View Full Version : Forced Induction
- Integras with greddy kits
- Manifold Importance
- Valve cuts in Pistons B16a2
- bluebox wiring
- video of my buddy's civic nothing to sweet but hey
- RC 440cc Injector
- Greddy Turbo Kit Instructions?
- Boosted setup with stock radiators..
- Check out this manifold
- took some pics of the R today...enjoy
- PRofec e vs. AVCR
- Rx7 Turbo project, starting DEC 16.
- FULL- RACE Kit...anyone got it here?
- clutchnet clutches???????
- i'm making a downpipe but need some advise
- Help! New with turbo setup
- Turbo + rain = disaster?
- hx on boost
- greddy manifold (t3)?
- Switched from SMC to Uberdata...Just want to say I love Uberdata!
- ANY GOOD TUNERS IN NORCAL(Central valley)??
- boost creep is freakin scary.
- t3/t67 debate...how much whp should you expect?
- Earl and Dan Benson of Benson's Machine Shop
- ** Tuning in/near Missouri **
- clutch review - Action 2MD in a d16y8
- DYNO RUN AT AGILE MEET
- missing link: universal?
- what is the best BOV?
- supercharger vs trubo which one is better for the engine
- Who needs a h22? Maybe I do???
- GSR Finally Tuned!
- Full A'PEXi turbo system............. opinions?
- Replacing Pistons on the B18b (Ls), what should I get
- Are My Spark Plugs Okay?
- ** Pics and Video of my DA **
- Clocking turbo...bolt issue
- VAFC to Hondata
- How many people have rebuilt their turbo?
- compressor map help......
- boost gauge...?
- Boosted mini me
- crazy timing issue with my obd1 converted y8 with uberdata...possibly the cause of my detonation.
- clutch is soft ?
- Quick easy question that i dont know, HOW to adjust timing
- Uberdata guys. Need help. Surging/high idle and idling VERY rich.
- need help with a dyno chart...
- B18 setup question
- Anyone close to NJ tune Emanage?
- Turbo question
- Is this detonation???
- mid/high rpm stumble/noise, getting worse - details inside - PLEASE HELP I'M GOING CRAZY
- BLOX turbo manifold
- LM-1 or PLX
- O-ringing head vs ringing block?
- Anyone know of turbokit for a F22
- SC50 numbers??
- Twin turbo B16... WHAT?
- Wastegate vaccum lines - where they go
- bov freezing in cold (anyone else)
- supercharger and nos Question???
- Too much boost with the greddy sohc kit...
- rod choices for d15b?
- high fuel pressure
- made myself a new manifold...
- Sounds like 10 bb's in a coffe can at 7500+RPM in 4th gear on my b16turbo
- MACHINE B-series LS 4th gen T3 project car - boost on a budget(lots of pics)
- wideband tuning
- need some help choosing turbo setup
- what do you think about this??
- need help suppost to dyno tomorrow at 10a.m.
- 2.5" Greddy Downpipe from Kteller.com
- Dynoed: Greddy turbo Y8+blue box+walbro/stock injectors+12.5 psi = 225whp/204tq!!!
- q45 80mm throttle body on h22
- tunin the prelude
- turboed GSR still not running right
- anyone buy from SIVERTURBO? (link inside).
- cold temps: no top end?
- I have a walbro 255 fuel pump in my car....How can I tell if it's a LP or HP??
- ARP Head Stud Question
- important: how to read turbine maps or what Turbine A/R on a GT30R Turbocharger
- no spark......need some advice/
- How much does a turbo kit cost to install at a local tuner shop?
- Drag Turbo Kit Filter Problem Solved
- Mini-me owners i have a question...
- Trackmasters Huntsville Alabama? Anyone vouch for Art?
- Need Help: Best Turbo Tranny
- Best daily driving turbo kit
- LSvtec turbo proposed buildup. Comments/Suggs please
- Fast-turbo.com---Beware!~do not buy!
- Force fed G35
- Cutting out when hitting v-tec/highspeed map?
- Greddy Profec-S
- Turbo issues
- Will this kit support 400hp easily?
- Turboed 97 Civic
- Head or no Head?
- Today is the day!
- Highest rev limit....
- Turbo teg injector ?
- Anyone running FULL Greddy kit?
- will it creep?
- check out my shitty soldering job
- piston 4 turbo gsr???
- D series manifold converted for B?
- any gsrs running gt30 or gt28?
- JRSC D-Series question..
- can anyone tell me a bit about h22's in eg's with a t3/t4 turbo??
- Help with fuel management PLEASE!
- T3 Super 60 Confusion
- Map issues
- my new toy !
- 500 whp on ACT Xtreme PP / street disc. ??
- what turbo is this?
- crvtec .... boost...
- Ferrari show/races video
- Is my LS tranny good for my ls/vtec set-up?
- HKS BOV Problem
- do i need sleeves
- Has anyone ever delt with TurboCalculator??
- B18C Teg, When can i expect boost
- T3/TDo4E flow rate??
- Just did a compression test... i think its a lil high?
- stupid uberdata question (might apply to hondata)
- SSAC is the shit, look what it did for my ride!
- Welp...I'm thinking about making the switch...Hondata--->AEM.
- Dump tube in the exhaust
- What to buy for tuning?
- boosted mini-me
- CP piston, SOHC wall clearence and ring gap >>
- injectors question
- how can i adjust my FPR???
- Where to get sandwhich plate for oil filter?
- H22 JRSC injectors install
- JacksonRacings supercharger Crank pulley upgrade
- What is your guys opinion about my idea...
- can you trick a map sensor?
- is there a plug between NGKbkr6 and NGKbkr7 ?????
- Will these injectors be enough?
- Any dyno/reviews of the mini-me manifold? (lovefab)
- Which turbo would start the fun earlier?
- Venom 400 Performance Control Module !
- can a missing link go bad?
- What size injectors? CRX LS t3/t04e turbo
- Hows My Setup? (gsr-Turb)
- Question for you guys
- Greddy E-Manage
- Garrett ball bearing turbos
- Skunk2 stage 1 exhaust cam for turbo car
- comparison(debate) lsvtec turbo or b20vtec turbo
- Opinions of stroker kit for B18
- pistons for h22 build
- Breaking in all-motor?
- GT28R Wastegate question
- 9:5:1 cr too high for turbo???
- Please help...car shakes when driving
- anyone use this manifold? found it on ebay
- comparison between golden eagle sleeves vs ari sleeves w/blockguard
- turbo GSR not running right
- ITR vs Skunk2 Stage1 cams for boost.
- D-Series SOCH Setup/Planning.
- wiseco piston ring question(tough one)
- ? 4 a friend : miata turbo mani.?
- what msd box to use on a boosted d series
- What is the stickiest 16" tire???
- new motor....questioning internals
- REAR WHEEL DRIVE VS. WRONG WHEEL DRIVE
- finally got my car to the dyno today
- I wanna see or hear your dyno Numbers on a BlowZilla Turbo...
- stupid wastegate question
- Need Opinions : Turbo setup
- NA to Boost, part 2, 10psi
- 250WHP WHat engine mounts?? Stock not good enough????
- Suggestions on a powerband
- ECU Codes and the USDM Cars they came in. Reference Guide
- PROCHARGER questions
- how to fit stock fans on radiator w/ turbo?
- Need Part # for GM 3 Bar Map Sensor and Boost Solenoid
- rom burner
- Who spends time searching for cracks in cylinder walls? I think this *might* help.
- Question about Studs (manifold to turbo)
- b16b Turbo
- FMU Vortech
- Rocket Motorsports Forged Turbo Rods
- Sohc Turbo Help?
- I want people's opinion.....
- NGK bu8h?????? anyone familiar with theses?
- What kinda power with LS block and Vtec head.
- Where to find an Aeromotive on rail adj FPR...
- having a problem w/ downpipe
- EBC or MBC?
- Wideband Pros and Cons: LM-1, PLX, FJO
- Vouch thread for FIPRACING.COM
- almost finished turbo should i start?
- question for B20 turbo experts
- DSM 450cc Injector into a SOHC Queston?
- what would be the ideal turbo for a gsr engine?
- 3bar map sensor, is the sve one good?
- best possible minor upgrades for b20 turbo
- TUrbo choice sc61 t3t4e gt series help
- ignition timing
- Pistons, Rods, ....
- D16A6T Exact Part List. Please
- b16 on nitrous
- should i upgrade my valve springs?
- turbo is not so loud! why?
- intercooler got a dent?
- is this turbo cappable of 200hp
- hack question!?!?
- bad part throttle
- PCV System: Why Do We Have them? Emissions?
- Spark Plug Temperature On Edelbrock Civic
- Johnnyracecar 8in intercooler
- built ls/vtec needs boost...t4/t67, gt4067, ...what turbo do you think?
- External oil pump questions....
- TRYING TO GET A TURBO LS GOING? POSSIBLE
- make your own wideband?
- turboing an eg hatch b16
- Should I change engine or not
- FINAL DESIGNS ON MINI ME!!
- stock b18b + t25?
- Bumper modification (greddy intercooler) question
- any uberdata users/ tuners in indiana
- 300hp b16-t, does this seem to be any good?
- High Compression + n2o?
- Turbo pick out help me out!
- Where can I buy an upgrade pulley for my JRSC?
- Boost Gauge Question
- ATTN:does anyone use megasquirt fuel management?
- UNDERSTANDING AIR/FUEL RATIOS
- Best Hondata Tuner in Md/Va
- Anyone know where I can find 4" Titanium Tubing?
- newbie question about turbo size
- an-r fitment b16..
- Things to replace while rebuilding engine , gaskets and such >>
- FMU
- Spraying Nirous into a SC/TC
- New Greddy BOV
- SOHC TURBO STALLING...HELP!!!!
- Intercooler question.
- Can uberdata be used if i'm going turbo?
- turbo d16 camshaft??? crane?
- uberdata w/ WB
- T25 Question
- forged flat top pistons - where to buy?
- some LS turbo track times...stock block, 150k miles!
- what happened to neptune?
- CCA or JRC intercooler?
- Turbo Wheels
- thoughts on cheapturbo.com kits
