View Full Version : Forced Induction
- Surging and code 14 help please
- ls vtec turbo Qs...
- Boosted 2000 Si CEL then overheat
- Innovative MTX-L wideband issue
- What wastegate spring with boost by gear
- How to get crank shaft bolt out??
- InlinePro Fitment
- Turbo ef filter fitment
- Overheating turbo gsr
- Skunk2 New Alpha 900hp Rods
- Max power stock ls bottom end
- You guys use ARP rod and crank bolts?
- Grams Performance Injectors
- 93 Civic/D16Y8 swap -- I want to turbo it
- Good engine builder in North Carolina?
- ls jackson racing supercharger help!!!
- When do you need new piston rings?
- Turbo Build Checklist
- D16GT35R Turbo build. input/ siggestions?
- 450whp GSR help!
- Will this oem exedy clutch work for 8psi?
- FP red turbo on a d16a6???
- stock f20b turbo opinions
- ecu problem or wiring problem?
- MOROSO Air/Oil Seperator
- b20b boost
- Boosted gsr logs out of s300 data logging while tuning
- Supercharger for ZC motor
- PTE 6466
- Minime Boosted. Your input would be great
- ls vtec turbo erratic idle only in traffic
- Rebuilt turbo is leaking oil from everywhere
- LS Turbo trouble
- B16A which turbo to use
- high boost sputtering
- Noob question about turbos
- 650whp clutch what have u experienced works
- Simple Turbo Setup Advice
- engine will not rev as high in high boost
- wtf my buddys b16 makes more hp than his gsr !!!
- D16Y8--->90 civic conversion Q's
- Just got retuned s2000 From Mase to Trackforged turbo manifold
- Need Advice. Ign bypass+ Digital ignition vs hondata CPR
- Boosted CRX Build (from Toronto Canda)
- bubbling/rumbling noise h22 turbo
- should be an easy question, downpipe/mainifold gaskets?
- bigger intercoolers and front bumper support
- Ignition module breaks within 100 miles
- Wrist Pin Circlips - How do you get the damn things out??
- JRSC B16 stuck in limp mode. hondata not powering on!
- Water mixing with oil FRESH laskey ls vtec
- What BOV on this car *vid*
- my "custom" gt28r
- T1 spec web cams?
- s366xl 700hp lag?
- Turbonetics turbo's?
- Identifying Connecting Rods
- Boosted 00 Civic Si - high idle problem
- Thank you Go-Autoworks! The Shodan and all of you!
- Super 60 turbo, suggested turbo size?
- Just a cool article i found while surfing
- Ricin4ever 2 year build
- Rebuild motor for boost. Civic si
- 10.5 CR on pump gas?
- a QUIET BOV
- Do JE pistons work well with boost?
- Mac valve wont stop clicking
- honda_power's Turbo 5th Gen Prelude Build
- H22 w/ Skunk2 Pro1 cams. Too big?
- Vitara Slugs on Eagle rods. Are the circlips bad?
- My Crane cam specs. Good for boost?
- new downpipe need a retune
- Reman d16 crank with boost, yes/no?
- Can I use this go autoworks mini ram on my setup? Help me
- A VERY good detonation & pre ignition article for you guys *Please Read*
- Turboing my Del Sol
- thoughts on this aftercooler
- Turbo b16a - same piston blows 3 times within 1000 miles
- Easiest way to pull turbo motor?
- JDM GSR GETTING BOOSTED TURBO HELP
- First PRL Boosted 8th Gen Build Thread
- Pic request log manifold intercooler piping
- What ever happened to RevHard?
- b18c1 turbo builds
- LS Block bore question
- Possible boost leak? Please help
- Building 3" integra exhaust, need help
- Boost creeping with boost by gear
- tial v-band clamp bolt size?
- Will Forged Pistons fit Stock Rods?
- Basemap Timing/Retard - LSVtec Turbo 12psi
- d16y7 Turbo Build begins!!
- My 639whp integra overview video
- AFR issues Turbo B
- 94 civic EG d15b7 turbo kit
- j32 civic turbo
- First LSV-T Build List
- Project: "I still had this stuff?"
- Nitrous Help
- B series block questions.
- any tips on setting launch control s300 d16t
- turbo advise
- clutch slipping on the dyno
- Can I install head studs without removing the head?
- Big 16g onto d16y7/y8?
- Engine blew after 1600 miles. please help me!
- boosting the b1
- Turbo dohc zc
- Where can I order a CP piston ring for saturday delivery? Need help ASAP.
- Specific intake manifolds better for forced induction?
- Hondata s100. Yes or no?
- B18 turbo running lean
- Modified Honda IAT Sensor in charge piping
- feed/return lines
- Is this Blow off valve junk? anyone try it?
- NOOB
- Muckman’s Integra High Compression Super Build
- poor mans R turbo build
- Street disk pic ! Anyone
- ****HELP WITH GSR BLOCK PUSHING 18g BUILD****
- S300 Launch Control settings- Too aggressive?
- throttle body sticking(70mm bdl tb)
- 2 stage boost controller for my set up?
- Suggestions On A Full Turbo Kit For A 95 Del Sol B16A2
- just picked up a turbo Kit.
- Turbo Parts list
- Unknown Fuel cut on dyno
- charcoal cannister removal?
- Anyone near Toledo Oh lower michigan know where i can get my car tuned on crome at?
- To get a decent air filter on it may take extreme measures
- YCP or Nippon Cast Piston Dealers?
- Blown up Precision Turbo?? Is this common on the new stuff?
- HUGE boost loss over 6000rpms
- civic b18 ef turbo ac
- rock piston brand vitara pistons any good?
- Turbo d16 catch can setup.
- Which Wideband?? Plz Help
- Undecided on motor
- issues at vtec
- is this a rod knock? video inside
- t3t4 Boost creep/boost cut problems? Any advice?
- zc ecu?
- 2012 rebuild with Silver Surfer. Dyno Results inside.
- JRSC D16Y8 on a D16Z6....what parts do I need?
- turbo ls civic
- Big problem with my Engine
- scat 89mm crank or micropolished ls crank
- 85x89 Sleeved High Compression E85 on 50/100 shot?
- boosting zc.
- My ign timing map, and plugs ? Plugs too hot maybe or timing ? help.
- new race fuel! Fuel The World (FTW-purple)!!
- trying to understand wastegates please help
- D15B Vtec Turbo Build
- Yo!
- Turbo problem
- Difference in spool up between 2 housings
- 4port solenoid boost control issue ?
- The "Monoturbo"
- Good supplier for Garrett turbos
- Most common swaps/turbo builds?
- Is there a company out there that make ROTREX for B series?
- Boost Solenoid not working?
- Crower 403/404's in LS stock valve train
- Need a Quick Spooling Turbo
- MAP sensor issue or something else?
- air leak sound
- bore stock sleeve and boost to make 300whp
- Should I upgrade my fuel pump?
- What can one tuner do differently than the other?
- d16y7 vitara's setup
- New cold start issue
- Blox log exhaust mani. studs? bolts stripped
- D series head question
- Vac Manifold to PCV port
- Garrett Id
- Oil temp sensor in moroso 5qt pan - what fittings to use
- boosted b18b, very low vacuum
- b18b1-turbo map issues
- Throttle Body Question, Need expert advice with experiance
- valve train questions
- b18c type r transmission
- turbo seals
- White smoke issue.
- ARP rod bolts for b18.. should I or not?
- how do my plugs look?
- help car smoking
- Boost issues
- TE04H turbo
- LS Turbo Rebuild, increasing boost, forged internals??
- Can way oversized fueling and turbo be detuned??
- Starting my "build" with a jackson racing supercharger. I need some help.
- Where can I buy quality oil lines?
- After Boost car running in limp mode
- B16 civic with jrsc
- Great read on compressor map creation and testing
- Car dies and does not turn back on til later.
- Precision 60-1 on stock b16
- B16 Turbo Build
- B18c Turbo Questions
- Garret T3 60-1 the Right Turbo for My Goals?
- Street/Track fuel pump questions: (700-800whp) on Ethanol
- Boost by Gear help/advice please
- Thank You Bisimoto!
- Turbo b16 put back to n/a
- wrap or not the charge pipe
- turbonetics t3/t4 50trim max HP rating
- Precision 5831 vs Precision 5431
- shuts off when hot
- Turbo gsr burns oil, help diagnose
- Turbo options for my 800hp V8 s13 build
- Holset h1c?????
- Turbo Oil Feed... too small?
- Need Help w/ Garrett Gt3582R
- Are these rc injectors seated correctly in my fuel rail? *pics*
- LS-T help...horrible idle.
- Anybody running Borg Warner EFR series turbos? post up your pics
- Resistor box wiring?
- Oil restrictor
- Looking for a very odd an injector fitting
- check list before taking my car to be tuned?
- Precision injector size??
- setting the timing on ls vtec turbo hondata
- New to turboin civics
- How to: DIY dual pump hanger...not for noobs
- What kind of turbo is this?
- compression test #'s..what to expect..
- just picked up 2nd honda for turbo build
- alright peeps, lets play diagnose this noise
- Water Cooled Turbo Setups
- jdm b20b 300whp
- 20lbs on pump gas...dd..opinions? Safe?
- Should I get this Boost controller? $5.50 so far
- Restrictor questions
- PCV System / Catch Can Setup for 500 HP B18C1 build.
- for the people on a budget.
- New and have some questions for reaching 500+hp
- A few general questions
- id 1000 and 255 wal bro enough for 500 whp on 110 octane?
- 97 Prelude Axles
- D15b7 minime turbo
- Forced Induction Beginner, F22B5 Project.
- Would a kink in oil catch line cause smoking at WOT?
- B20v turbo block building
- Turbo drain line - will this cause problems?
- turbo d16y7 base map
- Trying to make 900+
- The question I'm gonna get flamed for.... but what the hell
- Greddy TD04H-15G downpipe bolt size/thread
- b20v pcv
