View Full Version : Forced Induction
- What filter are you guys running with 4inch inlets?
- Turbo Build up Advice Needed. Knock sensor on B20 block ?
- Clutchnet Stage 2 clutch sounds: what is it?
- Turbonetics? Crap or good?
- Should wastegate see pressure before or after throttle body?
- Turbo kits for b18b EG
- Full Ball Bearing Turbo?
- Anyone with a Darton sleeved D series?
- car wouldnt start.....odd
- anyone know where i can get some reducers for my pipes
- boosting itr
- valve adjustment on 95 gsr
- idle change with compression?
- Kinda OT, but a question about those scanners they use at the dealorships....
- going to dyno today--> tuning SMC
- is my distributor bad??
- what is this hole for on my turbo?
- Trying to get a better understanding of....
- Size Comparison... Greddy 15g vs. stock eclipse turbo?????
- Yummmy SC54 (56K Yall been warned)
- boost controller or pressure relief valve, which one will....
- Choose a Turbo for X Factor
- anatomy of a deltagate mark II wastegate
- 255lph in-tanks- low pressure...
- who's got high boost w/ a stock intank and added inline...
- Skyline Vid
- just a quick VAFC hack question...already did search.
- OT: Japan Car Pics
- Does Portflow deal direct with customers?
- For AEM users: New software version 3.16 is available for download
- Budget LS Turbo Buildup
- 3 Inch Exhaust Cut-Out....Anybody have one on their setup?
- All crank pullies the same?
- Any more news on the Drop shop group buy?
- ****need help with turbo install****
- how does the b16 jrsc fit in the crx?
- Possible to blow a exhaust manifold gasket from boost?
- Turbo Came in the mail... What's the deal?
- "Deburring" forged Pistons
- would D series or DSM manifold fit B18 head?
- Darton vs GE
- Is D16/greddy turbo ok at 7psi w/stock fuel system?
- first road trip with turbo car!
- t3/t04b...any good?
- EFI PMS vs Hondata, Zdyne
- OT: Pics from my Japan trip: SuperAutobacs
- anyone use this setup? kinda like a hondata
- Turbocharging older engines, need advice......
- What kind of welder are all you DIY'ers using? MIG/TIG?????
- ... new s-afc...
- DRAG Kit problems!
- Are psi levels the same for different size turbos?
- How much PSI to the bar? Whats the conversion?
- BOV ? need an educated answer
- another Vafc question
- how many hits per bottle? (nitrous)
- Quick!! How to change JR Belt!!
- my nitrous is pulsing, whats up?
- What's better a 84mm b16 or a 84mm b18c?
- Apexi EL gauge questions
- Parts for an engine build?
- WTB a .63 turbine housing.
- boost or super charge????
- in line fuel pump
- Is my honda dealership getto??
- Cylinder Head Porting?
- Got my "drop shop" manifold today.
- Thermostats interchangeable??
- cool video
- Throttle and CEL 45/13 problems
- Is this me making a smart move or being a cheapskate? Pics inside
- Post the biggest ricers in your neighborhood...
- Measuring You Engine's Vitals After Performance Mods. (Air Fuel, Injector Duty Etc)
- To the golden person, I need sleeves please help.
- FS: EFI PMS system and new 440cc injectors
- turbo question
- Advance engine rebuild help, something is not “PERFECT” HELP
- Question on Vortech Blowoff valve
- Doh! Over-torqued 2 Cam Holder bolts... Snapped :(
- cams & n2o ?
- is there enough space for turbo?
- Hallman recalibrated Autometer A/F guages for more accuracy...
- GB:turbo mani's real cheap part II?
- F22 manifold,tial wastegate,spearco intercooler for sale brand new!!
- How Much Does a NOS Direct Port Kit Cost?
- Pressure drop due to intercooler efficiency.
- What compression should I run?
- tech question about my crazy A/F gauge
- power question
- nitrous question
- Motor Setup For Nitrous Question
- not on subject but i cant post in kill stories
- Chris Rado loses a 20k cell phone?
- hi-flow muffler for '95 hatch (Already searched)
- heres what i got so far, any input? (trbo setup)
- can i do this to an inline pump?
- leaks oil, still okay do to the normal things ?
- ls/vtec turbo w/obd-0 (management choices)
- T3/T04E but what trim should i go with?
- How much boost?
- HELP: Need ECU map
- Just got my turbo setup, Need some help! (with pics)
- any advantage of having a muffler??
- What intake air temps have you seen while tuning your car?
- Piping issue...GSR vs. LS
- which is better for OBDII, Hondata or EMS?
- non-OBD options
- Hondata - Which Application?
- Painting Intercooler?
- Got a tuning issue, need some helps guys.
- Project EK....D16Z/Turbo/NX
- Please Help! Runnng Lean in 2nd gear!
- Can anyone identify this Blowoff valve? *Video Clip*
- Identify the Manifold
- Has any1 tried to copy what the Hondata IM Gaskets do?
- new toys
- FOrce induction system help
- JB weld with turbo anyone???
- Bad ECU? VTEC surges and cuts out intermittently......???
- ALS: Anti Lag System
- throwing a "rich mixture code" NEED HELP PLEASE
- 1st Gen CRX Tech/Engine Build-up page updated
- ... turbine wheels... 76 trim vs stage 3...
- check out this New Nitrous kit !!!!
- Where to get a NEW EGT Probe Kit??
- Would you give a left nut and a pinky for this!!!
- anyone uses a T3 60-1?
- Anyone here road race w/ their turbo?
- hondata and injectors
- Turbo Timer Needed???
- what boost controller to get?
- help me in my debate...
- who has the best price on Hondata
- 00 Si, EMS w/ Greddy turbo kit, vtec not coming on?
- Civic HF manifold on Bserie
- hks camp ...err whats it do
- Power FC w/ 3 bar map sensor
- FS: Brand New HKS EVC 5 Boost Controller
- N/A Motor...... Ready for boost!
- FS: Hondata s100 stage 3bd,Si harness,Conversion harness,vtec ECU,Map sensor!! complete!!!
- Are B series drag manifolds interchangable?
- TECH Help! Boosted Teg wont start...
- OEM Turbo motor from Honda?
- JG/Edelbrock Intake manifold... WHICH THROTTLE CABLE ?
- Suddenly car will not start
- Hondata and MAP sensors?
- Help me choose a turbo
- 1998 GS ECU pinouts for HKS Turbo Timer
- Has anyone made 350ish wheel hp in w/ a LS motor on pump gas?
- hondata, and some other stuff, what to do?
- what should fuel pressure be at idle on a gsr motor boosted..
- prelude 4gen 3 in. exhaust
- Huge Parts Sale
- another zex smart nitrous kit
- Ok,Can you guys clarify this for me (involving going obd2-1)
- some GT30 info
- I'd like to do simple welding chores, how hard is it to...
- Random Tech High Flow Cat GB?
- turbo timer question....im confused..lol
- anyone know what flange is used on GReddy turbo kits?
- Need a new Manifold ASAP
- 9:1 JE pistons in an SI gives what CR is a GSR?
- Sale: Golden Eagle Block + Balanced Crank for $800!
- Turbocharger and Intercooler Questions
- Vouch for boomslang
- Oil where the turbo and manifold come together...????
- how much is safe on a d16 w/.....
- Anyone using Exedy cerametallic?
- Which wire is 12VIgn/12VConstant/Accessory on the steering wheel 94+Teg
- cometic gasket thickness.
- rev limiter.....too much fuel?
- 84mm sleeved b16?
- Yes ! The Inline Pro Gasket Sealed It !
- Drag's website?
- Quick Question regarding mounting the MaxRev Intercooler (on a 92 Hatch)
- AEM EMS fuel question
- Over filled my car with oil
- dump tube for wastegate
- Intake manifolds
- Thick Headgasket
- tricky intercooler plumbing
- A cure for broken camshaft syndrome?
- crx turbo
- Need instructions for APEXI ITC
- nitrous question
- aftermarket ignition with boost timing question
- how much boost w/ certain injectors...
- NX direct port 80 shot on this setup
- Any interest in a Darton groupbuy?
- HELP my fuel system is jacked
- Need a Accord turbo manifold
- NOS on 88-91 Civic DX
- Oil feed, oil drain kit
- Anyone use this port for turbo oil supply?
- unplugged butterflies ok?
- The most ULTIMATE turbo car ever
- OTI international cast T4 turbo manifold on D series?
- OT: Anyone ever search for their old posts??
- anybody with experience with Probe rods?
- Is the JRSC 12psi blower pulley ok...
- oil feed line running underneath the mani
- This forum sucks lately...:thumbdown:
- Just got my turbo. Questions about oil supply and schtuff.
- Need second opinions on Oil return line location
- In-tank Holley fuel pump vs any-make external
- Pro Racers and Ball-bearing turbos?
- spark plug gap for nitrous?
- Gravity feed? Any problem not doing it?
- anyone using the brake booster for their wastegate???
- Tial 35mm wastegate...........?'s
- 500 HP on pump gas!!!
- Was thinking turbo, need some ideas, new in this field
- information on IC
- Turbo people with PUSHER FANS.
- Serious Turbo Question
- B18C1 + B16A pistons +JRSC 8lbs = Trouble?
- TurboXS Boost Controllers
- MSD BTM w/Greddy blue box worth it?
- Dyno Results, Bad?
- Turbo choice
- Darton Sleeves - Best Price?
- To get inline Pro head gasket or not?
- The old S200 pricing is back!
- how can i tell what PSI is my Tial WG
- Anyone know were i can buy a drag 3 downpipe for a b-series.
- Wanna see a big snail?
- Need Help!!!
- Used turbo kit, good deal? what to look for in buying a used kit?
- Nitrous (what compression?)
- Where to purchase clutchmasters stage 5 HD 4puck?
- Selling items in FI
- Does displacement really matter?
- DSM injecters need help real quick on install
- look here for cheap nitrile/SBC pipe connectors
- wheres a good place to send my turbo to get rebuilt, clipped and polished????
- for future reference..... what's the most i can port out the GReddy 18G
- did someone order aem 30-1000 from us this week.
- F/S...10 lb NOS tank w/ bottle pressure gauge....MINT..selling CHEAP...
- Transmission ?'s ( i know your all sick of them :)
- Tempest MotorSports? Turbo Prelude?
- this may sound crazy.... but
- What Cometic headgasket do u recommend please...
- Turbo Manifold arrived from the Drop Shop today!
- LS turbo, What do I need for fuel system?
- Fuel pressure for sohc turbo?
- Possible Darton gb
- Any of you LS/B20 guys need some parts?
- can i use OEM headgasket with 81.5mm bore ??
- What's the best transmission for a turbo application?
- Cast Iron coting/spray??
