Just cracked a sleeve. Recommendations for sleeving?
Well it's 2015.. I have been around for a long time, but no experience with sleeving. I've done my share of searching.. and a lot of the threads i'm seeing are a bit dated.
I cracked a sleeve last week on the dyno in my piston/rod b18c1. Are all the older companies that sleeve still being used? Are there any that are more popular than others? Are they all pretty much the same in comparison? Price isn't really an issue, just want it done right (but please don't be afraid to share price as it will be taken into consideration). Looking to send my block out this week and would like those who have sleeved their blocks to give input/recommendations. Really only looking for a 4-500whp street car. Not sure if there are a particular recommended sleeve for that power level since i'm not building an all out race application. Turnaround time would be helpful too for comparison purposes. Thanks in advance
First lets see some carnage pics and figure out why the sleeve cracked<br /><br />How much power and tq were you making?
Re: Just cracked a sleeve. Recommendations for sleeving?
The motor is not torn down yet, but will post some as soon as it is. 9:1 JE pistons/Scat rods, stock gsr head/cams. Last pull the car made 370/250 on about 21psi out of an older school BW t04e 57 trim. Just took the motor apart for a rering not long before the dyno and also had the turbo rebuilt. Motor showed lots of blowby out of the VC breather on the dyno, so it was probably on it's last leg. It also had about 40k boosted miles on it. I never got it compression tested before the dyno so I'm not sure on those numbers.
What kind of fuel? When you put new rings did you hone? What was the ptw gap? Blow by means oil in the combustion chamber which leads to detonation
93 octane. Yes the block was honed, not sure on the ptw gap. My friend helped me since i've never done rings. We just left the ptw the same as what it was when we took them out, which matched what the JE instructions recommended for forced induction applications.
DO IT ON ALL FOURS
Benson is a PITA and does what he wants because he "knows better than you". Go with Golden Eagle or Darton (themselves). GE will be quite a bit cheaper than Darton, but you can't beat the single sleeve replacement of Darton MIDs.
With that said, the turn around time is ridiculously long and I'm pretty sure he's more expensive than darton or GE
I have a Benson block. The previous owner had issues with the sleeves sinking right after he got it, but sent it back and it was corrected and been running it since (2008) with no issues.
It will depend on how bad the crack is also some places won't sleeve it. I went with benson on mines. Sleeves are still good on the third build.
RS machines is also a decent sleeved option and is used on most of my friends cars. No issues running up to 900hp can vouch for.
And price is decent as well
got my rs sleeved block, supertech piston and skunk2 alpha rod setup for 1800
DO IT ON ALL FOURS
Some of the most respectable people on TI pushing pretty nuts hp number on their builds all personally recommend benson for his superior craftsmanship, as every block is sleeved by him personally.
I can vouch for Opel Engineering in chicagoland. Any brand sleeves you want, any specs you want. Ted is a really knowledgable and experienced guy. You can ship to them.
Welcome to Opel Engineering! | Opel
"We are responsible for setting over 10 National records. We have 4 national event wins, 4 division wins, a division championship and a runner up world championship."
Thank you everyone for the recommendations. I've decided to go with Darton mids as I'm getting a killer deal through a friend I can't pass up
DO IT ON ALL FOURS
moderator emeritus
