View Full Version : Forced Induction
- What mileage have you gotten out of your engine?
- Is it ok to run Dual pump mismatch??
- spooling up to 3psi, what gives?
- cost of FI
- Coolant in oil!?!
- Turbo setup
- turbo LSV issue, oil burn
- TURBO HONDAS IN EXTREME HEAT - - -
- Planning a 10k+ rpm motor + JRSC setup.
- heat issue HELP
- turbo down pipe and exhaust question.
- action clutch or competition stage 5 with the upgraded pressure plate
- No surprise, I'm ****ing up again? Catch can...
- no one stocks turbo manifolds!!?!!
- 1996 honda accord F22B2
- Finally Boosted!
- turboed ls hatch, stalling help
- Measurements to build your own ramhorn?
- What is the water/alcohol ratio of Snow Performance's Boost Juice?
- Will this MAC valve work for Hondata Boost by gear?
- rings wouldn't sit in correct.
- d16z6 turbo build
- Inline 4 procast piston opinions
- Best way to Build a B20V
- cheap turbo help
- First build ?s
- Good Comp ratio for 300whp gsr
- Dseries Block Notching
- Built shortblock sitting for a while...good to go?
- ls vtec turbo( vtec oil starvation) throws cel under full boost
- t31 4 bolt turbine horsepower limit
- D16A6 Turbo BEP t04e 50trim
- Walbro 255lph sock on 400lph?
- Various questions about turbo build please help
- Catch can question
- help with my stock b18b boost project
- Greddy Rs BOV Fitting Size
- Do I need this Oil Restrictor?
- Ek coupe to eg hatch built lsv turbo swap.
- Bolt on Build Ideas?? Help! Integra GS-R
- Different turbo exhaust housing doesn't fit.
- headgasket size?
- changing muffler 2.5'' to 3'' do i need a retune?
- 95 Supercharged hatch project
- 1992 Prelude Automatic Turbo
- 3'' pre-turbo piping on 4'' turbo?
- My 93 Del Sol turbo build
- whats this forum about?
- boosted del sol boost problems
- Hondata s300 map problems
- 93 ls vtec hatch questions?
- Feedback or thoughts on Crower valvetrain in a boosted application?
- DB1 Ls/Vtec Turbo - What should I expect from this setup ?
- Stock Minime+Boost. I am doing it! Advice Please
- 2000GSRTypeR's B18C1 GSR Build
- 94 civic B17 turbo -- idle problems /over heating
- wastgate to turbo ?
- Fittings to vent valve cover for catch can?
- 3.5 Inch DP, fit under fit under Integra
- Best size turbo for daily gsr
- N20 Timing Corrections
- About Intake Rotor
- b16a3 with mr2 supercharger
- NEW turbos, Experts your Advice is needed
- Regarding my exhaust (Muffler)
- 99 si civic ?
- S300 boost control question
- Help with wastegate elbow
- no lift shift...
- Excessive crank case pressure?
- Need some input on Itb Turbo
- RC750 to ID725 injectors, what's needed?
- Skunk2 Pro 1 cams vs OEM for daily driver (wear and tear)
- Broken wastegate bolt in cast iron manifold, fubar'ed?
- Nissan Sentra SpecV 700whp+
- D16Z6 Supercharged
- Intercooler question
- delphi injectors,how to wire for my boost build???
- 230-250 hp goal
- What turbo to choose ? Another query thread with detailed specifications...
- What the hell is going on here, why is this car so fickle about 95+ weather...
- h22 Catch Can Locations?
- Edelbrock 4730 Camshaft Dyno Comparison -- Making Power
- LSV Turbo 400-450whp low boost goal..
- wastegate buzz
- help with f20b
- D16y7 Turbo injectors....
- has anybody use these Injectors
- Self Tuning
- Wide bange reading ???
- Built ls vtec turbo. tranny?
- Builda'Teg's FIRST attempt at forced induction....
- Diagram or How to on walbro 255 fuel pump relay upgrade, spring mod for more fuel psi
- Help turbo ls smokes when warm
- turbo exhaust annoying- input please!
- trying to figure out how my car was set-up
- compressor wheel touching housing
- stand alone ECU?
- Do you run a blow-off-valve?
- What piston to head clearance are you guys running on your FI setups (with GSR head)
- Edelbrock Victor X Throttle cable help.
- Turbo d16y7 fuel injection
- Losing fuel psi overnight affect on-road driving?
- MSD Ignition Help!
- twin scroll ( divided) housing question
- Fake vs. Real Greddy type s bov
- Need help with nitrous setup !
- fuel line return question?
- Lsv turbo build help
- does intercooler piping size matter??
- Need a little help please!
- Safe to Drive Without Intercooler Connected?
- Ebay Turbo Questions!
- How to install vband wastegate
- LS Turbo Build DynoJet results in!!!!! T3 T4
- Turbo/manifold suggestions
- Running no oil pressure switch ok?
- Need help finding a good shop to balance the turbo shaft for my b18b
- Best B16 Head Porting for turbo application is done by ?
- engine break question: load vs. temp
- Turbo budget
- Any "custom" built fan shroud pix?
- D16z6 engine/turbo questions
- Someone post their 2.0L gt3071r setup!
- Damn noob question... What turbo is this... Ugh Noobs!!!
- Need advice for a turbo automatic d series
- Turbo build help please.
- Knocking Noise coming from i dont know where. Z6-T
- Help!!! LS Vtec Turbo Wont Start!!!
- Turbo feed line leaning against manifold
- boosted gsr 6262 ign issue help!
- HELP!!!
- Question on inlet//outlet 2 bolt adapters
- Electric water pump
- Help: Stalling issue
- Can I switch from low to high boost during a run?
- Dyno tune thursday, how much boost? stock b18b1, 60 trim
- d series turbo build looking for help
- going turbo, fuel pump question??
- Built B20 E85 Thread
- Gonna try some Darton Dry flanged sleeves
- go-autorworks aluminum radiator w/slimline fan
- 726whp 487wtq @ 26psi 10.20@150mph!! KMOD Performance RSX-VIDEO
- Boost questions..fuel pressure, ign. timing, etc.
- 93 cx hatch 1.5 swap?
- 720 or 330's?
- d15 vtech and motor work w turbo or just turbo?
- Just dropped it off at the builders
- Boosting a d14a4
- question for best transmission for turbo single cam?
- ls turbo in ek do i need to retune!?
- Bought a new turbo off craigslist and cant tell what it is.
- inlet elbow for wastegate?
- ***Diagnosis - Checking tool Vacuum gauge***
- B16 engine block, bad or good?
- Need a new clutch/pressure plate setup advice please
- some build advice
- ***The Basics of Reading a Spark Plug***
- smartest way to start a build off
- whats the biggedt bore size i can go on 81mm pistons
- Lets talk race gas
- vacuum line location for bov and wastegate
- Can someone help me ID this D series Cast manifold?
- Do you have to "break in" a new turbo system?
- 11.5:1 boost safe?
- Wide Band Location
- B16 JRSC on B18c6 = Low Boost?
- How does Freshdot's motor sound to you guys??
- HELLO IM NEW...NEED HELP PLEASE?
- cp pistons+ egale rods
- SC67 Turbo?
- how much hp will 1000cc injectors support?
- d16z6 wrist pin issue
- B series turbo build q's
- Sleeper DD build help
- Stock b16a, want ~250whp. T3 60/48 or 60/63
- So I just do all this and Ohio hires 180 more State cops
- how to connect external wastegate
- Is this a bad position for the air filter ?
- ***High-Performance Cooling System***
- TURBO TEGGY
- Catch can vacuum source??
- Ls-T build advice
- b16 turbo, white smoking
- LS-T t3/t04e turbo, sputtering problem when accelerating. Help!
- Need h22 shortblock built!!
- Turbo placements
- t70 turbo boost fitting
- What kind of MPG are you boosted guys seeing?
- just put my turbo would it turn on
- prologger with s300?
- d15z1 on an obd2 harness with obd1 ecu crank position sensor help
- S300 Data Logging
- B17 turbo
- neukin ac manifold and aftermarket radiator
- What's a good place or person to rebuild my turbo?
- Two likely newb questions
- turbo adapter flange problems
- Spawne's supercharged B20, sponsored by DDTECH
- Cleaning up dirty turbo manifolds/what surface finish
- Motorola map sensor 2.5 bar stock map housing
- B16a2 FI query.
- Installing arp head studs without removing head failure ><
- Tiny WG spring
- Neptune Y8
- turbo k20a2 problems - flatlining @5300 rpms
- Catch can fittings to block..?
- Color coding bearings checking for sizes??
- Wastegate Plumbing Question!
- Which sandwich plate, vtec distributor
- Heli-Coil help!
- Ls build questions
- **H-T Members Triggering an Intercooler Fan**
- it this a real turbonetics
- Clutch
- Preparing for more boost, criticize pls?
- cam timing retard question.
- which head should i use
- Turbo Suggestions
- B18c1 stock turbo help
- Eagle rod and Pistons Instal
- AEM gauges in California
- need help with build
- Injectors for boost?
- GT3076R running out of steam??
- High comp+boost build thread and GO-AUTOWORKS kit review!
- Oil catch can help
- What about these all integrated instrument clusters?
- Bought a motor today, question
- shaft play in and out?
- Please tell me if these pistons are good or not
- M&H 235/60/15 on Del Sol
- Downshifting with turbo bad?
- What gauges should I have
- ls or gsr for sleeving?
- Code 11 hmm I don't know why
- 650cc injectors???
- Greddy (mitsubishi) td04h need a oil restrictor?
- First time on dyno, horrible results, graph inside
- .pdf of c-speed gsr jrsc install floating around?
- My integra build
- '06 Accord - 500whp goal - Anything missing from my list?
- is it safe?
- June 8th is the day
- Noisy engine after rebuild with weisco pistons b18c
- radiator hose as IC piping
- Valve spring options h22
- ARP washer help!
- Couple questions about my turbo build
- How often does a EBC give problems?
