View Full Version : Forced Induction
- Built h22 back from dyno(chart inside)
- sc'ing gsr
- Type S Bov adjustment
- Best turbo set up
- So I put a virgin p28 into my obd2 civic
- Thermal Wrap questions
- will i need a retune?
- would this size slim fan fit stock civic radiator?
- Fuel Injector question????
- Fuel pressure with 650cc Injectors
- D16z6 head on y7 block, Dizzy question...
- Best alterntive to a filter on the compressor
- How big is an 18G?
- big boost (30psi)?
- B18a/b + crank
- I need some ideas here for my Hondata problem...
- VAFC on a non V-TEC car, can it be done?
- Ditching edelbrock fuel management. D16 turbo, need help
- 12.1 D series street car??Truth or fiction,help me out.
- what model ACTpressure plate is this??? (pic)
- REASEARCH HELP ON TURBOS>............
- For only 8-10 psi on a greddy 18g FMU or Blue box ?
- Look what came in the mail today....
- SI turbo kit suggestions
- How do you check used turbos to see if theyre still good??? Thinkin about buyin a used one
- greddy 15g into a 99-00 ex
- * Boosting a stock block LS/Vtec * QUESTIONS
- DPI to MPFi help JRSC
- Car burns oil....a quart a week
- lowering compression, on high compression map, lean, rich?
- Precision GT35 Turbo on ebay
- Smaller gap spark plug
- t3/t4 turbo piping on a h23 92 prelude.
- Torque specs on turbine housing of a garrett t3
- CIVIC EX 1.6LV-TEC D16Y8 TURBO
- DSM turbo flange measurements (searched)
- neeep help asap-crower torque specs
- wastegate settings
- can i use toda B with built gsr turbo?
- ***great american tune off*** ideas
- GSR crank in my b16a. Benifits?
- Ring Gap Recommendation
- *The great turbo test*
- built head, does vtec matter?
- Question about balancing
- Stock PVC system, and how it may have helped me?
- ATTN::SOHC GREDDY USERS---CHECK OUT MY GANGSTA ENGINE MANAGEMENT!!!
- 60 trim on a B16A
- wheres a good place to buy a 40mm wastegate
- OT: Why did Nissan do this?
- Heavier weight oil with boost?
- Which Intake Do I Need? Please Loooook
- combinig the vafc with field boxer to help with ecu reading boost
- Little comparison of BFG 225/50/15's vs normal tire...
- FMU & Different Disc's
- greddy tdo4 oil flange bolts?
- turbo prelude timing?
- MY 97 dx civic setup
- OT: The good ol' days...Post pics of your FIRST turbo install! :-)
- Mounting a stock RX7 intercooler on an EG Hatch.
- Think He'll Notice?
- how long will I last?
- Idle is too high (1k-1400)
- hondata NOS controls= high boost settings.........HMMM???
- Will i need a boost controller if i run hondata on a internal wastegate t3?
- car smoking questions
- Turboing a SOHC what are the requirements?
- OBD2 Hondata Cost??
- Lots of information on the Holset turbo line
- Need Basemap for AEM EMS v.1.03 rc750cc
- Running Lean Car Feels Weird Why?
- MSD Inline Fuel Pump Removal/Install
- Exhaust options. Magnaflow. Emission...
- Who all here tunes thier own cars with uberdata?
- GE, STR, Venom intake manifold users please look.
- IHI return line flange and gasket
- Scared the hell out of myself in an engine build
- Need some help with Mitsu flanges
- *** answer all my questions and solve my problem...receive $50 paypaled ***
- Part # for RC 750cc SATURATED Injectors?
- FS: ct26+ stock dp
- anyone have a problem with the greddy oil return line leaking?
- fuel cut defender
- Garret T25 flanged turbos - OEM applications?
- GReedy sp2 with turbo
- Head work gurus and valve job gurus
- Boosted H23a
- skunk2 stage 1 cams + turbo???
- I have a plan...not really need some help
- gsr cams...how can u tell? pix inside
- b18c nitrous
- my street whore (EF love + LS-T = teh sex) 56K, I can resize...
- e-manage problems please help!
- overkill?
- dynocom dyno, anyone used one?
- Instalation advices please
- Built GSR back from the dyno
- Turbo checklist. I think I have it all.
- Ever seen this internal gate???
- Intake Manifolds for a Turbo
- Bore of JG Victor X Intake Manifold
- Which pressure switch?
- Mase S Florida Tuning Session 3/17- 3/19
- turbo cams!?
- SX Regulator
- Home made turbo
- NGK BKR7E or BKR7E-11
- spark plug for supercharged s2000
- Gsr tranny vs. Ls tranny
- Anyone Ran one?
- dyno....head lift....hot antifreeze
- Differences in turboing a vtec vs non vtec?
- Good tuner's in southwest
- Is gearing overlooked with most boost builds?
- Where to get VP C16 in Maryland?
- my new 3"catback kteller pictures inside
- anyone know torque spec for obx lsd?
- Need MACHINE SHOP in MA
- Wiring up my FJO to my AEM EMS
- What kind of Fuel management requires professional tuning?
- Help With ARP Head Stud Torque Specs
- Ok so my motor was blown...(long)
- XS Power T3 Turbo any good?
- Innovate LM-1 videos = some good information!
- Which exhaust? Need some help
- Should i go with 2 1/2" or 3" exhaust?
- T28 BB
- D16ZC and Y8 Tranny
- TS04(searched)
- few questtns about knock sensors ECU´s and harnesses
- anyone boost a 01-05 civic lx yet?
- Installing RC 750cc's while still NA and question about partial throttle tuning
- water injection people...
- electric supercharger
- Ignition timing difference in summer vs. winter
- vacuum lines too long for a manual boost controller? MBC
- Greddy turbo kit - no intercooler/bov
- 2000 Si OEM foglights and greddy intercooler piping will it fit ???
- Tom Payne Ect
- where to tap the oil lines in my d15b7 for greddy turbo kit
- walbro
- hp gain with 7-8 psi on d15b7
- Edelbrock Victor X and B18b?? Got a good deal on it
- mitsubishi turbo for b16
- Does Wiseco make pistons for b16?
- anyone have a pic of a black Tial BOV??
- resistor box
- pics
- Hondata s200??
- does anyone run the plx m-250?
- Turbo identification....
- 92-96 H22 Prelude Turbo
- Any FTA guys out there have some fresh KEYS
- Highway driving with turbo
- any replacement for expensive couplers?
- A Hole in my downpipe!!!!
- car ran bad at low idle
- Will a 3in 3 bolt flanged DP fit on 18g greddy kit???
- Difference B/W Garrett and Precision GT35R?
- Which manifold is better?
- Are the wrx and dsm bov the same?
- built head with stock bottom?
- piping diameter of n1?
- My new 4" exhaust, check it
- where can i find a jackson racing intake manifold for a civic
- wrecked..think i can bend it back? (off topic i guess?)
- Anybody sussesfully using a PROFEC A?
- Cold plugs and Cold weather starting
- what size is a 50 shot nos jet...search is down
- EFI 101 Chicago April 2-3 **check-in**
- running injectors and fuel pump without somethin to run them?
- looking for sport compact article (st00pid tuned) link
- power potential of GT28R
- 84.5 mm bore and leaking issues??
- Gauging intrest in a MASE Dyno TUNING session in MEMPHIS TN
- Any advantage to using GSR oil pan on an LS?
- Good air fuel ratio for n20
- distance from fuel pump to rail?? for new fuel lines
- Question about d16y5 block and z6 head.
- putting 84 mm pistons in , do i need to resleeve?
- h22 intake mani in a 94 accord HELP!!
- My catch can setup... maybe it will help you guys...
- How many vacuum sources will I need?
- It finally happened after 50,000 miles of boost......
- JRSC Help! Car dies at a stop! Idles low.
- Just bought a...
- coolant in overflow ONLY when i hit boost ??
- there are 2 nipples on the greddy type s bov what do they go to?
- do you need to rewire anything on an obd1 motor with rc injectors?
- Exedy stg 1 or 2 for turbo ls
- very annoying BREAKING A ENGINE IN
- what is a safe a/f ratio?
- what is a good egt temp?
- Just got bottle refilled and....
- boosted d16:what spark plugs
- is this turbo to big
- FMU vs. Greddy blue box?
- Air/Fuel meter or Volt meter?
- Running my Vitara piston setup...Update for those interested
- Power FC for Civic's?
- will this del sol vtec radiator be okay for my 99 gsr turbo? (pics of condition)
- aftermarket D15b intake manifold
- what power to shoot for??
- Size Turbo to get?
- In the market for sc61.... HELP!
- *NorCal Tuning Rcrew 500+ whp*
- what internal wastegate could i use?
- how to secure the ac condenser?
- Question for Ontario guys about Toronto tuner "Neetronics"
- cant find a tdo4 manifold anywhere!
- zc turbo
- Phoenix Turbo dyno install...
- IS 75k miles too many too ad boost
- Turbo drain question
- Neptune systems????
- MDS ACTIVATION WITH, CAN IT BE USED WITH THE W.O.T SWITCH FOR NITROUS PLEASE HELP!!
- st00pid tuned, Neptuned, 442 whp stock motor H22!!!!
- s cover vs. e cover
- Looking for a D series Turbo!!
- hks type-1.. 1000 rpms off???
- greddy preludes post here
- Best place for wide band?
- ok ill try again...can someone point a turbo noob in the right direction
- ls tranny good for turbo?
- Tuning in South Florida
- Custom turbo, need some advice
- Zdyne tuning in NY?
- Turbo D Problems
- B16 @ 6 psi on 440 injectors and VAFC hack
- boosted k24a4 honda accord!!
- Whos making k series rods? h beam i beam titanium or whatever
- .::Blitz SBC ID install??::.
- Block gaurd and thick head gasket on a turbo b16
- boosting a 95mm crank
- Just got back from the track....what do you think?
- Paint for intercooler?
- Stock Turbo B16 11.7 Vid
- Help me out, misses to backfires
- 3 inch exhaust for a integra
- dsm blue top 450cc injectors
- vafc numbers for h22
- Anyone using this Garrett T3?
- sthinking of getting a AEM EMS
- Action 2MS 2MD D series users, Are you having this issue >>
- My Turbo EM2 done. Finally! *56k pack a lunch*
- Looking for a turbo/major work installer in Connecticut
- turbo ?
- h22/ del sol radiator hose question...
- will a 13b 1st gen auto DSM turbo work?
- Kinda dumb question, but how many liters?
