View Full Version : Forced Induction
- SFP manifolds .. who here runs em>?
- SOHC greddy turbo?
- Downpipe Disaster! I need some input into this. Completely spoiled me setup. How much?.
- need a good muffler shop in phoenix.
- Tossing around the idea of Turbo GSR
- n20 on a b20??
- building a d16z6 junkyard style. Input wanted.
- Need 4" 90 deg bends for intake pipe
- Might have some turbo issues
- LSD
- Fuel setup & lines
- too much boost for oem map?
- built d16a6 turbo potential?
- could i expect to fail cali emissions w/my boosted honda?
- Prob a dumb questions but want to make sure. On the cold side of my turbo there is
- turbo question
- b20 with nos
- GE VTEC Conversion
- Boost controller/ wastegate question
- all u guys running stock ecu's
- Exhaust: 2.5" for what psi/HP 3" for what psi/HP ?
- drag gen 111
- Clutch problem.. need help asap
- Turbo Flange stripped, re-tap?
- 2.5" IC piping to big?
- HOndata s100 in p28?
- I need a audio/video clip of aTurbo/Greddy Type S, or any other BOV that sounds nice ...
- A fuel fountain in my engine bay, lol. Just put on JRSC w/ B&M FPR...
- Gearbox question.
- SR20DET oil problems, on sc61 need help.
- im lost.....what turbo is right for me?
- drag downpipe
- vafc+settings=good and bad/no vafc hack,actual a/f tunning questions!!!!
- Tial 35mm wastegate vacuum question, FASTER SPOOL ?
- Need some opinions to help solve my problems
- Golden Eagle Vacuum Manifolds...
- cheapest place 2 do rebuilds on turbos(socal)
- Dyno whp on drag generation 3 kit
- Upgraded Header/Intake Manifold studs... info please.....
- Turbo JDM ITR Prob....Over Fuelling??
- B18C5 or B20/VTEC with JRSC
- Tial 38mm fire ring, availability!? Ben@importparts help
- Edelbrock turbo kit vs. Drag 3 kit for civic
- my engine got blowed for a stupid reson :(
- Anyone tried that new MOBIL1 OIL? 0w-40??
- Fluidyne Radiator and FAL (flex-a-lite) Fan
- Hondata Datalogging and VTEC Pressure light staying on even before VTEC! Problem?
- maximum size injector stock ECU can handle for 98 lude
- Help on picking Injectors
- BOV ON SUPERCHARGER LOL ????????????????
- Block guard ?'s...
- AEM EMS voltage control?
- What the difference between sc61 t3/t4 ar.69 and sc61 straight t4?
- Stock b16 rods and JE pistons...
- which Piston? (JE, SRP, WISECO, CP)
- vortech SC with aftercooler for GSR?
- whats the biggest turbo that will fit in a fith gen prelude
- CCA 31x6.5x2.75 intercooler???? Good for 15-20psi 300+whp???
- JohnnyRacer 6" intercooler???? Good or Bad???
- Bottleneck in my exhaust......
- Well it was the rag guys! I can't believe what it robbed me of!
- Redline Oil
- Precision Turbos
- Question on 2 step colder plugs. Can I use BRK7es's in my D16z6?
- BOOST CONTROLLERS
- COLD AIR intake for the turbo - PICS INSIDE!
- injectors cutting out at 1700-200 rpm?
- How does a JRSC regulate boost?
- Pencil torch enough to braze??
- Check out this turbo.
- what goes on turbo outlet?
- afc question
- GSR Greddy Turbo Question - Skunk2 Intake Manifold?
- AFC/ECU Reads Different Boost from Gauge
- jrsc/vafc help
- Worst that can happen with too large ring gaps?
- Another wannabe 400 whp guy....help
- uberdata website ---chip sharing and maybe even chip burning for a very small price
- Anyone know if a D series distributor shaft is the same as a B series distributor shaft?
- Apexi AVCR and EMS
- anyone know the color of pressure signal on 97 gsr
- 10.5:1 with boost?
- Can I go nitrous with my setup
- wat clutch for turbo gsr setup?????????
- Is painting an intercooler bad?
- Guy swears its not OBX/xs speed ebay bullshit...i say it is...what do you guys think
- Everyone with TurboXS RFL.
- Some pics of my techedge DIY 2.0 kit
- Newbi question about motors
- high compression w/boost = hard to ignite?
- Help Quick BOV Wont Open
- Aerodyne Turbo Kits: To be or Not to Be?
- oil cummin out the turbo? help
- What exactly is the V-AFC Hack, and what exactly does it do?
- NorCal Hondata Tuners???
- What rev limit on this setup?
- Main Cap bolt help!
- I need help on a decision about my set-up.
- would 93 RX7 550cc injectors work??? did search
- TB size
- anybody use an accord dizzy cap like the msd cap?
- think i found my oil leak need opinions
- how high can u rev on lsvtec?
- quick oil/turbo question
- AEM UEGO Wideband mounting in an Integra?
- JDM ITR
- are there any hondata tuners in wisconsin?
- Rev-hard Turbo Weirdness
- mrl2 additional fuel injector controller
- SRP pistons
- Question regarding internal wastegates.
- Greddy Blue Box need tuning???
- quick t3 question, search didn't help
- Need a list of factory turbo cars & any info on turbo.
- is this a homemade mani or what, worth $50?
- Take a look at this B16 Block (PICS)
- How to create 0 boost?
- Stupid turbo question
- h23 w/200k mi+nitorus
- Full-race T3/T67 or the Precision SC63 which one.
- Aluminum or Stainless Steel?
- Ant of you folks going to E-Town this weekend Oct 4th-5th?
- WHICH CAMS ARE THE BEST FOR AN INTEGRA WITH A JRSC????????????????????
- look how stupid i was, WG fell off on the way to a show!!!!!!!
- Which cams are the best for turbo?
- Quesion?
- What to look for when buying a mig welder?
- tdo5-12a turbo flange.
- Going turbo on the rex w/ z6...opinions?
- new to F/I can someone help explain turbo?
- pics of my setup
- Problem with ECU cutting revs at 4800-5000 RPM. Hondata experts? Electrical? Help!
- idle RPMs when setting distributor timing?
- b19c1 on its way
- Those with fuel sumps...How did you prep the inside??
- need to do stock rebuild for boost,what all is needed?
- Sorry..I need info...and not sure where to go.
- T3 water fitting HELP!
- Clutch options needed!!
- quick ?:14b fittings size
- who has the fastest 1/4 with a supercharger???????
- detnating in boost...help
- who has the most power with jrsc on gsr???????????????????????????
- jrsc pulleys?????????????????????????
- Just did my compression test on gsr motor 9:1 compression pistions
- installing vafc will i still need my missing link
- DEI header wrap on intercooler piping.....good or bad?
- DEI header wrap on intercooler piping?
- Cheapest place for TiAL???
- where to buy Stainless steel
- Help, K&N knockoff filter comparison, please help!!!!!
- which manifold would I need for a K3T turbo
- Help my turbo integra....did search but i dont think it matches mine
- think Ls supercharged,what would be best to use,as far as CAMS-AND TRANNY
- After 5psi car stops accelerating?
- Help! Fitting to fuel rail not correct? Stainless Fuel Line Mod
- i need some help please...
- how does a bov help
- Running coolant thru turbo SEPERATE from car coolant system..
- Comparing Turbos
- B20VTEC turbo oil feed from where? SEARCHED
- Has anybody heard of someone running 10's on drag radials???????
- Boost goes up after removal of the Cat.
- Stage 1 vs Stage2 Turbo for RSX-S
- ford vaccum thingy
- i feel like an ass for asking this question...stock exhaust size?
- Has anyone run more than 15psi on their 15g greddy kit?
- HELP- ? about cel and 02 sensor
- Making your own IC piping
- AEM EMS 30-1010 Maps
- nos question
- B18c turbo in eg
- ? for greddy turbo kit users
- SMC and JRSC
- valvetrain list needed for b18b going turbo later
- pr4 OR p75??
- 86-87 integra rods in a D series motor?
- how to identify austrian type-R at the SEMA in Vegas???!?!?!??!
- What wastegate to get
- Please give OPINIONS on my new set up. Upgrading BIG TIME!Thanks Arturbo!
- What Apex'i needs to do to assist with hack.
- OT: 400hp nitrous shot on a 350Z *Video*
- Socketing ECU. Can you check for good connections w/ Voltmeter?
- Custom intercooler endtanks
- Skunk2 or Edelbrock Intake manifold for D series????
- Edlbrock Intake for B series how do u mount the cable
- got some ?'s
- Whats more reliable?
- Might as well chalk up another for the 400+whp club...
- Went to the track last night, but.......
- Dyno numbers
- Anyone know what programming language Uberdata is written with?
- Dataloging widebaond readings
- SUPERCHARGER AND TURBO??????????????????????
- uglyasscivic goin down the strip
- whp with sc
- HELP PLEASE, custom turbo setup question!!!
- Need a host. 10 sec civic........
- what should timming be set at w/ turbo?
- injector duty cycle
- timing belt help!!!!!
- Now that im tuned, how to maintain ?
- SOHC turbo
- uberdata and pm6?
- idle problem and hondata?
- 550 primary injectors plus 1-4 450 secondaries equals?
- where to get tee for oil feed line?
- What SAFC settings should I use????
- Lovefab Shorty
- Here's a small vid of my turbo sol....(ehhh watch it if you're bored, not too entertaining)
- 412whp@22psi 2001 Prelude...
- Edelbrock Turbo Kit
- Intercooler Fitment w/ usdm & jdm integra front.
- wheres my oil going?
- too much for a greddy type 31?
- How much boost can a stock JDM GSR handle?
- help....
- No boost over 4.5k
- How does a BOV work???
- Finally.. b00st!! First impressions, and questions..
- Help tuning Uberdata!
- Quaife Noise
- Exhaust under fuel tank
- Help me with air filter (Pics)
- backfires
- turbo
- Im lost. Need your opinion. Detonation.
- Turbo needs tuning
- Turbo Videos
- Torque specs needed...ZC head, stock carbon gasket with ARP studs...
- super charger or turbo?
- Thats right...i need your help again!!!
- Need to find an AEM EMS tuner in So.California
- Do the new style MSD SCI Honda injectors fit directly?
- Hondata is a life saver again!
- SRT-4 intercooler
- RS/EXOSPEED SLEEVE
- Piston Compression for boost 20 psi.
- do my AFC setting look odd to you?
- 255 fuel pump-12:1 fmu-stock injectors running LEAN
- If my timing if off will my EGT tell me?
- turbo for a 00 si
- Whos running air filter directly on compressor?
- These are your wideband options
- heat shield for exhaust manifold??
- Cam position sensor for AEM?
- turbocharger orientation question
- Charge pipe question.
- EFI 101 SEMINAR in SOCAL!
- Does ANY manufacturer make a 2.5" cat-back?
