View Full Version : Forced Induction
- turbo question
- T3/T4 vs T3/T04e Oil Lines????
- Blown head gasket?
- whats better for boost h22 or h23?
- PLX M-300 Wiring Help
- NO POWER PLEASE HELP!!
- Exhuast leak from head to turbo manifold
- trying to problem shoot TPS
- Hondata S300 is 'offline' ......
- Add one more to the no oil pressure list
- wheres my oil line guy?
- Suzuki Vitara pistons in my dohc zc
- which oil return line?
- Internal wastegate isolation
- what psi can stock ls injectors handle?
- Another 12-second SOHC...
- i cant find it...!!!
- anyone know how to hook up this hks bov?
- Variable Geometry Turbochargers
- who is running clutchmasters twin disk?
- Tial 44mm gate not sealing ???
- Goal 700WHP: Is my setup worthy? What eles do I need?
- Upgrading from s200b to s300 worth it ?
- Can any name this LIP??????
- in engine bay intercooler?
- What size line and fittings for clutch master cylinder to slave cylinder
- final drive
- Needing my gsr tuned
- crome urberdata
- Prepping H22a for boost...
- Greddy Sohc turbo injector size?
- What are the types of "high-temp" coating for CAST IRON?
- TRack shOt LVMS
- My turbo mini-me... before and after buildup
- Built b18b having sputtering problems
- Compression test.
- What compression is best for D series t3?
- could there be fuel pump problems,due to runnin under half a tank,gettin on it!
- 1000cc Precision Injector o-ring problem
- GSR Intake Manifold Butterflies????
- Is this turbo any good?
- quick chipping question
- decided to go F/I was hoping for some input
- most effective place to ice down before/after runs
- do i need injector clips?
- which tranny/s should i look for (turbo B16)
- (Searched) Greddy Profec E-01 power supply?
- 5000 mile point
- Turbo off a diesel ( hear me out )
- wiring crusise control button for high/low boost
- Pass Emissions in NYC with AEM EMS?
- turbo parts need to leave
- We retuned my car lastweekeend !!!!
- Turbo Leak: Exhaust Leak?
- Turbo kits. Which brand is liked the best?
- Greddy TD04H-19T bolt on kit. Go or no go? Waste of money?
- turbo sohc?
- Made 194hp on 3psi, does that seem high?
- Short block b18
- ZEX cam: is something wrong?
- direct bolt on 3" cat? anywhere?
- What is this white smoke?
- My New JG-FAB custom set up
- will a carbon fiber hood be affected by heat from turbo???
- Turbo Sohc Pinging (searched)
- Can't find a before and after dyno!
- water cooled turbos?
- cant get datalogging to work.
- any rod and pistons combos(stock) that i can use in a d15b7 soon to be turbo??
- inline bov
- MAP sensor A/F problems
- b18c turbo
- evo vid
- Compression test?
- turbo ls leaking oil need a lil help
- anyone like the GREDDY sohc turbo kit?
- Hondata S300???
- need opinion for jdm d16a turbo set up
- Garrett T3 48/70 questions
- How bad is this knick on the top of the sleeve?
- Help! Another idle problem.
- oil pressure....around 5psi at idle and 35psi at 3500 rpm's HELP!
- Compression Check
- love fab wait...
- Drag Manifold Install question....
- dohc zc vs my 94 sohc vtec
- datalogging with plx r300?
- GM 3 bar MAP overkill?
- Do I get a turbo timer?
- What WG springs are these???
- Where to buy Motec PLM Wideband?
- Anyone using an AEM EMS and not using their little goodie bag?
- White Smoke?
- searched.. any info on this turbo???
- BLOWN TURBO???
- .....GSR block build up......do i need slevees???or not
- need help on my b16a2 turbo!!!!
- what do yall think about this??
- how to hook up turbonatics deltagate?
- help with turbo size...
- what is the skinniest turbo mani for a b18 in 91 dx.
- anyone running the stock gsr crankshaft with over 400hp?
- Eagle rods vs. the competition
- td04-13c
- I made it fit ........
- Anybody have exp. with ebay top-mount turbo kits?
- Apexi BOV
- 5-bolt exhaust gasket?
- no vacuum at idle
- My ER surge tank / fuel system
- Looking for a place to mount your Motorola 2.5 bar MAP?
- liquid 2 air and air to air intercoolers can you use booth.
- turbo + AC
- fuel problem..pics/explanation inside
- confuse about the t3/t4E and t3/t4B
- WTF Dyno #'s!!!!!Need input...
- mitsubishi manifold??
- b18b avg price for port n polish
- ITR cams with b16 springs and retainers
- accel 550s?
- LS b18b rebuild then turbo: Need advice
- Dropped Valve Follow-Up! Aftermarket valves?
- what size 4 bolt flange to get??
- What injector clips do I need?
- which msd setup for n2o?
- stock injectors
- Innovative T61 ITS?
- NepTune Q?: Rev Limiter?
- Plan on turbo'n a b16a. Need some advice Thnx
- Machine shop in reno nv??
- Should i run this setup?
- 5th gear boosting, MYTH or FACT??
- to sleeve or block guard???
- B18C1 BLOCK/B16 HEAD JR supercharger, NEED HELP ON A BELT
- Missing link..........
- b20 with gsr head
- Shaft play on non-BB turbo? How bad is this?
- Twin plate vs Single plate clutches
- revhard turbo manifold for ZC turbo setup need help!!!!
- Inline Fuel Pump? good/bad... let me know
- Need a little help with turbo charged b16
- Help need some opinions about this??
- Need help with water injection check valve
- Is this obd2-obd1 conversion harness any good?
- I boosted 5th gear..Now 4th cylinder has a little oil in it and my car and exhaust smokes white.. an
- HELP! question
- anybody that lives in the West Palm Beach, FL area that can help me
- nSandwich plate work with OEM GSR oil cooler?
- combo comparison gt61, gt35r
- IRRITATING NOISE: Only when car is dead cold
- FMU/Bigger Injectors Problem???
- T3 Compressor Outlet Bolt Size...... ????
- t3/t04 or t3 super 60
- gsr supercharger on a b16
- pump gas limits?
- Anyone use the Motorola 2.5 bar map sensor with an EMS?
- Biggest intercooler I can fit behind my bumper - EG hatch
- who has one of these custom manifolds from this guy?
- Limitations
- bov adjustment
- GT35R leaking coolant..PICS
- Anyone have a base map for 1000cc injector that idle fine??
- turbo exhaust need help!!
- what's with the new Mobil 5w-50?
- Turbo Manifold questions?
- Revhard or DRAG turbo manifold?
- what do you guys think of this turbo
- GOLDEN EAGLE OR ARP
- What Happen to DMH Performance?? Phone Cut Off & No E-mail Responses!!
- 301whp and 225tq @ 15 psi, thats nothing new right, but it was a SOHC!
- integra IC piping
- 250 HP and 200 torque, jrsc 11 psi, 25 shot.
- need a basemap for crome t25
- GREDDY DOWNPIPE- SEARCHED MORE THAN ONCE. HELP!!!!
- Precision Turbo's GT4067R details .
- boost controller question
- Which manifold?
- wastegate washer
- Turbo sizing questions (i'm not a newb)
- GT28RS and it doesn't fit
- Non BB Alternatives to the GT35R?
- rebuild??
- Oil Additives For Turbo Applications? Look Here
- AEM EMS Question... Throttle Pump???
- wtb- sohc d series complete turbo kit...greddy or soemthing
- Rebuild or buy new one?
- Cheapest Tuneing route for turbo
- Jackson Supercharger.......why doesn't anyone use water/meth? Or do they?
- DOHC ZC piston/con-rod cad file?
- Jus changed manifolds and......
- Does anyone know what the stock psi on a gt32 internal wastegate is?
- Why is boost falling off?
- 3 Bar Map Sensor? I've searched!
- AEBS intake manifold?
- Sleeves or no Sleeves??
- How long have u lasted on your tuned boosted B18 with stock sleeves
- JRSC users please help!!!
- are my pistons still usable after accident **pix**
- high idle. need help
- size runners
- Anyone Havethe TD40H kit i have some ?
- Got my LS-VTEC dynoed
- need help selecting turbo a/r for 4.6L stang
- Need help wiring TurboXS dual stage BC to steering wheel button
- Cam ?
- is this causing my smoke problem??
- Help me identify this turbo! T3/T04e
- greddy 18g question
- WG?
- Injectors and FMU
- Your SSAC or XSPower Setup!
- what BOV are you using for 500whp+ or 20-30psi STREET cars?
- Anyone Using rc sl4 550cc injectors
- What A/R and turbo is capale of producing boost for 3k-6k RPM range in B18B??
- Tripping the Map sesnor?
- GReddy blue box + 12-14psi = MAP sensor CEL?
- f22 turbo?
- custom intercooler core???
- finally got tuned..... kinda
- Is this repairable??
- Oil Pan Tap/Fitting Look OK?
- I had my srt4 tuned today (broke 500whp)
- I Need A Tuner
- is this common???
- will obd1 vtec. sol and dizzy work on obd0 head?
- how much boost on stock internals??(d15b7)
- Engine build help **cylinder wall scarring** 56k maybe
- One Fab:I want my manifold back its been 12 weeks now
- Oil leaking out of turbo after only 1 week of install???
- Help me find this map block-off plate please.
- turbo project 91 civic si
- 3" Apexi WS2 muffler - is it worth the $$$?
- vortech fmu with inline fuel pump, the good and bad?
- 62-1 on a b16????
- Need new Valves and Valve Guides?
- why colder plugs w/ turbo?
- turbo ef 4-door
- Does CRP Turbo have a phone number?
- Engine Break In methods, lets hear them........engine builders welcome
- Ramhorn turbo manifold thought I'd share.......
- Direct Port Nitrous with ITBs?
- what does a blown wastegate gasket sound like?
- need info about www.j-k-tuning.com
- Boost on stock H22A?
- too much smoke HELP
- T4 P trim versus GT35R versus GT40R - turbine wheel comparison ?'s
- Sohc Vtec setup
- Stock Fuel Pump Quest
- Need Help: Blow off valve blew off now car wont start :(
- measuring a tial wastegate
