View Full Version : Forced Induction
- B18c: 50 trim eBay turbo - Pump Gas Dyno Tune
- turbo kit? ahhh so many choices :(
- help me understand this!?!?!
- anyone got this for sale...
- midwest j&s cuztomz crx topmount
- What Boost Controllers Everyone Using?
- building h22a for turbo questions!!!
- Is this Turbo Right for my goal (425-450whp)??
- gm map sensor id.
- OBD1 LSVtec Turbo Questions...
- Questions About SingleCam Turbo
- boost+nitrous
- billet 6262
- how necessary is an oil catch can?
- Mac valve hookup confirmation 35A-AAA-DDBA-1BA
- Built single DP and a other questions..
- License plate with intercooler
- someone explain? P2W info?
- does honda injectors clips fit onto DSM eclipse 450cc injectors??
- turbo wont kick in
- Turbo size
- What do you think of this turbo?
- questions about damage srp pistons, and marin bearing caps/bridge
- E-Cutout
- Compressor housing nipple broke!
- is blox any good for f/i ???
- check this out!!!
- ram horn question
- Which 84mm Piston ring set to go with?
- D16z6: 60-1 9:1 Compression - E85 Dyno Tune
- E85, whats all the hype??
- question about boost by gear install
- time for a turbo rebuild?
- Identify this turbo, please!
- aluminum rod question?
- D16Z6 Turbo Build Parts List Help
- aem tru boost install questions
- Injector question E85
- Intercooler size on 92-95 Civic hatch?
- Sensors worth changing...
- areomotive a1000
- crome causing problem with Main Relay??
- injectors wont fit
- FUEL INJECTORS DONT FIT???
- Lower radiator hose hits Intercooler Piping?
- 3" turbo back exhaust with one resonator, no muffler..
- Is this normal for a Benson block...
- post your "FORCED INDUCTION" stock sleeve B20vtec builds...
- TOTAL SEAL PISTON RINGS ANYONE USING THEM?
- OIL CATCH CANS??
- B16 TURBO CAMS WHICH ONES BEST?
- D16 TURBO CAMSHAFT
- 85.5mm block
- After Market Pistons Stock Rods?
- ls vtec
- Questions about dual gates and controlling boost
- manifold runner length and spoon time
- h23 turbo build need help
- Putting the power to the ground?
- billet 62/62 vs BBT72 dyno
- My turbo build hatcccch..
- Do i need an oil restrictor???
- Advice on best motor oil for use with E85
- blown turbo seals?
- 3" DP and (2) 44mm WGs to 4" exhaust?
- Quick Question About tuning!!
- I need some info on diameter of ls/b16/gsr crank journals.
- poor mans type r: how much boost?
- Holset turbos- has anybody ran em?
- help identify this turbo
- boosting my stock civic need help!!!!
- PTE T67...Any good?
- Ebay Turbo DO Suck....
- Flange Compatibility Question
- tial wastegate vac port exhaust gas
- QUICK QUESTION NEED A QUICK ANSWER ABOUT JRSC
- ODB2 RESISTOR BOX WIRING::NEED HELP!!!
- NEED HELP!!! CAR WON'T REV PAST 5K RPM
- NonovUrbizniz's D16Z6 Turbo Build - like the Energizer Bunny, It keeps on going
- can't clock turbo
- No idea what turbo this is
- Will Talon 2g Denso 660cc injectors work?
- Air Werkes S400SX B16 dyno graph
- best performing half size intercooler
- Oil feed help...
- I think im going to throw in the towel...BUT I CANT! ;P
- Holset H1C + Log + EF = clearance?
- Finally got my car figured out: ITR with JRSC
- 1000cc Fuel injectors
- Wastegate questions
- NEED YOUR HELP TO BUILD MY 1ST MOTOR
- Difference between T3 .48 and .63
- blowing smoke turbo was good
- Whit smoke low comp
- help on cams setting for cam gears
- help finding adapters and piping for my turbo crx build
- dsm 440's and walbro 255 to much fuel for b20b?
- Defective gt3076r
- Looking for some intercooler measurements (fin count, thickness, etc.)
- at what point should you replace the stock valves
- Oil temperature
- Can use this turbo ???
- building your own manifold
- GT4088r (top mount)
- question about a gm 3 bar on a 92 modle civic
- does raceworks turbos exist
- B20-Vtec-Budget Build!! 13.2 psi 381whp
- b18c1 build questions
- Catch Can Install Help
- BLITZ Access ECU
- turbo size for d-series
- Vortech Supercharger for Civic Si (b16)
- Does the new billet 6765 come in a t4 twinscroll housing?
- best tranny for boost?
- Stock internal b16a turbo ??
- fully built darton lsvt setup please help
- I want strat turbo project in B16A..plz help me
- Throttle body swap? hard start?
- 44mm gods speed waste gate
- B series Blox turbo manifold fan clearance???
- i need help with a t25 garret turbo off a nissan.
- Turbo d series question
- Acceptable EGT's?
- Pump gas
- Turbo selection for all out K-Series
- K20z3: Greddy Turbo Kit / FlashPro - Pump Gas Dyno Tune
- turbo b18b high idle
- Finally stopped being lazy
- Nevada Emissions Question -- NV Guys Chime In!
- OEM honda b20 headgasket same as Golden Eagle 84mm Headgasket??
- How much HP?
- turbo
- Spark Plug Question
- Jdm B16a with Boost Question
- spooling performance or rcautoworks manifold combo?
- cost of a turbo set up for b18c1
- H22 Twin Scroll
- oil pressure sensor on obd1? plz help
- Help : DSM 440's In 89 B20b Hatch
- Pin size hole in an aftermarket sleeve.....have you EVER seen this before?
- What can stock B16 rods take...LOL?
- turbo inlet size HELP
- my budget set up... what do u guys think?
- Need help on turbo selection
- Engine Cooling (Radiator/Fan)
- JRSC Woes.........Dropping boost
- Stock internals on boost Success or Fail ??
- B16 Turbo Qustions
- Wastegate fitment issue...
- TURBO EXHAUST HOUSING CRACKED! HELP!
- help! car wont pass 3500 rpm.
- looking for topmount with ac
- Input on crank selection for sleeved b20
- Blox B18 turbo manifold question....
- questions?????
- turbo choices.
- H22 Turbo/stroker block suggestions
- About to build my motor inputs would be nice
- H22 Fully built Turbo Setup
- Gauging interest/Garrett GT32R Turbo, Intercooler, Oil lines, Boost gauge, IC piping
- TIAL 38 or TIAL 44??
- How much power from a stock gsr with t3/t4?
- OBD0 engine management, anything better than TurboEdit?
- D16y8 w/stock internals?
- TIAL V44 Questin?????
- best size intercooler for 350hp goals?
- budget b18.c1 build ef si hatch
- b20vtec build ?s
- TURBO TA3404
- GSR catch can or breather???
- Looking for FI ideas for a fun, street-driven 300whp EM1
- Gsr Turbo
- has anyone ever been satisfied w/ ssauto?
- It's finally finished
- Need help! 250hp on 16 psi?
- FI GODS PLEASE HELP B16-T ISSUES
- TD05 14b for my LS???
- Need Greddy Blue Box pic please!! Help!
- BOV not working!
- Ramhorn manifold Cooking hood
- Temporary FMU Use till tune B16 Need Help.
- Downpipe flange, did anyone ever invent a 5 bolt -> v-band adapter??
- Question about tuning company.
- turbo b20 ef build
- NEED Nitrous help 03 accord v-6
- Turbo with A/C?
- quite 3" turbo exhaust?
- D16Y8 REAR O2 SENSOR ON P28?
- IAT SENSOR:::NEED HELP!!!!!
- are my compression #s low or ok??
- d16y8 turbo
- RC SL9-550 question...
- 3 inch downpipe pic request
- 15g Turbo power capabilities
- How much HP can 310cc handle???
- Gasket on dumptube?
- Clutch recommeded for 350-400 hp
- Big Turbo
- what clutch to use 450-500 whp?
- black intercooler
- exhaust housing wont hold turbine housing
- CAN SOMEONE SEND ME A LINK OF THE 800hp GUYS
- BW S362 ett vs Precision 6262sp.... setup inside!
- what size coupler for stock GSR TB??
- Fuel systems!
- SRE integra IC piping kit???
- gt35r ok running low boost?
- FPR- CAR WONT START!!!!
- Recommended Gauges for Vortech Supercharger
- 4 Bolt Flange?
- Anyone running a Blackworks racing K series manifold?
- What to look for in a tuner?
- TURBO WONT FIT!!!!!!
- which style do you like better?
- help identify turbo
- d16z6 turbo build
- Identify this inlet flange?
- Good money to be made
- Need help deciding between my 2 turbos.
- B18A: Engine / Turbo Build - E85 Dyno Tune
- New Dyno numbers.... 600hp+ on stock K20a2 block
- ls/vtec builds boost then backfires ans falls flat
- B16 head -vs- GSR head for boost.
- compressor surge..
- D-Series help
- Turbo ? for you big hp guys
- dsm injector question
- b18c1 turbo build
- B18C1 Knocking.. time to build it up!
- ECU questions....
- Pros and Cons Of sleeveing an LS block vs a GSR block?
- Apexi Turbo Timer
- WHAT YOU GUYS THINK ABOUT THIS
- electronic exhaust cutout
- lsvtec turbo build
- ?'s on JRSC
- turbine?
- Highest hp on 91oct with "saftey" in mind?
- question please help
- which cams to get?
- how to store a turbo?
- Recent build.....
- NEED HELP car bogs after 2 grand.
- t3/t4 60trim (dyno graphs wanted)
- Car wont start after disconnecting 2.5 Motorola MAP Sensor HELP ASAP PLEASE!
- oil feed size !!!!!
- looking to boost my em1
- Questions about Garrett .42/.48 on a honda
- Ebay Turbo, Ye or Ne?
- FOR YOU AFI GUYS...HELP!!!!
