View Full Version : Forced Induction
- Could I get away with this? (high mileage turbo question)
- What kinda numbers???
- T3/T4 hybrid ball bearing tubo Help??
- what turbo to use on b16
- timing Q with FMU setup
- SOHC guys...which head do you prefer?
- Turbo hits 9lbs then backs down to 7lbs! What the heck is going on? Only happened after got the ca
- I need help please, new to turbos
- Turbo Manifold - Equal Length Polished Stainles Steel
- How does the td05-18g compare to other turboes
- how do you wire up GM map senser?
- drag turbo?
- Upgrade Fuel lines
- Spearco Intercooler GroupBuy IT'S UP AGAIN !!!
- Any body running more than 4 injectors?
- JG-Edelbrock Throttle Body Group Buy
- Drag 3 turbo intake help??
- Need 3 bar how to...
- Need to know?
- Cleaning the engine block...can ANY automotive machine shop do it?
- OT: Got a toothbrush? hehe
- Turbo prelude exhaust
- This turbo or that one?
- Turbo?
- Horrible day BOOOOM!!!!!
- OT: warranty trouble
- How does this turbo sound??
- Is it necessary to get my block honed before new pistons??
- Help with building custom turbo kit?
- Purple Smoke?
- please give me some of your pics
- Homemade Boost Controller
- Bad Dyno on my 93 Prelude VTEC Turbo because of knock sensor
- Antifreeze leaking?
- t25 noise
- well pulled my plugs ... please take a look
- front mount intercoolers
- Which turbo??
- Pics of the sweet new 3" exhaust!
- missing link?
- Custom turbo fitment? B-series motorheads help!
- Group buy on PWR intercoolers and aluminum radiators
- Removing the turbine housing? All bolts out, now what?
- aem regulator question about outlet port
- I need turbo installation help!! Literally
- Strength of a Vacuum Source?
- b20 turbo help?
- Eagle Crank and Rotating Assemblies
- Help with Zex install. Which wire for the throttle reponse sensor.
- Possible to paint...
- Eaton superchargers
- What is the webpage for VAFC hack info
- Cometic with stock block?
- v-afc questions
- Best Exhaust
- Asking for a friend: can the 2001 accord lx handle a turbo kit at 7psi on stock motor?
- LSVTEC?? can you use B18's
- another dsm injector/ car Q' SHOOT ME
- RPM activated switch for IAB?
- turbo question
- AVC-R injector duty cycle?
- One more time.........Size of my turbo
- Quick question..
- Greddy Type S BOV
- i bought a used turbo kit with a compressor staped with .50 a/r....
- Question about my b20 turbo
- help w/ greddy
- how do you boost past 12psi without going in limp mode w/ VAFC hack?
- ECU selfs adjust when you retard your ignition???
- What are these parts? and where do they go?
- Parting Out My 99' Turbo Si
- does anyone know where i can get the wiring schematics for the map sensor (99 honda civic si)
- Intercooler Question
- got some new parts and tools!
- DSM turbo on f22b
- Attn: VAFC HACK operatives - check this out!
- Do light flywheels and turbos mix well?
- Where to get a Tee to hook up an oil pressure gauge?
- am i pinging?
- Does anyone use the exedy racing clutch?
- t-25 turbo price (2g eclipse)
- New track time
- How do you install a Cartech FMU?
- HIKS my compression dropped
- Friend needs help
- TC05-12A Mitsubishi Cordia/Tredia/Galant?
- gauge holder for boost gauges?
- fuel pump?
- ITR cams+ turbo=?
- anyone hit 12's with JRSC>>???
- How can I cool down intake air temps?
- turbo kits for an ls
- what turbo came off of a 96 eclipse GST or GSX?
- Jerking?
- Arturbo 2.5/3 inch downpipe for sale
- B Series Turbo Setup...anyone got pix of their setup???
- H22A Turbo (92 Prelude)
- Would Anyone Be Interested in Garrett GT Ballistic BB Turbos?
- boost gauge install?
- Poll: Keep this turbo or go for a 60/63?
- Whats the best?
- is my turbine housing too small
- finally got my car back after the rebuild........ :) :)
- "normal" shaft play?
- What oil temp/oil pressure(s) do turbo cars see?
- compressor surge
- Another Junk Yard visit..no clue what turbo i just took
- Maxrev boosted h22a4
- GReddy e-manage updates?
- Good Place to Buy Tanabe Super Medallion? -nt
- When and Why would you nitrous a Turbocharged engine?
- Learned 2 important things today
- My experiences with Web Racing Cam
- Turbo Oiling setups...........lets discuss possable setups.
- 22" Slicks
- *Smog, Can you pass smog on a built motor with turbo? What are my chances?
- t25
- anyone bought from import-store.com?
- Looking to boost my B16.
- Anyone have experience with Cartech FMU?
- Need advice on Boost Spike!!
- Oil return fittings
- Deck plate sleeved blocks from Golden Eagle Mfg.
- Does ARP not make main studs for B18?
- AVCR install question
- same post as tech form: Anyone with a B&M fuel pressure gauge
- should you get a 3" cat for a 3" exhaust?
- will a 5gen dx head fit on my 6gen ex block
- HKS TT Harness Instructions
- Turbonetics turbo died at 1200 miles....
- Any one wanna take a guess at when this turbo will spool?
- GOT mut TURBOOO!! Now which is it? Sonny??
- Wheelie bars
- Fuel Problem
- i just came back from the machine shop.... LOOK INSIDE
- Where to get custom Downpipe?
- FT: Greddy Type-S BOV
- Got my Eagle rods...thanks, Damon!
- How did you route your turbo plumbing?
- Taking a rod trip in a turbo car
- Inline Pro Mani w/ Drag 3 Kit
- bov and funny smell
- isn't the guy with the blue civic one of the elite h-t members
- how much are darton sleeves for b series worth brand new
- bad fmu
- would this work in my civic?
- Turbo Engineering Corporation...
- Is anyone in the Dallas area currently (or have experience) building a custom turbo kit?
- list your spool time with b16
- where can i find the specs of the civc motors
- I need some DSM 450cc injectors.
- Am I running lean?
- Green wire for turbo timer? If we need it, where does it go?
- EGT meter thermocouple
- Found out what makes white smoke come out of the head breather..
- any DIY b series setups..already searched
- 02 Sensor housing bypass/or internal to external WG...
- T4 Questions? Help from T4 Turbo People. T4 Turbo Decisions.
- OBD0 to OBD1...?
- KKK K26 smae size as a T3?
- Used safc..reliable?
- who has the cheapest price for a AEM FPR?
- fuel problems!!!!
- WTF is up (honda tuning supercharger story)
- is the JRSC worth spending $1500 on?????
- Going Turbo, suggestions anyone?
- oil pressure guage tee
- i got my nitrous today
- Problems??
- Whats wrong with Turbonetics Deltagate?
- 85mm bore too big for a resleeved B20b?
- zdyne group buy
- Where to buy just a turbo?
- PowerFC Users
- moved the wastegate line to the charge pipe, should i move the AVC-R sensor there too?
- fpr's: b&m VS AEM
- I still want a turbo :( Why did I spend all my money of a Vtec head?!?!?!?
- How fast would a B16 in a Ek Hatch with Drag III Kit with 7psi,
- running lean up top
- HELP! Boost is suddenly falling off. . .
- anyone wanna make a buck or 2. i need a hondata chip burned. please
- Anyone run a straight T4?
- Cracked Manifold
- Will I need to make an adapter plate?
- Spearco Intercooler Group Buy Update
- Auto Performance Engineering Walbo Fuel pump?
- Optimal corner weights??? Give me a starting point for setting up a drag crx.
- Hondata: Which Rising Rate Regulator to use?
- OT: What is your favorite CS server?
- Turbo XS dual stage boost controller
- Do I need an intercooler with this setup?
- Jackson Racing SC Lean Problems
- Will Type R final drive be benefical on boosted GSR?
- was driving on the hwy today and....
- are you supposed to use teflon tape here?
- I need help with my Profec B
- Joining the darkside very soon :-)
- OT: Saturn or Tacoma?
- A little help on the ghetto turbo fuel set up
- Flywheel??
- has anyone ever heard of this palm diag tool for obd2 cars
- zdyne group buy (canada but all welcome)
- running rich while in full boost?
- what do you guys think of the manifold in bQQsted hybrid car?
- 3" exhaust and cat
- JG/Edlebrock Victor X Manifold Group Buy
- how much to install pistons/rods/blockguard?
- how do you know if a turbo is in good condition?
- PICS 4 my LS turbosetup almost completed
- Greddy Intercooler Piping for sale.
- damn ... oil return line leaking
- Quick Moroso Oil Pan help please
- How far away from the turbo.............
- compressor maps help
- Custom Turbo Kit For Sale (Maybe!!)
- What would happen if...
- OT:Thinkin of selling my motor
- What is your opinion?
- Smog police of out of state cars?
- Anyone with a Hondata stage 4 in toronto?......
- What was posted about a turbo with a blue backing plate
- anyone have a spare tial 35mm wastegate ring?
- Downpipe the size of a straw?
- Anyone selling a Hondata 3 bar map sensor??
- Trying to understand how hondata works!
- Need Help! Del Sol Radiator in a crx.
- what do i need to build a 93 del sol sohc vtec block??
- pics of my setup
- Good clutch for 400ish hp...
- What happaned????????
- VAFC Hack question. Help Please?
- Who are good dyno tuners in the bay area??
- information on this turbo?
- APEX-I Boost Gauge FS
- custom turbo kit for my ls..??
- Honda Turbo Jetski LOL
- Just had my first post-turbo scare .. kinda long
- I guess all these high priced turbo and engine parts in my closet blew my clutch...
- How come partial throttle is faster than full throttle?
- What mods to stock B16 block to hold 10psi
- License Plate blocking air to FMIC??
- OMG OMG OMG OMG!!!!!!!!!!!!!!!!!!
- ok, I've boosted for the first time in my car!!!!!
- who can i ask questions about for the vafc?
- Anyone using Hondata intake gasket?
- MAP Controller on a JDM B16 SiR II?
- Clutchnet or Clutchmasters??? I did a search, I did a search, i did a search
- cr-nsx from atlanta georgia
- start up problems
- DIY D-series turbo Q's?
