View Full Version : Forced Induction
- pulled head off after poor leakdown results. now what???
- 130K MILES too much for daily driver boosting (d16z6)???
- Looking for South Fla Tuners
- The age old question... fuel management (Integra LS, 8 psi)
- Does anyone have experience with ProEFI standalone ?
- 2.5" mandrel downpipe, or 3" hack job?
- adding additional o2 sensor and A/F gauge
- Any hints/suggestions for installing a Greddy turbo timer?
- Will this probe work?
- Please help!! idle probs, car shutting off, backfiring...WTF??
- Is this supposed to move? *PICS*
- new greddy turbo kit for 96-00 civic
- compression ratio check
- OT: Anyone in SoCal know AutoCad???
- equal length manifold oil return setups... help
- stay internal gate or go external ?
- VS Racing?
- Exedy Organic clutch for mild/moderate sohc turbo setup?
- Cel Code 3 with AFC hack and way too much fuel
- Follow up on my AFC Hack Thread
- what makes a precesion turbo so much better than a regular t3/t4
- what turbo is this adapter plate for??
- JRSC for Type R and SIR... Are they the same???
- very very quick injector wiring question
- Boosting HX
- homemade turbo kit need help ( manifold)
- how much smoke is acceptable when driving hard?
- Question on engine management for Turbo Accord.
- Noobie ??? about turbo setup on d16y8
- installed greddy turbo kit now getting cel
- Disable Knock sensor
- zex nitrous
- OT: VW OBD Software?
- Anyone running open DP on thier daily driver
- Where is the best place to buy Greddy Turbo Kit!!!
- !OMG~! Complete stealth electronic 2-Way Downpipe!!!
- Fastrax? Fasttrax? Fastrack? Fasttrack?
- Running from the turbine?
- N02 w/ big turbos?!?!
- For the D-series crowd, which is the better platform? The Y5 or Y8 head? Why??
- JRSC and exhaust size question
- Best gauges for nitrous?
- What should my timing be set at? turbo d16a6 look inside!
- Whats the best???
- help please!!!!! help!!!!!!!
- what is the V in sensor check in AFC????
- Fmic with a 14b?
- help wif setup....turbo B
- Walbro in-tank + DSM 450cc, FPR necessary?
- Adapter Plate
- direct turbine fuel injection???
- i hae a prob wth my valves always tapping,,(i keep re-adjusting them,,but they always mess up again
- Turbonetics Godzilla bov, what is the blue spring?
- e manage question.
- downpipe gasket
- Looking for a turbo...good reliable sources please
- Reason for not getting spark?
- Would upgrading from a starion FMIC to a large Spearco @7psi make a big difference?
- what is the biggest FMIC that can fit a 94 civic coupe dimension wise?
- Difference in the following spark plugs?
- noob question-
- jrsc problem O2 code
- my wideband is messed up
- where can i buy NGK BKR7E's in socal ?!??
- I need a COMPLETE greddy oil feed setup, what all is included?
- About to buy a Zex kit.....Any last words?
- 97 civic exhaust question?????
- questions on a fuel pump
- Which AEM EMS for my car?
- Custom CP pistons on H22 eagle rods for f22
- Need to find a 3 bolt offset cat flange
- Compression Ratio
- burning 1 1/2 qrt oil
- Traction bars or axles? What would you buy first?
- Pre-made intercooler pipes....who has them???
- Ok to run without BOV for about 1 week?
- leak down results. need some advice
- Turbo-Oil Problem, Need Your Input
- Which turbo should I choose??
- 4 and 5 bolt discharge & their necessity to hack at the block
- install problems need help bad!!!!!
- 450+whp Manifold choice?
- car smokes but compression test went good
- 3" Downpipe Flange
- What c/r & Piston company to use?
- Injector Seals: Moving to 450cc DSM's. Checking the facts. Quick questions.
- Best placement for wideband o2?
- ******** Pro Drive Oil Gear **********
- LS/Vtec Plus Turbo Oil Feed What Fitting?
- Strengthening D series transmissions
- 96-00 EX turbo.
- cat is smoking?
- Are there any 10 sec supercharged honda's?????????????
- MotorMatrix.com....need prices on some stuff!!!
- Golden Eagle Website!!
- D head gasket
- t3/t4 e trim, 5psi too less?
- Blitz Turbo Kit?
- turbo manifold ?
- Need help on cleaning turbo
- precision sc60 question
- First mod to a boosted H22??
- Oil pan leak!
- Help wierd whining sound.
- Car shut off after boosting!!
- sleeving on the east coast,somewhere close to FL
- searching for the B&M web site...
- Radiator problem ...
- 220 good for a garret t3, .60 .63 ?
- detonation amplifier diy article
- debating on my set up for 450 whp.
- is this setup safe?
- Archived too old: Pics of DSM 1g Side mount intercooler on 92-95 civics.
- how much HP are you making with rev hard?
- Super T Tig welding pics...
- think i blew my headgasket?? which one to buy now??
- pro drive oil pump gear
- Flex-a-lite fan install: fan wont kick on....
- Turbo 99-00 Si's, need some info.
- I'm BOOSTED!
- which spark plugs for JRSC b16
- hondata and timing
- What is the Best Turbo for a B16a SIR II...?
- dsm turbo rebuild kit?
- Report: Best tranny for boost.....
- Report: Best Tranny
- Turbo/Super and No2?
- Anyone using a Action stage 1MS clutchsetup?
- should i retard my timing by the distributor?
- No2 why not just o2
- Greddy GSR eats dipsticks
- How does dry N2O fuel management work?
- What exactly controls boost?
- Dyno Results!
- Holset Turbocharger
- what size turbo should i run???
- Turbo install questions...
- Axles
- Anyone have issues with DSM injectors + Hondata + boost ?
- AFC hack and PART THROTTLE boost??? Do you do it?
- how much needs to be upgraded to run a wet 75 shot?
- I heard a rumor about rods. Can you clear it up?
- what else do i need for 10psi?
- post up your b20 boosted motor set ups and experiences !!
- How often should oil be changed in turbo engines??
- Y7 stock fuel and ignition maps
- Timing advance/retard control knob
- Turbo b16a2.... post your 1/4 times or dyno specs.
- preventing oil leaks
- AFC Hack Pressure Sensor
- Nitrous Question.
- Civic VX Wideband 02 5 wires connector and pigtail .. hard to find
- need help with MSD BTM hookup...
- flat black sheets of plastic?????
- Management: Hondata vs Chipping
- how does dsm intercooler fit delsol?
- Relatively High Oil Pressure Today
- Turbo and long distance driving?
- New dyno results
- John English
- Finally pics of my set up,Lots and Lots of pics to see!
- Valve lash on turbo engines
- Is 10psi safe with my setup?
- 1.6 to a 1.8?
- Is it possible to upgrade a T3 compressor housing?
- Help! What Ohm are 99 SI injectors?
- blitz dd blowoff valve
- guys i need your help.....
- SOHC Turbo Question?
- questions about leaning out and vortech fmu
- Catalytic vs 2 step
- question about retaining a/c for turbo
- 400+ HP Club *Fuel System Setups*
- Trouble with AFC Hack. Help with diagnostic.
- Really need some input
- Tilton clutch or Final drive
- Going turbo. was wondering if I should sell my current all motor head or keep it for the turbo proje
- Set up "race" pcv system and car wants to die after revving, anyone else?
- manifold and turbo
- need suggestions and thoughts
- full race intercoolers
- Noticed the Greddy Turbo Kit for 92-95 Civic Sohc Vtec = no BOV...why?
- OT: anyone know anything about subaru svx's??
- Downpipe sizing
- *What's worng with my Blitz blow-off?*
- what do u guys think
- Cylinder Leak down Tester Kits
- Rate my Set-UP
- Do these readings look good? (Apexi SAVCR)
- quick question crx 450's
- couple JRSC questions...
- Burning oil after going turbo
- Last night my engine went BOOM BOOM!!
- Civic will not start sometimes
- What size slick?
- Which intercooler to match half radiator?
- Is this a good price for complete engine work?
- Cheap Oil Feed / Distribution Block Fitting!
- what map sensor do i have
- is it safe to run with no FMU with 5psi?
- homemade heatshields / heat transfer
- rev hard intecooler
- Some pictures of my turbo project
- garrett t20 or t25
- fuel sump... when is it necessary
- finished turbo install pix inside
- is FMU really nessasary for a turbo setup?
- Turbo ITR
- not a honda question but need help...turbo 1st gen mx-6 any pointers?
- Spent 4 hours searching the other night... Does anyone here have dyno numbers for...
- Black smoke at Idle...Help!!!
- vtec head, or build ls head for boost
- SOHC turbo questions??
- should i go 1 step colder?
- post your fastest 1/4 times using fmu+stock injectors
- JRSC on LS...vacuum lines and relay questions pics anyone? (? about Gude turbo cams too)
- which fmic design to fit 5th gen accord..
- Compression Q
- turbo performance manfolds...suck big time!!!!!
- first time at the track...
- anyone tried Turbo Specialties Extreme Superior Power Turbo Kit??
- can i just give an intercooler like this the chop to make it fit???
- How many times a day???
- Where to buy ENDYN breather kit
- fs: greddy 60mm egt gauge peak/warning
- SOHC ( d16z6 ) Whps. on stock internals.
- e-cutout with audible alarm
- tell me what FMU this is please!! sorry about crappy pics.
- Searched: DIY turbo rebuild? ( t3 with rebuild kit )
- which turbo to pick
- Drag I/C good enough for 400whp?
- Lost lots of coolant taking out turbo, should i just drain/refill or flush or other?
- check engine (code 7) plz help asap
- I think I have a problem with my Wastegate.....
- Speedpro...
- FINALLY GOT MY CAR DOWN THE TRACK
- How much do youu think I'll get?
- Lowest boost?
- Newbie Turbo ECU Question.
- Need help wiring up Blitz EGT Gauge!! Pics Included! :)
- 3" greddy exhaust
- Can someone run a honda part number and tell me the diffrence in these rings?
- Searched: T25.. can you turn it down to run 6-8psi? And how?
- compression
- Clutch help, no one seems to be able to give me a concrete answer.
- Turbo guys with FMIC, what's your cooling set-up!
- What do you have to do to put a B18C JRSC onto a B18B?
- does the afc II really advance timing
- Differences between the two?
