View Full Version : Forced Induction
- T-bolt Clamp size?....
- Silicone Intercooler Pipe???
- help car hesitates after 5000 rpm
- what pistons are these
- LEAN! Fuel Pulsation Dampner - Could It Be Causing My Problems?
- No boost..
- water air cooler
- anyone have a turbo ef w/ a b-series turbo and air conditioning?
- 38mm TiAL wastegate diaphragm ripped
- 3 bar map sensor question
- IS NGK 7 VPOWER COPPER PLUGS GOOD FOR TURBO
- NEEDD YOUR OPINION> SLEEVE DAMAGE
- what stock transmission is best for a turbo b-series?
- can a d-series manifold flange be swaped for a b-series one????
- Intercooler Question
- Tilton dual disc + H22 =
- motor oil
- Dealing with Zex Hyperformance Plugs
- Lost Tial 38mm WG nipple can i use brass fitting????
- My 400whp straight ls build...
- What NGK plugs you guys use?
- Best for the price Clutch/Flywheel combo
- My catch can gets full in 4 days...
- how much power can a d15b7 hold?
- HP Estimate based on Duty, Fuel Pres, AFR, RPM, etc...?
- best place to put blow off valve?
- cat. converter
- i need a machine shop in miami fl
- Update from my setup.. Teal Hatch CF'd out with a timeslip
- Video of Hondoctors 96 Turbo Integra GSR 4door, 500+whp
- any thoughts on my set-up? 2.0L dart
- GAS TANK
- ???F22 how much boost can a stock 94 and up F22 hold with out blowing it??? plz help
- Do you need turbo in order to add a BOV?
- Options for my B18C1 Head...need help
- What wastegate elbow are people using with their Meutek manifolds?
- Jackson Racing Stage 3 Supercharger Price?
- GM 3Bar & Hondata S300 & Picture
- eBAY boost controller ?'s
- ecu help
- What Turbo to run on LS-T and keep A/c,P/S with inline pro SS mani?
- how much boost can can i run on nippon pistons
- FAST wideband controler
- Edelbrock Performer X Turbo Kit.
- head gasket???
- B18c or B20B
- Have a question would like opinions
- No Vtec ...........has my solenoid gone bad??????????
- 4 vents on valve cover
- anyone run ngk 9's on there turbo setup
- Stock flywheel or aftermarket flywheel?
- what holset turbo to use on an s2000?????
- gt35r
- Car won't go above -10 vacuum!
- wastegate issues, and questions. help is appreciated.
- gsr sleeves
- Gsr turbo tranny
- Intercooler size
- Need some advice on turbo return line from block on a gsr
- nitrous and piston question
- A/C and turbo manifold question before I start install
- Anyone running a PROLOGGER??? (no answers on there site)
- Oil lines
- Some Minor Questions Before Boost (Yes Again)
- turbo sohc, boost spiking? wastegate spring? Help thanks!
- need help with mbc install
- When ordering a Motorola 2.5 bar map sensor from Digikey.com...
- turbo
- re: ebay sandwich adapters any good?
- Anyone else have a "black cloud"?
- Switching tunes & Boost control with A/C button
- hondata question
- will a b16 handle a t20
- Diesel Truck BOV Neat Innovations
- oil restrictors
- Main cap studs????
- bolts on around bov stripped
- catch can options??
- Tons of blue smoke... compression is 150,180,150,180... HELP ME
- looking for some info on SRP piston
- t3t04e downpipe flange question
- Missfiring with turbo....
- GT30r + b16: .82 or .63 housing, spool time, and its effects....?
- fuel pump relay voltage
- boost controller for supercharger???
- top mount or cast iron????
- what would be better
- VAFC WITH BOOST HELP
- help with Supercharger installation
- help wanna order new boost controller today AVCR,AEM,Profec,blitz sbc lmk....
- I need a .63 a/r 4-bolt Precision housing for my SC50. Best way to get one?
- Master Power Turbos?
- reliable b16 300whp, stock rebuild ok?
- I want a b16 ef with a/c, what mani+downpipe combos are there?
- Realistic power expectations for b16a2 with peakboost kit@6.5psi
- Is it neccessary to use an additional sealant (copper spray) to install head gasket
- Technical discussion-PSI relation to Torque and Turbo Size.
- 85mm DART block, HG suggestions...O-Ring? Stepped? Need input
- anyone running this?
- How many of you tuned your own setup?
- Plugs are white but AFR Reads 11:1
- hey have a boosted civic
- Adjustable FPR Needed?
- timing on b16??
- Ibeam forged rods+rs-machine oem pistons handle 100 shot
- anti lag :::Searched:::
- Big 16g evo turbo
- b18a1 gsr tranny ....?????
- This Sh*t depresses me!
- Blown Engine :( Pics >>>
- any cheap places that can weld me some piping? in socal
- where is hermsfab???
- POV, Pop Off, relef valve question
- loosing boost at 6.5 - 7k rpm upwards
- Had a little dyno accident...
- EBC "Gain" knob?
- Problem W/JRSC'd Type R
- new dyno #s with the 35r
- street tuning
- looking for a good machine shop in South Florida
- Fuel PSI for DSM 450's
- Ls turbo thoughts on hp and tq
- gt series manifold
- high HP on importbuilder rods?..anyone using them??
- gt series turbos
- car bogs off the line and i can't figure the problem, need help.
- Nitrous Gurus! I need help on big bore high compression ls/vtec
- Piston expanding??
- clip of dyno 30 secs ls vtec turbo ek
- oil leaks on the back of the compressor housing
- How to mount JRC 6" IC on EG?
- TONY1.. post your catchcan setup
- i have a aem ems with a wideband do i still need a boost controller
- bov problem..
- Highflow Cat vs. Test Pipe
- Dont get a card in your parents name with out them knowing for a turbo build.
- Tuners-Running lean after 6k.
- my zc turbo i have vf8 vs ct26 ???
- back from the machine shop
- ***Going Turbo GOOD or BAd Head B16***
- Ever heard of a turbo binding at a certain psi? I'm stumped.
- before tuning.
- Denso universal o2 sensor question
- Jackson racing fmu and main relay
- Innovative LC1-XD1 Hookup Troubles
- Questions about Low Compression b16 motor with Stage 3 GT full race turbo kit, spool times
- shitty luck leads to this headgasket question
- Hondata s300
- Breather tanks
- help with turbo on an 03' accord ex-v6
- Why am I still pushing coolant??
- 15g greddy kit on a 00 EX? carb #'s still in effect?
- how to check wg spring psi
- Are these gsr cams?
- Pistons H22A1 turbo
- lay off the boost till new rings break in or no?
- Best Builders
- 99 SiR b16a2 turbo
- Fuel Questions
- do you think it would be safe to boost my motor?
- turbo h22 can u use a stock fuel pressure regulator ???
- My lil dyno video.
- Should I Supercharge or Turbocharge My EP3
- intake manifold for b18c4
- Gsr turbo
- motor mount brand advice
- homemade or not?
- full race stage 1 gt28rs kit?
- Engine dyno testing Bullseye Power
- Fast Idle???
- MY DRAG CAR PICS
- RPM 76 mm Throttle body
- prelude Si turbo
- Help me identify these pistons
- anny has a Dyno Sheets from a xs-power turbo
- Help finding a manifold
- Block Guards
- manual timing? "tuning"
- cc-fab/CTP B-series Ramhorn review.
- Where's the Synapse engineering BOV?
- i have a question
- my Sc60 topmount setup
- removing butterfly valves off IM
- Weird Vacume Cans on b18a1 manifold
- ..Bov Identification....
- witch single cam can hold more boost
- Elect. Boost Controller locking feature?
- 300 hp A6, 680 injectors, FPR needed?
- Built Sleeved H22 Turbo Reliability
- t4 turbo manifold for a 600+hp H22 engine.
- alot of people probally ask this question but posted some pictures to let u know im serious
- Just pistons?
- single plate carbon clutchs?
- ITR or PR3 intake valves?
- stock cylinder sleeves and boost
- DSM BOV not holding 10psi? WTF?
- Dyno my car yesterday.
- OBD2 Tuning
- any turbo regrets?
- new clutch install..whats wrong??
- t3 60-1
- Its been a while, is the new Neptune out yet?
- A few questions about doing an oil return line from the turbo.
- anyone got pics of EVo's intercooler on a civic?
- GT4088R -Top mount
- Almost ready for a tune.....
- Thoughts on using scavenge pumps for low-mounted turbo's oil drain
- turbo b18c1...opinions please
- quick bearing question...(ACL's)
- bored d16 ok??
- E-manage
- Hondata S300/Wideband Question
- updated pics of my sfwd car
- my dyno results....car jumped right off the dyno on 1st pull :( vid inside
- Ignition timing map for H22. Please post sample map for boost
- Advanced igniton timing... can it cause overheating?? Help please.
- Safe Ebay things?
- picture of eg civics with intercooler and fog lights
- should i get a new turbo manifold??
- Top Mount VS. Ram Horn... Need some opinon's...
- supra help please
- Intercooler fitment(EG)...Searched
- Vacume Block ...???
- vacume source making a big difference?
- OEM headgasket for boost?
- newb catch can ?
- how much hp do you think?
- Stock Cams or Crower 62402T-2 for LS/Turbo set up
- Tuning Problem on turbo b16a2!!!!
- new dyno numbers...
- Quick Question, plz help!
- GSR cams
- Which E-Manage?
- Tony 1 tune e85 10lbs boost
- nitrous ques?
- Who can tune E85?? need to be in the Southeast!
- I need 2" to 2.5" silicon 90 coupler......
- Automatic turbo EG6.....?
- Nitrous Single Cam
- wich best crank for b20vtec 550+hp
- Shaft Play..?
- Help with choosing a boost controller
- longest lasting twin disk?
- turbo questions
- what spark plugs you guys run on turbo setup
- Boost creep from hell!!
- Bearing Clearance
- best headgasket for boosted A6?
- Oil Temperatur In Turbo GSR?
