View Full Version : Forced Induction
- quick question about hondata and injectors!!! please help!!
- OverHeating STILL????????WTF?????????
- couple of questions before i order my turbo
- to all past turbo owners
- How to install boost gauge...?
- wont boost
- what should i set my plug gap, LS TURBO
- turbo folks: post the type of oil you use
- Tunning Question
- turbo and stock exhaust
- how much power will a tdo5 18g support and question about waste gates
- turbo bag
- Cams for B18 trubo setup... pros/cons
- spark plug gap for nirtous?
- anyone thought of peltier cooling systems on intercoolers?
- Blue Box Q
- Those with VAFC hack... did you connect the blue wire??
- Where to buy GM 3bar map????
- Revhard stage III
- Is this guy BS or for real?
- turbo teg vs yamaha R6 2
- Clogged Cat Issue - - Boosted 98 LS
- D15B7 Turbo Question
- JRSC falls flat on its face
- Can someone please help..
- B16 CRX (Delsol) 11.60 @ 129mph (New Victoria Record)
- Terrible numbers on dyno......can anyone give me an answer!!!!!!!
- Ok i've never pulled a head, just a simple question..
- Stock B16 w/ InlinePro Headgasket, how many PSI?
- best oem ic???
- Sohc Turbo Questions...
- Help!
- Intercooler piping. Mild steel or aluminum?
- what went wrong?
- exhaust for turbod cars
- Built D series ppl need your help!
- GReddy missfire? Been fighting for a month.
- which ecu?
- not honda related, but turbo none the less
- D series cam comparison
- Leaky bottle
- Greddy E-manage question
- Will LEADED gas do me any good (Seriously) ?
- Numbers after buildup a bit sad .... HELP!!
- throttle body question, please help..
- signs toward bad 02 ?
- Does no one make a Equal length mani thats ac compatable??
- quick ? about MBC isntallation..
- backyard tuning 7/7/2k3
- EGT gauge: Where did you guys tap into the exhaust manifold?
- Ways to Up your boost...?
- Greddy Profec-B Remote Switches
- rc blank injectors
- anyone from MN who can BUTT TUNE my HONDATA??!!!
- installed this over the weekend..got a question
- Max PSI for Blue Box and E-Manage
- Block Guard vs Sleeves
- vafc hack
- Dumptube suggestions?
- is there anything wrong with a turbo that is glowing red and putting out alot of heat?
- Just installed my 450cc injectors with the S-AFC2, now some minor ???'s...
- Engine Bucking Wildly at Idle?????
- turbo+b16+hondata+stock injectors=possible?
- Walbro part#GSS342 fit 94GSR?
- Turbo Sticker
- sorry if this is a repost
- what blowoff valve is better?
- opinions on drag turbo kits?...
- Fuel Mgt Help (91 crx si w/Z6 and Greddy kit)
- Are there any good inexpensive clutches for a D series tranny that will hold 250-275 FWHP?
- is my wastegate bad????
- Major problem with new block...
- NPB 12.74 @ 113MPH LS/Vtec turbo
- help me out...school project
- Part # for plug that works with GM 3 Bar map sensor?
- Slow spool to full boost
- Turbo Coupe
- Where to get wastegate elbow extension?
- OT: Been a while, but i'm kinda back
- Intercooler cfm? is it enough
- Greddy boost guage and Hondata reading discrepency??
- AND THE WINNER IS: Andy Puric of Ontario Canada -- You won $500 KS Kredit
- 3 bar Map sensor Problem?
- stolen stuff
- need help on hoooking up a apex i s afc spec 2
- opinions on SFP manifolds
- Air/water intercooler in a dc2
- JR fmu??
- Anybody want some things from Japan!
- injector help , o-ring?
- Dyno questions.......stock b16
- TURBO R? @ 11:1 ? yeah?
- Race gas
- need turbo info
- $450 for a rebuild and cartridge???? too much?
- QUAD TURBO?????
- Clutch reccomendations for 80% street driven 20% Drag
- Turbo Kits For Hybrid Civics?
- Cali guys - how the hell do you pass emissions/smog?
- Finally in the 10s took so long
- 13.4 @105 in B18C1 turbo crx...
- oil for turbo?
- transmission question auto/manual for turbo
- help on overheating turbo si
- ACT Street Disc Vs Organic?
- Blue box and VAFC together...any problems?
- maintenance on uninstalled parts
- wanting to go 15psi-20 psi where do i START AND WHAT DO I NEED PLEASE TELL ME IF I MISSED ANYTHING
- b18b questions
- Rc engineering worksheet, system fuel pressure?
- Just did a compression test-- now here's my plan...
- help...problem with boosted 'lude
- Turbo Prelude Exhaust
- some pics of my project so far. .
- drag kit for 2000 si fit on 93 hatch with b16?
- Which clutch to go with?
- Jackson racing fmu???
- fuel pressure regulator
- Exhaust gas smell
- Midwest Tuners for E-manage?
- DSM 450CC injectors.
- Post pics of ur tubo manifolds and down pipes please
- need help on turbo sizing tdo5 18g as opposed to t3/t4
- Greddy Type S BOV Soft? Hard?
- wiring for nitrous
- what will cause a rod to punch through a block?
- greddy blue box on custom ls turbo?
- anyone use the garrett GT30 or GT25 turbo?
- Where is a good place to find a super charger and turbo for a 92 civic vx runnin a b18c5 type r head
- how rating on golden eagle block and customer service
- deltagate mk 2 wastegate
- Problem durinf Solo 1 has now escalated on to the streets - help plz .. . . . .
- Turboed tegs... radiators?
- Intercooler piping with Lovefab Sidewinder
- OT: Been practicing with the welder
- To anyone who has bypassed an ignitor w/ MSD 6A
- Profec-B Spec II Questions
- I need a picture of the APexi EGT guage probe..
- boost problems with turbo prelude....
- I am nub with turbos....
- Breaking In Pistons, Rods, Rings
- turbopanda pistons and rods
- max rev downpipe and manifold users, please post pics of oil return! [no msg]
- boosting stock sleeves b16a
- oil feed line pressure...
- funny smells and lose of idle
- DRAG or GREDDY FMIC?
- ballpark hp number???
- Best Manifold for under 500???
- Need help with wastegate issues......
- Oio Temperatures
- stainless manifold
- New to turbo, intercooler needed?
- Ran my car for the first time 11.76@120 at MIR
- lookin for hondata chipped obd 1 p72
- Anyone here selling a built hatch?
- will a 57trim make 450whp
- CRX looking to boost (b16a)
- will 99-00 civic si drag 3 kit fit into 95 integra ls???
- What size intercooler on my ITR?
- Full Floating or Pressed Wrist pins on boosted GSR?
- does tranny make a big difference?
- need help car boosts but stuters under open throttle please help
- O2 sensor voltages... whats good.. im running lean..
- My SC61 .5 bar progress (timeslip inside)
- 03 accord turbo?
- Can I use a hondata 2bn?
- Wanting to Run greddy E-manage
- Boosted TEG Problems
- Honda prelude RC 370cc fuel injectors
- are there fuel maps when you start your car?
- full-race manifold require any bracing?
- What to do with $250-300 dollars?
- Endyn catch can install question
- Difference between T3/T4E and T3/T4B (best turbo set up for a CRX HF B16
- I need Prog-Studio V 5.13 NOW!!!!! please please please help
- DSM 450 Injector Question
- anyone know the output of stock honda knock sensor?
- Should I go Turbo?
- drag kit manifold
- Damage from Leaded Race Gas?
- Apexi GT spec I/C for 92-92 civic -??can i use it ?
- Rebuild Part 1 (56k go Eat dinner)
- All motor setup, want to run a little N20, is this safe?
- Please Read my Rebuild Parts list - Am I missing something??
- tranny issues?
- rusted turbo piping, help....
- Saw Mike Laskey on NOPI Vision today!
- FI pics from Darknights. (56k beware)
- Civic D14A8 turbokit? Anyone?
- AC Removal: 3G Teg
- Post up your House of Color Paint
- JRSC pushin' 8lbs... new injectors???
- Water injection accesories.....
- exhaust for jrsc gsr
- FINALLY 01 CIVIC TURBO!!!!
- power steering or no power steering is the question
- JRSC What to do, What to do???
- broken piece! Where to get? (pictures might be a bit big)
- My GFs project test fitted in the car....
- where to find DIY turbo manifold kits?
- most boost to a d series
- questions about making my own gaskets
- hondata 2bn
- need some EMS help
- need references...
- What wire off the O2 sensor do i connect the lead off my A/F gauge too?
- everyone who runs an aeromotive external pump w/ sump
- power estimation, what should i be making?
- Will this Spearco intercooler fit on my R with out cutting?
- went back to the dyno today
- TD04H-15G on an LS?
- how fast can i kill a turbo??
- Best "Bang for the Buck" Reliable FI on a 95 LS
- will greddy turbo kit for a teg gsr fit my EG hatch?
- Oem vs Bronze Valve Guides
- JRSC Rebuild Interval
- t3/to4e 57 trim compressor spool on my integ
- Opinion on Overbore pistons
- 2 very newb questions
- How much will i benefit from an equal length manifold?
- FMU?
- can i see some pictures of gauge locations on ef
- I have a greddy turbo kit and a front mount IC. How much piping do I need?
- Put new motor and turbo in, but it wont run right. I think its electrical......
- A couple pics of the 372whp 9psi wonder...
- MF2 wiring question
- Are these 9.0:1 compresssion pistons?
- FMIC vs. SMIC dilemma - price, HP difference, bling/theft factor, etc.
- Check Engine Light with UBERTEG Chip Help!!
- Pic of NOS microswitch install
- HELP!! Not making any boost!
- Will this work?
- What kind of oil do you use during break in period?
- turbo question on accorrd
- A little help
- WTF!! is wrong
- My car is now boosting. FINALLY!!!
- homemade race gas?
- clutch problemm.........
- turbo teg acting really weird, need help.
- boost gauge--electric vs. mech
- How to Find Out Trim
- turbo seals gone bad ??
- boost leak on a jrsc?
- apexi boost controller any good?
- gck axle part number
- OT Kinda:porsche 944 turbo?
- I was 2 quarts low?!?!
