View Full Version : Forced Induction
- everytime i take my rad cap off, coolant explodes everywhere, why?
- What turbos bolt up to the DRAG III downpipe?
- D16Z6 head?... oversized valves??
- Help with D16Z6 Turbo Setup. Nothing but the best parts!
- running sluggish all of a sudden
- Removing JRSC: Any tips to make this a small uninstallation??
- Wastegate constantly shuttering
- whats the best place to buy piping?
- GT35R or GT3076R
- 3 bar map sensor question?
- GT28RS: What amounts of PSi can it push, how do you control the internal wastegate?
- Bogging and Stalling
- rebuilt turbo b18 + del sol + AC = huh?
- what timing setting should i have when i start the car and drive ???
- problem ..OBX LSD
- just wondering... is there a step by step engine build thread?
- Oil return question
- Walbro 255HP fuel pump kit for Prelude... make it work on my integra?
- Boost control needed to supress surge?
- wich msd blaster coil??
- lookin for a high lift cam for TCed Z6..
- Any clue on power @6 PSI on 60trim turbo on stock b16 engine
- Anyone feel sick after driving in traffic in your turbo car?
- car bogging at high rpm with new injectors
- Question about egt gauge
- edelbrock victor x intake manifold - problems with other brands throttle bodies?
- Need new 6psi belt, where to get it?
- Boosted b16 fuel questions
- Having a problem running lean...
- Are my rings going soft?
- WTB: stage 3/4 obd0 hondata willing to pay good money
- 15g boost problem
- Injectors larg eneough?
- Some questions on Greddy Turbo kit for GSR
- Hondata tuner..... within 5 hours of Michigan?
- Very confused, need help!!!
- Loudest BOV
- What can these turbos support?
- aem uego wideband o2 sensor users - what are your opinions?
- lsvtec with NOS????
- Turbosmart Manual boost controller
- So, Who can build a motor, through and through
- My 99 turbo prelude needs REAL help
- what needed for install???
- Many question... New to FI... Please help me out...
- fuel injector,ecu and nos question
- Used turbos
- help
- turbo manifold...
- Greddy or Drag turbo kits ???
- Basemap Needed!!
- Latest Mod: RC 550cc injectors in the 7thgen
- turbo b18b
- TurboStore.com? Turbocalculator.com
- EGT Temperatures
- Cam journal damage
- NEED A TUNER for my k-pro turbo ep3 in MA
- help with N2O
- question about clutch....need to know soon...
- clutch question....please help..need to know soon
- 96 Integra Turbo-Ideas Please-
- How low does everybodys turbo hang?
- 1 bolt holding down fuel rail?
- HONDATA DATALOGGIN WTF?????
- xs power turbo questions
- i need a tuner
- b series exhaust manifold adapter?
- tial bov not sounding right
- Any kind brush on paint/coating for turbine housing avalible?
- cams for turbo ls, other than crower 402t's?
- need some parts...
- gapless rings + boost?
- Help w/ accord compression and Boost???
- do all b series oil pans fit??
- Possible to keep A/C and power steering?
- Ebay clutch Gripforce is it worth the money if selling my car???
- D Series Greddy Manifold mate STD IHI Turbo, need adapter...
- H22 stock fuel pump capabilites? (searched)
- S2S1 cams good for turbo?
- Braided wategate line for Turbosmart 48mm ???'s
- The OBX intake manifold. Some advice please.
- another boost spike
- Need help on my EP3 turbo, k-pro or emanage, need a wideband tunner in MA or NE
- best plugs for th3e turboes job...???
- Oil dissapearing...
- HKS Twin Power (DLI) Or Aem C2di ???
- AEM EMS losing its maps! Anyone have this happen?
- stroke differences between LS and B18C1/5/6
- Tial 50mm BOV?
- Manifold Suggestions??
- GT3240?
- darton mid sleeve's...
- need some help on tuning meth
- LS Block or B20 Block.
- 10.5:1+Crower 404s+6psi boost=12.71@106 in my LS!
- newbie SEARCHED little more help please b18c type R
- potentially buying a car. first time boost user. insight?
- b16a tranny question
- downpipe for hks Cast Iron Exhaust Manifolds
- What are most of you funning for total timeing?
- How do you feel about this one? very important.
- post pics of your pipe/large hose from turbo to airfilter..need ideas
- ** Turbo project finished, need help on whats going on **
- uberdata problems..huge fuel spike in 1.70 but not in 1.66?
- what turbo for this setup?????? and a bunch of other stuff
- turbo whistle sound...
- mini me turbo questions....compression too high?
- turbonater
- what the best out engine to turbo
- Pics of H22 turbo mani.
- will i need arp head studs for my lsvtec built turbo??
- Where to find T3 V band turbine housings?
- Clutch Slipping on my Dyno day, need some help.
- Boost going to All motor
- b18 or b20 for boost
- Walbro 255lph low pressure???
- b16 turbo throwing CEL 5??
- RSX Comptech S/C High boost pulley
- another problem
- What do I need?
- Need some opinions/suggestions before starting up (lots of pics)
- fuel cutting off at 6000 rpms on d16z6???
- Limits of my Turbo set-up/Motor...
- PSI
- blow off valve
- t3/60-1 spool time
- Next step for SOHC turbo; mini me swap or get tuned?
- B20/VTEC turbo Won't start- Please help
- CODE 16 trouble starting
- Problem with new fuel pump.
- b18b vs b16
- Anyone datalogging with Innovate LM1?
- Maximum rpm on stock B16 head?
- NEED TRACTION!!!!!!!!!
- AEM's 0db0 standalone
- What Hp range?
- please help OVERHEATING
- oil feed size for an sc61
- 400whp rsx-s stock motor
- New b16 turbo not running right.
- how much hp do you gain with fmic?
- e-cutout
- odd sound just started....
- can you tell me what turbo is this ?
- Got a new downpipe made
- Media Tumbling a block to make it look like brand new
- Turbo being unusually loud???? Need the experts for this one...
- XS-POWER TURBO KITS???
- Anyone use STR fuel rail with JG manifold....pic inside.....
- turbo manifold questions/
- Turbo Size
- WHP expectations ?
- T3 to t4 compressor upgrade
- resistor box install for dsm injector question...
- TURBO PROBLEM HELP
- need Vacuum source for TurboSmart wastegate
- relayed alarm to turbo timer, but shock sensor is too sensitive.HOW can i relay the shock sensor to
- Ebay Turbo
- where to tap for coolant b18b
- need optional Mount for Oil pressure gauge.
- what size injectors
- Dyno, please post your oppinion
- 286 WHP DYNO'D TODAY car is "busting up" WTF!?!?
- blox manifold
- PICS GE Vaccum Manifold and Brake Booster I.D.
- Overheating STILL!!!!!!
- rpm fluctuating at idle (searched but nothing about THIS exact problem found)
- Thoughts on Valvoline VR1 20w50
- saturated or p&h injectors what to go with
- Metal Shavings in Vtec Solenoid
- http://www.boosted-hybrid.com/...?t=326 I need this article?
- Ignition question????
- trying to turbo crx with b16
- what cam to run with nitrous?
- All I can say is ,You gotta see this
- What's the BEST 52mm ELECTRONIC boost gauge that reads P.S.I?
- 92 civic hb ls/vtec turbo
- SMIC vs FMIC
- distinguising between heads and comonents
- getting bored with 15g, would the gt28r be a good replacement?
- Can I turbo a build head b20?
- Need Help, Boost issues
- 84mm Arias piston VS an 84mm Weisco piston...
- if i run hondata do i still need my sacf2
- h22a+Boost
- Nitrous Jet Calculator? HELP!
- pucked clutch break-in?
- SPOON TUNING
- A little disappointed..
- Quick question, Anyone have problems getting car to idle properly
- Surging idle after missing link removal....
- Another Exospeed Scam
- B18 Engnine Overview?
- What are the holes for?????
- Gt35r
- what turbo to buy?
- Turbo insulation kits/wraps
- my piston at 10psi...LOL
- NISSAN SR20 T25..worth rebuilding?
- common failure for boosted STOCK b16a's
- Which Direction, help clear this up!
- new to the turbo game
- instantly warm??
- Turbo sizing for 1st gen civic 1200
- Tried searching but doesnt help me much
- stiffer spring for greddy internal wastegate?? please help/already searched.
- turbo b16 help
- Guess that Regulator...Anyone know what this is?
- tilting turbo for fitment? how much is too much?
- j-k-tuning?
- Daily Drive GSR turbo choices: SC61 or smaller turbo ie GT28R/S or holset?
- will 94+ integra inercooler piping fit 92+ civic ? searched
- adding a cam?
- New to turbo, car is over heating.....
- "creating" my own precision turbo setup...
- need help with my Safc. pro's only :p
- will a turbo from a chrysler laser or ford probe fit my civic?
- eclipse turbo manafold on a sohc
- what injectors are these?
- who does dyno tuning in n.y
- ** Help IDing These Arias Pistons! PICS!! **
- What's the defference in hondata s100 w/boost and s200 w/boost?
- Full-Race Prostreet Manifold
- Non Honda Engine managment Q
- Will Del Sol turbo pipes fit on 92-95 civic??
- Turbo Help
- turbo question pls help a newb!
- $20 for a bosch distributor cap and rotor shipped!!!Not bad.
- is my fan ok?
- GT37?
- Need a tuner asap
- Full Race B-series GT Stage I (plots, impressions and comparisons)
- anyone got Greddy Turbo Kit papers for teg??
- What causes sleeves to drop - just had motor redecked
- 2.5" or 3" turboback for t3/t4 @ 8psi??
- drag gen 3 fmic/charge pipes with oem fogs?
- Wired Speed Lab = Horrible
- knock control
- all right...turbo people...tell me about your insurance setup
- Anyone here using 3bar GM map sensor with Uber 1.7???
- zex dry kit (white wire)
- T3/60-1 and T3/67 Pics (FYI)
- WOLF 3D for b18c turbo CRX What you think?
- My friends turbo del sol dyno
- TurboXS Dual Stage BC install
- Downpipe exhaust leak...ok to drive?
- Hitting dyno on sat, have a couple of ?'s
- resleeved b20 vs resleeved b18
- New Fuel pressure regulator design: looking for feedback
- Intercooler advice
