1000 miles in, have a look at these pistons please
Ok as title says, I've done about 1000 miles since the map and I've had to take the head off.*
No running issues or anything like that, I over tightened the oil pressure switch and cracked the block. School boy error I know.
So I'm taking apart to get welded up.*
Anyway, here are the pistons in the exact state they were when head came off. No wiping or cleaning.*
What do you think, *about right, *bad, not*ideal, very good??
Pic of valves too
Pic of valves too
Re: 1000 miles in, have a look at these pistons please
Yea id say it was running a bit rich, some brake parts cleaner should take that off.
Looks like a car that runs on gasoline to me.
WD40/brake clean the tops if you want, but I wouldn't even bother.
Thanks everyone.
Yeah it runs on shell vpower.
As I said, no apparent running issues. Just had to whip the head off to sort this crack out on back of block.
Thanks for the input
The head probably has done best part of 100k. But I had it all pressure tested before I fitted it. It came of a dc2.
Pic of the graph below for those interested
Engine spec is:
B16a2
81mm wiseco pistons
Manley rods
Acl bearings
Arp bolts
Dc2 head with b18c4 cams
1000cc Sard injectors
Ebay copy gt30 turbo
Cast inline pro manifold
3 inch downpipe and exhaust.
Tial waste gate
Car is a eg civic
Engine spec is:
B16a2
81mm wiseco pistons
Manley rods
Acl bearings
Arp bolts
Tial waste gate
Car is a eg civic
