View Full Version : Forced Induction
- Advice Needed: Stock B18B Turbo
- where to buy 90 degree metal elbow
- GT Series BB turbo's.
- lsvtec 307whp on 18psi with turbonetic t3t4 is something wrong?
- turbo sizing.
- Car sputters
- getting hot , turbo sohc
- Upgrading internal components for more boost
- stock b18c 8 psi - turbo selection
- difference in feeling between detonation and misfire
- Turbo On 2000 GSR. Fuel Problems? Air/Fuel Lean. DETAILED
- my precision intercooler mounts, "upside" down style
- Can i run a t4?????
- How much for turbonetics T60-1
- Throttle body for M-Cutout
- Question for D-series turbo guys
- exhaust leak questions...
- T04
- Rocket Motorsports springs/retainers
- HP limits of a Walbro 190 LPH
- Need Help PLEASE!!Wastegate issues
- Would like to pay someone local (soCAl) to burn me an uberData .bin!!!!
- max psi on 91octane with 9:1c/r
- t3 60 trm .48/.60 a/r VS t3/t04e 57 trim .50/.63 a/r for a stock b18b???
- Quick timing question. Brain Fart
- obx Turbo Inake Manifold h22
- Full Race Robotic TIG Welds
- bov flange...can you?
- block guard installation without taking it to a machine shop? Yay or nay?
- Do i need to rebuild my motor to run a turbo?
- Looking at buying a USDM drag/turbo CRX but im in the UK
- Name that part !
- What Happened?
- Is a T3/T4 too big?
- Who do i ask about turbo prices here on H-T?
- Si engine swap
- Help on piston/rods decision and install
- Best Vtec point for boosted K20?
- UBERDATA Info
- Just drove my first 400+ whp Honda....
- inch pounds vs foot pounds ????
- Opinions on Road Dynos
- HOW ABOUT A B18A1 + TBO335 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- how many Hp will i make w/ my z6
- d16z6 with garrett t3 .48-.60
- might have too big of a turbo on my hands
- Blown seals + crankcase ventilation
- plugging up oil feed line?
- b20/b18b supercharging questions...
- VSV PERFORMANCE IN CARROLLTON TX IS MOVING!?!?!?!?!
- AEM fuel rail and Precsion turbo injectors on an H22
- Trying to trick the overly intelligent OBDII ECU.... Idea #45,132
- vortech blower on itr... not your same old questions.....
- length and diameter for vacuum lines?
- Good Turbo Mufflers (Quiet)
- SC61 which wheel..???
- what is a good Turbo?
- Looking for S-AFC II Tuner (dyno preferred) in Washington, have $$$
- 519whp on PUMP 91 Octane
- Blitz BOV question
- summit cutout experience?
- Crown Series DIY kits?
- TEO4H
- engine builders - largest end gap on compression ring?
- Turbo turbo turbo!!
- GT30R vs GT32E
- Manley rods?
- Tuners around Tampa
- any uberdata users in Phx ?
- SOHC headgasket issues and dowel height size?
- Buying used internals?
- Need Serious, Realistic Answer. How Practical is a 16psi setup, daily, little knowledge... Seriously
- nos b16a question
- what is Q31 on the ecu board???
- Anyone ever seen a brand new t3 go for...
- Most Powerful stock stroke B16A in the World? RLZ Engineering Headwork!!!!! Dyno charts inside!
- Anyone boosted a CRVTEC?
- 93 octane @20psi?
- Debate: Dyno Tuning vs. Street Tuning (tuners chime in)
- Oil Pan Tap
- how much can a stock H23 produce on boost?
- Who can do a Direct port setup for me on an H22?
- Turbo oil feed/return lines, help on sizes, and diagnos a related prob
- Turbonetics 60-1 or Precision which one???
- Ok i tired the search but i cant find the vitara d-series piston threads
- What size downpipe for an open downpipe?
- For a supercharged setup... what is better?
- Q on combo turbo?
- What type of turbo?
- Turbo too big or just right for D16?
- Anyone here run the Autronic PnP, read me
- Need help on wiring gauges for DC2!!
- off topic - problems with my order at importparts.com
- valve measurments
- I have no serial port for dataloggin will this work?
- Once i was FI, ran a little hotter on coolant temp, Is a lower temp. coolant fan switch needed ...
- costs for tuning?!
- Question about nirtous kit
- Civic has an odd problem... help
- Can someone please check their injector volts for me?
- Totall off topic, but i know the answer is here. Boat related
- help with b18c5 bearings
- how do i get uberdata?
- do you have connected your dashpot diaphragm?
- wrx + No2 + lots of boost = Boom/oh F@#$
- nissan turbo for B18A
- expansion slot question...
- Hondata tuners in Tennessee??
- picking a turbo?
- Will Teg GSR piping for 96-00 Civic w/GSR swap?
- help on turbo kit
- What can I beat with 265whp?
- Does anyone use a lighted crank pulley?
- Uberdata vs. Bandaids
- data logging nokia usb cable installation p28 help.
- fuel issues ?¿
- turbo b17
- Can anyone give me part # for Kteller piping for my eg ???????????
- calling everying that has a z10 block girdle
- intercooler for g3 teg w/ no mod's
- Turbo location....left or right?
- who's got the most hp out of a sohc turbo?
- ctr cams on boost
- Hondata help: solid Cel & bad idle
- unsprung clutch question...
- apexi n1
- BOV Leaking?? What to do?
- Reading oil dipstick
- Crower or Skunk2 Turbo Cams vs. Stock B16 or ITR Cams
- Very confused.. no boost after installing Vac. manifold, Catch Can
- Need help with the Greddy Profec B spec 2
- "BACKDOOR" ?? with big PT intercooler?
- SINGLE CAM BEATINGS
- B18A1+WRX stock turbo
- Whatup from Kirkuk, IRAQ!
- UBERdata question
- 600+whp TUrbocharger???
- decisions....life
- b18b1 club.
- Newbie questions! Want your opinion(Turbo kit) before I drop the dough!
- boost creeppp uh oh!! help
- help with burning with moates burner
- Finally SWAPed: REVHARD IM clearance problem+More? HELP! FULL-RACE
- SINGLE CAM -150 Shot, 10.3:1 Comp, Whos A Genius?
- what should i set my vafc for boost?
- Why isnt my car revving?
- No nuts?
- flywheel and pressure plate question ....
- uberdata not saving correctly?
- JDM H22A Supercharger Questions
- Rebuilding a Turbo?
- How much boost is too much on a B16?
- egt or a/f guage as third guage...
- Confused about static timing
- Anyone have big all motor cams in thier FI setup?
- using a switch on J1 on a chipped ECU?
- Ever seen a TT set up like this before?
- Pictures of my broken tranny
- turbo question
- QUESTION!!! what kind of piece is missing to rebuild a b18a1????B18A1+WRX stock turbo???
- Boost controller "clicking"
- Precision Injectors
- GT30R on my D16 / or I keep my SC50 .63ar ???
- So You want to turbo your SOHC and want ideas about the numbers it will make - NEWBIE INFO
- blox mani and what downpipe???
- Turbo Piping
- vacuum lines--CONFUSING problem or no?
- Need help I may drop blower for Turbo for Mustang gt
- DSM injetors, CRX harness, GSR MOTOR ????
- plugging oil squirter/ jet
- 3inch intercooler piping???
- what's this mean ?
- fire ring
- Oil Pressure Drop After New Pump Install
- >>> HOMEGROWN TURBO SET UPS - - Whatcha Got?
- Mini me + backdoor style IC
- going over intercooler rating? >>
- Used Japenese Engine for Turbo Civic??
- Genboard v3 anyone running it
- Help install A/F gauge .......searched with no results
- Today was a bad day... any advice would be appreciated.
- anyone run the compressor on passenger side with NEUKIN manifold????
- best motor for turbo?
- would this work
- which head woulod you use for high hp setup?
- Cold weather tuning.....are higher a/f's normal?
- Rebuild Kits
- What size intercooler do I need?
- plx m300 wideband on jdm b16 w/ pr3 *searched
- what would happen if...
- Internal to external wastegate?
- fmu and inlne pump now car loads up bad when not in boost?? help
- B16A2 using Hondata Socketed P72?
- heres a ? for yall
- Ever heard of this happening??? Water pump problem... I guess!
- 150 Direct Port *VS* 15psi Boost. Nitrous wins for 1/4....?
- Driving on cold engine???
- Buying turbo
- Boost leak...vacuum leak...im so stuck!
- valve spring specs
- dsm turbo injectors on b18b...
- Garrett t4 down pipe flange where to buy them???
- turbo size
- 97 Honda Civic Turbo problem
- Max power on stock rods?
- plastic intake manifold for honda ?
- What Sould i use for fuel
- B16 Boosted with Skunk Stage 1 Cams
- stock or low comp. on 84mm gsr motor
- Dyno B18B LS turbo T3/T4
- just boosted.
- chipped p28 with nitrous bad idea?
- can i make 400 whp on stock ls head?
- I think I finally picked a turbo!!
- where to purchase tbolt clamps?
- nitrous question
- Which Cluth? Stage 1 or Stage 3??
- Ball Bearing Turbo Oil Requirements
- What is the Safe limit of the "Effective compression ratio" on a B16a ??
- Check valve issues
- Automatic Transmission that will hold Turbo?
- Wastegate elbow
- Opinions/Diagnosis please..... suddenly rich and other tales of woe....
- purchasing hondata ROM editor
- Back from the Dyno, New #'s
- top fuel turbo kit
- Does this look good
- Happy Thanksgiving Everyone!!!
- SAFC or VAFC for D16a6
- anyone ever make traction bar set-up for dc2 for 3" dp
- Need help with JRSC on B20VTEC in a crx
- b16 Turbo dyno 3's with VAFC Hack
- hondata problem? motor has extreme hesitation will not rev past 6k
- help me identify my turbos (pics inside)
- need basemap created. ill pay for it. >>
- Running CTR Intake Cam on my JRSC'd GSR motor... Any good?
- Anyone boosted a Cr-vtec?
- downpipe....gasket or no???
- cam gear on sohc d16z6
- need a opinion on my d16a6
- your opinion..ls/vtec boosted or b16 boosted
- Rear Bumper protecter with 3" exhaust
- Apexi ihi BB turbo?
- serached clutch QUICK question i happen to have about my new new new clutch
- base fuel pressure
- is aftermarket oil pump gear???
- Magnaflow exhaust :vent: looking for other options
- 99-00 Civic Si B16a. Want to buy a turbo. Whats the best setup?
- Tilton twin disc clutch ??'s
- torn between 81mm bore and 84mm bore - please help
