View Full Version : Forced Induction
- Gsr turbo bogging
- Newb Engine Builder: I Question, U Answer
- Intercooler repair
- OBX TOPMOUNT IS LIKE CRACK!!!!!!!!!!!!!!!
- turbo?
- JRSC , AEM FI/C TSX
- FINDING A COMPRESSOR MAP??
- What rods to use?
- High duty cycle on low boost?
- Need help identifying some RODS!!!
- b20b hi or low comp???
- lsv 6262 ek build
- boost need help
- One interesting A2W inter-cooler design.
- buying used garret turbo
- Can you "convert" AN-12 to NPT? Would it leak if i re-tap?
- s300 starter boost control settings
- Fuel Injectors
- B16 boosted @ 450whp needs upgrade ignition?
- downpipe ?
- Blown headgasket? leaky seals??
- where to purchase a longer fuel line
- Which GTX3071R Turbo is best for a Forged B18C4?
- Stuttering...
- who is using skunk2 tuner1 cams in their turbo setup?
- ID - siemens - thin long injector ? on b series
- PCV delete, sludge problems?
- BOOSTED 2000 SI SPUTTERING/MISFIRING
- spooling sooner
- Vortech Tensioner Pulley?
- pics of return line and turbo is this to tight of a degree?
- BIG BOOST ISSUE...PLEASE HELPPP
- HELP: LST setup wont rev past 3500rpm..
- Divided Exhaust housing? Hx35
- Coolant temp control ever an issue?
- overboost / vapor lock?
- Oil Line Help
- SMOKE PROBLEM Questions
- IN NEED OF A GOOD OIL PAN
- boost issue!
- Want to boost Z6/B7 mini-me, questions
- eagle bearing clearance?
- Identifying pistons
- need help finding a top mount
- Tranny for boost?
- Radiator Help/Advice
- Where to get small v-bands for dump tube
- RIP GT3076R :(
- supercharging b16
- What is better h22 or b-series 4 boosting !!
- So I been wondering when rebuilding a Honda engine even if cylinder bores are measure
- Engine Builders: Oil Clearances too tight
- y7 block +z6 head + greddy turbo tdo4 HELP!
- BWR front mount manifold??? anyone??
- block fitting size
- Injector size recommend for turbo
- weldon or magnafuel
- Supercharging D15?
- B16 transmission with boost...
- 450whp with 1000cc RC Eng. too much?
- AN adapter for rear PCV vent opening?
- intercooler piping size
- looking for turbo kit
- what are markings p2t on cams stand for? good for boost?
- long road trip with boosted car?
- oil drain back suggestion needed
- Any reviews or feedback from SpeedMaxPerformance (S-Max) Intercoolers?
- Twin Wastegate Setups
- B16a jdm headbolts and studs
- Max whp on single walbro255
- Boost creep/Boost control plumbing
- built gsr stays at 3k rpm
- Routing turbo water lines the right way,
- Turbo air filter
- GO-AUTOWORKS 62MM Pro Kit
- Fully Built block on stock b16 head?
- washer fluid bottle relocate.
- Opinions on turbo brands...
- stock valve train on turbo build
- Gone through 2 turbos already, help me diagnose!
- How a Turbo Functions - Updated Video
- Racebum's Build Thread - 300whp ITR
- 89 si ef hb with jrsc chipped obd1 ecu with fujita intake.
- New MVS Knockoffs
- 150 psi on a c5 block?
- idle too rich or lean
- aem 6060 ecu and msd dis4 installation
- 5 bolt downpipe
- Walbro 400lph???
- Making the switch! Which legit turbo is similar to this eBay?
- Oil pan tap
- noob situation...
- Smoke out down pipe
- question about my gsr turbo set up
- Got a super hero package today....
- Noob Trying to save a lil money Will this work ? main bearings
- Car sat for 6 months - now having problems
- best turbo for my h22 setup?
- Turbo Honda/Acura Pics/Theory/Installation/Discussion/FAQ
- G.E sandwhich plate fittings
- advice on driving to tune
- low or high pressure
- ram horn ?
- budget boost build
- Oil level drop while running?
- New billet Compressor wheel in a older generation turbocharger?
- Anyone Upgrade A GT3076R?
- BKR7E Plugs
- Speed Factory Turbo Manifold. Yes or no?
- d15z1/y8 turbo... good learning platform?
- Turbo ?s
- This is why I avoid other people's projects..
- Intercooler piping routing w/ bumper exit downpipe/ or dual backdoor?
- Quick oil pan question b20 vs b16
- TD06-20g on b18c1 max psi !? HELp
- Greg@Go-Autoworks
- Turbo LSVTEC- Which Crank?
- LS big turbo build help?
- k20 build parts gathering precision 6266, tuners help
- 60mm exhaust too small?
- good idea?
- Whats a good brand
- tilton twin twin disc ???
- Darton Sleeved b18a1?? PICS!
- precision 825hp intercooler
- turbo?boost?supercharge?
- CDI - Crane or MSD?
- Stock ls vtec turbo help!
- b16 sounds like a subaru
- rs machine pistons
- Help with Front Facing Manifold
- Does This look like an oil restrictor or no?
- Walbro 400lph Instal on EK (1996-2000 Civic) V.1.2
- Boost controller help.
- looking for those with boosted h22
- LSv Turbo - No oil on dipstick
- What to put on my integra ls?
- Fuel pump/injector planning web app
- Walbro 400lph Install on EK (1996-2000 Civic)
- 400whp with 650cc injectors is it possible?
- D16a1 Blacktop boosted?
- Precision Ball Bearing 6766 Billett
- ls/vtec + blox type c's + boost =?
- Tial mvs without water cooling
- Noob question, what is so special about the k20?
- Thinking about swapping a boosted b16a in my coupe
- Better than OEM knock control?
- SMOKE PROBLEM
- B16 Oil pan fit GSR?
- darton h22 problems
- RC SL4-750 questions?
- Hondata S300 Version 2
- which oil after break in? d16
- Budget LSV build- input welcome
- A2W Turbo Del Slo Build Thread
- Lightweight Crankshaft B18C
- bad gas?? running pig rich.
- Foam filters? yay or nay?
- Gsr Head Question????
- Bisimoto injectors? Julio?
- Turbo Choice Turbonetics or Precision
- quicker spool / wastegate
- Wastegate placement concerns and advice needed
- Piston choice?
- s2000 turbo build question
- Turbo B20 VTEC BUILD!!
- BC rods turbo gsr
- 700+hp Daily Driven Dyno
- bearing choices, more clearance needed
- Oil line kit opinions
- Log vs ram manifold low boost on high rev motor
- Help Identify this turbo please?
- Oil cooler on ls/vtec and booste setup...oil pressure worries?
- head lifting? 437hp 3076 d16
- hx35 bolt on 70 ar or t3t04e stage 5 60 trim
- Precision turbo help.
- Garrett turbo help please
- EG hatch b18c 11:1, boost options? Sc or turbo
- Completion Clutch Super Single in a turbo B series
- Need a little advice on my built h22
- oil pressure feed line
- noob questions on normal wear and maintenance
- D16+Edelbrock turbo kit+cali law mess
- 92 civic hatch.. oil from turbine (turbo charged)
- Very qucik wastegate question?
- turbo and high compression
- E85 Stock Block CTR Piston's on Boost Dyno Graph!!
- go autowork spec turbo
- Head Lifted!
- Catalytic Convertor for Turbo Integra
- precision CEA turbos
- mines13's living in the 90's DA street car build... Full interior & no "hella flush".
- Low oil pressure!
- Diagnostic & General Discussion: Using Twin Boost Solenoid's
- Fuel System - H22 Turbo
- b18c1 build need some advice and make shure im on the right track
- tourque settings for arp eagle rod bolts
- B16 Turbo problems!!
- Tutorial: How To Crimp Injector Pins using a "W" type crimper
- Which air filter would be better?
- ineedavtec's turbo hatch build
- Advice needed: Cam Setup-- Engine builders chime in
- ARP head stud question.
- V-tech sandrail
- Turbo mounted in the rear of the car!?
- How much air filter "area" do I need?
- itr valves
- turbo stock h22????
- max rpm on ls/vtec
- My Turbo 2.0 LSVTEC build
- LS Turbo Idea/noobie
- Boosted B17 92 Gsr? Few Questions
- my del sol
- quick vacuum manifold question.
- Denso, Injector Dynamics Which I Use on Budget???!!!
- I want 200WHP from my D16Y8 with a turbo. What's needed to hold the power?
- Low compression piston identification?
- Using a z31 T3 on my GSR....
- Engine sleeve in Midwest area?
- What turbo setup h22a2?
- Optimal cam overlap? B18 with ITR cams and a big turbo
- Turbo VS Nitrous. Help/Suggestions?
- sohc jrsc problem
- turbo seals
- bearing choice
- quick question, can i use this hose end on my -3 AN feed line?
- SOHC noobie..few boost questions
- What Dog Engagement Gear Set Are You Running?
- Posting Blocks
- GSR build. Fueling Q's
- 15psi of boost on B20B stock sleeves?
- some help on this turbo
- Catchcan setup, boosted accord.
- 96 Civic Turbo smoking off and on??
- Valve spring recommendations for ITR cams
- Rebuild a journal 6062 or up to ceramic 6262?
- turbo or swap?
- reliability of properly installed block guard?
- Turbonetics Deltagate Mark II opinions
- tial alpha q (aka bong) or tial qr flows more?
- SUPERCHARGED F20c & F22c ADD POWER
- Em1 GSR build On the quest for 700+Hp lots of pics
- Hp limit .63 a/r - 70 a/r garret 60-1
- JRSC Lower Idler Pulley Problem!!
- who is running an sls log manifold?
- Hondata S200 Issue Or Something Else?
- stock b20vtec on 8psi tuned hp goals??
- Turbohatchsoontobecoupe build... 96Gsr
- Precision turbo's??
- F22a1 supercharger?
