
- 99 Turbo SI breaks up
- sprark racing manifold
- Help me! What is this turbo???
- Can I run a stock Rad.
- Which boost controller, Turbo XS?
- TURBO CLOCKING ASSISTANCE NEEDED
- Upgraded Header Studs
- question from a new guy..
