View Full Version : Forced Induction
- O2 sensor locations
- *** Pic Request: AN Fuel Line Setup ***
- Turbo Setup Help
- (look)..This Tops all the Problems..(HELP)
- I give up! what turbo parts are appropriate for my build?
- new dyno sheet today
- APEXI AVC-R FOR SALE
- give me some suggestions about my exhaust...
- internal wastegate + boost controller = what i want? help!
- Pictures of my new Topmount turbo kit....T3/t67 powered!
- Turbo back to Na?
- Could factory turbo motors boost for a long time ?
- VERY Lean After Highway Cruising
- boost creep problem
- BOV question...
- d15b turbo question, what all is envolved?
- traction bars with drag turbo kit.
- Fuel Injector clips
- Need help with turbos
- e cut out help
- is this place legit?
- Where to find Hobbs pressure switches?
- Turbo teg compression test results help
- blow off valve flanges
- axles for 400-500 hp
- T-3 60 Trim Compressor .48 A/R achieve boosting at what RPM?
- Chipped ECUs
- Does gauge brand matter?
- Switching from open to closed loop dumptube - How much will it affect my tune?
- Is my afr safe?
- Dumping EXT. gate back into downpipe vs. atmospherical dump & sizing q's
- d15b7 w/ z6 head or just whole z6 ??
- Boost cut outs
- Chip burning-HELP ME
- B18 or B20 boosted???
- Anyone boosting a ZC motor
- Crower valvetrain in a itr
- mobil 1....now syn blend?
- Discuss: How is OBD-I Hondata staying afloat?
- TOTAL TIMING ON TURBO D-SERIES...???
- Brand New Garrett T3/T4 57 trim for $500, is that a good price?
- Supercharger On A 00 Civic SI Question!
- Bar to Vacuum conversion???
- Anyone know anything about rx-7's?
- Anyone have a t25 with 80 a/r
- ford t3 downpipe gasket where can i buy one?
- wheels size for turbo setup?
- D-series oil pressure question
- making my own vaccum manifold......
- radiator replacement
- b16a Turbo Question!!!!!
- Would shortening the wastegate arm help boost from falling off at high rpms?
- b16 turbo Qs searched couldnt find anything
- We need everyones help!
- Need help identifying fuel pump
- Intake Manifold Tappin
- What should i do...
- do i need a steel or aluminum flange for bov?
- Does anyone here make 400+ ft-lbs of torque? Clutch and axle setups.
- Need help with turbo manifold
- Neeed FAST software 1.02
- Car idles very low after turbo install (explanation + video clip inside)
- Other Rod options for H22's? Besides Crower and Eagle....
- vtec turbo tech question
- skunk2 intake manifold
- Greddy boost controller manual, anyone got one?
- Another case of a displaced thrust washer.
- Another case of displaced thrust washers
- What axles are you guys running?
- Anyone know what chipping your ecu technically does? (searched)
- Rajay turbo anyone heard of putting them on cars??? airplane turbo
- Stock Cat, High Flow Cat, Test Pipe????
- turbo size?
- just got my turbo ls tuned. what do ya think?
- My LS turbo build..
- Im ready for the racing seazon
- best headgasket for high boost
- JDM ITR 4.7FD Tranny User's... how does it like boost?
- My new TC
- greddy type s vs rs
- Newb Questions about timing
- Which head gasket is thicker the D16Y7 or the D16Y8
- Turbo Escalade Video 12.88 on 24inch rims a must see
- FI B16's making over 350 whp????
- BIG PROBLEMS........
- should i clear my cat?
- engine is being loaded with fuel. What's the deal?
- Tial wastegate, dumptube flange
- Will Blown HEadGasket Ruin your turbo?
- pressure sensors question
- About to do 10lb. CRV pulley upgrade!
- Sleeves H23a Turbo?
- Where to buy wastegate dumptube piping?
- Question about overheating on boosted d16
- Lean spiking
- Supercharger, please don't bash
- anyone use carbon fiber pipes for turbo?
- Neptune...Tuning With an FMU or greddy piggyback...HELP
- IAT help..
- Does anyone make a closed loop dumptube for Inline Pro setup?
- AEM 3.5 Bar or GM 3 bar Q??
- Turbo hits motor, manifold doesn't fit.
- B Series manifold that will fit a TD04 Turbo
- boost=temp rise
- 300whp on stock mounts
- greddy turbo time and harness
- maintance on my turbo question...
- Whats this all about ... ???
- New manifold: LoveFab Mini-me EQ
- air temp from turbo??
- ebay manifold?
- drag kit fuel pump
- T3/T04E - what compressor/turbine/trim to choose?
- anyone know how to tune e-manage?
- Uberdata fuel pressure question. Hose on or off?
- what clutch would you suggest?
- RC 1200CC injector install, having slight problem.
- ls/vtec turbo set up, need help
- internal wastegate....4psi to 8psi?
- advice on turbos
- what kind of muffler are these?
- Finished turbo now need help
- What is the size of Greddy Part # 12050026 (Intercooler)
- TROUBLE SHOOT Q/A's.
- Help with gauge install. may need a pic or two
- Turbo LS1 vs turbo civic on pump gas
- 410/270 81.5mm stock sleeved B18C, SC61, CTR cams
- do i have everything i need for my build?? help with prices
- Neptuned H22...397whp/304ftlb @ 11psi....
- How do you double nut your stud?
- garrett T-series t3/t4e .58 45 trim for sale
- what octane would i have to use for this setup
- Re-tune after MSD 6al
- fuel question
- D16 parts mate with D17?
- Compressor housing bolt stripped!! am i screwed?
- can you guys tell me if my wastegate is in the wrong place
- Need measurements for the bolt holes on the DELTAGATE wastegate are TIAL and Deltagate the same flan
- Turbo/Supercharger owners, BE HONEST
- What turbo for Civic/CRX?
- confirmed: nokia usb data cable works with neptune datalogger
- Greddy Profec b spec2 or turbo xs dual stage mbc
- the finished turblow d15 project- 56k go make blowoff noises
- RevHard kit not capable of making over 350hp @ 18psi and turbo still be effcient???
- up grading fuel system?
- will a dsm manifold work on a ls engine?
- question on back door intercooler?
- is this turbo big enough?
- timing belt slips in boost on the ls
- Breaking in a turbo? Wtf?
- to where should i clock the middle section??
- Anyone hard line oil return?
- oil in turbo???
- anyone ever used seafoam w/ a supercharger?
- Final suggestion for turbo
- Crower 404 better than 402T on turbo LS??
- I wanna come to the darkside :) Need build up advice. and i have a few ?'s
- Does this Oil pressure sound good?
- i think i got everithing?
- Gt28r on a b18b
- Found this turbo FS, Should I buy?
- IC piping??
- a lil video of my turbo hatch
- Some piping i been working on all night!
- 300whp on an ls wat do i need to buy..
- AEM Tuners/Users quick question!!!
- Can anyone help me with this part number? Garrett turbo
- loosing power towards top end..... help!
- why do turbo diesels whistle so damn loud?
- LSD bearing seperator...Where to find tool?
- hondata s200
- boost gauge ?
- F23 Block/H22 Head(214whp/195wtq@6 PSI)
- fuel pressure at idle for 91 integra b18b
- Built B16 people: Did you bore your motor out or just keep the stock bore?
- what plug wires do you guys run?
- X-Factor Street Series Turbo Kit????
- Puurty please....give me a final opinion on my turbo choice
- Need help B16 eg.....JRSC or Greddy kit....need opinions and advice
- Oil Line Kit
- turbo timer install and still able to arm alarm w/ car on?
- In need of advice
- Should i get a bigger turbo?
- blockguard
- SS Fuel Supply Line. Quick question
- tranny question
- Turbo maintenance
- msd digital 6 or 7al-2 ?
- Top cylinder brace ?
- Cut Out After Install
- how to bling bling OUTSIDE of intercooler
- eedelbrock b16 (civic si) turbo kit
- should a fuel pump be part of my custom turbo setup?
- HELP! restricted after 120 days???
- Been running greddy turbo on a sohc for a few years now. Want more power!!!
- opinions needed on which turbo kit
- Hondata and MSD SCI
- Can someone help me please!
- Wideband Sensor mounted sideways?
- saturated or peak & hold injectors
- supra turbo
- highest but safest psi u can go on a stock gsr bottom end
- video of my exhaust. (boosted d16y8 with 3 inch piping)
- My Electronic Boost Controller
- What's a good turbo manifold
- DEFI BOOST GUAGE HELP
- built h22a owners, chime in
- d16 questions about upgrade soon
- location of oil restrictor??????
- Turbo guys have all the answers an help on this issue in the ef forum.
- does my a/f gauge working ok? (vid inside)
- This helps right?
- Where can i buy this Apexi Boost Gauge?
- Best way to detect where oil is coming from?
- someone tell me if i got scammed!!!!!!!!!!!!
- turbos
- Who makes a equal length a/c mani that will fit my dp that fits a drag cast mani?
- Turbo choices for B16 motor
- To those that have blown their motors from too much boost, did you turbo get taken out too?
- 550's work with hondata and 8lbs of boost
- need some help...tial bov..serached...please im worried
- Factory H23 rod strength...How much Power can they handle?
- What coolant for GT28R?
- What do you think?
- Need hep IDing my turbo is it an E or B?
- turbo question
- need help with turbo build please
- what turbo is this? garrett.
- Vacum??? to let oil in return oil line work better?
- Boring out a block in the Bay Area, CA
- DIFFERENCES IN GT SERIES TURBOS VS T SERIES TURBOS
- I dont even know....car is a pos
- Any high HP guys running ebay FMIC?
- Walbro fuel pump question
- ITR tranny vs stock b16 tranny for boost
- How much psi u running on DRAG t3/t4 kit?
- Why do boosted single cam 1.6 seem to make more torque than boosted dual cam 1.6L?
- Turbo blankets?
- opinions on my turbo setup for my d16z6
- Pic of my new Low boost/ High boost switch (greddy profec b spec II)
- any place making a testpipe (cat) with flex section?
- boost, temp?
- any placethat makes a testpipe (cat) with flex section?
- Got turbo. Time for engine build!
- Well... she's gone
- Any Shops with Dyno in VA-tech area
- To restrict or not to...?
- 1g BOV bad?
- 400hp EF vs 1200cc bike video
