View Full Version : Forced Induction
- turbo D non vtec setups
- Turboedit info
- which manifold would you use?
- turbo to big???
- Oil feed line question
- wiseco stock bore piston clearance HELP
- EBAY Turbo Timer
- engine problem help
- Very bad idle until engine warm, possibly tune
- Why is my turbo still leaking oil?
- how many shots can i run on nitrous
- please help guys on my setup!! s400 borg warner vs pt67
- b16a2 vortech supercharged
- i gotts turbo lag
- Deltagate and Tial 38mm interchange?
- Sources for water to air and heat exchangers anyone link me ?
- need help with d16y8 turbo build
- Quality downpipes *searched*
- RNR's k24/k20 t67 turbo dyno results
- i bought a motor
- Intercooler Fitment????
- Precision Injectors a new design?
- WHAT!? Is this true or is this an joke?
- Turbo
- Plug Tubes or worse?
- My First build (almost done i want opinions)
- help Installing manual boost controller.
- anyone ever had this happen?
- Need Help With LEAK
- Help ! Turbo B16 .. Valve seals ?
- any one have the link to the h-t's sweetest turbo setups?
- turbo specs need info please
- Will a d16 jrsc fit a d15b2?
- Nitrous with S300
- Turbo charge pipe pressure test
- gsr trans upgrade?
- 97itr cams or blox type b
- OEM gaskets or other??
- how thick of a headgasket
- recommend turbo for j-series.
- Water Temp gauge??
- Is My Fuel System Good Enough
- How much for turbo install???
- Which Turbo Manifold???
- Which Engine
- no spool on turbo
- Del Sol 3" Turbo Exhaust.
- ls rebuild with gsr crank
- hp rating on this block
- 3INCH intercooler piping over KILL?
- Tuners ...picky about setup???
- Greddy Turbo need info on it 20g turbo td-06 greddy trust
- Need Info: Fabbing Surge Tank
- JRSC & N2O....experience with the combo? Feedback on this?
- edelbrock
- ls/v turbo oil lines and rev limit
- quick fuel pump question
- Post your Vibrant race/Burns mufflers
- Twin turbo?
- Cam Gear Explosion, Any Ideas?
- ecu question
- Trade Teg 4 built 1.8/crx/turbo or SC or NOT?
- big 16g turbo on built d16z6? anyone?
- Smoking at idle. Fresh rebuild
- single cam boost
- ITR JRSC Help
- holset questions
- blown head gasket wtf
- Garrett T34 on B16A2!
- My first build?
- Which bore Gauge-Digital or Dial?
- I have a dumb ?
- Bogging after 30% or more pedal
- Blitz or hks ssq BOV
- nos on a b16A EF?
- Help diagnose this piston failure.
- where can I find a manifold flange
- Oil Return line????
- hey ls vtec help!!
- HT Silicone Coating
- changing intercoolers?
- Replacement for greddy td04 19t turbo??
- Question for Manufactors who make LS/VTEC Kits, GE and others
- ebay turbo kit?
- need to have turbo rebuilt
- Can anyone help me identify this turbo?
- Sleeved Block Question
- nitrous jetting question
- Pain in the butt trying to find fmic to fit with 96-98 ek fogs
- Wastegate to atmopshere
- Ls/Vtec Turbo set-ups and results?
- Do i really need to run a vaccum block?
- which turbo to go with?
- how many shots of noz an i running
- Turboing my b16a help
- 1000 cc Injectors! Best?
- Help with NGK plus
- EG & DC Intercooler piping
- sc61 trim size
- built ls
- newbee needs a turbo
- Where to find Kamakazi headers?
- Supertech Pistons
- DC 4-2-1 headers or oem itr headers?
- need help with the right turbo for my new setup
- Import Tuner Magazine 90 Honda Civic
- jrc 6 inch intercooler limitation?
- d series ebay turbo kit
- Stock fuel system????
- Boosted GSR O2 Sensor Question?
- What do you have your 2 step set at??
- Hondata CEL ?
- What setup to do 10's?
- stock LS computer and 440s
- need some help overheat issue
- RMS Ryans DC2 fab/build thread
- ls crank
- Oil resrictors?? Do i need one?
- Boosted SOHC no spark prob
- I Need Help on this B16 Head Rebuild PLS
- Odd misfire issue. LS/b18b
- Catch can fittings?? help me out
- AN fuel setup questions
- MAP Sensor Wiring
- first ls bottom end build need some help
- ok to run turbo tuned/chipped ecu on stock motor?
- twin charge, supercharger and turbo???
- Best turbo
- b18 block b16 head ls-v Good for turbo ??
- d16 complete build/ got some questions
- backdoor intercooler pics/links?
- blox turbo manifold
- Low RPM bog
- Turbo Causing Excessive Crankcase Pressure
- what rings do you run with your vitaras?
- Help me go over my turbo parts list
- best ways to make good hp on a n2o LS.
- helloooo
- gsr JRSC installed but having many problems help me asap!!!**
- The Wideband o2 do I need it?
- Looking for C16 In NH/VT/Eastern NY
- Boost by gear settings, I need advice
- B16A2 GT30R info & visuals :)
- Intercooler Mounting
- Piston to Wall Clearance for Wisecos @ ~400 HP?
- What oil pressure for a fully built motor?
- castiron manifold
- Will these plugs work?
- f22a1 turbo manifold fitting problem
- precision ptb 60trim oil restrictor
- injector problems. top of pistons soaked!
- Greddy oil catch can installation/mod advise
- New DEI Turbo blanket???
- Debating on running E85 on a b16a turbo crx
- SC6169 Input
- Help! JRSC GSR Boost Issues..
- Evans Tuning T4 Bushing Street Kit
- Edelbrock Camshafts #4730 + Vortech
- boost question
- Fuel Issue and question with walbro fuel pump
- b18c turbo question(very general)
- Turbo sizing help?
- Smoking
- jrsc questions
- 1991 CRX B18C Turbo Radiator?
- GT28Rs > 18g
- What size is this garrett turbo, need help..
- b18b, greddy turbo, need some input!
- White/Light blue smoke from exhaust, at random times?
- search is crap ?
- What problems
- D16 cam help
- Precision SC6262...
- smoking when not underload
- My not-so-lovely Lovefab Experience... (nissan rb25)
- HElp!! starting turbo car issue
- R/S Ratio questions
- bkr7e DISCONTINUED
- skunk2 stage 2 pro on turbo engine?
- h22 coolant feed for gt turbo
- Would I benefit from just going with forged pistons & not rods in a GSR?
- Is a b17 a good motor to turbo?
- what size turbo?
- 97 Accord lx 4d, turbo problems.
- Best turbo
- JRSC iTR!
- Usual Signs of Cracked/Broken Ring Lands?
- Type R turbo? how many pounds?
- Using a Rod with a machined Journal?
- Push or pull Fan & shroud
- 3" exhaust...How Loud??
- HELP!** intake man. removed and oil on top of valves???
- Integra Turbo Help
- boost problems with jrsc
- Crome Tuning NH/MA? H22T
- GSR Turbo ??
- Turbo GSR Oil question??
- F22 is boosted but small problems
- 86mm to big for boost??
- JDM B18c turbo
- Nippon Denso vs. Walboro fuel pumps
- BOV flange material
- Your dream build post your ultimate setup here
- drive with no tune
- Hondata Boost Control Solenoid
- Need a intercooler made
- tial w/g question
- Any turbo E85 cars on spray?
- b18c5 turbo or all motor
- Air fittings for tial wastegate, fittment?
- Re-Searching: RFL Blow Off Valve
- CTR pulley...OEM better?
- LoveFab SST +GT3582R
- What is all this with my Wastegate...?
- help with turbo question?
- delete
- '93 honda Del Sol Si-Turbo
- B16A2 Safe Boost?
- 4g63 parts on b18
- any thoughts on this one?
- Turbo D-series build questions
- Poor Man's Type R Turbo Question
- Larger wastegate for small turbo!?
- Would E85 do this?
- Slight compressor surge - harmful?
- Help Identifying Turbo
- CC stage 5 clutch not disengaging issue
- 3in downpipe set up
- b18b1 stock sleeve ? boost?
- B16A Oil Temp Sensor position - size/possible? *picinside*
- Camshaft Selection for D16y8
- Ek IC Piping: Where did you get yours?
- picture request hx40 or hx30 with ramhorn
- Jrsc mpg
- Ball bearing turbo coolant lines
- turbo for dummies? anyone know of a good write up?
- What is the 14b manifold flange type?
- Co2 intercooler spraying??
- rebuild input
- 87 octane supercharger or turbo?
- Supertech Valvetrain
- Please help me solve the following problems with my stock 95 LS
- where to buy arias piston rings and which type?
- dual wastgates?
- rpm service throttle body
- Jackson Supercharger b18 Question: what belt
- victor x manifold
- b series turbo with PS and AC??
- boosted d16y7 question
