View Full Version : Forced Induction
- Do you guys think this will fit?
- ATTN: If you drive a Turbo'd B18B, please post your 1/4 time and setup, thanks!
- goig turbo on my 90 b16a crx, have a question about clearance
- Will old AFC hack work for hack?
- hondata tuners in austin
- who sells built motors?
- Piston and Ring Damage
- Completed Results of our D Series Head Porting Project (56K Beware)
- Will a B18c5 (type-r) LSD fit in a 96 LS tranny?
- HELP! Turbo for 2000GSR
- ecu brains, what do you think?
- Can INLINE pro head gasket be RE-used
- Let see the chicks representin the boost...
- r
- What Kind Of Fuel System Do I Need
- My inlinepro headgasket is leaking!
- What would be a good turbo?
- OT: Is 140mph possible on Radar or GPS with a civic?
- td04 15g Greddy Turbo on a b18b
- Butt Weld pipes in the bay area (Ncal)
- ... eagle rods... h-beam vs i-beam...
- what oil pump is good for 550whp!!!
- Need help with clutch...ASAP!!!
- Anyone use an 80mm gauge on an integra?
- Supercharged, Turbo Performance CLICK HERE
- Custom Turbo kit - What combination to retain A/C?
- OT: RIP JDM GSR 1000288
- best piston/rod combo without sleeves?
- My new downpipe, opinions and criticism welcome :)
- turbo mafia t shirts whos interested pics inside
- Apexi Turbo timer install on crx
- T3/60-1 Questions
- Need 5,6or7psi spring Help!
- compressor on driver side..advantages?
- Oil coolers? ARe they hard to install yourself?
- Neon SRT-4, I'd get it
- GReddy Turbo Kit install problem
- dump tube question
- Did I buy the right stuff?
- HT newbie
- ls/vtec and JRSC w/ 6psi pulley
- Max Rev kit, vs. a Stage III Drag kit.
- turbo shirts
- should i start my car with stock ecu/will it be ok?
- JRSC air/water i/c thoughts.
- F22b turbo help
- faulty wires around my ecu are causing my car to die
- where can i get a cheap oil catch can.... i mean super cheap
- How well would this IC fit?
- Please help, I'm stumped!
- ... 3-bar map sensor with hondata
- ... fuel system upgrade... 300-350whp...
- sohc vtec greddy kit being a pain in the ass...fitment problems, common?
- Can i reuse my bearings on a rebuild????
- ls/vtec turbo questions...
- Nylons and FMIC's
- Can hondata OBD 0 with pr3/pwo run a SOHC
- Very Informative ish! Greddy/Int. gate peeps, read up!
- SixtyDashOne....Me....and my car! (not 56k friendly)
- 100,000 Mile D16Z6 Greddy Turbo What Do I Need
- please, please just answer this questiong about my inline
- fields vtec/fuel controller
- Anyone selling an air filter piping to the turbo???
- 3 inch V.s. 2 1/2 inch exhaust on a SOHC
- What do you do when Smog check comes around?
- Pictures of the egg-mobile!
- 0-60ft times before and after LSD
- yes! my fuel system is almost complete!
- inline pump....12v? toggle?
- turbo guys please help me out!! thanks
- F22 build up
- How do you make a $80,000 Type-R
- misfire codes with greddy kit
- HKS SSQ BOV How Much Boost????
- difference between b16a1 and GSR cams? exhaust the same?
- Do turbo's need to be broken in?
- flow specs for walbro intank pumps
- Hmm, thoughts on this?
- wiggins clamps?
- b16 w/gsr trans,better for boost?
- oil return line help
- How much boost with FMU + Inline
- Please help ASAP Gap for spark plugs??
- Boost Spring Help
- OT : my godzilla back on the road !!!! :D
- Wastegate Install Question
- turbo oil pan?????SOHC???
- Autotune here for Hondata!!!!
- Dyno day in CT, vwvortex.com, but hondas are def. welcome !!!!!!! =) =)
- boosting but not goin anywhere
- big nos = what kind of engine mods?
- any stock b20vtec turbo boosting?
- methanol Madness!!!
- For all u b20vtec turbo
- hf manifold on a d16a1
- 5.0 Injector size?
- WTB/ Need a 99 GSR ECU.
- Injector pic need help
- Found some cheap new turbo stuff on ebay..?
- Liquid Intercooler
- ALL mtr to TURBO
- Ideal B-Series Turbo Gear Ratio?
- How do I tune St00pidly?
- overboost killing horsepower????
- Good Idea? Octane Related
- Hondata vs. AEM EMS
- Is an external coil with the modifed cap worth it without the ignition box?
- Which Precision Turbo??
- Whats the next step for power?
- oil feed line help
- Picking The Right Hondata System for me?
- what boost gauge should i run?
- Need to upgrade brakes...Suggestions????
- got mt AEM EMS what the hell does "non factory FI vehicles require additional hardware"?
- wiring accessories with standalone?
- Power steering fluid leaked every where, now I hear weird noise from the belts???
- Effects of inline fuel pump on stock FPR and stock intank fuel pump
- How can you tell from Aluminized Piping to Mild Steel piping?
- copper fuel line
- Humming noise in new turbo install. Coming from fuel pump?
- What do you think of this manifold?
- CRV Pulley on a JRSC B18C
- EcuControl.com, any luck?
- greddy oil filter "sandwitch" adapter for sending oil to turbo
- How big is Maxrev Intercooling piping?
- Will my clutch hold? if not, what will?
- turbo/bov flutter?
- Hondata 3-step option, or MSD 2step??
- H22 turbo hatch pics and dyno video
- Best Place to get o2 bungs?
- do you really need a BOV
- What whp is the rev hard IC good to?
- Post pics of integra gauge pods...
- APEXi IHI turbo, which is it?
- Want to post to classifieds... how to get rid of the trial user status?
- Manual Boost Controllers
- CAMP1320 Spark manifold pics
- help with turbo.
- blank turbo castings?
- Map Sensor Flange
- diy: Downpipe...need help
- anyone using 75lb. MSD injectors with HONDATA?
- Best intake manifold on a FI h22
- Do I need Sleeves??
- 18g question
- vibrating from drivers side when car is hot
- Dynos in Michigan?
- Greddy turbo guestion??? possibly stupid but tell me why?
- Cometic Head Gasket for Turbo?
- how can you tell the difference between ball bearing and non-bb turbos?
- pics of my friends turboed, built, 90 integra.(56k beware)
- b2ovtec turbo help
- shave block question
- Friday is a big day!!
- why nitrous good with high compression ??
- b20 vs gsr oil pump
- Any Socal (OC area) Dyno Hookups?
- fuel issues with gsr
- how many lbs to recover NA hp??
- B&M Vibrating fuel pressure gauge kicks ass!
- MD VA WV H-T members
- pics of the new manifold and wastegate
- Gasket help
- how much boost?
- funny dumb idea
- nitrous refill question..
- Any probs running new fuel injectors without tuning?
- ? about my inline pump (wires)
- ?'s about downpipe bolts/gasket
- New pics of the $hitbox
- World Electronics boost controller
- IHI R48C Turbo?
- Drag Gen 2 IC install pics from 5th gen lude (cutting bumper support)
- Cheapturbo.com Comments?
- B20B
- just so u know ......about the apexi turbo kit
- You turbo guys should like this. I am swiching from JRSC to Turbo. Help me choose my setup.
- Road Race Engineering Resonators
- What size's of silicone vacuum hose are normally needed for bov's, wg's and boost gauges?
- need help on tial 35 mm wastegate.
- 2.5" or 3" exhaust??
- b20 Turbo Help!
- Anyone got pics of their type 31 greddy intercoolers?
- How to break in new motor for Turbo?
- I need some help on how to move a front clip aroud
- How do I get rid of Code 90?.....Please help!
- $2,100 for a CRX is this good or bad!
- how to install inline fuel pump
- Need To Know If This Price Is Fair? B18C1 Sleeved
- Piston Ring Question
- First time Data Log....NEED HELP!!!!
- Accord turbo manifold (4th gen)
- Good size turbo
- anyone having trouble getting into vtec under boost?
- What clutch is best for a SI/W A Greddy TK
- JRSC Crank pulley's
- Quick pic of my engine bay.
- what size injectors???
- Turbo help
- NOT a honda but turbo related pic
- oil pump questions!
- turbo idle ?
- Boy do I feel ignorant...whats the AR and trim for my turbo?
- Oil line feed installed. Broke Oil Presser switch.
- Apexi Kit for the B series ...
- the "replacement"
- reusing some head parts
- Questions on Intercooler Piping Diameters
- Request for: IC Piping Diagram For DC integras
- To answer a lot of the intake manifold mysteries...
- BOV Location?
- Spoon Exhaust on a Boosted car
- Block gaurd???
- Golden Eagle Mfg Titanium Fuel Rail Pics!!!
- Hondata S200 w/ factory injectors?
- Pictures finally
- best compression SOHC
- hondata & techedge help
- Car won't start, need help...
- Sohc turbo maifold on a dohc?
- Does Greddy injectors 720cc make low resistor injectors?
- Stock LS with a 60-1?
- EGT probe in manifold? bad spot????
- Oil feed for turbo...
- jackson racing 250 hp ls
- Working on fuel system for NOS and some day turbo
- Greddy Type-31 How much HP?
- Making a turbo kit...need help on turbo size
- Remove stock o2 for wideband tuning?
- Drag Gen III - Downpipe Picture Request
- general a/f tuning question
- apex'i autotimer a/f help
- Golden Eagle Mfg.
- Dallas boosted hondas:
- knige-edging a crankshaft
- Manifold Pressure Testing, Flow Testing, ETC --- NEED TEMPORARY DONORS
- 1600cc Injectors... What fuel rails???
- Any Automatic Hondata user???
- which turbo kit for 92-95 civic ex coupe?
- ... blockguard... recommendations...
- Hondata Now Has AUTOTUNE
- whats your fuel pressure at?
- OHH NO...Shaft Play?
- Greddy Type-S BOV... how do I make it stop fluttering?
- Maximum boost with wastegate spring and boost controller...
- How much boost can I run on my stock gsr
- Identify this injector (RC)
- Questions About Turbo Setup
- What axles do you run?
- max rev diy piping
